    Starling Max 2 Sideways Bench Testing
    • Myles LevineM
      Myles Levine
      I am trying to perform some tests, for which it would be much easier to hold the drone sideways (rather than propellers pointing down). However, I am unable to get the propellers to spin, even in manual mode, when the drone is in this orientation. It makes perfect sense for a drone to throw an AHRS error when like this, but is there a workaround so I can spin the propellers in manual mode?
      Thank you!
        Eric Katzfey ModalAI Team @Myles Levine
        @Myles-Levine Have you tried with the QGroundControl motor (actuator) spin tab?
        Myles LevineM 1 Reply Last reply Reply Quote 0
        • Myles LevineM
          Myles Levine @Eric Katzfey
          @Eric-Katzfey Thanks, just tried that, but got this error: 2026-02-11 11_25_32-Clipboard.png
            @Myles-Levine You should see an actuators tab. Do you have our standard VOXL SDK loaded on the drone?
            • Myles LevineM
              @Eric-Katzfey How do I check?
              • Myles LevineM
                Myles Levine @Myles Levine
                @Myles-Levine Nevermind, I got it working through the voxl interface instead of Qgroundcontrol. Thank you.
