  3. voxl2 is not booting
15 Posts 2 Posters 1.9k Views 1 Watching
  • Jetson NanoJ Jetson Nano
    successfully\n[PROGRAM] flashed \"PrimaryGPT\" successfully\n[PROGRAM] flashed \"BackupGPT\" successfully\n[PROGRAM] flashed \"PrimaryGPT\" successfully\n[PROGRAM] flashed \"BackupGPT\" successfully\nqdl: firehose operation timed out\n\nFlash flat build passed\n"}
    this is full log
    this is the end line
    Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Could you verify that this issue is due to missing sensor at U18 port c52abe21-3536-4362-8a36-86faf76b4a5c-image.png
      @Jetson-Nano , the boot issue is not related to the missing U18 (which is a secondary barometer, which was removed from the revised VOXL2 design a while ago (in M0154 revision of the VOXL2 board). The sensor was not used. https://docs.modalai.com/voxl2-onboard-sensors/#barometers
      I will double check with the team how to proceed in your case.
        Jetson Nano
        Veteran
        @Alex-Kushleyev Thank you for your reply. I have a old voxl2 as well as new revised voxl 2, the one not booting is the new one, When I compared it to the old design I didn't find the barometer, but I also had noticed that the new design do not have them, i asked just in case whether it would be the cause. Thank you for clearing the query.
        Please discuss with your team and let me know how can I proceed, If you need anymore data from me I can provide it.😊
          #9
          Hi @Jetson-Nano,
          You have an option to send the board back to use for diagnostics for a fee (if you would like to do that, please fill out the RMA form : www.modalai.com/rma). However, the likelihood for a positive result is not very high because the board and the SoC is so complex and finding micro fractures can be very difficult.
          Also, let me clarify why you are able to flash the board in EDL mode, but not boot. When in EDL mode, the majority of VOXL2 SoC is not actually running. You basically have direct USB to FLASH storage access in order to write the low-level partitions. So it might look like the board flashes fine, but when you try to boot into the OS, some issue may prevent the board from booting completely.
          There is a way to perform some more diagnostics on your own as well. VOXL2 has a debug console UART port, which is accessible via J3 : https://docs.modalai.com/voxl2-connectors/#j3---legacy-board-to-board-connector-b2b (pins 27, 29, which are unprotected, 1.8V levels).
          Even though normally we use a perf kernel which disables prints to the console, when the VOXL2 boots, there are debug messages printed to console before the kernel starts. See example below. It also possible to enable the Kernel messages to console witih a debug kernel, which we could provide if needed (or you could also build it yourself, i can tell you how).
          Do you have any add-on boards (like M0130, which has an unpopulated connector with console debug 4-pin J6, which is level shifted to 3.3V). I will see if we have any other options to tap into the debug console.
          • https://docs.modalai.com/lte-io-breakout-usb-hub-datasheet/#connector-callouts (look for J6 in the diagram, but it's not populated on the actual board)
          • the pinout of J6 on M0130, starting witih pin1 is (3.3V, DBG_RX (in), DBG_TX (out), GND)
          We also used to make M0017 but it's EOL. https://docs.modalai.com/m0017/
          Here is an example of debug console output on a VOXL2 (M0154) with perf kernel (no prints from kernel itself). You should see what debug prints you get on your damaged board, perhaps it will actually tell you what the issue is.
          Log Type: B - Since Boot(Power On Reset),  D - Delta,  S - Statistic
          S - QC_IMAGE_VERSION_STRING=BOOT.XF.3.2-00354-SM8250-1
          S - IMAGE_VARIANT_STRING=Soc8250LAA
          S - OEM_IMAGE_VERSION_STRING=4ff32558f5a2
          S - Boot Interface: UFS
          S - Secure Boot: Off
          S - Boot Config @ 0x00786070 = 0x00000001
          S - JTAG ID @ 0x00786130 = 0x0015a0e1
          S - OEM ID @ 0x00786138 = 0x00000000
          S - Serial Number @ 0x00786134 = 0xb211f0e6
          S - OEM Config Row 0 @ 0x007841e0 = 0x0000000000000000
          S - OEM Config Row 1 @ 0x007841e8 = 0x0000000000000000
          S - Feature Config Row 0 @ 0x007841f8 = 0x0040200000000400
          S - Feature Config Row 1 @ 0x00784200 = 0xc000000000000000
          S - Core 0 Frequency, 1516 MHz
          S - PBL Patch Ver: 5
          S - PBL freq: 600 MHZ
          D -      6208 - pbl_apps_init_timestamp
          D -     39432 - bootable_media_detect_timestamp
          D -       970 - bl_elf_metadata_loading_timestamp
          D -       709 - bl_hash_seg_auth_timestamp
          D -      6316 - bl_elf_loadable_segment_loading_timestamp
          D -      5492 - bl_elf_segs_hash_verify_timestamp
          D -      6999 - bl_sec_hash_seg_auth_timestamp
          D -       819 - bl_sec_segs_hash_verify_timestamp
          D -        35 - pbl_populate_shared_data_and_exit_timestamp
          S -     66980 - PBL, End
          B -     80795 - SBL1, Start
          B -    196023 - SBL1 BUILD @ 20:33:25 on Mar 24 2022
          B -    200171 - usb: usb_shared_hs_phy_init: hs phy cfg size , 0xc
          D -     10584 - sbl1_hw_init
          D -        30 - boot_flash_init
          B -    615002 - UFS INQUIRY ID: KIOXIA  THGJFAT0T44BAILB1001
          B -    616710 - UFS Boot LUN: 1
          D -       884 - Auth Metadata
          D -    419406 - sbl1_xblconfig_init
          D -         0 - boot_config_data_table_default_init
          D -       336 - boot_config_data_table_init
          B -    641506 - CDT Version:3,Platform ID:11,Major ID:1,Minor ID:0,Subtype:3
          D -     17324 - sbl1_hw_platform_pre_ddr
          D -         0 - devcfg init
          B -    670573 - PM: PM 0=0x4000008000000040:0x40
          B -    670664 - PM: PM 1=0x4000008000000040:0x800
          B -    675209 - PM: PM 2=0x4000008000000020:0x800
          B -    679875 - PM: PM 5=0x400000000000000:0x0
          B -    684511 - PM: POWER ON by CBLPWR, POWER OFF due to FAULT UVLO
          B -    697504 - PM: PMA_2 PON:CBL ON:PON OFF:FLT FAULT1:UVLO
          B -    697504 - PM: PMA_3 PON:CBL ON:PON OFF:FLT FAULT1:UVLO
          B -    804346 - PM: SET_VAL:Skip
          B -    804895 - PM: PSI: b0x00_v0x53
          B -    810964 - PM: Device Init # SPMI Transn: 5397
          B -    819962 - PM: Driver Init # SPMI Transn: 531
          B -    832772 - PM: battery Id: 7574
          B -    832772 - PM: Debug Board detected
          D -    173576 - pmic XBL init
          D -     28548 - vsense_railway_cpr init
          D -    209657 - sbl1_hw_pre_ddr_init
          D -         0 - boot_dload_handle_forced_dload_timeout
          D -      1494 - sbl1_load_ddr_training_data
          D -      5124 - sbl1_ddr_set_params
          B -    901519 - eCDT MRR - Data Starting Address: 0x09066D00
          B -    903715 - DSF version = 156.8.18
          B -    907161 - Manufacturer ID = ff, Device Type = 8
          B -    910760 - Rank 0 size = 4096 MB, Rank 1 size = 4096 MB
          D -     31354 - sbl1_ddr_init
          D -         0 - boot_pre_ddi_entry
          B -    923967 - do_ddr_training, Start
          B -    954406 - DDR: Start of DDR Training Restore
          B -    963830 - Frequency = 1805 MHz
          B -    963830 - DDR: End of DDR Training Restore
          D -     40168 - do_ddr_training, Delta
          D -     47793 - sbl1_do_ddr_training
          D -         0 - sbl1_hand_control_to_devprog_ddr
          D -      1006 - boot_ddi_entry
          B -    983167 - Pimem init cmd, entry
          D -     10736 - Pimem init cmd, exit
          D -     13878 - sbl1_post_ddr_init
          D -         0 - sbl1_hw_init_secondary
          B -   1003694 - APDP Image Load, Start
          D -       824 - Auth Metadata
          D -       488 - Segments hash check
          D -      9638 - APDP Image Loaded, Delta - (8204 Bytes)
          D -         0 - boot_dload_dump_security_regions
          B -   1021780 - usb: UFS Serial - e53d3d65
          B -   1026264 - usb: chgr -  SDP_CHARGER
          D -      8387 - boot_dload_check
          D -         0 - boot_cache_set_memory_barrier
          D -         0 - boot_smem_debug_init
          D -       366 - boot_smem_init
          D -        31 - boot_smem_alloc_for_minidump
          B -   1047492 - PM: SMEM Chgr Info Write Success
          D -      4118 - boot_smem_store_pon_status
          D -        30 - sbl1_hw_platform_smem
          D -        92 - boot_ddr_share_data_to_aop
          D -       518 - boot_clock_init_rpm
          D -         0 - boot_vsense_copy_to_smem
          D -         0 - boot_share_flash_data
          D -        30 - boot_populate_ram_partition_table
          D -        31 - boot_populate_ddr_details_shared_table
          D -         0 - sbl1_tlmm_init
          D -         0 - sbl1_efs_handle_cookies
          D -         0 - boot_apt_test
          B -   1094218 - OEM_MISC Image Load, Start
          D -       732 - Auth Metadata
          D -       305 - Segments hash check
          D -      9272 - OEM_MISC Image Loaded, Delta - (8192 Bytes)
          B -   1106875 - QTI_MISC Image Load, Start
          D -      5368 - QTI_MISC Image Loaded, Delta - (0 Bytes)
          B -   1123833 - PM: PM Total Mem Allocated: 2964
          D -      7686 - sbl1_pm_aop_pre_init_wrapper
          B -   1128408 - AOP Image Load, Start
          D -       885 - Auth Metadata
          D -      1921 - Segments hash check
          D -     13908 - AOP Image Loaded, Delta - (198224 Bytes)
          B -   1145641 - QSEE Dev Config Image Load, Start
          D -       976 - Auth Metadata
          D -       549 - Segments hash check
          D -     12505 - QSEE Dev Config Image Loaded, Delta - (45520 Bytes)
          B -   1167174 - QSEE Image Load, Start
          D -      4331 - Auth Metadata
          D -     21685 - Segments hash check
          D -     70760 - QSEE Image Loaded, Delta - (3260452 Bytes)
          D -       152 - sbl1_hw_play_vibr
          B -   1246718 - SEC Image Load, Start
          D -      2989 - SEC Image Loaded, Delta - (0 Bytes)
          B -   1253214 - CPUCPFW Image Load, Start
          D -      4728 - CPUCPFW Image Loaded, Delta - (0 Bytes)
          B -   1261785 - QHEE Image Load, Start
          D -       854 - Auth Metadata
          D -      2715 - Segments hash check
          D -     12596 - QHEE Image Loaded, Delta - (448728 Bytes)
          B -   1277675 - OEM_HYP Image Load, Start
          D -      5277 - OEM_HYP Image Loaded, Delta - (0 Bytes)
          B -   1286795 - STI Image Load, Start
          D -      5093 - STI Image Loaded, Delta - (0 Bytes)
          B -   1295914 - APPSBL Image Load, Start
          D -      1037 - Auth Metadata
          D -     13024 - Segments hash check
          D -     23851 - APPSBL Image Loaded, Delta - (2510848 Bytes)
          D -         0 - sbl1_appsbl_arch_determination
          B -   1328946 - SBL1, End
          D -   1252085 - SBL1, Delta
          S - Flash Throughput, 202000 KB/s  (6556580 Bytes,  32309 us)
          S - DDR Frequency, 1555 MHz
          UEFI Start     [ 1548]
          ModalAI v1.0
           - 0x09FC01000 [ 1552] Sec.efi
          ASLR        : ON
          DEP         : ON (RTB)
          Timer Delta : +1 mS
          RAM Entry 0 : Base 0x080000000  Size 0x03B800000
          RAM Entry 1 : Base 0x180000000  Size 0x100000000
          RAM Entry 2 : Base 0x0C0000000  Size 0x0C0000000
          Total RAM   : 0x1FB800000
          UEFI Ver    : 5.0.220324.BOOT.XF.3.2-00354-SM8250-1
          Build Info  : 64b Mar 24 2022 20:33:48
          Boot Device : UFS
          PROD Mode   : TRUE
          Retail      : TRUE
          PM0: 30, PM1: 32, PM2: 39, PM3: 33, PM5: 36,
          UFS Boot LUN: 1
           Valid primary and !Valid backup partition table
           Restore backup partition table by the primary
           Restore backup partition table success
          HW Wdog Setting from PCD : Disabled
          DisplayDxe: SW renderer mode enabled!
          DisplayDxe: Resolution 640x480 (1 intf)
          SPSSDxe:: SPSSDxe_PreLoadChecks SPSS loading in UEFI not supported for this chipID = 455
          UsbConfigLibOpenProtocols: PMI version (0x20)
          UsbConfigInit: UsbConfigInit, not start on port: 0, mode 0
          UsbConfigInit: UsbConfigInit, not start on port: 1, mode 0
          UsbConfigPortsQueryConnectionChange: usbport->connectstate: ATT
          APC1 IDDQ WC 0 , L2:0, CPU[0]:175, CPU[1]:175, CPU[2]:175, CPU[3]:175
           APC1 Total 700
          LoadSys  TIME 0ms
          tsens  TIME 1ms
          scm  TIME 2ms
          Load CPU 0 Slp: 0x6C, Int: 0x16
          Load CPU 1 Slp: 0xE0, Int: 0xFFFFFF65
          Load CPU 2 Slp: 0x94, Int: 0xFFFFFFF1
          Load CPU 3 Slp: 0x107, Int: 0xFFFFFFB1
          Load GPU 0 Slp: 0x99, Int: 0x13B adc_min:0x19E adc_max:0x15C
          Load NPU 0 Slp: 0x2C, Int: 0x4F
          LmhIsenseInit Pre CPU  TIME 0ms
          GLD IDDQ WC 0
          LmhIsenseSubSysEntry Post SubSysEntryCb  TIME 0ms
          LmhIsenseSubSysEntry Post LmhIsenseSubSysInit  TIME 0ms
          LmhIsenseInitSubSys Post SubSysEntry  TIME 0ms
          LmhIsenseInitSubSys Post SubSysTrim  TIME 0ms
          LmhIsenseInitSubSys Post SubSysExit  TIME 0ms
          LmhIsenseInit Post CPU  TIME 0ms
          GPU IDDQ 60
          LmhIsenseInitSubSys Post SubSysExit  TIME 1ms
          LmhIsenseInit Post GPU  TIME 2ms
          Entering in func1 of NPU  TIME 2ms
          NPU IDDQ 70
          LmhIsenseInit Post NPU  TIME 2ms
          isense  TIME 5ms
          ISENSE TOTAL TIME 5ms
          Disp init wait [ 2031]
          Platform Init  [ 2050] BDS
          Platform           : QRD
          Chip Name          : QRB5165
          Chip Ver           : 2.1
          Chip Serial Number : 0xB211F0E6
          Silver cluster Core 0 Freq: 1516 MHz
          UEFI Total : 542 ms
          POST Time      [ 2090] OS Loader
          Loader Build Info: May 17 2024 23:45:26
          VB: Non-secure device: Security State: (0xF7F)
          VB: RWDeviceState: Succeed using devinfo!
          KeyPress:0, BootReason:0
          Fastboot=0, Recovery:0
          GetVmData: making ScmCall to get HypInfo
          GetVmData: No Vm data present! Status = (0x3)
          VM Hyp calls not present
          Booting from slot (_a)
          Booting Into Mission Mode
          Loading Image Start : 2109 ms
          Loading Image Done : 2109 ms
          Total Image Read size : 4096 Bytes
          Loading Image Done : 2135 ms
          Total Image Read size : 17981440 Bytes
          Loading Image Start : 2141 ms
          Loading Image Done : 2166 ms
          Total Image Read size : 25165824 Bytes
          In Ubuntu ab ota platform, we don't use the system_a / _b slotGetVmData: making ScmCall to get HypInfo
          No Ffbm cookie found, ignore: Not Found
          Memory Base Address: 0x80000000
          Decompressing kernel image start: 2169 ms
          Decompressing kernel image done: 2537 ms
          Dtbo hdr magic mismatch 0, with D7B7AB1E
          DTB offset is incorrect, kernel image does not have appended DTB
          Cmdline: noinitrd  earlycon=msm_geni_serial,0xa90000 androidboot.hardware=qcom androidboot.console=ttyMSM0 androidboot.memcg=1 lpm_levels.sleep_disabled=1 video=vfb:640x400,bpp=32,memsize=3072000 msm_rtb.filter=0x237 service_locator.enable=1 androidboou
          RAM Partitions
          Add Base: 0x0000000080000000 Available Length: 0x000000003B800000
          Add Base: 0x0000000180000000 Available Length: 0x0000000100000000
          Add Base: 0x00000000C0000000 Available Length: 0x00000000C0000000
          ERROR: Could not get splash memory region node
          kaslr-Seed is added to chosen node
          Shutting Down UEFI Boot Services: 2607 ms
          Start EBS        [ 2607]
          BDS: LogFs sync skipped, Unsupported
          App Log Flush : 23 ms
          Exit EBS        [ 2645] UEFI End
            Hi @Jetson-Nano,
            D -         0 - devcfg init
            UEFI Start     [ 1548]
            ModalAI v1.0
            ASLR        : ON
            DEP         : ON (RTB)
            Timer Delta : +1 mS
            Boot Device : UFS
            PROD Mode   : TRUE
            Retail      : TRUE
            UFS Boot LUN: 1
             APC1 Total 700
            LoadSys  TIME 0ms
            tsens  TIME 1ms
            scm  TIME 2ms
            GLD IDDQ WC 0
            GPU IDDQ 60
            NPU IDDQ 70
            isense  TIME 5ms
            Platform           : QRD
            Chip Name          : QRB5165
            Chip Ver           : 2.1
            UEFI Total : 542 ms
            RAM Partitions
            Start EBS        [ 2607]
            Jetson Nano
            Veteran
            @Alex-Kushleyev thank you for reverting back, I will check what you suggested. Try to run diagnostics by myself. I will have to check whether I have M0130, and M0017. I have M0151, will that work.
              @Jetson-Nano , no, sorry M0151 does not have the console UART connection at all.
                Jetson Nano
                Veteran
                @Alex-Kushleyev will the microhard add-on board support it?
                  @Jetson-Nano , yes M0048 has a serial console port that is labeled in the docs (see diagram: https://docs.modalai.com/microhard-usb-carrier/) . It should work. When in doubt (if you dont see any debug prints), you can test it on a working voxl2 as well.
                    Jetson Nano
                    Veteran
                    @Alex-Kushleyev sure , i will test it out , thank you for your support. I will get back to you with the result once I test it out.
                      Jetson Nano
                      Veteran
                      #15
                      @Alex-Kushleyev Could you please share the pinouts of the serial console port. I am not able to find it anywhere.
