  3. VOXL 2 J18 port for External FC
15 Posts 2 Posters 1.2k Views 1 Watching
  • Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Hey @Vinny @Eric-Katzfey ,
    guys I am trying to use the J18 port on voxl 2 for connecting the external FC ( flight core v2).
    While I try to run it , the voxl-mavlink-server is throwing error.
    I assigned the autopilto_uart_bus to 12 as mentioned in the documentation.
    voxl2:/$ voxl-mavlink-server
    loading our own config file
    primary_static_gcs_ip:        192.168.168.2
    secondary_static_gcs_ip:      192.168.8.11
    onboard_port_to_autopilot:    14556
    onboard_port_from_autopilot:  14557
    gcs_port_to_autopilot:        14558
    gcs_port_from_autopilot:      14559
    en_external_uart_ap:          1
    autopilot_uart_bus:           12
    autopilot_uart_baudrate:      921600
    autopilot_mission_delay_start:      -1
    autopilot_mission_delay_sound:      0
    autopilot_mission_notif_dur:      0.10
    udp_mtu:                      500
    gcs_timeout_s                 4.50
    en_external_ap_timesync:      1
    en_external_ap_heartbeat:     1
    Received standard error event SNS_STD_ERROR_NOT_SUPPORTED
    Couldn't configure flight_controller sensor
    ERROR:   fc_sensor_initialize failed
    ERROR:   Failed to initialize slpi
    ERROR:   Encountered error while initializing bus 12
    ERROR: Unable to configure bus 12 (baudrate 921600) with voxl_io
    Stopping autopilot io module
    Stopping gcs io module
    Stopping pipe io module
    closing remaining client pipes
    closing remaining server pipes
    Removing PID file
    exiting
      Jetson Nano
      Veteran
      the error mentioned above was caused by the voxl-px4 server, once I disabled it was solved.
      Still I was not able to see the data from the external FC
      udp_mtu:                      500
      gcs_timeout_s                 4.50
      Successfully opened bus 12 at baudrate 921600
      starting qrb5165 external AP receive thread
      Adding primary GCS IP address from conf file to list: 192.168.168.2
      Added new UDP connection to 192.168.168.2
      Adding secondary manual gcs IP address to udp connection list: 192.168.8.11
      Added new UDP connection to 192.168.8.11
      • Jetson NanoJ Jetson Nano
        udp_mtu:                      500
        gcs_timeout_s                 4.50
        Jetson Nano
        Veteran
        @Jetson-Nano
        now it is getting data from fc , it was a issue with baudrate, the J18 port can not handle 3000000 baudrate.
        still i am facing an issue, where the QGC is not getting connected, the qgc is loading,then getting disconnected, again regaining connection this is going in a loop.
        I tried increasing the udp_mtu still no change, same behaviour.
        The error is mentioned below.
        Sending topic message
        --- msg_id: 1033
        --- topic name: uart_data
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        --- msg_id: 1033
        MAVLINK-server
         "primary_static_gcs_ip":        "192.168.168.100",
                "secondary_static_gcs_ip":      "192.169.168.2",
                "onboard_port_to_autopilot":    14556,
                "onboard_port_from_autopilot":  14557,
                "gcs_port_to_autopilot":        14558,
                "gcs_port_from_autopilot":      14559,
                "en_external_uart_ap":  true,
                "autopilot_uart_bus":   12,
                "autopilot_uart_baudrate":      921600,
                "autopilot_mission_delay_start":        -1,
                "autopilot_mission_delay_sound":        false,
                "autopilot_mission_notif_dur":  0.1,
                "en_external_ap_timesync":      1,
                "en_external_ap_heartbeat":     10,
                "udp_mtu":      800,
                "gcs_timeout_s":        1
        after this issue, the mavlink server is shuting down and showing the below error
        Couldn't locate SUID for flight_controller
        Failed to detect flight controller sensor
        Removing PID file
        exiting
        rebooting and running again gives
        voxl2:~$ voxl-mavlink-server
        primary_static_gcs_ip:        192.168.168.200
        secondary_static_gcs_ip:      192.169.168.1
        udp_mtu:                      800
        gcs_timeout_s                 1.00
        existing instance of voxl-mavlink-server found, attempting to stop it
        Adding primary GCS IP address from conf file to list: 192.168.168.200
        Added new UDP connection to 192.168.168.200
        Adding secondary manual gcs IP address to udp connection list: 192.169.168.1
        Added new UDP connection to 192.169.168.1
        CONNECTED to GCS at 192.168.168.200
        Detected Autopilot Mavlink SYSID 188
        WARNING: UART parser dropped 1 packets from external AP at i=346
        WARNING: UART parser dropped 1 packets from external AP at i=359
        WARNING: UART parser dropped 1 packets from external AP at i=437
        WARNING: UART parser dropped 1 packets from external AP at i=527
        WARNING: UART parser dropped 1 packets from external AP at i=543
        WARNING: UART parser dropped 1 packets from external AP at i=738
        WARNING: UART parser dropped 1 packets from external AP at i=6
        WARNING: UART parser dropped 1 packets from external AP at i=132
        WARNING: UART parser dropped 1 packets from external AP at i=353
        WARNING: UART parser dropped 1 packets from external AP at i=833
        WARNING: UART parser dropped 1 packets from external AP at i=57
        WARNING: UART parser dropped 1 packets from external AP at i=20
        Detected Autopilot Mavlink SYSID 57
        Detected Autopilot Mavlink SYSID 55
        WARNING: UART parser dropped 1 packets from external AP at i=0
        The mavlink sysid is changing
        udp_mtu:                      500
        gcs_timeout_s                 1.00
        WARNING: UART parser dropped 1 packets from external AP at i=128
        WARNING: UART parser dropped 1 packets from external AP at i=302
        Detected Autopilot Mavlink SYSID 65
        WARNING: UART parser dropped 1 packets from external AP at i=84
        WARNING: UART parser dropped 1 packets from external AP at i=68
        WARNING: UART parser dropped 1 packets from external AP at i=92
        WARNING: UART parser dropped 1 packets from external AP at i=141
        DISCONNECTED FROM GCS 192.168.168.200
        Detected Autopilot Mavlink SYSID 28
          @Jetson-Nano
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          --- msg_id: 1033
          MAVLINK-server
                  "udp_mtu":      800,
                  "gcs_timeout_s":        1
          Removing PID file
          exiting
          udp_mtu:                      800
          gcs_timeout_s                 1.00
          udp_mtu:                      500
          gcs_timeout_s                 1.00
          @Jetson-Nano Can you try a lower baudrate, like 57600, and see if that works better?
            Jetson Nano
            Veteran
            @Eric-Katzfey I tried lower baudrate also, the behaviour is similar.
              @Jetson-Nano Do you still get those messages from voxl-mavlink-server about dropped packets from external AP?
                @Jetson-Nano Are you using WiFi to connect with QGC?
                  Jetson Nano
                  Veteran
                  @Eric-Katzfey yes I still had that messages popping up
                    Jetson Nano
                    Veteran
                    @Eric-Katzfey No I was using the Microhard module. Irrespective of the communication module, these many time should the sysid change and the packet lose should not occure, right?
                      Jetson Nano
                      Veteran
                      #10
                      I changed the Mavlink version to what you had mentioned here, I felt the errors were similar
                      Link
                      this is when baudrate is 57600
                      primary_static_gcs_ip_port:   14550
                      secondary_static_gcs_ip:      192.169.168.2
                      secondary_static_gcs_ip_port: 14550
                      autopilot_uart_baudrate:      57600
                      autopilot_mission_force_restart:      0
                      udp_mtu:                      0
                      gcs_timeout_s                 1.00
                      Successfully opened bus 12 at baudrate 57600
                      Adding primary GCS IP address from conf file to list: 192.168.168.200:14550
                      Added new UDP connection to 192.168.168.200:14550
                      Adding secondary manual gcs IP address to udp connection list: 192.169.168.2:14550
                      Added new UDP connection to 192.169.168.2:14550
                      CONNECTED to GCS at 192.168.168.200:14550
                      Waiting to detect autopilot sys id...
                      ^C
                      received SIGINT Ctrl-C
                      Starting shutdown sequence
                      exiting read thread
                      qrb5165 external ap interface stopped
                      WARNING: Received 12 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
                      WARNING: Received 41 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
                      WARNING: Received 32 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
                      WARNING: Received 36 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
                      WARNING: Received 18 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
                      exiting gcs udp listener thread
                      udp gcs io stopped
                      Removing PID file
                      exiting
                      this is when baudrate is 921600
                      udp_mtu:                      0
                      gcs_timeout_s                 1.00
                      Detected Autopilot Mavlink SYSID 130
                      WARNING: UART parser dropped 1 packets from external AP at i=10
                      ^C
                      exiting read thread
                      WARNING: Received 11 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
                      WARNING: Received 54 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
                      WARNING: Received 10 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
                      WARNING: Received 7 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
                      WARNING: Received 9 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
                      udp gcs io stopped
                      Removing PID file
                      exiting
                      voxl2:~$
                        Link
                        udp_mtu:                      0
                        gcs_timeout_s                 1.00
                        ^C
                        exiting read thread
                        udp gcs io stopped
                        Removing PID file
                        exiting
                        udp_mtu:                      0
                        gcs_timeout_s                 1.00
                        ^C
                        exiting read thread
                        udp gcs io stopped
                        Removing PID file
                        exiting
                        voxl2:~$
                        Jetson Nano
                        Veteran
                        voxl-mavlink-server -z
                        voxl2:~$ voxl-mavlink-server -z
                        Enabling UDP to slpi recv debugging
                        Enabling qrb5165 external AP recv debugging
                        Enabling UDP to slpi send debugging
                        Enabling qrb5165 external AP send debugging
                        Enabling UDP GCS recv debugging
                        Enabling UDP GCS send debugging
                        udp_mtu:                      0
                        gcs_timeout_s                 1.00
                        onboard  pipe  ID:  84 compid: 197
                        to AP msg ID:    84 sysid:130   to bus: 12
                        onboard  pipe  ID: 330 compid: 197
                        to AP msg ID:   330 sysid:130   to bus: 12
                        onboard  pipe  ID:   0 compid: 196
                        to AP msg ID:     0 sysid:130   to bus: 12
                        from GCS    ID:   0 port: 14550 IP: 192.168.168.200
                        to AP msg ID:     0 sysid:255   to bus: 12
                        from gcs pipe ID:   0  compid: 190
                        from gcs pipe ID:   0 compid: 100
                        to GCS      msgid:    0 compid 100
                          udp_mtu:                      0
                          gcs_timeout_s                 1.00
                          @Jetson-Nano Looks like you are never receiving anything FROM the AP. Only sending stuff TO it. Can you put an oscilloscope on the RX / TX UART lines to see what the traffic looks like. For some reason it doesn't seem like the UART is setup properly on either the FC or the DSP so with an oscilloscope you can better see what is going on.
                            Jetson Nano
                            Veteran
                            @Eric-Katzfey I am facing a different error,
                            udp_mtu:                      0
                            gcs_timeout_s                 1.00
                            ERROR:   Received error from ring_buf_push in p_slpi_receive_callback: ERR_NO_SPACE
                              udp_mtu:                      0
                              gcs_timeout_s                 1.00
                              Jetson Nano
                              Veteran
                              #14
                              These mentioned errors were only observed while using microhard unit
                              voxl2:/$ voxl-mavlink-server -z
                              udp_mtu:                      200
                              gcs_timeout_s                 1.00
                              RECV  msg ID:    74 sysid:  1 from bus: 12
                              RECV  msg ID:    30 sysid:  1 from bus: 12
                              RECV  msg ID:    31 sysid:  1 from bus: 12
                              RECV  msg ID:   105 sysid:  1 from bus: 12
                              RECV  msg ID:    32 sysid:  1 from bus: 12
                              RECV  msg ID:   331 sysid:  1 from bus: 12
                              RECV  msg ID:     1 sysid:  1 from bus: 12
                              RECV  msg ID:   411 sysid:  1 from bus: 12
                              RECV  msg ID:   132 sysid:  1 from bus: 12
                              RECV  msg ID:   111 sysid:  1 from bus: 12
                              RECV  msg ID:   141 sysid:  1 from bus: 12
                              RECV  msg ID:    83 sysid:  1 from bus: 12
                              RECV  msg ID:   245 sysid:  1 from bus: 12
                              RECV  msg ID:    85 sysid:  1 from bus: 12
                              RECV  msg ID:    36 sysid:  1 from bus: 12
                              RECV  msg ID:   106 sysid:  1 from bus: 12
                              to GCS      msgid:  105 compid   1
                              to GCS      msgid:   32 compid   1
                              to GCS      msgid:   30 compid   1
                              to ob pipe  ID: 331  compid:   1
                              to gcs pipe ID: 331  compid:   1
                              to GCS      msgid:  331 compid   1
                              to ob pipe  ID:  31  compid:   1
                              to gcs pipe ID:  31  compid:   1
                              to GCS      msgid:   31 compid   1
                              to ob pipe  ID:  30  compid:   1
                              to gcs pipe ID:  30  compid:   1
                              to ob pipe  ID: 105  compid:   1
                              to gcs pipe ID: 105  compid:   1
                              to ob pipe  ID:  32  compid:   1
                              to gcs pipe ID:  32  compid:   1
                              to ob pipe  ID: 132  compid:   1
                              to gcs pipe ID: 132  compid:   1
                              to GCS      msgid:  132 compid   1
                              to AP msg ID:   111 sysid:  1   to bus: 12
                              to gcs pipe ID: 111  compid:   1
                              to GCS      msgid:  111 compid   1
                              to ob pipe  ID: 141  compid:   1
                              to gcs pipe ID: 141  compid:   1
                              to GCS      msgid:  141 compid   1
                              to ob pipe  ID:  83  compid:   1
                              to gcs pipe ID:  83  compid:   1
                              to GCS      msgid:   83 compid   1
                              to ob pipe  ID:  85  compid:   1
                              to gcs pipe ID:  85  compid:   1
                              to GCS      msgid:   85 compid   1
                              to ob pipe  ID:  36  compid:   1
                              to gcs pipe ID:  36  compid:   1
                              to GCS      msgid:   36 compid   1
                              to ob pipe  ID:  74  compid:   1
                              to gcs pipe ID:  74  compid:   1
                              to GCS      msgid:   74 compid   1
                              to ob pipe  ID: 106  compid:   1
                              to gcs pipe ID: 106  compid:   1
                              to GCS      msgid:  106 compid   1
                              RECV  msg ID:     0 sysid:  1 from bus: 12
                              to ob pipe  ID:   0  compid:   1
                              to gcs pipe ID:   0  compid:   1
                              to AP msg ID:    84 sysid:  1   to bus: 12
                              RECV  msg ID:   410 sysid:  1 from bus: 12
                              to ob pipe  ID: 410  compid:   1
                              to gcs pipe ID: 410  compid:   1
                              to GCS      msgid:  410 compid   1
                              onboard  pipe  ID: 331 compid: 197
                              to AP msg ID:   331 sysid:  1   to bus: 12
                              to AP msg ID:   330 sysid:  1   to bus: 12
                              to AP msg ID:     0 sysid:  1   to bus: 12
                              to ob pipe  ID: 245  compid:   1
                              to gcs pipe ID: 245  compid:   1
                              to GCS      msgid:  245 compid   1
                                udp_mtu:                      200
                                gcs_timeout_s                 1.00
                                Jetson Nano
                                Veteran
                                #15
                                hey,
                                I observed something while the above behaviour still persists.
                                The modem and the camera server is showing not running while checking through the inspect services command.
                                I do not know whether this is related to this issue, but the voxl 2 is rebooting after sometime, the reboot is not constant and I am not able to able to find the reason for the reboot. Can everything be related to each other.
                                I am using the Microhard modem
