  3. Microhard Integration on VOXL m500
Scheduled Pinned Locked Moved Development Drones
m500
1 Posts 1 Posters 660 Views
  • ModeratorM Offline
    1. Which Microhard units do you recommend for reliable integration with the VOXL m500 (both for the air unit and the ground unit)?
    2. Could you provide a complete wiring map or diagram showing how to physically connect the Microhard modem to the VOXL board, including power supply details and which ports to use?
      • This will help us avoid trial-and-error and ensure correct setup.
    3. Do you provide flash files or firmware for the Microhard air and ground units that are configured to work with the m500 out of the box?
      • If not, can you supply support through what’s needed to configure both units manually?
    4. Do you provide documentation that explains how to access and configure the Microhard units via their IP interfaces?
      Specifically, we’re looking for a step-by-step guide (PDF or otherwise) that shows how to:
    • Enter the Microhard configuration interface (e.g., IP address access)
    • Set communication parameters and network settings
    • Pair the air and ground units to establish a working link
