    Ublox zed f9p GPS not connecting
    Software Development
    414
    • Karteek GandiboyinaK
      Karteek Gandiboyina
      HI,
      Im trying to connect ublox zed f9p 15b(https://www.u-blox.com/en/product/zed-f9p-module). im using voxl2 dev kit.
      i connected the gps to j19 pin (uart at pin 2,3) there seems to be no issue with the connection. but im not getting any gps message published
      tarling-px4-dev-kit (D0011):/$ journalctl -b -u voxl-px4
      -- Logs begin at Mon 2025-11-17 07:25:30 UTC, end at Thu 2026-02-26 20:09:53 UTC. --
      Feb 23 22:58:05 m0054 systemd[1]: Starting px4...
      Feb 23 22:58:07 m0054 systemd[1]: Started px4.
      Feb 23 22:58:07 m0054 voxl-px4[2203]: [INFO] Reading from /etc/modalai/voxl-px4.conf
      Feb 23 22:58:07 m0054 voxl-px4[2203]: Found DSP signature file
      Feb 23 22:58:07 m0054 voxl-px4[2203]: [INFO] Daemon mode enabled
      Feb 23 22:58:07 m0054 voxl-px4[2203]: *************************
      Feb 23 22:58:07 m0054 voxl-px4[2203]: AIRFRAME=MULTICOPTER
      Feb 23 22:58:07 m0054 voxl-px4[2203]: GPS=AUTODETECT
      Feb 23 22:58:07 m0054 voxl-px4[2203]: RC=SPEKTRUM
      Feb 23 22:58:07 m0054 voxl-px4[2203]: ESC=VOXL_ESC
      Feb 23 22:58:07 m0054 voxl-px4[2203]: POWER MANAGER=VOXLPM
      Feb 23 22:58:07 m0054 voxl-px4[2203]: AIRSPEED SENSOR=NONE
      Feb 23 22:58:07 m0054 voxl-px4[2203]: DISTANCE SENSOR=NONE
      Feb 23 22:58:07 m0054 voxl-px4[2203]: OSD=DISABLE
      Feb 23 22:58:07 m0054 voxl-px4[2203]: DAEMON_MODE=ENABLE
      Feb 23 22:58:07 m0054 voxl-px4[2203]: SENSOR_CAL=ACTUAL
      Feb 23 22:58:07 m0054 voxl-px4[2203]: ARTIFACT_MODE=DISABLE
      Feb 23 22:58:07 m0054 voxl-px4[2203]: EXTRA STEPS:
      Feb 23 22:58:07 m0054 voxl-px4[2203]: INFO  [px4] mlockall() enabled. PX4's virtual address space is lock
      Feb 23 22:58:07 m0054 voxl-px4[2203]: INFO  [px4] assuming working directory is rootfs, no symlinks neede
      Feb 23 22:58:07 m0054 voxl-px4[2203]: INFO  [muorb] Got muorb init command
      Feb 23 22:58:07 m0054 voxl-px4[2203]: Sending initialization request
      Feb 23 22:58:07 m0054 voxl-px4[2203]: Got topic data before configuration complete
      Feb 23 22:58:08 m0054 voxl-px4[2203]: *************************
      Feb 23 22:58:08 m0054 voxl-px4[2203]: AIRFRAME: MULTICOPTER
      Feb 23 22:58:08 m0054 voxl-px4[2203]: GPS: AUTODETECT
      Feb 23 22:58:08 m0054 voxl-px4[2203]: RC: SPEKTRUM
      Feb 23 22:58:08 m0054 voxl-px4[2203]: ESC: VOXL_ESC
      Feb 23 22:58:08 m0054 voxl-px4[2203]: POWER MANAGER: VOXLPM
      Feb 23 22:58:08 m0054 voxl-px4[2203]: AIRSPEED SENSOR: NONE
      Feb 23 22:58:08 m0054 voxl-px4[2203]: DISTANCE SENSOR: NONE
      Feb 23 22:58:08 m0054 voxl-px4[2203]: OSD: DISABLE
      Feb 23 22:58:08 m0054 voxl-px4[2203]: ARTIFACT_MODE: DISABLE
      Feb 23 22:58:08 m0054 voxl-px4[2203]: EXTRA STEPS:
      Feb 23 22:58:08 m0054 voxl-px4[2203]: Running on M0054
      Feb 23 22:58:09 m0054 voxl-px4[2203]: INFO  [param] selected parameter default file /data/px4/param/param
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [parameters] BSON document size 2241 bytes, decoded 2241 byte
      Feb 23 22:58:10 m0054 voxl-px4[2203]: Starting IMU driver with no rotation
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'icm42688p start -s'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13807556, local time:
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'icp101xx start -I -b 5'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13847307, local time:
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [modules__muorb__slpi] muorb aggregator thread runnin
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] muorb protobuf initalize method succeeded
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] succesfully did ADVERTISE_TEST_TYPE
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Creating pthread test_MUORB
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Successfully created px4 task PX4_test_MUORB
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] succesfully did SUBSCRIBE_TEST_TYPE
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] succesfully did TOPIC_TEST_TYPE
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] muorb test passed
      Feb 23 22:58:10 m0054 voxl-px4[2203]: ______  __   __    ___
      Feb 23 22:58:10 m0054 voxl-px4[2203]: | ___ \ \ \ / /   /   |
      Feb 23 22:58:10 m0054 voxl-px4[2203]: | |_/ /  \ V /   / /| |
      Feb 23 22:58:10 m0054 voxl-px4[2203]: |  __/   /   \  / /_| |
      Feb 23 22:58:10 m0054 voxl-px4[2203]: | |     / /^\ \ \___  |
      Feb 23 22:58:10 m0054 voxl-px4[2203]: \_|     \/   \/     |_/
      Feb 23 22:58:10 m0054 voxl-px4[2203]: px4 starting.
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic log_message
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [parameters] Starting param sync THREAD
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [parameters] Starting param sync THREAD
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] before starting the qshell_entry task
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Creating pthread qshell
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Successfully created px4 task PX4_qshell with
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell entry.....
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] after starting the qshell_entry task
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Init app map initialized
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_reset_requ
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Marking DeviceNode(parameter_client_reset_response) as
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic parameter_update
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Marking DeviceNode(parameter_server_set_used_request)
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_r
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Marking DeviceNode(parameter_client_set_value_response
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised i
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: icm42688p start -s
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'icm42688p'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg1 = 'start'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg2 = '-s'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** SPI Device ID 0x26000a 2490378
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_accel
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_gyro
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [icm42688p] ICM42688P::probe successful!
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] on SPI bus 1
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] icm42688p #0 on SPI bus 1
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [icm42688p] >>> ICM42688P this: b26012d8
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: icm42688p start -s
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic qshell_retval
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] Register interrupt b214ec48 e61ebf5
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_gyro_fifo
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_accel_fifo
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic imu_server
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: icp101xx start -I -b 5
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'icp101xx'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg2 = '-I'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg3 = '-b'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg4 = '5'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** I2C Device ID 0xb76329 12018473
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 5
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] icp101xx #0 on I2C bus 5
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb]  address 0x63
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: icp101xx start -I -b 5
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceINFO  [qshell] Send cmd: 'temper
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13882130, local time:
      Feb 23 22:58:10 m0054 voxl-px4[2203]: Looking for qmc5883l magnetometer
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] cmd returned with: -1
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13922352, local time:
      Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [qshell] Command failed
      Feb 23 22:58:10 m0054 voxl-px4[2203]: Looking for ist8310 magnetometer
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13958469, local time:
      Feb 23 22:58:10 m0054 voxl-px4[2203]: Looking for ist8308 magnetometer
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 13998516, local time:
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'gps start -d 6 -b 115200'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 14028093, local time:
      Feb 23 22:58:10 m0054 voxl-px4[2203]: Looking for ncp5623c RGB LED
      Feb 23 22:58:10 m0054 voxl-px4[2203]: Node(qshell_req) as advertised in process_remote_topic
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: temperature_compensation star
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'temperature_compensation'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic sensor_correction
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: temperature_compensati
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: qmc5883l start -R 10 -X -b 1
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'qmc5883l'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg2 = '-R'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg3 = '10'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg4 = '-X'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg5 = '-b'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg6 = '1'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** I2C Device ID 0x80d09 527625
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] Set up I2C bus mutex for bus 1
      Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [muorb] [drivers__device] i2c probe failed
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [SPI_I2C] PX4_qshell: no instance started (no device
      Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [muorb] [qshell] Failed to execute command: qmc5883l start -R
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: ist8310 start -R 10 -X -b 1
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'ist8310'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** I2C Device ID 0x60e09 396809
      Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [muorb] [qshell] Failed to execute command: ist8310 start -R
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: ist8308 start -R 12 -X -b 1
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'ist8308'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg3 = '12'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [drivers__device] *** I2C Device ID 0xb0c09 723977
      Feb 23 22:58:10 m0054 voxl-px4[2203]: ERROR [muorb] [qshell] Failed to execute command: ist8308 start -R
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: gps start -d 6 -b 115200
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'gps'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg2 = '-d'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg3 = '6'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg4 = '-b'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg5 = '115200'
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Creating pthread gps
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Successfully created px4 task PX4_gps with ti
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: gps start -d 6 -b 1152
      Feb 23 22:58:10 m0054 voxl-px4[2203]: INFO  [muorb] [gps] GPS UART baudrate set to 115200
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: land_detector start mu
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_land_detected
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox firmware version: HPGL1L5 1.40
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox protocol version: 27.40
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox module: ZED-F9P
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised i
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: manual_control start
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'manual_control'
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg1 = 'start'
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: manual_control start
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic manual_control_setpoint
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: control_allocator start
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'control_allocator'
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic control_allocator_status
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Marking DeviceNode(control_allocator_status) as advert
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_motors
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_servos
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_servos_trim
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: control_allocator star
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: load_mon start
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'load_mon'
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: load_mon start
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic cpuload
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: rc_update start
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'rc_update'
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] GPS UART baudrate set to 115200
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [gps] Got ack to initial CFG_VALSET!
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: rc_update start
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: commander start
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'commander'
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Creating pthread commander
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [tasks] Successfully created px4 task PX4_commander w
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic led_control
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [muorb] [commaINFO  [qshell] Send cmd: 'commander start'
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 16635298, local time:
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [qshell] Send cmd: 'flight_mode_manager start'
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [qshell] qshell return value timestamp: 16765888, local time:
      Feb 23 22:58:13 m0054 voxl-px4[2203]: INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADC
      Feb 23 22:58:19 m0054 voxl-px4[2203]: nder] LED: open /dev/led0 failed (22)
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic tune_control
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: commander start
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic event
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic mavlink_log
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [health_and_arming_checks] Preflight Fail: Accel 0 un
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [health_and_arming_checks] Preflight Fail: Compass Se
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic health_report
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic failsafe_flags
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_armed
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_control_mode
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_status
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic failure_detector_status
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised i
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] qshell gotten: flight_mode_manager start
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg0 = 'flight_mode_manager'
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell]   arg1 = 'start'
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic vehicle_command
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [qshell] Ok executing command: flight_mode_manager st
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [dataman] data manager file '/data/px4/dataman' size is 78666
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic transponder_report
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic rtl_time_estimate
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic position_setpoint_tri
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic telemetry_status
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [mavlink] partner IP: 127.0.0.1
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic obstacle_distance
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic offboard_control_mode
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Advertising remote topic timesync_status
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] GPS UART baudrate set to 115200
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [uORB] Advertising remote topic actuator_controls_status_0
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(vehicle_command_ack) as adv
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 145
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [uORB] Marking DeviceNode(telemetry_status) as advert
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [px4] Startup script returned successfully
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [logger] logger started (mode=all)
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] Got ack to initial CFG_VALSET!
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox firmware version: HPGL1L5 1.40
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox protocol version: 27.40
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox module: ZED-F9P
      Feb 23 22:58:19 m0054 voxl-px4[2203]: INFO  [muorb] [health_and_arming_checks] Preflight Fail: Attitude f
      Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox firmware version: HPGL1L5 1.40
      Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox protocol version: 27.40
      Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] u-blox module: ZED-F9P
      Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] GPS UART baudrate set to 115200
      Feb 23 22:58:35 m0054 voxl-px4[2203]: INFO  [muorb] [gps] Got ack to initial CFG_VALSET!
      this is the log, i see that the gps is recognized by the voxl but it resets for some reason.
      #!/bin/sh
      # PX4 commands need the 'px4-' prefix in bash.
      # (px4-alias.sh is expected to be in the PATH)
      . px4-alias.sh
      echo -e "\n*************************"
      echo "AIRFRAME: $AIRFRAME"
      echo "GPS: $GPS"
      echo "RC: $RC"
      echo "ESC: $ESC"
      echo "POWER MANAGER: $POWER_MANAGER"
      echo "AIRSPEED SENSOR: $AIRSPEED_SENSOR"
      echo "DISTANCE SENSOR: $DISTANCE_SENSOR"
      echo "OSD: $OSD"
      echo "ARTIFACT_MODE: $ARTIFACT_MODE"
      echo "EXTRA STEPS:"
      for i in "${EXTRA_STEPS[@]}"
      do
              echo -e "\t$i"
      done
      echo -e "*************************\n"
      # In order to just exit after starting the uorb / muorb modules define
      # the environment variable MINIMAL_PX4. (e.g. export MINIMAL_PX4=1)
      # This is useful for testing / debug where you may want to start drivers
      # and modules manually from the px4 command shell
      if [ ! -z $MINIMAL_PX4 ]; then
          /bin/echo "Running minimal script"
          exit 0
      fi
      # Figure out what platform we are running on.
      PLATFORM=`/usr/bin/voxl-platform 2> /dev/null`
      RETURNCODE=$?
      if [ $RETURNCODE -ne 0 ]; then
          # If we couldn't get the platform from the voxl-platform utility then check
          # /etc/version to see if there is an M0052 substring in the version string. If so,
          # then we assume that we are on M0052.
          VERSIONSTRING=$(</etc/version)
          M0052SUBSTRING="M0052"
          if [[ "$VERSIONSTRING" == *"$M0052SUBSTRING"* ]]; then
              PLATFORM="M0052"
          fi
      fi
      # We can only run on M0052, M0054, or M0104 so exit with error if that is not the case
      if [ $PLATFORM = "M0052" ]; then
          /bin/echo "Running on M0052"
      elif [ $PLATFORM = "M0054" ]; then
          /bin/echo "Running on M0054"
      elif [ $PLATFORM = "M0104" ]; then
          /bin/echo "Running on M0104"
      else
          /bin/echo "Error, cannot determine platform!"
          exit 0
      fi
      # Sleep a little here. A lot happens when the uorb and muorb start
      # and we need to make sure that it all completes successfully to avoid
      # any possible race conditions.
      /bin/sleep 1
      param select /data/px4/param/parameters
      # Load in all of the parameters that have been saved in the file
      param load
      # IMU (accelerometer / gyroscope)
      if [ "$PLATFORM" == "M0104" ]; then
          /bin/echo "Starting IMU driver with rotation 12"
          qshell icm42688p start -s -R 12
      else
          /bin/echo "Starting IMU driver with no rotation"
      fi
      # Start Invensense ICP 101xx barometer built on to VOXL 2
      qshell icp101xx start -I -b 5
      qshell temperature_compensation start
      # Auto detect the magnetometer. If one or both of these devices
      # are not connected it will fail but not cause any harm.
      # Rotation 10 = ROLL_180_YAW_90
      /bin/echo "Looking for qmc5883l magnetometer"
      /bin/echo "Looking for ist8310 magnetometer"
      /bin/echo "Looking for ist8308 magnetometer"
      # Rotation 12 = PITCH_180
      qshell ist8308 start -R 12 -X -b 1
      # GPS and magnetometer
      if [ "$GPS" != "NONE" ]; then
              # On M0052 the GPS driver runs on the apps processor
                  gps start -d /dev/ttyHS2 -b 115200
              # On M0054 and M0104 the GPS driver runs on SLPI DSP
              else
                  qshell gps start -d 6 -b 115200
              fi
      fi
      starling-px4-dev-kit (D0011):/$ px4-listener vehicle_gps_position
      TOPIC: vehicle_gps_position
      starling-px4-dev-kit (D0011):/$ px4-listener sensor_gps
      never published
      this is usr/bin/voxl-px4-start i updated the baudrate to match with my gps ublox baud rate but the problem remains same. Please help
      Karteek GandiboyinaK 1 Reply Last reply Reply Quote 0
        Karteek Gandiboyina @Karteek Gandiboyina
        I used this "https://forum.modalai.com/topic/3257/voxl2-gps-taking-long-time-to-connect-sometimes-never-connects" but it did not help. @Alex-Kushleyev @Eric-Katzfey
          Eric Katzfey ModalAI Team @Karteek Gandiboyina
          @Karteek-Gandiboyina Unfortunately, we don't have any experience with that unit. It looks like it is hooked up correctly since you get a response from it. What baud rate did you change it to? You can try running the latest version of px4 but we have spent very little time testing it so use with extreme caution: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-mainline-px4_1.17.0-1.0.2-202602240859_arm64.deb. Perhaps load that, remove the propellers, and just verify that it can properly see the GPS? And what if you just remove the baud rate option on the start command, does that change anything?
            @Karteek-Gandiboyina Also, for reference: https://forum.modalai.com/topic/4403/starling-2-max-with-ublox-f9p-ultralight/7?_=1772217162290
              Karteek Gandiboyina @Eric Katzfey
                      else
                      fi
              fi
              Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [logger] logger started (mode=all)
              Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] GPS UART baudrate set to 115200
              Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] Got ack to initial CFG_VALSET!
              Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] u-blox firmware version: HPGL1L5 1.40
              Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] u-blox protocol version: 27.40
              Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [gps] u-blox module: ZED-F9P
              Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [health_and_arming_checks] Preflight Fail: Accel
              Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [health_and_arming_checks] Preflight Fail: Attitu
              Feb 23 22:58:15 m0054 voxl-px4[2177]: INFO [muorb] [health_and_arming_checks] Preflight Fail: Compas
              Its the same even without the baudrate. I will try the PX4-mainline option.
              • E
                emarcphera @Karteek Gandiboyina
                @Karteek-Gandiboyina the gps drivers on px4 1.14 don't support that gps, it fails some configuration step if I remember correctly and that's why it gets stuck in a detected loop. Switching to mainline px4 worked for me.
                    Karteek Gandiboyina @emarcphera
                    @emarcphera @Eric-Katzfey thank you so much after upgrading to voxl-mainline im getting GPS readingScreenshot from 2026-02-28 01-45-10.png
