<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Microhard Integration on VOXL m500]]></title><description><![CDATA[<ol>
<li>
<p dir="auto">Which Microhard units do you recommend for reliable integration with the VOXL m500 (both for the air unit and the ground unit)?</p>
</li>
<li>
<p dir="auto">Could you provide a complete wiring map or diagram showing how to physically connect the Microhard modem to the VOXL board, including power supply details and which ports to use?</p>
<ul>
<li>This will help us avoid trial-and-error and ensure correct setup.</li>
</ul>
</li>
<li>
<p dir="auto">Do you provide flash files or firmware for the Microhard air and ground units that are configured to work with the m500 out of the box?</p>
<ul>
<li>If not, can you supply support through what’s needed to configure both units manually?</li>
</ul>
</li>
<li>
<p dir="auto">Do you provide documentation that explains how to access and configure the Microhard units via their IP interfaces?<br />
Specifically, we’re looking for a step-by-step guide (PDF or otherwise) that shows how to:</p>
</li>
</ol>
<ul>
<li>Enter the Microhard configuration interface (e.g., IP address access)</li>
<li>Set communication parameters and network settings</li>
<li>Pair the air and ground units to establish a working link</li>
</ul>
]]></description><link>https://forum.modalai.com/topic/4447/microhard-integration-on-voxl-m500</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 00:27:42 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/4447.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 May 2025 14:28:54 GMT</pubDate><ttl>60</ttl></channel></rss>
