  3. VOXL2 GPS taking long time to connect, sometimes never connects
4 Posts 3 Posters 1.3k Views 2 Watching
  • A Offline
    Aaky
    I am using VOXL2 with SDK 1.1.2 installed. I am facing very strange issue with Holybro M8N GPS on J19 connected to VOXL2. This GPS takes very long time to actually start to publish GPS data on sensor_gps topic. I changed GPS, VOXL2, cable everything in my custom drone setup still this issue isn't getting solved. The time to publish data over sensor_gps as I said is very random and what I can see on logs as shown below is this GPS module keeps printing Baudate and verrsion info and after long time actually starts to publish sensor_gps topic.
    Logs :
    voxl2:~$ /usr/bin/voxl-px4 -d
    Found DSP signature file
    [INFO] Disabling daemon mode
    GPS=AUTODETECT
    RC=CRSF_RAW
    ESC=VOXL_ESC
    POWER MANAGER=VOXLPM
    DISTANCE SENSOR=NONE
    OSD=DISABLE
    DAEMON_MODE=DISABLE
    SENSOR_CAL=ACTUAL
    EXTRA STEPS:
    INFO  [muorb] SLPI: muorb aggregator thread running
    INFO  [muorb] SLPI: Creating pthread test_MUORB
    INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
    INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
    INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
    INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    INFO  [muorb] SLPI: Advertising remote topic log_message
    INFO  [muorb] SLPI: Starting param sync THREAD
    GPS: AUTODETECT
    RC: CRSF_RAW
    ESC: VOXL_ESC
    POWER MANAGER: VOXLPM
    DISTANCE SENSOR: NONE
    OSD: DISABLE
    EXTRA STEPS:
    Running on M0054
    INFO  [muorb] SLPI: before starting the qshell_entry task
    INFO  [muorb] SLPI: Creating pthread qshell
    INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
    INFO  [muorb] SLPI: qshell entry.....
    INFO  [muorb] SLPI: after starting the qshell_entry task
    INFO  [muorb] SLPI: Init app map initialized
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Advertising remote topic parameter_update
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
    INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
    WARN  [parameters] ignoring unrecognised parameter 'PCA9685_FUNC1'
    WARN  [parameters] ignoring unrecognised parameter 'PCA9685_MIN1'
    INFO  [parameters] BSON document size 2711 bytes, decoded 2711 bytes (INT32:34, FLOAT:91)
    INFO  [logger] logger started (mode=all)
    INFO  [muorb] SLPI: qshell gotten: icm42688p start -s
    INFO  [muorb] SLPI:   arg0 = 'icm42688p'
    INFO  [qshell] Send cmd: 'icm42688p start -s'
    INFO  [muorb] SLPI:   arg1 = 'start'
    INFO  [muorb] SLPI:   arg2 = '-s'
    INFO  [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
    INFO  [muorb] SLPI: ICM42688P::probe successful!
    INFO  [muorb] SLPI: on SPI bus 1
    INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: >>> ICM42688P this: 3176eb60
    INFO  [muorb] SLPI: Ok executing command: icm42688p start -s
    INFO  [qshell] qshell return value timestamp: 127455205, local time: 127460597
    INFO  [muorb] SLPI: Register interrupt b21d3364 e61feffc 3176eb60
    INFO  [uORB] Advertising remote topic sensor_gyro_fifo
    INFO  [uORB] Advertising remote topic sensor_accel_fifo
    INFO  [uORB] Advertising remote topic imu_server
    INFO  [qshell] Send cmd: 'icp101xx start -I -b 5'
    INFO  [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
    INFO  [muorb] SLPI:   arg0 = 'icp101xx'
    INFO  [muorb] SLPI:   arg2 = '-I'
    INFO  [muorb] SLPI:   arg3 = '-b'
    INFO  [muorb] SLPI:   arg4 = '5'
    INFO  [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
    INFO  [muorb] SLPI: icp101xx #0 on I2C bus 5
    INFO  [muorb] SLPI:  address 0x63
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
    INFO  [qshell] qshell return value timestamp: 127498623, local time: 127499767
    INFO  [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
    INFO  [muorb] SLPI: qshell gotten: qmc5883l start -R 10 -X -b 1
    INFO  [muorb] SLPI:   arg0 = 'qmc5883l'
    INFO  [muorb] SLPI:   arg2 = '-R'
    INFO  [muorb] SLPI:   arg3 = '10'
    INFO  [muorb] SLPI:   arg4 = '-X'
    INFO  [muorb] SLPI:   arg5 = '-b'
    INFO  [muorb] SLPI:   arg6 = '1'
    INFO  [muorb] SLPI: *** I2C Device ID 0x80d09 527625
    ERROR [muorb] SLPI: i2c probe failed
    INFO  [muorb] SLPI: PX4_qshell: no instance started (no device on bus?)
    ERROR [muorb] SLPI: Failed to execute command: qmc5883l start -R 10 -X -b 1
    INFO  [qshell] cmd returned with: -1
    INFO  [qshell] qshell return value timestamp: 127543572, local time: 127545535
    ERROR [qshell] Command failed
    INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
    INFO  [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
    INFO  [muorb] SLPI:   arg0 = 'ist8310'
    INFO  [muorb] SLPI: *** I2C Device ID 0x60e09 396809
    INFO  [muorb] SLPI: ist8310 #0 on I2C bus 1
    INFO  [muorb] SLPI:  (external)
    INFO  [muorb] SLPI:  address 0xE
    INFO  [muorb] SLPI:  rotation 10
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
    INFO  [qshell] qshell return value timestamp: 127591343, local time: 127593355
    INFO  [muorb] SLPI: qshell gotten: gps start
    INFO  [muorb] SLPI:   arg0 = 'gps'
    INFO  [muorb] SLPI: Creating pthread gps
    INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097647
    INFO  [muorb] SLPI: Ok executing command: gps start
    INFO  [qshell] qshell return value timestamp: 127626449, local time: 127627358
    Looking for ncp5623c RGB LED
    INFO  [muorb] SLPI: GPS UART baudrate set to 115200
    INFO  [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
    INFO  [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    INFO  [muorb] SLPI:   arg0 = 'rgbled_ncp5623c'
    INFO  [muorb] SLPI:   arg2 = '-X'
    INFO  [muorb] SLPI:   arg4 = '1'
    INFO  [muorb] SLPI:   arg5 = '-f'
    INFO  [muorb] SLPI:   arg6 = '400'
    INFO  [muorb] SLPI:   arg7 = '-a'
    INFO  [muorb] SLPI:   arg8 = '56'
    INFO  [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
    INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
    INFO  [muorb] SLPI:  address 0x38
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    INFO  [qshell] qshell return value timestamp: 127667309, local time: 127668970
    INFO  [uORB] Advertising remote topic sensor_mag
    INFO  [uORB] Advertising remote topic sensor_baro
    Starting VOXL ESC driver
    INFO  [qshell] Send cmd: 'voxl_esc start'
    INFO  [muorb] SLPI: qshell gotten: voxl_esc start
    INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
    INFO  [uORB] Advertising remote topic actuator_outputs
    INFO  [muorb] SLPI: VOXL_ESC: Starting VOXL ESC driver
    INFO  [muorb] SLPI: VOXL_ESC: Opening UART ESC device 2, baud rate 2000000
    INFO  [muorb] SLPI: VOXL_ESC: Successfully opened UART ESC device
    INFO  [muorb] SLPI: VOXL_ESC: Detecting ESCs...
    ERROR [muorb] SLPI: VOXL_ESC: ESC 0 version info response timeout
    ERROR [muorb] SLPI: VOXL_ESC: ESC 1 version info response timeout
    ERROR [muorb] SLPI: VOXL_ESC: ESC 2 version info response timeout
    ERROR [muorb] SLPI: VOXL_ESC: ESC 3 version info response timeout
    ERROR [muorb] SLPI: VOXL_ESC: ESC ID 0 was not detected
    ERROR [muorb] SLPI: VOXL_ESC: ESC ID 1 was not detected
    ERROR [muorb] SLPI: VOXL_ESC: ESC ID 2 was not detected
    ERROR [muorb] SLPI: VOXL_ESC: ESC ID 3 was not detected
    INFO  [muorb] SLPI: VOXL_ESC: Use extened rpm packet : 0
    ERROR [muorb] SLPI: VOXL_ESC: Critical error during ESC initialization. Exiting
    ERROR [muorb] SLPI: Task start failed (-1)
    ERROR [muorb] SLPI: Failed to execute command: voxl_esc start
    INFO  [qshell] qshell return value timestamp: 128021859, local time: 128026849
    Starting CRSF RC driver
    INFO  [qshell] Send cmd: 'crsf_rc start -d 7'
    INFO  [muorb] SLPI: qshell gotten: crsf_rc start -d 7
    INFO  [muorb] SLPI:   arg0 = 'crsf_rc'
    INFO  [muorb] SLPI:   arg2 = '-d'
    INFO  [muorb] SLPI:   arg3 = '7'
    INFO  [muorb] SLPI: Ok executing command: crsf_rc start -d 7
    INFO  [muorb] SLPI: Crsf serial opened sucessfully
    INFO  [muorb] SLPI: Crsf serial is single wire. Telemetry disabled
    INFO  [uORB] Advertising remote topic input_rc
    INFO  [qshell] qshell return value timestamp: 128094033, local time: 128096811
    INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
    INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
    INFO  [muorb] SLPI:   arg0 = 'voxlpm'
    INFO  [muorb] SLPI:   arg4 = '2'
    INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
    INFO  [muorb] SLPI: Set i2c address 0x6a, fd 4
    INFO  [muorb] SLPI: Set i2c address 0x44, fd 4
    INFO  [uORB] Advertising remote topic battery_status
    INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
    INFO  [muorb] SLPI:  address 0x44
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
    INFO  [uORB] Advertising remote topic power_monitor
    INFO  [qshell] qshell return value timestamp: 128157208, local time: 128160050
    INFO  [qshell] Send cmd: 'sensors start'
    INFO  [muorb] SLPI: qshell gotten: sensors start
    INFO  [muorb] SLPI:   arg0 = 'sensors'
    INFO  [uORB] Advertising remote topic sensor_selection
    INFO  [uORB] Advertising remote topic sensors_status_imu
    INFO  [uORB] Advertising remote topic vehicle_acceleration
    INFO  [uORB] Advertising remote topic vehicle_angular_velocity
    INFO  [uORB] Advertising remote topic sensor_combined
    INFO  [uORB] Advertising remote topic vehicle_air_data
    INFO  [uORB] Advertising remote topic vehicle_gps_position
    INFO  [uORB] Advertising remote topic vehicle_magnetometer
    INFO  [uORB] Advertising remote topic sensor_preflight_mag
    INFO  [uORB] Advertising remote topic sensors_status_mag
    INFO  [uORB] Advertising remote topic vehicle_imu
    INFO  [uORB] Advertising remote topic vehicle_imu_status
    INFO  [muorb] SLPI: Ok executing command: sensors start
    INFO  [qshell] qshell return value timestamp: 128399847, local time: 128406757
    INFO  [uORB] Advertising remote topic sensors_status_baro
    INFO  [qshell] Send cmd: 'ekf2 start'
    INFO  [muorb] SLPI: qshell gotten: ekf2 start
    INFO  [muorb] SLPI:   arg0 = 'ekf2'
    INFO  [uORB] Advertising remote topic vehicle_attitude
    INFO  [uORB] Advertising remote topic vehicle_local_position
    INFO  [uORB] Advertising remote topic estimator_event_flags
    INFO  [uORB] Advertising remote topic estimator_innovation_test_ratios
    INFO  [uORB] Advertising remote topic estimator_innovation_variances
    INFO  [uORB] Advertising remote topic estimator_innovations
    INFO  [uORB] Advertising remote topic estimator_sensor_bias
    INFO  [uORB] Advertising remote topic estimator_states
    INFO  [uORB] Advertising remote topic estimator_status_flags
    INFO  [muorb] SLPI: Ok executing command: ekf2 start
    INFO  [uORB] Advertising remote topic ekf2_timestamps
    INFO  [uORB] Advertising remote topic vehicle_odometry
    INFO  [uORB] Advertising remote topic estimator_aid_src_baro_hgt
    INFO  [qshell] qshell return value timestamp: 128640714, local time: 128646314
    INFO  [uORB] Advertising remote topic estimator_aid_src_fake_pos
    INFO  [uORB] Advertising remote topic estimator_aid_src_fake_hgt
    INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
    INFO  [uORB] Advertising remote topic estimator_aid_src_gravity
    INFO  [qshell] Send cmd: 'mc_pos_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_pos_control start
    INFO  [muorb] SLPI:   arg0 = 'mc_pos_control'
    INFO  [uORB] Advertising remote topic takeoff_status
    INFO  [muorb] SLPI: Ok executing command: mc_pos_control start
    INFO  [qshell] qshell return value timestamp: 128713324, local time: 128716216
    INFO  [qshell] Send cmd: 'mc_att_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_att_control start
    INFO  [muorb] SLPI:   arg0 = 'mc_att_control'
    INFO  [muorb] SLPI: Ok executing command: mc_att_control start
    INFO  [qshell] qshell return value timestamp: 128772173, local time: 128773048
    INFO  [qshell] Send cmd: 'mc_rate_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_rate_control start
    INFO  [muorb] SLPI:   arg0 = 'mc_rate_control'
    INFO  [uORB] Advertising remote topic rate_ctrl_status
    INFO  [muorb] SLPI: Ok executing command: mc_rate_control start
    INFO  [qshell] qshell return value timestamp: 128857776, local time: 128860993
    INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
    INFO  [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
    INFO  [muorb] SLPI:   arg0 = 'mc_hover_thrust_estimator'
    INFO  [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
    INFO  [qshell] qshell return value timestamp: 128918353, local time: 128920491
    INFO  [qshell] Send cmd: 'mc_autotune_attitude_control start'
    INFO  [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
    INFO  [muorb] SLPI:   arg0 = 'mc_autotune_attitude_control'
    INFO  [uORB] Advertising remote topic autotune_attitude_control_status
    INFO  [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
    INFO  [qshell] qshell return value timestamp: 128970439, local time: 128974044
    INFO  [qshell] Send cmd: 'land_detector start multicopter'
    INFO  [muorb] SLPI: qshell gotten: land_detector start multicopter
    INFO  [muorb] SLPI:   arg0 = 'land_detector'
    INFO  [muorb] SLPI:   arg2 = 'multicopter'
    INFO  [muorb] SLPI: Ok executing command: land_detector start multicopter
    INFO  [qshell] qshell return value timestamp: 129023565, local time: 129025792
    INFO  [uORB] Advertising remote topic vehicle_land_detected
    INFO  [qshell] Send cmd: 'manual_control start'
    INFO  [muorb] SLPI: qshell gotten: manual_control start
    INFO  [muorb] SLPI:   arg0 = 'manual_control'
    INFO  [muorb] SLPI: Ok executing command: manual_control start
    INFO  [uORB] Advertising remote topic manual_control_setpoint
    INFO  [qshell] qshell return value timestamp: 129075211, local time: 129077910
    INFO  [qshell] Send cmd: 'control_allocator start'
    INFO  [muorb] SLPI: qshell gotten: control_allocator start
    INFO  [muorb] SLPI:   arg0 = 'control_allocator'
    INFO  [uORB] Advertising remote topic control_allocator_status
    INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
    INFO  [uORB] Advertising remote topic actuator_motors
    INFO  [uORB] Advertising remote topic actuator_servos
    INFO  [uORB] Advertising remote topic actuator_servos_trim
    INFO  [muorb] SLPI: Ok executing command: control_allocator start
    INFO  [qshell] qshell return value timestamp: 129330519, local time: 129333718
    INFO  [qshell] Send cmd: 'load_mon start'
    INFO  [muorb] SLPI: qshell gotten: load_mon start
    INFO  [muorb] SLPI:   arg0 = 'load_mon'
    INFO  [muorb] SLPI: Ok executing command: load_mon start
    INFO  [uORB] Advertising remote topic cpuload
    INFO  [qshell] qshell return value timestamp: 129385562, local time: 129388333
    INFO  [qshell] Send cmd: 'payload_deliverer start'
    INFO  [muorb] SLPI: qshell gotten: payload_deliverer start
    INFO  [muorb] SLPI:   arg0 = 'payload_deliverer'
    INFO  [muorb] SLPI: Ok executing command: payload_deliverer start
    INFO  [qshell] qshell return value timestamp: 129425493, local time: 129426935
    INFO  [qshell] Send cmd: 'rc_update start'
    INFO  [muorb] SLPI: qshell gotten: rc_update start
    INFO  [muorb] SLPI:   arg0 = 'rc_update'
    INFO  [muorb] SLPI: Ok executing command: rc_update start
    INFO  [qshell] qshell return value timestamp: 129687963, local time: 129690196
    INFO  [uORB] Advertising remote topic rc_channels
    INFO  [qshell] Send cmd: 'commander start'
    INFO  [muorb] SLPI: qshell gotten: commander start
    INFO  [muorb] SLPI:   arg0 = 'commander'
    INFO  [muorb] SLPI: Creating pthread commander
    INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097639
    INFO  [muorb] SLPI: Ok executing command: commander start
    INFO  [uORB] Advertising remote topic led_control
    INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
    INFO  [qshell] qshell return value timestamp: 129888704, local time: 129890950
    INFO  [uORB] Advertising remote topic tune_control
    INFO  [uORB] Advertising remote topic event
    INFO  [uORB] Advertising remote topic mavlink_log
    INFO  [muorb] SLPI: Preflight Fail: Accel 0 uncalibrated
    INFO  [muorb] SLPI: Preflight Fail: Gyro 0 uncalibrated
    INFO  [muorb] SLPI: Preflight Fail: Compass 0 uncalibrated
    INFO  [uORB] Advertising remote topic health_report
    INFO  [uORB] Advertising remote topic failsafe_flags
    INFO  [uORB] Advertising remote topic actuator_armed
    INFO  [uORB] Advertising remote topic vehicle_control_mode
    INFO  [uORB] Advertising remote topic vehicle_status
    INFO  [uORB] Advertising remote topic failure_detector_status
    INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
    INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
    INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
    INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
    INFO  [qshell] Send cmd: 'flight_mode_manager start'
    INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
    INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
    INFO  [uORB] Advertising remote topic vehicle_command
    INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
    INFO  [qshell] qshell return value timestamp: 130010462, local time: 130016037
    INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
    INFO  [muorb] SLPI: Advertising remote topic transponder_report
    INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
    INFO  [muorb] SLPI: Advertising remote topic position_setpoint_triplet
    INFO  [modal_io_bridge] Modal IO Bridge driver starting
    INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
    INFO  [muorb] SLPI: Advertising remote topic telemetry_status
    INFO  [mavlink] partner IP: 127.0.0.1
    INFO  [muorb] SLPI: Advertising remote topic vehicle_visual_odometry
    INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
    INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
    INFO  [muorb] SLPI: Advertising remote topic timesync_status
    INFO  [uORB] Advertising remote topic actuator_controls_status_0
    INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
    pxh> INFO  [muorb] SLPI: GPS UART baudrate set to 9600
    INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command_ack) as advertised in process_remote_topic
    ERROR [muorb] SLPI: ====> GLOBAL R to Earth: 76.967037 (42)
    INFO  [uORB] Advertising remote topic estimator_aid_src_ev_hgt
    INFO  [uORB] Advertising remote topic estimator_aid_src_ev_pos
    INFO  [uORB] Advertising remote topic estimator_aid_src_ev_vel
    INFO  [uORB] Advertising remote topic estimator_aid_src_ev_yaw
    INFO  [muorb] SLPI: Preflight Fail: Attitude failure (roll)
    INFO  [muorb] SLPI: GPS UART baudrate set to 38400
    INFO  [muorb] SLPI: u-blox firmware version: SPG 3.01
    INFO  [muorb] SLPI: u-blox protocol version: 18.00
    INFO  [muorb] SLPI: u-blox module: NEO-M8N-0
    INFO  [muorb] SLPI: Advertising remote topic ping
    Please help urgently over this problem @Alex-Kushleyev @Eric-Katzfey since I am stuck with this issue since last two days.
    @Alex-Kushleyev just FYI this is the same custom drone with M0065 firmware for controlling 8 actuators which you shared with me, I am just keeping these two issues separate.
    • A Aaky
      Logs :
      GPS=AUTODETECT
      RC=CRSF_RAW
      ESC=VOXL_ESC
      OSD=DISABLE
      DAEMON_MODE=DISABLE
      SENSOR_CAL=ACTUAL
      EXTRA STEPS:
      ______  __   __    ___
      | ___ \ \ \ / /   /   |
      | |_/ /  \ V /   / /| |
      |  __/   /   \  / /_| |
      | |     / /^\ \ \___  |
      \_|     \/   \/     |_/
      px4 starting.
      GPS: AUTODETECT
      RC: CRSF_RAW
      ESC: VOXL_ESC
      OSD: DISABLE
      EXTRA STEPS:
      Running on M0054
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      @Aaky Can you try an experiment? Can you change qshell gps start to qshell gps start -b 38400 in /usr/bin/voxl-px4-start and see if that helps?
      A 1 Reply Last reply
        Aaky
        @Eric-Katzfey It seems to be working fine with
        qshell gps start -b 115200
        Still trying to do stress testing.
        • A Aaky
          @Aaky , we are working on resolving the GPS detection issue related to uart baud rate changes - if forcing the baud rate works reliably then just stick with that !
          • Karteek GandiboyinaK Karteek Gandiboyina referenced this topic on
