  4. Powering Servos from M0065/PWN Breakout
11 Posts 3 Posters 907 Views 1 Watching
  • M Offline
    M Offline
    Matt69
    Hi Modal AI team,
    My question is can the M0065/PWN Breakout power PWN connection for servo (signal, power, ground).
    Is there a threshold for motor power requirements to where for smaller servos an external power source isn't but it is needed for larger servos? Can you clarify what is recommended?
    • M Matt69
      Hi Modal AI team,
      @MattB69 ,
      The 5V output on M0065 (10-pin connector with pwm outputs) should not be used to power any servos. The 5V signal is generated from 3.3V (coming from VOXL2) using a step-up converter, only capable of 80mA output).
      Link Preview Image
      VOXL 2 IO Datasheet
      favicon
      the 3.3V (which is coming from VOXL2), also should not be used to power servos, as that would be risking bringing down a major power rail on VOXL2.
      M 1 Reply Last reply
        @MattB69 ,
        Link Preview Image
        VOXL 2 IO Datasheet
        favicon
        M Offline
        M Offline
        Matt69
        Thank you so much for the reply! Your answer makes sense. My only question is that the wiring diagram is misleading from the D0015 setup. It seems that for these servos that the wiring diagram does not show an external power source. Can you confirm that the diagram needs to updated, or is this an edge case (due to maybe a smaller servos used) where those servos can be power from VOXL2/IO/PWN power (for just the D0015 use case).
        Or possibly that this diagram intentionally also shows compute logic and it needs an ESC. Can you also confirm if true that the ESC was initially left off diagram?
        Take a look:
        Source:
        https://docs.modalai.com/voxl2-D0015/
        Once again thanks for responding, I absolutely love using your guys stuff - it makes everyone's stuff look bush league.
        -Matt
        • M Matt69
          Take a look:
          Source:
          -Matt
          Hello @MattB69 ,
          Sorry I made a mistake regarding the current rating of the step-up regulator. the 80mA number was for a very low input voltage (to the step-up regulator). with 3.3V intput to the step-up regulator, M0065 can support up to 350mA of output current at 5V, but we still do not recommend using it for powering servos.
          So this means that our documentation for D0015 flight configuration is in conflict with documentation for M0065 board (which says use 5.0V for reference only).
          Even though we have tested it in the D0015 configuration with "some" servos (i am not sure which ones were used), we still do not recommend powering servos using 5V from M0065. We will update the D0015 documentation.. Thanks for pointing it out!
            Hello @MattB69 ,
            M Offline
            M Offline
            Matt69
            All is clear now. Thanks Alex!
            • M Matt69
              M Offline
              M Offline
              Matt69
              wrote on last edited by Matt69
              One more additional question about D0015 Diagram. The diagram shows that the Airspeed sensor board is being powered by 5V spliced from pin 1 on M0054 J19 connection.
              Also in the documentation, MCBL-00089 (Modal AI custom wire) is called out to be used for this connection of M0054 to GPS/LIDAR/Airspeed (see: https://docs.modalai.com/voxl2-D0015/)
              My issue is that MCBL-00089 does not natively have this 5V connection pinned. See screenshot from MCBL-00089 purchase page. This also matches the MCBL-00089 that I bought.
              (Source: https://www.modalai.com/products/mcbl-00089?srsltid=AfmBOoqMsjLJnhWpaEPHMT_G8Yh8ix-NsRjJgGycprWXTBS-i_xqN8xY)
              Main question: Is the expectation that the user modifies MCBL-0089 to make this splice themselves? Or am I missing something here?
              Alex KushleyevA wilkinsafW 2 Replies Last reply
              • M Matt69
                @Matt69 , good question. let me ask someone else to help with that 🙂
                • M Matt69
                  wilkinsafW Offline
                  wilkinsafW Offline
                  wilkinsaf
                  @Matt69
                  1. A UBEC was used for the servo connections, and they SHOULD NOT be powered from the board. We will update that drawing, thank you for pointing that out
                  2. As this was a first time build we did create that custom cable to deliver power to the airspeed sensor. We will make a note for that in the layout
                  Appreciate you pointing these things out so we can make those adjustments!
                  • wilkinsafW wilkinsaf
                    @Matt69
                    M Offline
                    M Offline
                    Matt69
                    @wilkinsaf
                    So to confirm - it is Modal AI's recommendation that the user modifies MCBL-0089 to allow for board (Voxl 2 Pin 1) to power airspeed sensor for this configuration? (Until you guys release a new custom cable for this use case?)
                    • M Matt69
                      @wilkinsaf
                      @Matt69 , yes you should splice the cable as needed. I will double check if we have plans to release a new cable, it will probably depend on the demand.
                        M Offline
                        M Offline
                        Matt69
