  3. How to Enable QUP19 and QUP13 as UARTs on VOXL 2 (ttyHS2 / ttyHS3)?
9 Posts 3 Posters 1.6k Views 2 Watching
  • Y Offline
    Y Offline
    yardy
    Hi everyone
    I'm working on a VOXL 2, M0054 , voxl2_SDK_1.4.1
    I’ve successfully used /dev/ttyHS1 (QUP7) via J3, but I’m currently trying to enable and use:
    /dev/ttyHS2 → QUP19 (GPIO 2 and 3, J5 pins 48 and 49)
    /dev/ttyHS3 → QUP13 (GPIO 38 and 39, J5 pins 97 and 98)
    These devices show up in /dev, but the corresponding pins remain unclaimed in the pinctrl debug output:
    cat /sys/kernel/debug/pinctrl/*/pinmux-pins | grep -E 'GPIO_2|GPIO_3|GPIO_38|GPIO_39'
    pin 2 (GPIO_2): 894000.qcom,qup_uart (GPIO UNCLAIMED) function qup19 group gpio2
    pin 3 (GPIO_3): 894000.qcom,qup_uart (GPIO UNCLAIMED) function qup19 group gpio3
    pin 38 (GPIO_38): a94000.qcom,qup_uart (GPIO UNCLAIMED) function qup13 group gpio38
    pin 39 (GPIO_39): a94000.qcom,qup_uart (GPIO UNCLAIMED) function qup13 group gpio39
    How can I claim it to UART?
    Many Thanks!
    • Y yardy
      Hi everyone
      Many Thanks!
      @yardy ,
      Since the devices appear in /dev/ttyHS*, it means they are already mapped and pins are claimed by the kernel, so it's all set up. You will just need to use the correct adapter board that plugs into VOXL2 and exposes these uart connections.
      The GPIO mapping is not relevant here because the pins are not used as GPIO (different kernel driver (uart) ).
      Y 1 Reply Last reply
        @yardy ,
        Y Offline
        Y Offline
        yardy
        thanks for replying.
        I'm using the dev test board but couldn't establish the comm
        any ideas?
        B.R
        • Y yardy
          any ideas?
          B.R
          @yardy , can you please clarify how exactly you are testing the communication using HS2 and HS3?
            Y Offline
            Y Offline
            yardy
            @Alex-Kushleyev , Thanks for the response!
            VOXL 2 mounted on the VOXL 2 Developer Test Board.
            CP2102 USB-to-UART dongle connected to my PC.
            For QUP19 (ttyHS2):
            GPIO_2 (TX) connected to RX on CP2102 via JP1 (for level shifter) and J9
            GPIO_3 (RX) connected to TX on CP2102 via JP1 (for level shifter) and J9
            GND to GND
            on the voxl2:
            stty -F /dev/ttyHS2 115200
            cat /dev/ttyHS2
            echo "Hello from VOXL2 HS2" > /dev/ttyHS2
            on my PC:
            OS: Ubuntu 22.04
            screen /dev/ttyUSB0 115200
            When I send text from the PC side, I expect it to appear in the cat output on VOXL2, and vice versa.
            with /dev/ttyHS1 it works.
            VinnyV 1 Reply Last reply
            • Y yardy
              For QUP19 (ttyHS2):
              GND to GND
              on the voxl2:
              cat /dev/ttyHS2
              on my PC:
              OS: Ubuntu 22.04
              Hi @yardy
              Are you using the jumper blocks J14.15/J14.17 to JP1.10/JP1.12 respectively for QUP_19?
              That will result in 3.3V RX/TX signals at J9 on M0144.
              Just want to clarify so that SW is not chasing any red herrings.
              • VinnyV Vinny
                Hi @yardy
                Y Offline
                Y Offline
                yardy
                @Vinny
                yes I am.
                • Y yardy
                  @Vinny
                  yes I am.
                  @yardy ,
                  Can you please try the following:
                  • install screen on voxl2 by running apt install screen, then you can use the tool to simplify your testing.
                  • bridge the RX and TX for a particular UART that you are testing (on the Developer Test Board) and run a simple test such as :
                  screen /dev/ttyHS2 115200
                  When you type into the terminal while running screen, if the communication is working, you should see the characters that you type being printed in the terminal.
                  If you still do not see any chars in this test, please use an oscilloscope to probe the UART TX line at the test board (while TX is not connected to the RX) and see if you see any data on the waveform when you type in the terminal on the voxl2 side while screen is running.
                    @yardy ,
                    Y Offline
                    Y Offline
                    yardy
                    wrote on last edited by yardy
                    #9
                    Hi @yardy
                    It was connected to JP1.9/JP1.11 (because of the jumpers... I was wrong)
                    It's working!
                    Many thanks🤙
