    QDL device not connected
    • W
      will.huang.oksi
      To whom it may concern,
      following this instruction to https://docs.modalai.com/voxl2-unbricking/
      slide the SW2 switch into the ON position,
      but in QDL Tool, it shows QDL device not connected.
      I have confirmed that the USB-C cable works with other VOXL devices.
      Any suggestions or anything I missed?
      Thank you for your precious time on this.
      W 1 Reply Last reply 29 May 2025, 17:53 Reply Quote 0
      • W
        will.huang.oksi @will.huang.oksi
        if you need any other information for this question,
        please don't hesitate to let me know.
        Thank you for helping!
        W 1 Reply Last reply 30 May 2025, 17:21 Reply Quote 0
        • W
          Hello ModalAI Team,
          If you need any additional information regarding the issue I’m currently experiencing, please don’t hesitate to let me know.
          I appreciate your time and support on this matter.
          W 1 Reply Last reply 1 Jun 2025, 22:12 Reply Quote 0
          • W
            Hello ModalAI Team,
            Here is the HW and SDK info
            • ModalAI Flight Deck M0054
            • VOXL system image 1.8.02-M0054-14.1a-perf
            • VOXL suite 1.4.1
            Thank you.
            Z N 2 Replies Last reply 2 Jun 2025, 18:06 Reply Quote 0
            • Z
              ZuraNeb @will.huang.oksi
              @will-huang-oksi
              Hello, thank you for your patience.
              Can you run the lsusb command and let us know the output? (As the voxl is plugged in)
              • N
                Nathan Raras ModalAI Team @will.huang.oksi
                Hello @will-huang-oksi,
                In response to @ZuraNeb as well, when running "lsusb" in your terminal with the device powered on and connected over USB, you should see the following device:
                If not, I'd recommend filing an RMA and we can further debug the issue: https://www.modalai.com/pages/rma
                W 1 Reply Last reply 3 Jun 2025, 16:41 Reply Quote 0
                • W
                  will.huang.oksi @Nathan Raras
                  Hello @Nathan-Raras and @Nathan-Raras ,
                  I don't see any Qualcomm device with running "lsusb".
                  I also have confirmed that the USB-C cable is able to access another VOXL device.
                  So I have submitted the RMA
                  Please let me know if any questions or suggestions.
                  Thank you very much for supporting.
                  1 out of 7
