  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. CPU Temperature Logging
voxl2cpusensors
5 Posts 3 Posters 1.9k Views 1 Watching
  • Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Hey,
    I designing a chasis for my custom airframe including the ideal components from a Starling 2 Drone. I'm designing a heatsink on the design. For that I would like to do a graphical performance analysis of CPU's temperatures, utils.
    In the web-portal, I am able to see the live feed and plots of the various crtical parameters including CPU temperatures, utils etc. Is there a way, I can get to access these data and retireve them from VOXL2 for further analysis?
    • Jetson NanoJ Jetson Nano
      Hey,
      @Jetson-Nano You can use voxl-logger in order to capture the voxl-cpu-monitor output
        Jetson Nano
        Veteran
        Thanks for reverting @tom. I'm able to download the logs. But here can I see the CPU temperature readings and utils data? I ran the VOXL2 for a shorter instance and observed that only logging of critical data available.
        -- Logs begin at Tue 2024-10-29 10:07:40 UTC, end at Tue 2024-10-29 10:19:04 UTC. --
        Oct 29 10:07:40 m0054 systemd[1]: Started voxl-cpu-monitor.
        Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: loading our config file
        Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: =================================================================
        Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: en_auto_standby:  0
        Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: normal_cpu_mode:  auto
        Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: standby_cpu_mode: powersave
        Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: fan_mode:         auto
        Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: Init complete, entering main loop
        Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: client "voxl-camera-server21297388" connected to channel 0  with client id 0
        Oct 29 10:07:43 m0054 voxl-cpu-monitor[1447]: client "qvio-server53044883" connected to channel 0  with client id 1
        -- Reboot --
        Oct 29 10:18:37 m0054 voxl-cpu-monitor[1492]: client "voxl-camera-server20186581" with id 1 has disconnected from channel 0
        Oct 29 10:18:38 m0054 voxl-cpu-monitor[1492]: client "voxl-camera-server09386053" connected to channel 0  with client id 1
          -- Reboot --
          @Jetson-Nano Have you looked at voxl-inspect-cpu?
          K 1 Reply Last reply
            K Offline
            K Offline
            kerct
            @tom Is there a way to voxl-logger the outputs from voxl-inspect-cpu and play it so that I can see the graphs on voxl-portal? Currently I can only voxl-inspect-cpu or view the graphs in real-time on voxl-portal, but I would like to record the data when the drone flies and review it post-flight
