<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CPU Temperature Logging]]></title><description><![CDATA[<p dir="auto">Hey,</p>
<p dir="auto">I designing a chasis for my custom airframe including the ideal components from a Starling 2 Drone. I'm designing a heatsink on the design. For that I would like to do a graphical performance analysis of CPU's temperatures, utils.</p>
<p dir="auto">In the web-portal, I am able to see the live feed and plots of the various crtical parameters including CPU temperatures, utils etc. Is there a way, I can get to access these data and retireve them from VOXL2 for further analysis?</p>
]]></description><link>https://forum.modalai.com/topic/3982/cpu-temperature-logging</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 03:05:58 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3982.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Nov 2024 07:36:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CPU Temperature Logging on Mon, 23 Jun 2025 08:47:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a> Is there a way to voxl-logger the outputs from voxl-inspect-cpu and play it so that I can see the graphs on voxl-portal? Currently I can only voxl-inspect-cpu or view the graphs in real-time on voxl-portal, but I would like to record the data when the drone flies and review it post-flight</p>
]]></description><link>https://forum.modalai.com/post/22732</link><guid isPermaLink="true">https://forum.modalai.com/post/22732</guid><dc:creator><![CDATA[kerct]]></dc:creator><pubDate>Mon, 23 Jun 2025 08:47:11 GMT</pubDate></item><item><title><![CDATA[Reply to CPU Temperature Logging on Sun, 01 Dec 2024 18:39:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2016">@Jetson-Nano</a> Have you looked at <code>voxl-inspect-cpu</code>?</p>
]]></description><link>https://forum.modalai.com/post/19929</link><guid isPermaLink="true">https://forum.modalai.com/post/19929</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Sun, 01 Dec 2024 18:39:47 GMT</pubDate></item><item><title><![CDATA[Reply to CPU Temperature Logging on Fri, 29 Nov 2024 13:31:04 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for reverting <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/4">@tom</a>. I'm able to download the logs. But here can I see the CPU temperature readings and utils data? I ran the VOXL2 for a shorter instance and observed that only logging of critical data available.</p>
<pre><code>-- Logs begin at Tue 2024-10-29 10:07:40 UTC, end at Tue 2024-10-29 10:19:04 UTC. --
Oct 29 10:07:40 m0054 systemd[1]: Started voxl-cpu-monitor.
Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: loading our config file
Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: =================================================================
Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: en_auto_standby:  0
Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: normal_cpu_mode:  auto
Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: standby_cpu_mode: powersave
Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: fan_mode:         auto
Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: Init complete, entering main loop
Oct 29 10:07:42 m0054 voxl-cpu-monitor[1447]: client "voxl-camera-server21297388" connected to channel 0  with client id 0
Oct 29 10:07:43 m0054 voxl-cpu-monitor[1447]: client "qvio-server53044883" connected to channel 0  with client id 1
-- Reboot --
Oct 29 10:18:37 m0054 voxl-cpu-monitor[1492]: client "voxl-camera-server20186581" with id 1 has disconnected from channel 0
Oct 29 10:18:38 m0054 voxl-cpu-monitor[1492]: client "voxl-camera-server09386053" connected to channel 0  with client id 1
]]></description><link>https://forum.modalai.com/post/19928</link><guid isPermaLink="true">https://forum.modalai.com/post/19928</guid><dc:creator><![CDATA[Jetson Nano]]></dc:creator><pubDate>Fri, 29 Nov 2024 13:31:04 GMT</pubDate></item><item><title><![CDATA[Reply to CPU Temperature Logging on Wed, 27 Nov 2024 20:07:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/2016">@Jetson-Nano</a> You can use <code>voxl-logger</code> in order to capture the <code>voxl-cpu-monitor</code> output</p>
]]></description><link>https://forum.modalai.com/post/19919</link><guid isPermaLink="true">https://forum.modalai.com/post/19919</guid><dc:creator><![CDATA[tom]]></dc:creator><pubDate>Wed, 27 Nov 2024 20:07:43 GMT</pubDate></item></channel></rss>
