    Different package version from voxl-cross and Voxl2
    • R
      remill
      I am having an issue with compiling a library with voxl-cross and runing it on the Voxl2 board. I did compile on voxl-cross but when I try to run a programme that use the library. I got an error with libusb :
      voxl-tcp-neuro: symbol lookup error: /usr/local/lib/libcaer.so.3: undefined symbol: libusb_set_log_cb
      After a researching on google and asking AI chat bot. I found that the version of libusb on the Voxl2 board is 1.0.21 in contrast to 1.0.27 on voxl-cross. The result is that libusb missing libusb_set_log_cb.
      I tried to update the version on Voxl2 but I did not succed because 1.0.21 is the latest version availible on ubuntu 18, but voxl-cross seem to run ubuntu 24.
      Is there a way to make it work ?
        Eric Katzfey ModalAI Team @remill
        @remill said in Different package version from voxl-cross and Voxl2:
        1.0.27
        Perhaps you can build the desired version of libusb from source and install it? We have used this approach for a variety of other "third party" libraries. Examples are here: https://gitlab.com/voxl-public/voxl-sdk/third-party?page=1
        • R
          remill @Eric Katzfey
          I tried it based on this project
          but it need a CMakeList.txt for it to compile. I did build other third party library succesfully, but building libusb from source file does not provide a CMakeList.txt, at least from their github. The only way they sugesst to install is with apt.
          Is their a way to build from source without a Cmakelist.txt file ?
            @remill libusb doesn't use cmake. It uses autogen.sh, configure, make, etc. These are standard Linux build tools. If you enter a query such as "How do I build libusb on Linux?" into Google and check AI mode it will provide you with all the steps.
            • R
              Thanks Eric, building directly on the Voxl2 platform works.
