  3. QDL device not connected
7 Posts 3 Posters 1.2k Views
  • W Offline
    W Offline
    will.huang.oksi
    To whom it may concern,
    following this instruction to https://docs.modalai.com/voxl2-unbricking/
    slide the SW2 switch into the ON position,
    but in QDL Tool, it shows QDL device not connected.
    I have confirmed that the USB-C cable works with other VOXL devices.
    Any suggestions or anything I missed?
    Thank you for your precious time on this.
    W 1 Reply Last reply
    • W will.huang.oksi
      W Offline
      W Offline
      will.huang.oksi
      if you need any other information for this question,
      please don't hesitate to let me know.
      Thank you for helping!
      • W will.huang.oksi
        W Offline
        W Offline
        will.huang.oksi
        Hello ModalAI Team,
        If you need any additional information regarding the issue I’m currently experiencing, please don’t hesitate to let me know.
        I appreciate your time and support on this matter.
        • W will.huang.oksi
          Hello ModalAI Team,
          W Offline
          W Offline
          will.huang.oksi
          Hello ModalAI Team,
          Here is the HW and SDK info
          • ModalAI Flight Deck M0054
          • VOXL system image 1.8.02-M0054-14.1a-perf
          • VOXL suite 1.4.1
          Thank you.
          Z N 2 Replies Last reply
          • W will.huang.oksi
            Hello ModalAI Team,
            • VOXL suite 1.4.1
            Thank you.
            Z Offline
            Z Offline
            ZuraNeb
            wrote on last edited by ZuraNeb
            @will-huang-oksi
            Hello, thank you for your patience.
            Can you run the lsusb command and let us know the output? (As the voxl is plugged in)
            • W will.huang.oksi
              Hello ModalAI Team,
              • VOXL suite 1.4.1
              Thank you.
              N Offline
              N Offline
              Nathan Raras
              Hello @will-huang-oksi,
              In response to @ZuraNeb as well, when running "lsusb" in your terminal with the device powered on and connected over USB, you should see the following device:
              If not, I'd recommend filing an RMA and we can further debug the issue: https://www.modalai.com/pages/rma
              • N Nathan Raras
                W Offline
                W Offline
                will.huang.oksi
                Hello @Nathan-Raras and @Nathan-Raras ,
                I don't see any Qualcomm device with running "lsusb".
                I also have confirmed that the USB-C cable is able to access another VOXL device.
                So I have submitted the RMA
                Please let me know if any questions or suggestions.
                Thank you very much for supporting.
