  3. Teledyne FLIR Lepton 3.5 Integration
18 Posts 2 Posters 2.7k Views 1 Watching
  • george kollamkulamG Offline
    george kollamkulam
    I was looking to integrate the Teledyne FLIR Lepton 3.5 onto the Starling 2 UAV (running PX4) using SPI/I2C. Could you advise on the steps involved? Would this need any driver level modifications or is sufficient to configure certain pre-defined parameters?
    • george kollamkulamG george kollamkulam
      @george-kollamkulam ,
      Please take a look at this document : https://docs.modalai.com/voxl2-d0014/#downward-range-finder-and-flir-lepton
      You will need M0157 adapter + actual Lepton sensor. The M0157 adapter will plug into the M0173 camera front end. Then it will be pretty much plug and play.
      Let me check how to get M0157 - it does not appear to be in the shop.
        @george-kollamkulam , can you please check if you already have the M0157 adapter installed in your Starling 2?
        Just for completeness, we are updating M0157 to M0187 which has identical functionality but also has additional i2c-gpio circuit to perform a hardware reset of lepton and tof sensor if needed. Also a small change in dimensions.
        However, if you already have M0157, which you should, it should work just fine.
        george kollamkulamG 2 Replies Last reply
          george kollamkulam
          @Alex-Kushleyev thanks, I have the M0157 adapter installed on my Starling 2.
            george kollamkulam
            @Alex-Kushleyev It looks like our Starling 2 UAV has the M0157 adapter, the M0173 board (Yellow PCB that also connects to the 3 AR0144 sensors and the TOF sensor), and the 7pin cable that connects the M0157 adapter to the M0173 board. Just to clarify, this configuration is sufficient to integrate (plug-and-play) the Teledyne FLIR Lepton 3.5 without modifying the drivers? If not, do you have any recommended thermal sensors that can directly fit into this hardware and software architecture? I'd be happy to buy them.
              @george-kollamkulam , yes FLIR Lepton 3.5 just inserts into M0157 board which has the socket for the bare Lepton sensor.
              Once you install the sensor into the docket, boot up voxl2 and run voxl-lepton-server. It will autogenerate a default config file /etc/modalai/voxl-lepton-server.conf that will look like this.
              	"spi_bus":	14,
              	"spi_speed":	16000000,
              	"en_i2c":	false,
              	"i2c_bus":	0,
              	"shutter_mode":	"auto",
              	"flow_shutter_s":	20,
              	"closePeriodInFramesInAir":	1,
              	"openPeriodInFramesInAir":	0,
              	"desiredFfcPeriodMsInAir":	360000,
              	"desiredFfcTempDeltaCentiDegInAir":	600,
              	"en_rotate":	false
              You will need to change the SPI bus to 0 and , set en_i2c to true and i2c_bus to 4 because this is the configuration for this Hardware arrangement (M0173 + M0157) per the following documentation : https://docs.modalai.com/voxl2-d0014/#downward-range-finder-and-flir-lepton
              Then you can run voxl-lepton-server again in foreground or enable the systemd server using systemctl enable voxl-lepton-server and systemctl start voxl-lepton-server . After that you shoud be able to see the Lepton output using voxl-portal.
              george kollamkulamG 1 Reply Last reply
                	"spi_bus":	14,
                	"en_i2c":	false,
                	"i2c_bus":	0,
                	"en_rotate":	false
                george kollamkulam
                @Alex-Kushleyev thanks, this seems to be working well. Can you also share what voxl-lepton-tracker is used for?
                George
                  George
                  @george-kollamkulam , the lepton tracker is an implementation of optic flow tracker for the lepton data, you can see the details here : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-lepton-tracker/-/blob/master/src/feature_tracker.cpp
                    george kollamkulam
                    @Alex-Kushleyev I tried using the Lepton 3.5 sensor again, but this time I was unable to see the feed on the voxl portal, although voxl-lepton-server and voxl-camera-services were running. Additionally, I couldn't hear the clicking sound from the lepton sensor that was previously present. What could be the issue here? Is there anything I'm missing?
                    I also noticed that the rear tracking camera wasn't functional (I'm not sure if this is related to the functioning of the lepton camera). It was seen on the voxl system check page on the voxl portal.
                      @george-kollamkulam , are you saying that just the Lepton and the tracking cameras are not working now, but all the other cameras are working fine?
                      voxl-camera-server and voxl-lepton-server are completely independent and should not be interfering. However, Please try to unplug the lepton sensor from M0173 board and see if the tracking camera starts working again.
                      it seems like maybe there is some power issue, since lepton is not clicking, since it should be doing that as soon as it gets power.
                        george kollamkulam
                        @Alex-Kushleyev I did a power cycle on the lepton sensor and it seems to be working now (click sound and feed available). All cameras except the rear tracking camera seems to be working fine (screenshot attached below). It doesn't show up on the voxl portal. How can we resolve this?
                          @george-kollamkulam , can you please provide output of “voxl-camera-server -l”? This will show us which cameras are detected (excluding lepton). Note that running this command will stop the camera server if it is running in the background.
                            george kollamkulam
                            Number of cameras detected: 4
                            On the voxl portal system check, it returned false for tracking_rear (VOXL-Camera-Server) and error for imageSensor2 (VOXL Image Sensors).
                            ![Screenshot from 2025-07-09 10-43-06.png](Request Entity Too Large)
                              You are using a version of SDK which had a bug that was suppressing most of the prints, so voxl-camera-server -l is not reporting any information.
                              To fix this, please use the latest version of libmodal-journal package (you can get it from here : http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64//libmodal-journal_0.2.6-202505081055_arm64.deb
                              How many cameras do you actually have on your Starling 2? is it 4? Two tracking, one Hires camera and on TOF?
                                george kollamkulam
                                @Alex-Kushleyev apart from the lepton sensor, I have 5 (1 hires, 1 tof and 3 tracking).
                                Can you please point me to the resource that explains how to update the libmodal-journal package? Would I need to reinstall ROS2 Foxy or anything else?
                                George
                                  George
                                  @george-kollamkulam , in order to install the updated libmodal-journal package, you just download the file that i linked to VOXL2, lets say you put it in /home/root/.
                                  Then, using adb you go to /home/root and execute:
                                  dpkg -i libmodal-journal_0.2.6-202505081055_arm64.deb
                                  Then you just run voxl-camera-server -l and you should see a lot more information being printed.
                                    george kollamkulam
                                    @Alex-Kushleyev here's the system response.
                                    voxl2:/$ cd /home/root
                                    voxl2:~$ dpkg -i libmodal-journal_0.2.6-202505081055_arm64.deb
                                    (Reading database ... 137565 files and directories currently installed.)
                                    Preparing to unpack libmodal-journal_0.2.6-202505081055_arm64.deb ...
                                    Unpacking libmodal-journal (0.2.6-202505081055) over (0.2.5) ...
                                    Setting up libmodal-journal (0.2.6-202505081055) ...
                                    Processing triggers for libc-bin (2.27-3ubuntu1.6) ...
                                    voxl2:~$ dpkg -l | grep libmodal-journal
                                    ii libmodal-journal 0.2.6-202505081055 arm64 Journaling library
                                    voxl2:~$ voxl-camera-server -l
                                    DEBUG: Attempting to open the hal module
                                    DEBUG: SUCCESS: Camera module opened on attempt 0
                                    DEBUG: ----------- Number of cameras: 4
                                    DEBUG: Cam idx: 0, Cam slot: 0, Slave Address: 0x0030, Sensor Id: 0x0356
                                    DEBUG: Cam idx: 1, Cam slot: 1, Slave Address: 0x0034, Sensor Id: 0x0577
                                    DEBUG: Cam idx: 2, Cam slot: 3, Slave Address: 0x007A, Sensor Id: 0x2975
                                    DEBUG: Cam idx: 3, Cam slot: 6, Slave Address: 0x0030, Sensor Id: 0x0356
                                    DEBUG: Note: This list comes from the HAL module and may not be indicative
                                    DEBUG: of configurations that have full pipelines
                                    DEBUG: Number of cameras: 4
                                    Stats for camera: 0
                                    1280 x 800
                                    1280 x 800
                                    1280 x 800 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    1280 x 800 HAL_PIXEL_FORMAT_BLOB
                                    1280 x 768 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    1280 x 768 HAL_PIXEL_FORMAT_BLOB
                                    1280 x 720 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    1280 x 720 HAL_PIXEL_FORMAT_BLOB
                                    1024 x 738 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    1024 x 738 HAL_PIXEL_FORMAT_BLOB
                                    1024 x 768 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    1024 x 768 HAL_PIXEL_FORMAT_BLOB
                                    864 x 480 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    864 x 480 HAL_PIXEL_FORMAT_BLOB
                                    800 x 600 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    800 x 600 HAL_PIXEL_FORMAT_BLOB
                                    800 x 480 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    800 x 480 HAL_PIXEL_FORMAT_BLOB
                                    720 x 480 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    720 x 480 HAL_PIXEL_FORMAT_BLOB
                                    640 x 512 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    640 x 512 HAL_PIXEL_FORMAT_BLOB
                                    640 x 480 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    640 x 480 HAL_PIXEL_FORMAT_BLOB
                                    640 x 400 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    640 x 400 HAL_PIXEL_FORMAT_BLOB
                                    640 x 360 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    640 x 360 HAL_PIXEL_FORMAT_BLOB
                                    352 x 288 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    352 x 288 HAL_PIXEL_FORMAT_BLOB
                                    320 x 240 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    320 x 240 HAL_PIXEL_FORMAT_BLOB
                                    240 x 320 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    240 x 320 HAL_PIXEL_FORMAT_BLOB
                                    176 x 144 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    176 x 144 HAL_PIXEL_FORMAT_BLOB
                                    1280 x 800 HAL_PIXEL_FORMAT_RAW10
                                    1280 x 800 HAL_PIXEL_FORMAT_RAW12
                                    1280 x 800 HAL_PIXEL_FORMAT_RAW16
                                    1280 x 800 HAL_PIXEL_FORMAT_RAW_OPAQUE
                                    min = 54
                                    max = 1596
                                    1596
                                    min = 0ns
                                    max = 1318629735ns
                                    Stats for camera: 1
                                    4056 x 3040
                                    3840 x 2160
                                    1920 x 1080
                                    1920 x 1080
                                    1920 x 1080
                                    1280 x 720
                                    1280 x 720
                                    1280 x 960 HAL_PIXEL_FORMAT_YCbCr_420_888
                                    1280 x 960 HAL_PIXEL_FORMAT_BLOB
                                    4056 x 3040 HAL_PIXEL_FORMAT_RAW10
                                    4056 x 3040 HAL_PIXEL_FORMAT_RAW12
                                    4056 x 3040 HAL_PIXEL_FORMAT_RAW16
                                    4056 x 3040 HAL_PIXEL_FORMAT_RAW_OPAQUE
                                    3840 x 2160 HAL_PIXEL_FORMAT_RAW10
                                    3840 x 2160 HAL_PIXEL_FORMAT_RAW12
                                    3840 x 2160 HAL_PIXEL_FORMAT_RAW16
                                    3840 x 2160 HAL_PIXEL_FORMAT_RAW_OPAQUE
                                    1920 x 1080 HAL_PIXEL_FORMAT_RAW10
                                    1920 x 1080 HAL_PIXEL_FORMAT_RAW12
                                    1920 x 1080 HAL_PIXEL_FORMAT_RAW16
                                    1920 x 1080 HAL_PIXEL_FORMAT_RAW_OPAQUE
                                    min = 100
                                    max = 35200
                                    2200
                                    min = 0ns
                                    max = 243753000ns
                                    Stats for camera: 2
                                    240 x 1629
                                    240 x 1629 HAL_PIXEL_FORMAT_RAW10
                                    240 x 1629 HAL_PIXEL_FORMAT_RAW12
                                    240 x 1629 HAL_PIXEL_FORMAT_RAW16
                                    240 x 1629 HAL_PIXEL_FORMAT_RAW_OPAQUE
                                    min = 54
                                    max = 0
                                    min = 0ns
                                    max = 0ns
                                    Stats for camera: 3
                                    1280 x 800
                                    1280 x 800
                                    min = 54
                                    max = 1596
                                    1596
                                    min = 0ns
                                    max = 1318629735ns
                                      Stats for camera: 0
                                      1280 x 800
                                      1280 x 800
                                      min = 54
                                      max = 1596
                                      1596
                                      min = 0ns
                                      max = 1318629735ns
                                      Stats for camera: 1
                                      4056 x 3040
                                      3840 x 2160
                                      1920 x 1080
                                      1920 x 1080
                                      1920 x 1080
                                      1280 x 720
                                      1280 x 720
                                      min = 100
                                      max = 35200
                                      2200
                                      min = 0ns
                                      max = 243753000ns
                                      Stats for camera: 2
                                      240 x 1629
                                      min = 54
                                      max = 0
                                      min = 0ns
                                      max = 0ns
                                      Stats for camera: 3
                                      1280 x 800
                                      1280 x 800
                                      min = 54
                                      max = 1596
                                      1596
                                      min = 0ns
                                      max = 1318629735ns
                                      george kollamkulam
                                      @Alex-Kushleyev would you be able to help troubleshoot this error with the rear tracking camera?
