  2. Software Development
  3. VOXL SDK
  4. voxl-cross error when building voxl-open-vins-server
Scheduled Pinned Locked Moved VOXL SDK
7 Posts 4 Posters 3.2k Views 1 Watching
  • S Offline
    S Offline
    SKA
    Hi!
    When I try to build voxl-open-vins-server using voxl-cross:V4.4, first I run:
    ./install_build_deps.sh qrb5165 dev
    After which I build and face this error:
    voxl-cross(4.4):~(voxl-open-vins-server)(0.5.6)$ ./build.sh qrb5165
    Found voxl-cross version: 4.4
    -- Using voxl-cross 64-bit toolchain for QRB5165 ubun1 18.04
    -- C Compiler  : /usr/bin/aarch64-linux-gnu-gcc-7
    -- C++ Compiler: /usr/bin/aarch64-linux-gnu-g++-7
    -- Sysroot     : /opt/sysroots/qrb5165_1
    -- C flags     : -isystem=/usr/lib/gcc/aarch64-linux-gnu/7/include -isystem=/usr/local/include -isystem=/usr/lib/gcc/aarch64-linux-gnu/7/include-fixed -isystem=/usr/include/aarch64-linux-gnu -isystem=/usr/include -idirafter /usr/include -march=armv8.2-a
    -- CXX flags   : -isystem=/usr/include/c++/7 -isystem=/usr/include/aarch64-linux-gnu/c++/7 -isystem=/usr/include/c++/7/backward -isystem=/usr/lib/gcc/aarch64-linux-gnu/7/include -isystem=/usr/local/include -isystem=/usr/lib/gcc/aarch64-linux-gnu/7/include-fixed -isystem=/usr/include/aarch64-linux-gnu -isystem=/usr/include -idirafter /usr/include -march=armv8.2-a
    -- Link Flags  :  -B/opt/sysroots/qrb5165_1/usr/lib/ -L/opt/sysroots/qrb5165_1/usr/lib/gcc/aarch64-linux-gnu/7 -L/opt/sysroots/qrb5165_1/usr/lib/aarch64-linux-gnu -L/opt/sysroots/qrb5165_1/usr/lib -L/opt/sysroots/qrb5165_1/lib/aarch64-linux-gnu -L/opt/sysroots/qrb5165_1/usr/lib/aarch64-linux-gnu -L/opt/sysroots/qrb5165_1/lib -L/usr/lib64 -L/usr/lib
     DEBUG BUILD
    -- EN_ION_BUF enabled
    CMake Warning (dev) at CMakeLists.txt:35 (find_package):
      Policy CMP0167 is not set: The FindBoost module is removed.  Run "cmake
      --help-policy CMP0167" for policy details.  Use the cmake_policy command to
      set the policy and suppress this warning.
    This warning is for project developers.  Use -Wno-dev to suppress it.
    CMake Error at /usr/share/cmake-3.31/Modules/FindBoost.cmake:1858 (file):
      file STRINGS file "/usr/include/boost/version.hpp" cannot be read.
    Call Stack (most recent call first):
    CMake Warning at /usr/share/cmake-3.31/Modules/FindBoost.cmake:1031 (message):
      Imported targets and dependency information not available for Boost version
      0.0.0 (all versions older than 1.33)
      /usr/share/cmake-3.31/Modules/FindBoost.cmake:1539 (_Boost_COMPONENT_DEPENDENCIES)
      /usr/share/cmake-3.31/Modules/FindBoost.cmake:2151 (_Boost_MISSING_DEPENDENCIES)
    CMake Error at /usr/share/cmake-3.31/Modules/FindPackageHandleStandardArgs.cmake:233 (message):
      Could NOT find Boost: Found unsuitable version "0.0.0", but required is at
      least "1.63.0" (found /usr/include, )
      /usr/share/cmake-3.31/Modules/FindPackageHandleStandardArgs.cmake:601 (_FPHSA_FAILURE_MESSAGE)
      /usr/share/cmake-3.31/Modules/FindBoost.cmake:2409 (find_package_handle_standard_args)
    -- Configuring incomplete, errors occurred!
    make: /usr/local/bin/cmake: No such file or directory
    make: *** [Makefile:257: cmake_check_build_system] Error 127
    Let me know how I can get past this, thanks!
    B 1 Reply Last reply
    • S SKA
      Hi!
       DEBUG BUILD
      B Offline
      B Offline
      bendraper
      Also experiencing this issue. @Eric-Katzfey could you provide any inside here? I've also tried different branches in the open vins server repo and different branches for install_deps such as staging and sdk_1.6
      B Eric KatzfeyE 3 Replies Last reply
      • B bendraper
        B Offline
        B Offline
        bendraper
        @Alex-Kushleyev any ideas?
        • B bendraper
          @bendraper Yes, we can recreate the failure. We need to release voxl-cross 4.8. We're working on it.
          • B bendraper
            @bendraper Actually, if you try to build the dev branch in voxl-cross:V4.4 it works but you first need to initialize the submodule with git submodule update --init. Can you try this with the dev branch and see if it works for you?
              B Offline
              B Offline
              bendraper
              @Eric-Katzfey I got about a million warnings when actually building but it did appear to build after initializing the submodules. Thanks!
              zauberflote1Z 1 Reply Last reply
              • B bendraper
                zauberflote1Z Offline
                zauberflote1
                @bendraper
                I hope this quick clarification helps for warnings:
                CMake Policy warnings: OV internally (external dir in the repo) still uses boost and references an older cmake version -- it's a harmless warning for devs (as you are building from scratch)
                Yaml-cpp lib warnings: This is a third party dependency that gets compiled from scratch during the make/build process. We use C++ 17 but the library is based on an older C++ version; nevertheless, it compiles fine on C++ 17 with minor warnings. -- it's a harmless warning
                TrackOCL warning: ModalFlow is a core library written in C++ 17 that allows function call usage as done in TrackOCL, i.e., the narrowing conversion is harmless in this case.
                That being said, we are actively working on the dev branch, so all flight--impacting warnings are hopefully caught early. We currently have no flight-impacting warnings/bugs identified, but if you found one warning/bug that caught your attention, please feel free to share.
                All the best,
                ZBFT
