    VOXL 2 Connecting an External Flight Controller Problem
    793
    • R
      ravi
      Hi @Moderator,
      I am using VOXL2 and FCv2.
      and following VOXL 2 Connecting an External Flight Controller
      Document for FCv2 and VOXl2 connection and configuration.
      Setup
      Both FCv2 and VOXl2 are connected to the PC.
      And J1 of FCv2 and J18 of VOXL2 is connected for MAVLINK UART connection.
      ![Conenction details](b6c6849c-e75f-468c-9c1c-05be34ff146e-image.png image url)
      SW configuration
      • voxl-mavlink-server config file. (/etc/modalai/voxl-mavlink-server.conf)
              "primary_static_gcs_ip":        "",
              "secondary_static_gcs_ip":      "",
              "onboard_port_to_autopilot":    14556,
              "onboard_port_from_autopilot":  14557,
              "gcs_port_to_autopilot":        14558,
              "gcs_port_from_autopilot":      14559,
              "en_external_uart_ap":  true,
              "autopilot_uart_bus":   12,
              "autopilot_uart_baudrate":      57600,
              "autopilot_mission_delay_start":        -1,
              "autopilot_mission_delay_sound":        false,
              "autopilot_mission_force_restart":      10,
              "autopilot_mission_notif_dur":  0.1,
              "en_external_ap_timesync":      1,
              "en_external_ap_heartbeat":     1,
              "udp_mtu":      0,
              "gcs_timeout_s":        4.5
      "/etc/modalai/voxl-mavlink-server.conf" 66L, 3249C written
      • voxl-inspect-services
      Scanning services...
       Service Name             |  Enabled  |   Running   |  CPU Usage
       docker-autorun           | Disabled  | Not Running |
       modallink-relink         | Disabled  | Not Running |
       voxl-camera-server       |  Enabled  | Not Running |
       voxl-cpu-monitor         | Disabled  | Not Running |
       voxl-dfs-server          | Disabled  | Not Running |
       voxl-elrs-startup        | Disabled  | Not Running |
       voxl-feature-tracker     | Disabled  | Not Running |
       voxl-flow-server         | Disabled  | Not Running |
       voxl-iim-server          | Disabled  | Not Running |
       voxl-imu-server          | Disabled  | Not Running |
       voxl-io-server           | Disabled  | Not Running |
       voxl-lepton-server       | Disabled  | Not Running |
       voxl-lepton-tracker      | Disabled  | Not Running |
       voxl-logger              | Disabled  | Not Running |
       voxl-mavcam-manager      |  Enabled  |   Running   |     0.0%
       voxl-mavlink-server      |  Enabled  |   Running   |     0.0%
       voxl-mini-tof-server     | Disabled  | Not Running |
       voxl-modem               |  Enabled  |   Running   |     0.0%
       voxl-open-vins-server    | Disabled  | Not Running |
       voxl-osd                 | Disabled  | Not Running |
       voxl-portal              |  Enabled  |   Running   |     0.0%
       voxl-px4-imu-server      | Disabled  | Not Running |
       voxl-px4                 | Disabled  | Not Running |
       voxl-qvio-server         | Disabled  | Not Running |
       voxl-rangefinder-server  | Disabled  | Not Running |
       voxl-remote-id           | Disabled  | Not Running |
       voxl-rpx-sever           | Disabled  | Not Running |
       voxl-seek-server         | Disabled  | Not Running |
       voxl-softap              | Disabled  | Not Running |
       voxl-state-estimator     | Disabled  | Not Running |
       voxl-static-ip           | Disabled  | Not Running |
       voxl-stitcher            | Disabled  | Not Running |
       voxl-streamer            |  Enabled  |   Running   |     0.0%
       voxl-tag-detector        | Disabled  | Not Running |
       voxl-tflite-server       | Disabled  | Not Running |
       voxl-time-sync           | Disabled  | Not Running |
       voxl-uvc-server          | Disabled  | Not Running |
       voxl-vision-hub          | Disabled  | Not Running |
       voxl-vrx                 | Disabled  | Not Running |
       voxl-vtx                 | Disabled  | Not Running |
       voxl-wait-for-fs         |  Enabled  |  Completed  |
      • voxl-mavlink-server status
      voxl2:/$ systemctl status voxl-mavlink-server
      ● voxl-mavlink-server.service - voxl-mavlink-server
         Loaded: loaded (/usr/bin/voxl-mavlink-server; enabled; vendor preset: enabled)
         Active: active (running) since Thu 2025-05-01 17:59:43 UTC; 6min ago
        Process: 1675 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
       Main PID: 1968 (voxl-mavlink-se)
          Tasks: 30 (limit: 4915)
         CGroup: /system.slice/voxl-mavlink-server.service
                 └─1968 /usr/bin/voxl-mavlink-server
      May 01 17:59:43 m0054 voxl-mavlink-server[1968]: autopilot_mission_delay_sound:      0
      May 01 17:59:43 m0054 voxl-mavlink-server[1968]: autopilot_mission_force_restart:      10
      May 01 17:59:43 m0054 voxl-mavlink-server[1968]: autopilot_mission_notif_dur:      0.10
      May 01 17:59:43 m0054 voxl-mavlink-server[1968]: udp_mtu:                      0
      May 01 17:59:43 m0054 voxl-mavlink-server[1968]: gcs_timeout_s                 4.50
      May 01 17:59:43 m0054 voxl-mavlink-server[1968]: en_external_ap_timesync:      1
      May 01 17:59:43 m0054 voxl-mavlink-server[1968]: en_external_ap_heartbeat:     1
      May 01 17:59:43 m0054 voxl-mavlink-server[1968]: =================================================================
      May 01 17:59:43 m0054 voxl-mavlink-server[1968]: Sending library name request: libslpi_qrb5165_io.so
      May 01 17:59:43 m0054 voxl-mavlink-server[1968]: Sending initialization request
      • systemctl restart voxl-mavlink-server
      May 01 19:22:02 m0054 voxl-mavlink-server[16506]: received SIGTERM
      May 01 19:22:02 m0054 systemd[1]: Stopping voxl-mavlink-server...
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: Successfully opened bus 12 at baudrate 921600
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: starting qrb5165 external AP receive thread
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: Not connecting to primary gcs ip:
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: Not connecting to secondary gcs ip:
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: Init complete, entering main loop
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: Starting shutdown sequence
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: Stopping autopilot io module
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: exiting read thread
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: qrb5165 external ap interface stopped
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: Stopping gcs io module
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: exiting gcs udp listener thread
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: udp gcs io stopped
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: Stopping pipe io module
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: closing remaining client pipes
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: closing remaining server pipes
      May 01 19:22:03 m0054 voxl-mavlink-server[16506]: Removing PID file
      May 01 19:22:03 m0054 systemd[1]: Stopped voxl-mavlink-server.
      May 01 19:22:03 m0054 systemd[1]: Starting voxl-mavlink-server...
      May 01 19:22:05 m0054 systemd[1]: Started voxl-mavlink-server.
      May 01 19:22:05 m0054 voxl-mavlink-server[17426]: loading our own config file
      May 01 19:22:05 m0054 voxl-mavlink-server[17426]: =================================================================
      May 01 19:22:05 m0054 voxl-mavlink-server[17426]: Parameters as loaded from config file:
      Problem
      • Currently using SDK 1.4
      • I disabled the voxl-px4 service on VOXL2.
      • Connected FCv2 TELEM1 port J1 with J18 port of VOXL2.
      • Using baudrate 57600 on both
      • Now for J18 port on VOXL2 using “autopilot_uart_bus”: 12 (SLPI_QUP2_UART/QUP2) in configuration.
      • Now, it seems DSP libslpi is getting hung/stuck and not responding, as shown in voxl-mavlink-server status. The last line is "Sending initialization request". Then there is no log form mavlink-server.
      • Now, if I restart the MAVLink server. after stopping the interrupt. port seems open and then closes. as above log.
      Is it an issue with SLPI, or is the DSP UART port not usable for MAVLINK?
      Help me debug and provide a resolution.
      Thanks.
      Ravi
      • R
        ravi @ravi
        @ravi
        Find the VOXL2 app versions.
        voxl2:/$ voxl-version
        kernel:       #1 SMP PREEMPT Mon Nov 11 22:08:01 UTC 2024 4.19.125
        hw platform:  M0054
        mach.var:     1.0.0
        SKU:          MRB-D0006-4-V1-C11-T1-M23-X0
        voxl-suite:   1.4.4-202504302200
        Packages:
        Repo:  http://voxl-packages.modalai.com/ qrb5165 dev
        Last Updated: 2025-05-01 18:00:20
        List:
        libfc-sensor                              1.0.7-202503131014
        libmodal-cv                               0.5.17-202504301813
        libmodal-exposure                         0.1.4-202504301817
        libmodal-journal                          0.2.4-202504250956
        libmodal-json                             0.4.6-202504301809
        libmodal-pipe                             2.13.0-202504211020
        libqrb5165-io                             0.4.9-202504291621
        libvoxl-cci-direct                        0.3.1-202504301829
        libvoxl-cutils                            0.1.4-202504301826
        modalai-slpi                              1.1.20-202504131441
        qrb5165-dfs-server                        0.2.0-202309221318
        qrb5165-imu-server                        1.2.0-202504241319
        qrb5165-mini-tof-server                   0.2.2-202504291141
        qrb5165-rangefinder-server                0.1.5-202502211754
        qrb5165-system-tweaks                     0.3.5-202503241242
        qrb5165-tflite                            2.8.0-2-202210071637
        voxl-benchmark-vio                        0.5.7-202504041555
        voxl-bind-spektrum                        0.1.1-202403271220
        voxl-camera-calibration                   0.5.9-202411191414
        voxl-camera-server                        2.1.2-202504281425
        voxl-capture                              0.0.1-202206110121
        voxl-ceres-solver                         2:1.14.0-10-202504291324
        voxl-configurator                         1.0.1-202504301741
        voxl-cpu-monitor                          0.5.3-202504231157
        voxl-cross-template                       0.0.1-202504171512
        voxl-docker-support                       1.3.1-202404041529
        voxl-elrs                                 0.4.4-202504041253
        voxl-esc                                  1.5.2-202504292017
        voxl-feature-tracker                      0.5.2-202412171357
        voxl-flow-server                          0.3.6-202403180603
        voxl-gphoto2-server                       0.0.10-202210072352
        voxl-iim-server                           0.0.3-202503210929
        voxl-io-server                            0.0.5-202502191136
        voxl-joystick-server                      0.0.1-202504291738
        voxl-jpeg-turbo                           2.1.3-7-202504301743
        voxl-lepton-server                        1.3.3-202412171302
        voxl-lepton-tracker                       0.0.4-202412190958
        voxl-libgphoto2                           0.0.4-202204111958
        voxl-libuvc                               1.0.7-202210072357
        voxl-logger                               0.5.3-202504141224
        voxl-mavcam-manager                       0.5.8-202504080850
        voxl-mavlink                              0.1.5-202504301802
        voxl-mavlink-server                       1.4.7-202504291641
        voxl-modem                                1.1.6-202504301834
        voxl-mongoose                             7.7.0-2-202504301848
        voxl-mpa-to-ros                           0.3.9-202407091506
        voxl-mpa-tools                            1.3.8-202504221446
        voxl-open-vins                            0.4.18-202504301757
        voxl-open-vins-server                     0.3.10-202504071452
        voxl-opencv                               4.5.5-3-202504301748
        voxl-osd                                  0.1.6-202504241636
        voxl-portal                               0.7.10-202504240926
        voxl-px4                                  1.14.0-2.0.104-202504231041
        voxl-px4-imu-server                       0.1.2-202205131833
        voxl-px4-params                           0.7.0-202504301738
        voxl-qvio-server                          1.1.1-202411151825
        voxl-remote-id                            0.0.9-202309191605
        voxl-reset-slpi                           0.0.1-202405130827
        voxl-rpx-server                           0.0.1-202409271312
        voxl-rtp                                  0.0.1-202206101543
        voxl-state-estimator                      0.0.5-202504181708
        voxl-stitcher                             0.0.2-202206161634
        voxl-streamer                             0.7.5-202412021550
        voxl-suite                                1.4.4-202504302200
        voxl-tag-detector                         0.0.4-202206302112
        voxl-tflite-server                        0.4.1-202504301555
        voxl-utils                                1.4.7-202504301851
        voxl-uvc-server                           0.1.7-202405141018
        voxl-vision-hub                           1.8.21-202504291456
        voxl-vtx                                  1.3.13-202504291344
        voxl-wavemux                              0.0.1-202503181201
        voxl2-io                                  0.0.3-202405011635
        voxl2-system-image                        1.8.02-r0
        voxl2:/$
          Eric Katzfey ModalAI Team @ravi
          @ravi Can you stop the system service for voxl-mavlink-server (e.g. systemctl stop voxl-mavlink-server) and run it from the command line instead with the -z option to see all message traffic? You should see something like this:
          voxl2:/$ voxl-mavlink-server -z
          Enabling UDP to slpi recv debugging
          Enabling qrb5165 external AP recv debugging
          Enabling UDP to slpi send debugging
          Enabling qrb5165 external AP send debugging
          Enabling UDP GCS recv debugging
          Enabling UDP GCS send debugging
          primary_static_gcs_ip:        192.168.0.131
          secondary_static_gcs_ip:      192.168.8.11
          onboard_port_to_autopilot:    14556
          onboard_port_from_autopilot:  14557
          gcs_port_to_autopilot:        14558
          gcs_port_from_autopilot:      14559
          en_external_uart_ap:          1
          autopilot_uart_bus:           12
          autopilot_uart_baudrate:      57600
          autopilot_mission_delay_start:      -1
          autopilot_mission_force_restart:      0
          udp_mtu:                      0
          gcs_timeout_s                 4.50
          Successfully opened bus 12 at baudrate 57600
          Adding primary GCS IP address from conf file to list: 192.168.0.131
          Added new UDP connection to 192.168.0.131
          Adding secondary manual gcs IP address to udp connection list: 192.168.8.11
          Added new UDP connection to 192.168.8.11
          to AP msg ID:     0 sysid:  1   to bus: 12
          RECV  msg ID:    70 sysid:255 from bus: 12
          • R
            ravi @Eric Katzfey
            For testing, I changed the UART port to 2 and then change to port 12.
            stopped service and ran "voxl-mavlink-server -z"
            and got the following errors.
            ![68d1045c-eaa7-46ee-b0de-b313bee851cb-1000019409.jpeg](/assets/uploads/files/1762187345269-68d1045c-eaa7-46ee-b0de-b313bee851cb-1000019409.jpeg) code_text
            Then rebooted the VOXl2 and tried again, and got this log. But no MAVLink connection with FCv2. using J1 of FCv2 to connect with J18 of VOXL2.
            udp_mtu:                      500
            gcs_timeout_s                 4.50
            onboard  pipe  ID: 330 compid: 197
            to AP msg ID:   330 sysid:  1   to bus: 12
            onboard  pipe  ID:  84 compid: 197
            to AP msg ID:    84 sysid:  1   to bus: 12
            onboard  pipe  ID: 331 compid: 197
            to AP msg ID:   331 sysid:  1   to bus: 12
            Check by heartbeat check. But no ap heartbeat.
            voxl2:~/old_backup/etc-modalai/modalai$ voxl-inspect-mavlink mavlink_ap_heartbeat
            waiting for pipe to connect
            • R
              ravi @ravi
              Also, seeing the following error messages pointing flight controller.
              Sending topic message
              --- msg_id: 1033
              --- topic name: uart_data
              --- msg_id: 1033
              Connection error: connection reset
              --- msg_id: 1033
              Got response cb 0
              Got flight controller event
              Received standard error event SNS_STD_ERROR_NOT_SUPPORTED
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              Got response cb 0
              --- msg_id: 1033
              • R
                ravi @ravi
                @ravi
                mavlink-server status issue seems random.
                I stopped the service and changed the baud rate, and ran app from the terminal "voxl-mavlink-server"
                Seems MAVLink connection established. and getting an AP heart rate at 0.3Hz.
                Then I tried the same with mavlink service.
                I terminated it running process for the mavlik-server.
                They started the MAVLink service. and checked status and not starting.
                voxl2:/$ systemctl start voxl-mavlink-server
                   Active: failed (Result: exit-code) since Thu 2023-03-02 13:29:47 UTC; 3s ago
                  Process: 11260 ExecStart=/usr/bin/voxl-mavlink-server (code=exited, status=255)
                  Process: 11253 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
                 Main PID: 11260 (code=exited, status=255)
                Mar 02 13:29:47 m0054 voxl-mavlink-server[11260]: ERROR: Unable to configure bus 12 (baudrate 460800) with voxl_io
                Mar 02 13:29:47 m0054 voxl-mavlink-server[11260]: Stopping autopilot io module
                Mar 02 13:29:47 m0054 voxl-mavlink-server[11260]: Stopping gcs io module
                Mar 02 13:29:47 m0054 voxl-mavlink-server[11260]: Stopping pipe io module
                Mar 02 13:29:47 m0054 voxl-mavlink-server[11260]: closing remaining client pipes
                Mar 02 13:29:47 m0054 voxl-mavlink-server[11260]: closing remaining server pipes
                Mar 02 13:29:47 m0054 voxl-mavlink-server[11260]: Removing PID file
                Mar 02 13:29:47 m0054 voxl-mavlink-server[11260]: exiting
                Mar 02 13:29:47 m0054 systemd[1]: voxl-mavlink-server.service: Main process exited, code=exited, status=255/n/a
                Mar 02 13:29:47 m0054 systemd[1]: voxl-mavlink-server.service: Failed with result 'exit-code'.
                Then tried from the terminal again, getting the error as below.
                autopilot_uart_baudrate:      460800
                udp_mtu:                      500
                gcs_timeout_s                 4.50
                Couldn't locate SUID for flight_controller
                Failed to detect flight controller sensor
                ERROR:   fc_sensor_initialize failed
                ERROR:   Failed to initialize slpi
                ERROR:   Encountered error while initializing bus 12
                Removing PID file
                exiting
                udp_mtu:                      500
                gcs_timeout_s                 4.50
                Removing PID file
                exiting
                voxl2:/$
                • R
                  ravi @ravi
                  I am testing with J18(VOXl2) and J1(TELEM1) port.
                  Seems SLPI is throwing a lot of errors in demsg.
                  and @115200 buadrate.
                  • MAVLink connections are getting lost in a few minutes.
                    and getting rx loss of 124% on FCv2 QGC.
                  Can you let me know if the J18 DSP port is buggy or how to fix these errors?
                  After a few minutes or a few restarts of VOXl-mavlink-server. it stops working and shows an error and exits
                  ERROR: Unable to configure bus 12 (baudrate 115200) with voxl_io
                  Removing PID file
                  exiting
                  ====> dmesg log while voxl-mavlink-server running stopped working and throwing an error when starting
                  [  460.730018] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  460.730717] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  460.730901] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  460.790600] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  460.853124] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  460.853154] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  460.860922] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  460.860928] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  460.861499] 1118855912:Entered
                  [  460.861942] 1118855912:SMD QRTR driver probed
                  [  460.862983] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  460.866169] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  460.866208] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  460.874694] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  462.106273] Fatal error on slpi!
                  [  462.106348] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_1:0x68:sns_stream_service.c:436:req_found.
                  [  462.106375] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  462.108414] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  462.108416] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  462.120395] rpmh_rsc_send_data: 17 callbacks suppressed
                  [  462.120396] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  462.120423] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  462.121677] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  462.121691] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  462.122027] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  462.122151] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  462.122757] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  462.122886] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  462.178193] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  462.240639] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  462.240671] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  462.240789] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  462.247665] 1118855912:Entered
                  [  462.248151] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  462.248158] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  462.249366] 1118855912:SMD QRTR driver probed
                  [  462.252554] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  462.254897] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  462.254962] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  462.261500] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  463.481618] Fatal error on slpi!
                  [  463.481694] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_1:0x68:sns_stream_service.c:436:req_found.
                  [  463.481720] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  463.483312] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  463.483315] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  463.495481] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  463.495494] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  463.495505] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  463.495516] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  463.495528] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  463.495539] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  463.495551] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  463.498539] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  463.498548] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  463.498944] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  463.499294] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  463.499834] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  463.499987] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  463.558705] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  463.619354] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  463.619389] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  463.626313] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  463.626319] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  463.629242] 1118855912:Entered
                  [  463.631383] 1118855912:SMD QRTR driver probed
                  [  463.633320] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  463.633334] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  463.633688] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  463.641981] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  464.864191] Fatal error on slpi!
                  [  464.864266] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found.
                  [  464.864291] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  464.867315] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  464.867320] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  464.883697] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  464.883706] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  464.885643] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  464.885787] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  464.887190] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  464.887455] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  464.945581] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  465.007996] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  465.008139] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  465.015414] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  465.015420] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  465.015924] 1118855912:Entered
                  [  465.016498] 1118855912:SMD QRTR driver probed
                  [  465.019954] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  465.023578] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  465.023627] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  465.029301] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  466.256347] Fatal error on slpi!
                  [  466.256432] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found.
                  [  466.256456] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  466.259074] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  466.259079] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  466.275522] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  466.275806] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  466.277897] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  466.278247] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  466.279336] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  466.279500] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  466.338642] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  466.399095] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  466.399127] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  466.405824] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  466.405830] 1118855912:Entered
                  [  466.405832] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  466.406031] 1118855912:SMD QRTR driver probed
                  [  466.407495] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  466.411445] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  466.412552] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  466.419864] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  467.641878] Fatal error on slpi!
                  [  467.641957] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_1:0x68:sns_stream_service.c:436:req_found.
                  [  467.641983] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  467.644997] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  467.645001] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  467.656914] rpmh_rsc_send_data: 19 callbacks suppressed
                  [  467.656915] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  467.656940] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  467.658270] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  467.658280] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  467.658668] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  467.659779] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  467.661747] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  467.661931] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  467.716145] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  467.778657] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  467.778688] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  467.778800] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  467.786334] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  467.786340] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  467.786864] 1118855912:Entered
                  [  467.787109] 1118855912:SMD QRTR driver probed
                  [  467.790948] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  467.795012] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  467.795026] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  467.800505] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  469.020359] Fatal error on slpi!
                  [  469.020432] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found.
                  [  469.020458] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  469.022405] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  469.022408] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  469.034300] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  469.034318] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  469.034337] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  469.034348] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  469.034360] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  469.034371] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  469.034382] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  469.040876] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  469.040986] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  469.041166] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  469.041336] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  469.042154] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  469.042336] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  469.101055] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  469.161468] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  469.161515] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  469.168694] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  469.168702] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  469.168830] 1118855912:Entered
                  [  469.169190] 1118855912:SMD QRTR driver probed
                  [  469.170647] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  469.177803] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  469.178019] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  469.183206] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  470.408342] Fatal error on slpi!
                  [  470.408426] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found.
                  [  470.408454] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  470.410929] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  470.410934] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  470.428290] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  470.428426] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  470.430688] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  470.430827] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  470.431771] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  470.431903] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  470.491572] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  470.554485] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  470.554528] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  470.561372] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  470.561377] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  470.562108] 1118855912:Entered
                  [  470.562411] 1118855912:SMD QRTR driver probed
                  [  470.567554] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  470.569456] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  470.569501] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  470.575413] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  471.808443] Fatal error on slpi!
                  [  471.808525] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found.
                  [  471.808553] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  471.811212] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  471.811217] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  471.827600] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  471.827611] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  471.829473] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  471.829658] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  471.830216] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  471.830370] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  471.885397] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  471.947763] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  471.947797] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  471.955860] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  471.955865] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  471.957236] 1118855912:Entered
                  [  471.958811] 1118855912:SMD QRTR driver probed
                  [  471.959979] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  471.962094] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  471.962128] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  471.969208] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  473.190744] Fatal error on slpi!
                  [  473.190818] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found.
                  [  473.190843] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  473.193872] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  473.193878] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  473.205809] rpmh_rsc_send_data: 11 callbacks suppressed
                  [  473.205810] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  473.205837] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  473.206983] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  473.206995] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  473.207337] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  473.210007] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  473.210544] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  473.211534] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  473.267488] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  473.329966] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  473.330083] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  473.337309] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  473.337313] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  473.337774] 1118855912:Entered
                  [  473.338098] 1118855912:SMD QRTR driver probed
                  [  473.339277] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  473.343685] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  473.343696] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  473.351954] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  474.571003] Fatal error on slpi!
                  [  474.571089] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_1:0x68:sns_stream_service.c:436:req_found.
                  [  474.571117] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  474.574318] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  474.574322] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  474.586295] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  474.586323] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  474.587793] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  474.587808] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  474.592474] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  474.592629] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  474.593885] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  474.594047] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  474.648774] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  474.710135] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  474.710177] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  474.716090] 1118855912:Entered
                  [  474.716142] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  474.716147] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  474.716593] 1118855912:SMD QRTR driver probed
                  [  474.718796] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  474.724814] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  474.724833] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  474.730730] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  475.966509] Fatal error on slpi!
                  [  475.966596] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_1:0x68:sns_stream_service.c:436:req_found.
                  [  475.966624] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  475.969220] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  475.969224] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  475.981165] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  475.981191] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  475.983399] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  475.983410] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  475.987724] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  475.987865] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  475.989595] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  475.989762] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  476.047626] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  476.107799] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  476.107835] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  476.114130] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  476.114135] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  476.116482] 1118855912:Entered
                  [  476.119264] 1118855912:SMD QRTR driver probed
                  [  476.121677] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  476.122117] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  476.122133] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  476.130800] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  477.367311] Fatal error on slpi!
                  [  477.367394] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_1:0x68:sns_stream_service.c:436:req_found.
                  [  477.367420] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  477.370476] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  477.370480] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  477.382395] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  477.382419] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  477.383806] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  477.383817] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  477.384136] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  477.384263] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  477.384816] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  477.385120] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  477.443490] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  477.506162] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  477.506193] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  477.506290] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  477.512803] 1118855912:Entered
                  [  477.513075] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  477.513079] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  477.513148] 1118855912:SMD QRTR driver probed
                  [  477.515628] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  477.521213] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  477.521250] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  477.525781] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  503.375461] Fatal error on slpi!
                  [  503.375541] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_1:0x68:sns_stream_service.c:436:req_found.
                  [  503.375566] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED.
                  [  503.378697] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting
                  [  503.378700] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2054]: Shutting down slpi
                  [  503.390607] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030
                  [  503.390638] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040
                  [  503.391897] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service
                  [  503.391976] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service
                  [  503.392269] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi
                  [  503.393461] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi
                  [  503.394021] subsys-restart: subsystem_powerup(): [kworker/u19:0:2054]: Powering up slpi
                  [  503.394144] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000
                  [  503.455432] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset
                  [  503.515539] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up
                  [  503.515566] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received
                  [  503.521829] 1118855912:Entered
                  [  503.521855] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up
                  [  503.521861] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2054]: Restart sequence for slpi completed.
                  [  503.522191] 1118855912:SMD QRTR driver probed
                  [  503.523845] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi
                  [  503.530404] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service
                  [  503.530421] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service
                  [  503.535973] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3
                  [  928.349273] perf: interrupt took too long (2502 > 2500), lowering kernel.perf_event_max_sample_rate to 79750
                  [ 1413.270080] perf: interrupt took too long (3128 > 3127), lowering kernel.perf_event_max_sample_rate to 63750
                  [ 2701.369922] perf: interrupt took too long (3915 > 3910), lowering kernel.perf_event_max_sample_rate to 51000
                  FCv2 QGC mavlink status when communication working
                  nsh> mavlink status
                  instance #0:
                      mavlink chan: #0
                      type:        GENERIC LINK OR RADIO
                      flow control: OFF
                      rates:
                        tx: 1322.9 B/s
                        txerr: 0.0 B/s
                        tx rate mult: 0.050
                        tx rate max: 1200 B/s
                        rx: 4758.9 B/s
                        rx loss: 128.0%
                      Received Messages:
                        sysid:  1, compid:197, Total: 3287 (lost: 425347)
                          msgid:    0, Rate:  0.3 Hz, last 0.15s ago
                          msgid:  330, Rate:  7.3 Hz, last 0.18s ago
                          msgid:  331, Rate: 12.1 Hz, last 0.05s ago
                          msgid:   84, Rate: 11.6 Hz, last 0.08s ago
                        sysid:  1, compid:196, Total: 37 (lost: 0)
                          msgid:    0, Rate:  0.3 Hz, last 2.44s ago
                      FTP enabled: YES, TX enabled: YES
                      mode: Onboard
                      Forwarding: On
                      MAVLink version: 2
                      transport protocol: serial (/dev/ttyS6 @115200)
                  FCv2 QGC mavlink status when "connection to mission computer lost"
                  mavlink status
                  instance #0:
                      mavlink chan: #0
                      flow control: OFF
                      rates:
                        tx: 1621.3 B/s
                        txerr: 0.0 B/s
                        tx rate mult: 0.050
                        rx: 0.0 B/s
                        rx loss: 125.6%
                      Received Messages:
                        sysid:  1, compid:197, Total: 6025 (lost: 765633)
                        sysid:  1, compid:196, Total: 69 (lost: 0)
                      mode: Onboard
                      Forwarding: On
                      MAVLink version: 2
                  Please update if J18 is usable or not for MAVLink?
                    @ravi J18 should work. Let's try this one step at a time and see if we can figure out where the issue is. Start by disabling the voxl-mavlink-server, voxl-px4, etc. services and power cycle the VOXL 2. With port set to 12 and baudrate at 57600 does voxl-mavlink-server -z show connection with autopilot? If so, does it stay connected? And can you connect GCS? If all of that works fine, power cycle the VOXL 2 and just make sure that it reliably works. Let me know how all that goes before we move to the next step.
                      @ravi Keep in mind you must power cycle the VOXL 2 between each thing you do because the DSP (SLPI) won't cleanly shut down and if you try to start voal-mavlink-server again it will fail.
                      • R
                        ravi
                        I tested J18(VOXl2) SDK 1.5 and J1(FCv2) firmware V1.15.2.
                        VOXL2 is connected with FCv2.
                        FCv2 connected with QGC.
                        I rebooted VOXL2. But after a few minutes, MAVLink connection broke.
                        I will test J18 later.
                        Now, to move forward. using J9 for 5G modem and connected with J1 FCv2.
                        Connection seems stable. Now the connection is lost.
                        But now the major issue is that RX loss is 124%.
                        I disabled messages 331,84 and configured 330 @ 10Hz.
                        Still, I am experiencing a 21.3% Rx loss.
                        The only messages visible is Heatbeat(0) and Obstacle_distance(330).
                        I did check. How many messages does FCv2 lose?
                        seems to be successfully receiving only 10-11 messages per second
                        and losing 254 messages per second.
                        So, actually getting only <5% messages successfully.
                        mavlink status with VOXL2 default configuration of vision-hub
                        instance #0:
                            mavlink chan: #0
                            flow control: ON
                            rates:
                              tx: 639.8 B/s
                              txerr: 0.0 B/s
                              tx rate mult: 0.302
                              rx: 13464.5 B/s
                              rx loss: 124.4%
                            Received Messages:
                              sysid:  1, compid:197, Total: 97158 (lost: 12227092)
                                msgid:    0, Rate:  1.0 Hz, last 0.04s ago
                                msgid:   84, Rate: 31.3 Hz, last 0.01s ago
                                msgid:  331, Rate: 32.4 Hz, last 0.03s ago
                                msgid:  330, Rate: 20.3 Hz, last 0.02s ago
                              sysid:  1, compid:196, Total: 1135 (lost: 0)
                                msgid:    0, Rate:  0.9 Hz, last 0.08s ago
                            mode: Normal
                            Forwarding: On
                            MAVLink version: 2
                            transport protocol: serial (/dev/ttyS6 @230400)
                        mavlink status with VOXL2 disabled 331, 84, and 331@10Hz in vision-hub config
                        instance #0:
                            mavlink chan: #0
                            flow control: OFF
                            rates:
                              tx: 1106.7 B/s
                              txerr: 0.0 B/s
                              tx rate mult: 0.310
                              rx: 1828.2 B/s
                              rx loss: 21.3%
                            Received Messages:
                              sysid:  1, compid:197, Total: 7820 (lost: 180596)
                                msgid:    0, Rate:  1.0 Hz, last 0.37s ago
                                msgid:  330, Rate: 10.0 Hz, last 0.06s ago
                              sysid:  1, compid:196, Total: 672 (lost: 0)
                                msgid:    0, Rate:  0.9 Hz, last 0.97s ago
                            mode: Normal
                            Forwarding: On
                            MAVLink version: 2
                            transport protocol: serial (/dev/ttyS6 @921600)
                        • if MAVLink mode changed to onboard mode
                        instance #0:
                            mavlink chan: #0
                            flow control: OFF
                            rates:
                              tx: 21751.5 B/s
                              txerr: 0.0 B/s
                              tx rate mult: 1.000
                              tx rate max: 46080 B/s
                              rx: 2429.8 B/s
                              rx loss: 82.9%
                            Received Messages:
                              sysid:  1, compid:197, Total: 44616 (lost: 3811731)
                                msgid:    0, Rate:  1.0 Hz, last 0.51s ago
                                msgid:  330, Rate: 10.0 Hz, last 0.01s ago
                                msgid:  111, Rate:100.9 Hz, last 0.08s ago
                              sysid:  1, compid:196, Total: 1358 (lost: 0)
                                msgid:    0, Rate:  0.9 Hz, last 1.02s ago
                            mode: Onboard
                            Forwarding: On
                            MAVLink version: 2
                        • Is it expected behaviour?
                        • How to debug Rx loss?
                          Also, there is a huge difference in success and loss.
                        • Is PX4 filtering or discarding packets?
                        • Originally, we were losing 95% messages, and it is showing 21.3% loss.
                        • How to calculate Rx loss because the actual is way higher?
                          @ravi It's acting like you have a mismatch in baudrate settings for the UARTs. Try setting the baudrate to 115200 for port 12 in /etc/modalai/voxl-mavlink-server.conf. In order to setup the FCv2 connect to QGC with USB and set SER_TEL1_BAUD to 115200 8N1, then reboot. Make sure you are connected to the TELEM1 connector on FCv2 and J18 on VOXL 2.
                          • R
                            ravi @Eric Katzfey
                            As said,
                            Currently, I am using J9 of a 5G modem and connected with J1 of FCv2.
                            Connection seems stable. using a 921600 baud rate with port 2.
                            The major issue is RX loss.
                            seeing 95% message loss, as I explained in an earlier post.
                            below is mavlink status visible on QGC mavlink console:
                            nsh> mavlink status
                            instance #0:
                                mavlink chan: #0
                                flow control: OFF
                                rates:
                                  tx: 1106.7 B/s
                                  txerr: 0.0 B/s
                                  tx rate mult: 0.310
                                  rx: 1828.2 B/s
                                  rx loss: 21.3%
                                Received Messages:
                                mode: Normal
                                Forwarding: On
                                MAVLink version: 2
                            As above, the RX loss showing is 21.3% which is huge.
                            It is in normal mode. If I change the mavling mode to onboard, it is an 83% loss. and with vision hub odomatry, distance massages it is getting worst like 125%.
                            Now. This Rx loss does not match the number.
                            As per this MAVLink status, the total successfully received messages are 7820, and the lost are 180596.
                            So, actual loss is (180596/(7820+180596)) = 95.8%.
                            And it is showing only 21.3%.
                            So, MAVLink is working between VOXl2 and FCv2. Currently using UART port 2 of VOXl2, not 12. I will debug it later. Once setup is complete.
                              @ravi Here is what I see on my setup testing with baudrate 921600, TELEM1 (J1), and J18 (12):
                              nsh> mavlink status
                              instance #0:
                                  GCS heartbeat valid
                                  mavlink chan: #0
                                  flow control: OFF
                                  rates:
                                    tx: 1773.5 B/s
                                    txerr: 0.0 B/s
                                    tx rate mult: 1.000
                                    rx: 570.5 B/s
                                    rx loss: 0.0%
                                  Received Messages:
                                    sysid:255, compid:190, Total: 2341 (lost: 57)
                                      msgid:  126, Rate:  nan Hz, last 0.01s ago
                                      msgid:    4, Rate:  0.1 Hz, last 2.27s ago
                                      msgid:    0, Rate:  1.0 Hz, last 0.58s ago
                                      msgid:   69, Rate: 29.1 Hz, last 0.02s ago
                                    sysid:  1, compid:197, Total: 108 (lost: 0)
                                      msgid:    0, Rate:  1.0 Hz, last 0.86s ago
                                  mode: Normal
                                  Forwarding: Off
                                  MAVLink version: 2
                                  ping statistics:
                                    last: 14.29 ms
                                    mean: 31.46 ms
                                    max: 135.44 ms
                                    min: 13.21 ms
                                    dropped packets: 0
                                @ravi I'm suspecting you have a bad cable or the cable is subject to some interference. Can you try this on a benchtop with just a VOXL 2 and an FC v2 and no other components? Is it currently integrated into a custom drone? Can you look at the signal quality on the TX and RX UART lines with an oscilloscope?
