ESC 2 MINI rapidly blinking after firmware update
As stated in the headline, after running some spin tests I wanted to update the firmware of the esc with the
voxl-esc-upload-firmware-all.shthe script failed after uploading the firmware at 30% for each motor. Now the motors rapidly blinks.
I'm using a voxl2 together with the voxl2 mini esc.
Voxl2 has the newest SDK 1.4.3 versionoutput of the voxl-esc-scan.py
Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.9 VOXL Platform: M0054 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 2000000 Sending library name request: libslpi_qrb5165_io.so Sending initialization request INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Updated baud rate to 230400 INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 230400, protocol: bootloader INFO: ESC Information: INFO: --------------------- --------------------- Connection error: connection reset VOXL Platform: M0054 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 250000 Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Received standard error event SNS_STD_ERROR_NOT_SUPPORTED INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Connection error: connection reset Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Updated baud rate to 230400 Received standard error event SNS_STD_ERROR_NOT_SUPPORTED WARNING: No ESC(s) detected VOXL Platform: M0054 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 921600 Connection error: connection reset Received standard error event SNS_STD_ERROR_NOT_SUPPORTED INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Updated baud rate to 230400 >>> Got an exception from send_request <<< >>> Send succeeded after retries <<< Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Connection error: connection reset WARNING: No ESC(s) detected VOXL Platform: M0054 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 57600 Sending topic message --- msg_id: 1033 --- topic name: uart_config Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Sending topic message --- msg_id: 1033 --- topic name: uart_config Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Connection error: connection reset Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_config Got response cb 0 Updated baud rate to 230400 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 WARNING: No ESC(s) detected ERROR: not all ESCs foundIf i follow the recovery.md and try to rerun the firmware flash it just this is what i get:
Usage: - Autodetect board and upload latest firmware to all ESCs: ./voxl-esc-upload-firmware-all.sh - Autodetect board and upload latest firmware to a single ESC ID <esc_id>: ./voxl-esc-upload-firmware-all.sh <esc_id> Detecting ESCs... ERROR: No ESC boards detected.. Here is output of voxl-esc-scan Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.9 VOXL Platform: M0054 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 2000000 Sending library name request: libslpi_qrb5165_io.so Sending initialization request INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Connection error: connection reset Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Updated baud rate to 230400 WARNING: No ESC(s) detected VOXL Platform: M0054 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 250000 >>> Got an exception from send_request <<< >>> Got an exception from send_request <<< >>> Send failed after retries <<< Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Connection error: connection reset Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Sending topic message --- msg_id: 1033 --- topic name: uart_config Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_config Updated baud rate to 230400 Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Connection error: connection reset Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 WARNING: No ESC(s) detected VOXL Platform: M0054 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 921600 Sending topic message --- msg_id: 1033 --- topic name: uart_config Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Sending topic message --- msg_id: 1033 --- topic name: uart_config Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Connection error: connection reset Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_config Updated baud rate to 230400 Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 WARNING: No ESC(s) detected VOXL Platform: M0054 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 57600 Sending topic message --- msg_id: 1033 --- topic name: uart_config >>> Got an exception from send_request <<< >>> Got an exception from send_request <<< >>> Send failed after retries <<< Sending topic message --- msg_id: 1033 --- topic name: uart_data >>> Got an exception from send_request <<< >>> Got an exception from send_request <<< >>> Send failed after retries <<< Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Connection error: connection reset Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Sending topic message --- msg_id: 1033 --- topic name: uart_config Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_config Updated baud rate to 230400 Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Sending topic message --- msg_id: 1033 --- topic name: uart_data Connection error: connection reset Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 5 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: uart_data Got response cb 0 WARNING: No ESC(s) detected ERROR: not all ESCs foundAny help how i can unbrick the ESC? this is the second time that happens, while other esc had no issues with the firmware flashing procedure.
Thanks in advance
Phil
Tried to manual install the firmware but it loses connection after ish 30% of upload
./voxl-esc-upload-firmware.py --firmware-baud-rate 250000 -f firmware/modalai_esc_firmware_m0129_3_v39_20_9c6233d6.bin --id 0 Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.9 INFO: Firmware file name : firmware/modalai_esc_firmware_m0129_3_v39_20_9c6233d6.bin INFO: Firmware file size : 23776 bytes VOXL Platform: M0054 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 250000 Sending library name request: libslpi_qrb5165_io.so Sending initialization request INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400 Updated baud rate to 230400 INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 230400 INFO: ESC(s) detected: [] WARNING: Specified ESC ID not detected; perform manual power cycle now Updated baud rate to 230400 INFO: Installing firmware to ESC ID 0 : firmware/modalai_esc_firmware_m0129_3_v39_20_9c6233d6.bin Progress: 36% [################## ] >>> Got an exception from send_request <<< >>> Send succeeded after retries <<< Connection error: connection reset ERROR: An error occured during the write process. -
@astro_phil Make sure that voxl-px4 is not running while you're trying to talk to the ESC.
systemctl stop voxl-px4That's the first thing i disabled/stopped.
I also ensured px4 is not running in voxl-inspect-services.
Even the voxl-esc wizard does run into the same issues.I also removed any uart device from the connectors. Before testing the previous steps.
@astro_phil What SDK version are you running?
voxl-version@astro_phil , your ESC is currently in a state where the ESC firmware is corrupted, so it remains in bootloader mode, waiting to be flashed with firmware. It is not bricked (or maybe it is, depending on the definition of "bricked"
), as it just needs to be flashed and you are running the correct procedure.I am unsure why this is happening, but it seems that it is not related to the ESC itself - the errors you are getting are coming from the DSP UART bridge (the UART that ESC connects to is actually routed to the DSP and there is a bridge application that allows to talk to the ESC from CPU via the DSP).
We will get back to you with more things to try.
@astro_phil Before trying the ESC commands can you double check that voxl-px4 is not running and then enter
voxl-reset-slpi, then wait 5 seconds, and then try the ESC commands? -
@astro_phil Can you also capture the
dmesgoutput when this happens? -
dmesgoutput when this happens?This time it got stuck in the flashing progress.
and i got a fatal error on slpi as seen in the dmesg log.voxl2:~$ voxl-version ──────────────────────────────────────────────────────────────────────────────── system-image: 1.8.02-M0054-14.1a-perf kernel: #1 SMP PREEMPT Mon Nov 11 22:08:01 UTC 2024 4.19.125 ──────────────────────────────────────────────────────────────────────────────── hw platform: M0054 mach.var: 1.0.0 ──────────────────────────────────────────────────────────────────────────────── voxl-suite: 1.4.3 ──────────────────────────────────────────────────────────────────────────────── Packages: Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/ Last Updated: 2025-04-09 08:14:54 List: kernel-module-voxl-fsync-mod-4.19.125 1.0-r0 kernel-module-voxl-gpio-mod-4.19.125 1.0-r0 kernel-module-voxl-platform-mod-4.19.125 1.0-r0 libfc-sensor 1.0.7 libmodal-cv 0.5.16 libmodal-exposure 0.1.3 libmodal-journal 0.2.3 libmodal-json 0.4.3 libmodal-pipe 2.10.6 libqrb5165-io 0.4.9 libvoxl-cci-direct 0.2.5 libvoxl-cutils 0.1.1 modalai-slpi 1.1.19 mv-voxl 0.1-r0 qrb5165-bind 0.1-r0 qrb5165-dfs-server 0.2.0 qrb5165-imu-server 1.1.3 qrb5165-rangefinder-server 0.1.5 qrb5165-slpi-test-sig 01-r0 qrb5165-system-tweaks 0.3.5 qrb5165-tflite 2.8.0-2 voxl-bind-spektrum 0.1.1 voxl-camera-calibration 0.5.9 voxl-camera-server 2.1.2 voxl-ceres-solver 2:1.14.0-10 voxl-configurator 1.0.0 voxl-cpu-monitor 0.5.3 voxl-docker-support 1.3.1 voxl-elrs 0.4.2 voxl-esc 1.5.1 voxl-feature-tracker 0.5.2 voxl-flow-server 0.3.6 voxl-fsync-mod 1.0-r0 voxl-gphoto2-server 0.0.10 voxl-gpio-mod 1.0-r0 voxl-io-server 0.0.5 voxl-jpeg-turbo 2.1.3-5 voxl-lepton-server 1.3.3 voxl-lepton-tracker 0.0.4 voxl-libgphoto2 0.0.4 voxl-libuvc 1.0.7 voxl-logger 0.5.0 voxl-mavcam-manager 0.5.8 voxl-mavlink 0.1.4 voxl-mavlink-server 1.4.5 voxl-modem 1.1.5 voxl-mongoose 7.7.0-1 voxl-mpa-to-ros 0.3.9 voxl-mpa-tools 1.3.7 voxl-open-vins 0.4.17 voxl-open-vins-server 0.3.0 voxl-opencv 4.5.5-2 voxl-osd 0.1.3 voxl-platform-mod 1.0-r0 voxl-portal 0.7.9 voxl-px4 1.14.0-2.0.98 voxl-px4-imu-server 0.1.2 voxl-px4-params 0.6.7 voxl-qvio-server 1.1.1 voxl-remote-id 0.0.9 voxl-reset-slpi 0.0.1 voxl-ros2-foxy 0.0.1 voxl-state-estimator 0.0.4 voxl-streamer 0.7.5 voxl-suite 1.4.3 voxl-tag-detector 0.0.4 voxl-tflite-server 0.3.9 voxl-utils 1.4.6 voxl-uvc-server 0.1.7 voxl-vision-hub 1.8.20 voxl-vtx 1.2.2 voxl2-io 0.0.3 voxl2-system-image 1.8.02-r0 voxl2-wlan 1.0-r0 ────────────────────────────────────────────────────────────────────────────────Running the commands
voxl2:~/voxl-tools/voxl-esc/voxl-esc-tools(master)$ systemctl stop voxl-px4 voxl2:~/voxl-tools/voxl-esc/voxl-esc-tools(master)$ voxl-reset-slpi Sending kill slpi command! voxl2:~/voxl-tools/voxl-esc/voxl-esc-tools(master)$ ./voxl-esc-upload-firmware.py --firmware-baud-rate 250000 -f firmware/modalai_esc_firmware_m0129_3_v39_20_9c6233d6.bin --id 0 Detected Python version : 3.6.9 (default, Mar 10 2023, 16:46:00) [GCC 8.4.0] Found voxl-esc tools bin version: 1.9 INFO: Firmware file name : firmware/modalai_esc_firmware_m0129_3_v39_20_9c6233d6.bin INFO: Firmware file size : 23776 bytes VOXL Platform: M0054 Detected RB5 Flight, VOXL2 M0054 or M0104! INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 250000 Sending library name request: libslpi_qrb5165_io.so Sending initialization request Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Couldn't configure flight_controller sensor INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400and the dmsg output
[ +14.486977] Fatal error on slpi! [ +0.000114] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_0 exceeded processing time limit for library 0xb25d9728. [ +0.000073] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED. [ +0.002289] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting [ +0.000021] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2087]: Shutting down slpi [ +0.013036] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030 [ +0.000076] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000018] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.003508] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service [ +0.000298] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service [ +0.000830] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi [ +0.000869] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi [ +0.001171] subsys-restart: subsystem_powerup(): [kworker/u19:0:2087]: Powering up slpi [ +0.000498] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000 [ +0.071421] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset [ +0.063029] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up [ +0.000067] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received [ +0.002257] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up [ +0.000008] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2087]: Restart sequence for slpi completed. [ +0.000187] -139437848:Entered [ +0.000449] -139437848:SMD QRTR driver probed [ +0.010916] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi [ +0.002408] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service [ +0.001058] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3 [ +0.001283] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service [ +14.493230] Fatal error on slpi! [ +0.000113] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_0 exceeded processing time limit for library 0xb25d94f8. [ +0.000070] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED. [ +0.001215] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting [ +0.000014] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2087]: Shutting down slpi [ +0.013131] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030 [ +0.003115] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service [ +0.000243] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service [ +0.001668] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi [ +0.000832] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi [ +0.001114] subsys-restart: subsystem_powerup(): [kworker/u19:0:2087]: Powering up slpi [ +0.000403] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000 [ +0.070834] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset [ +0.062804] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up [ +0.000058] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received [ +0.008549] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up [ +0.000007] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2087]: Restart sequence for slpi completed. [ +0.002205] -139437848:Entered [ +0.002883] -139437848:SMD QRTR driver probed [ +0.004222] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi [ +0.002885] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service [ +0.000020] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service [ +0.004621] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3 [Apr 9 08:44] Fatal error on slpi! -
I tried flashing the ESC over my PC with a USB to UART adapter, which worked flawless.
Trying to launch px4 now yields the same error messages.voxl2:~$ voxl-px4 [INFO] Reading from /etc/modalai/voxl-px4.conf Found DSP signature file [INFO] Daemon mode enabled ************************* AIRFRAME=MULTICOPTER GPS=AUTODETECT RC=CRSF_RAW ESC=VOXL_ESC POWER MANAGER=VOXLPM AIRSPEED SENSOR=NONE DISTANCE SENSOR=NONE OSD=DISABLE DAEMON_MODE=ENABLE SENSOR_CAL=ACTUAL ARTIFACT_MODE=DISABLE EXTRA STEPS: ************************* INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM. INFO [px4] assuming working directory is rootfs, no symlinks needed. INFO [muorb] Got muorb init command Sending initialization request Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete INFO [muorb] [modules__muorb__slpi] muorb aggregator thread running INFO [muorb] muorb protobuf initalize method succeeded INFO [muorb] succesfully did ADVERTISE_TEST_TYPE INFO [muorb] [tasks] Creating pthread test_MUORB INFO [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097656 INFO [muorb] succesfully did SUBSCRIBE_TEST_TYPE INFO [muorb] [tasks] Creating pthread test_MUORB INFO [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097655 INFO [muorb] succesfully did TOPIC_TEST_TYPE INFO [muorb] [tasks] Creating pthread test_MUORB INFO [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097654 INFO [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE INFO [muorb] [tasks] Creating pthread test_MUORB INFO [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097653 INFO [muorb] muorb test passed ______ __ __ ___ | ___ \ \ \ / / / | | |_/ / \ V / / /| | | __/ / \ / /_| | | | / /^\ \ \___ | \_| \/ \/ |_/ px4 starting. INFO [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0 INFO [muorb] [uORB] Advertising remote topic log_message INFO [parameters] Starting param sync THREAD INFO [muorb] [parameters] Starting param sync THREAD ************************* AIRFRAME: MULTICOPTER GPS: AUTODETECT RC: CRSF_RAW ESC: VOXL_ESC POWER MANAGER: VOXLPM AIRSPEED SENSOR: NONE DISTANCE SENSOR: NONE OSD: DISABLE ARTIFACT_MODE: DISABLE EXTRA STEPS: ************************* Running on M0054 INFO [muorb] [qshell] before starting the qshell_entry task INFO [muorb] [tasks] Creating pthread qshell INFO [muorb] [qshell] qshell entry..... INFO [muorb] [tasks] Successfully created px4 task PX4_qshell with tid 2097652 INFO [muorb] [qshell] Init app map initialized INFO [muorb] [qshell] after starting the qshell_entry task INFO [param] selected parameter default file /data/px4/param/parameters INFO [muorb] [uORB] Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic INFO [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic INFO [muorb] [uORB] Advertising remote topic parameter_update INFO [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_t INFO [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic INFO [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_t INFO [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic >>> Got an exception from send_request <<< >>> Send succeeded after retries <<< Sending topic message --- msg_id: 1033 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_I_ACC --- topic name: parameter_client_set_value_request Sending topic message --- msg_id: 1033 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_MAX --- topic name: parameter_client_set_value_request Connection error: connection reset Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_XY_VEL_P_ACC Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Got response cb 0 Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_YAW_EXPO Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_MAN_EXPO Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_P Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_VEL_MAX_DN Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_VEL_MAX_UP Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for MPC_Z_VEL_P_ACC Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC5_MAX Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC5_MIN Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC6_MAX Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC6_MIN Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC7_MAX Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC7_MIN Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC8_MAX Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC8_MIN Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_CHAN_CNT Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_FLTMODE Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_KILL_SW Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_PITCH Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_ROLL Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_THROTTLE Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for RC_MAP_YAW Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for SDLOG_PROFILE Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request ERROR [parameters] Timeout waiting for parameter_client_set_value_response for SYS_AUTOSTART Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request ERROR [parameters] Timeout waiting for parameter_client_set_value_response for THR_MDL_FAC Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Connection error: connection reset ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_BAUD Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_CONFIG Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_FUNC1 Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got flight controller event Received standard error event SNS_STD_ERROR_NOT_SUPPORTED Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_FUNC2 Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_FUNC3 Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_FUNC4 Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_RPM_MIN Sending topic message --- msg_id: 1033 --- topic name: parameter_client_set_value_request Got response cb 0 ERROR [parameters] Timeout waiting for parameter_client_set_value_response for VOXL_ESC_VLOG INFO [parameters] BSON document size 2522 bytes, decoded 2522 bytes (INT32:34, FLOAT:82) Starting IMU driver with no rotation Sending topic message --- msg_id: 1030 --- topic name: qshell_req Sending topic message --- msg_id: 1033 --- topic name: qshell_req Got response cb 0 Got response cb 0 INFO [qshell] Send cmd: 'icm42688p start -s' Connection error: connection reset Connection error: connection reset ERROR [qshell] command timed out ERROR [qshell] Command failed Sending topic message --- msg_id: 1030 --- topic name: qshell_req Sending topic message --- msg_id: 1033 --- topic name: qshell_req Got response cb 0 INFO [qshell] Send cmd: 'icp101xx start -I -b 5' Got response cb 0 Connection error: connection resetdmesg output
[ +0.007947] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3 [Apr 9 13:16] Fatal error on slpi! [ +0.000121] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found. [ +0.000062] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED. [ +0.001457] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting [ +0.000014] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2079]: Shutting down slpi [ +0.013438] rpmh_rsc_send_data: 3 callbacks suppressed [ +0.000008] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030 [ +0.000020] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030 [ +0.003267] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service [ +0.000012] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi [ +0.001113] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service [ +0.003764] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi [ +0.001176] subsys-restart: subsystem_powerup(): [kworker/u19:0:2079]: Powering up slpi [ +0.000494] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000 [ +0.064541] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset [ +0.062698] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up [ +0.000048] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received [ +0.003001] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up [ +0.000014] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2079]: Restart sequence for slpi completed. [ +0.007566] 359684328:Entered [ +0.000623] 359684328:SMD QRTR driver probed [ +0.002753] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service [ +0.000358] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service [ +0.007085] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi [ +0.001658] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3 [ +14.479033] Fatal error on slpi! [ +0.000111] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_1 exceeded processing time limit for library 0xb25d9728. [ +0.000074] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED. [ +0.001843] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting [ +0.000015] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2079]: Shutting down slpi [ +0.013163] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030 [ +0.003133] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi [ +0.000080] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service [ +0.000157] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service [ +0.001062] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi [ +0.003001] subsys-restart: subsystem_powerup(): [kworker/u19:0:2079]: Powering up slpi [ +0.000382] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000 [ +0.070747] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset [ +0.061514] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up [ +0.000270] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received [ +0.006709] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up [ +0.000016] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2079]: Restart sequence for slpi completed. [ +0.000103] 359684328:Entered [ +0.001518] 359684328:SMD QRTR driver probed [ +0.001876] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi [ +0.002996] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service [ +0.000127] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service [ +0.009617] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3 [ +5.216763] Fatal error on slpi! [ +0.000116] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found. [ +0.000061] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED. [ +0.001201] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting [ +0.000013] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2079]: Shutting down slpi [ +0.013377] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030 [ +0.000077] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000046] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000018] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000017] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000018] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000017] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000017] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.002919] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi [ +0.000755] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service [ +0.000159] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service [ +0.000604] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi [ +0.001291] subsys-restart: subsystem_powerup(): [kworker/u19:0:2079]: Powering up slpi [ +0.000346] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000 [ +0.067077] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset [ +0.061404] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up [ +0.000263] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received [ +0.003080] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up [ +0.000015] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2079]: Restart sequence for slpi completed. [ +0.008128] 359684328:Entered [ +0.002953] 359684328:SMD QRTR driver probed [ +0.003042] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi [ +0.001505] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service [ +0.000031] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service [ +0.005837] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3 -
[ +0.007947] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3 [Apr 9 13:16] Fatal error on slpi! [ +0.000121] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found. [ +0.000062] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED. [ +0.001457] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting [ +0.000014] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2079]: Shutting down slpi [ +0.013438] rpmh_rsc_send_data: 3 callbacks suppressed [ +0.000008] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030 [ +0.000020] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030 [ +0.003267] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service [ +0.000012] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi [ +0.001113] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service [ +0.003764] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi [ +0.001176] subsys-restart: subsystem_powerup(): [kworker/u19:0:2079]: Powering up slpi [ +0.000494] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000 [ +0.064541] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset [ +0.062698] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up [ +0.000048] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received [ +0.003001] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up [ +0.000014] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2079]: Restart sequence for slpi completed. [ +0.007566] 359684328:Entered [ +0.000623] 359684328:SMD QRTR driver probed [ +0.002753] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service [ +0.000358] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service [ +0.007085] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi [ +0.001658] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3 [ +14.479033] Fatal error on slpi! [ +0.000111] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_1 exceeded processing time limit for library 0xb25d9728. [ +0.000074] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED. [ +0.001843] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting [ +0.000015] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2079]: Shutting down slpi [ +0.013163] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030 [ +0.003133] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi [ +0.000080] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service [ +0.000157] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service [ +0.001062] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi [ +0.003001] subsys-restart: subsystem_powerup(): [kworker/u19:0:2079]: Powering up slpi [ +0.000382] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000 [ +0.070747] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset [ +0.061514] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up [ +0.000270] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received [ +0.006709] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up [ +0.000016] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2079]: Restart sequence for slpi completed. [ +0.000103] 359684328:Entered [ +0.001518] 359684328:SMD QRTR driver probed [ +0.001876] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi [ +0.002996] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service [ +0.000127] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service [ +0.009617] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3 [ +5.216763] Fatal error on slpi! [ +0.000116] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x69:sns_stream_service.c:436:req_found. [ +0.000061] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED. [ +0.001201] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting [ +0.000013] subsys-restart: subsystem_shutdown(): [kworker/u19:0:2079]: Shutting down slpi [ +0.013377] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030 [ +0.000077] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000046] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000018] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000017] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000018] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000017] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.000017] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.002919] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi [ +0.000755] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service [ +0.000159] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service [ +0.000604] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi [ +0.001291] subsys-restart: subsystem_powerup(): [kworker/u19:0:2079]: Powering up slpi [ +0.000346] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000 [ +0.067077] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset [ +0.061404] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up [ +0.000263] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received [ +0.003080] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up [ +0.000015] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:2079]: Restart sequence for slpi completed. [ +0.008128] 359684328:Entered [ +0.002953] 359684328:SMD QRTR driver probed [ +0.003042] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi [ +0.001505] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service [ +0.000031] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service [ +0.005837] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3@astro_phil Yeah, the DSP just keeps resetting. Either there is a hardware issue or some piece of software has been corrupted. Can you do a complete reinstallation of the SDK? Perhaps back down to v1.4.1 and just see if that makes any difference?
I reflashed the voxl with the voxl2_SDK_1.4.1
unfortunately, without any changes.
Spinning the motors with the esc-tools does work for a couple of seconds but stops with a connection reset error aswell.
PX4 does not start at all and i still get the SLPI error in the dmesg log.voxl2:/$ voxl-version -------------------------------------------------------------------------------- system-image: 1.8.02-M0054-14.1a-perf kernel: #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125 -------------------------------------------------------------------------------- hw platform: M0054 mach.var: 1.0.1 -------------------------------------------------------------------------------- voxl-suite: 1.4.1 -------------------------------------------------------------------------------- Packages: Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/ Last Updated: 2025-04-10 07:49:18 WARNING: repo file has changed since last update, packages may have originated from a different repo List: kernel-module-voxl-fsync-mod-4.19.125 1.0-r0 kernel-module-voxl-gpio-mod-4.19.125 1.0-r0 kernel-module-voxl-platform-mod-4.19.125 1.0-r0 libfc-sensor 1.0.7 libmodal-cv 0.5.16 libmodal-exposure 0.1.3 libmodal-journal 0.2.2 libmodal-json 0.4.3 libmodal-pipe 2.10.6 libqrb5165-io 0.4.9 libvoxl-cci-direct 0.2.5 libvoxl-cutils 0.1.1 modalai-slpi 1.1.19 mv-voxl 0.1-r0 qrb5165-bind 0.1-r0 qrb5165-dfs-server 0.2.0 qrb5165-imu-server 1.1.2 qrb5165-rangefinder-server 0.1.4 qrb5165-slpi-test-sig 01-r0 qrb5165-system-tweaks 0.3.4 qrb5165-tflite 2.8.0-2 voxl-bind-spektrum 0.1.1 voxl-camera-calibration 0.5.9 voxl-camera-server 2.1.1 voxl-ceres-solver 2:1.14.0-10 voxl-configurator 0.9.7 voxl-cpu-monitor 0.5.3 voxl-docker-support 1.3.1 voxl-elrs 0.4.1 voxl-esc 1.5.1 voxl-feature-tracker 0.5.2 voxl-flow-server 0.3.6 voxl-fsync-mod 1.0-r0 voxl-gphoto2-server 0.0.10 voxl-gpio-mod 1.0-r0 voxl-io-server 0.0.4 voxl-jpeg-turbo 2.1.3-5 voxl-lepton-server 1.3.3 voxl-lepton-tracker 0.0.4 voxl-libgphoto2 0.0.4 voxl-libuvc 1.0.7 voxl-logger 0.4.9 voxl-mavcam-manager 0.5.7 voxl-mavlink 0.1.1 voxl-mavlink-server 1.4.4 voxl-modem 1.1.5 voxl-mongoose 7.7.0-1 voxl-mpa-to-ros 0.3.9 voxl-mpa-tools 1.3.7 voxl-open-vins 0.4.16 voxl-open-vins-server 0.3.0 voxl-opencv 4.5.5-2 voxl-osd 0.1.1 voxl-platform-mod 1.0-r0 voxl-portal 0.7.5 voxl-px4 1.14.0-2.0.94 voxl-px4-imu-server 0.1.2 voxl-px4-params 0.6.3 voxl-qvio-server 1.1.1 voxl-remote-id 0.0.9 voxl-reset-slpi 0.0.1 voxl-state-estimator 0.0.4 voxl-streamer 0.7.5 voxl-suite 1.4.1 voxl-tag-detector 0.0.4 voxl-tflite-server 0.3.9 voxl-utils 1.4.4 voxl-uvc-server 0.1.7 voxl-vision-hub 1.8.17 voxl-vtx 1.1.8 voxl2-io 0.0.3 voxl2-system-image 1.8.02-r0 voxl2-wlan 1.0-r0 --------------------------------------------------------------------------------PX4 output
voxl2:~/voxl-esc/voxl-esc-tools(master)$ voxl-reset-slpi Sending kill slpi command! voxl2:~/voxl-esc/voxl-esc-tools(master)$ voxl-px4 [INFO] Reading from /etc/modalai/voxl-px4.conf Found DSP signature file [INFO] Daemon mode enabled ************************* AIRFRAME=MULTICOPTER GPS=AUTODETECT RC=CRSF_RAW ESC=VOXL_ESC POWER MANAGER=VOXLPM AIRSPEED SENSOR=NONE DISTANCE SENSOR=NONE OSD=DISABLE DAEMON_MODE=ENABLE SENSOR_CAL=ACTUAL ARTIFACT_MODE=DISABLE EXTRA STEPS: ************************* INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM. INFO [px4] assuming working directory is rootfs, no symlinks needed. INFO [muorb] Got muorb init command Sending initialization request Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete Got topic data before configuration complete INFO [muorb] SLPI: muorb aggregator thread running INFO [muorb] muorb protobuf initalize method succeeded INFO [muorb] succesfully did ADVERTISE_TEST_TYPE INFO [muorb] SLPI: Creating pthread test_MUORB INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656 INFO [muorb] succesfully did SUBSCRIBE_TEST_TYPE INFO [muorb] SLPI: Creating pthread test_MUORB INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655 INFO [muorb] succesfully did TOPIC_TEST_TYPE INFO [muorb] SLPI: Creating pthread test_MUORB INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654 INFO [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE INFO [muorb] SLPI: Creating pthread test_MUORB INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653 INFO [muorb] muorb test passed ______ __ __ ___ | ___ \ \ \ / / / | | |_/ / \ V / / /| | | __/ / \ / /_| | | | / /^\ \ \___ | \_| \/ \/ |_/ px4 starting. INFO [muorb] SLPI: Advertising remote topic log_message INFO [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0 INFO [parameters] Starting param sync THREAD INFO [muorb] SLPI: Starting param sync THREAD ************************* AIRFRAME: MULTICOPTER GPS: AUTODETECT RC: CRSF_RAW ESC: VOXL_ESC POWER MANAGER: VOXLPM AIRSPEED SENSOR: NONE DISTANCE SENSOR: NONE OSD: DISABLE ARTIFACT_MODE: DISABLE EXTRA STEPS: ************************* Running on M0054 INFO [muorb] SLPI: before starting the qshell_entry task INFO [muorb] SLPI: Creating pthread qshell INFO [muorb] SLPI: qshell entry..... INFO [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652 INFO [muorb] SLPI: Init app map initialized INFO [muorb] SLPI: after starting the qshell_entry task INFO [param] selected parameter default file /data/px4/param/parameters INFO [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic INFO [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic INFO [muorb] SLPI: Advertising remote topic parameter_update INFO [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to INFO [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic INFO [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to INFO [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic INFO [parameters] BSON document size 2517 bytes, decoded 2517 bytes (INT32:35, FLOAT:81) Starting IMU driver with no rotation INFO [qshell] Send cmd: 'icm42688p start -s' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: icm42688p start -s INFO [muorb] SLPI: arg0 = 'icm42688p' INFO [muorb] SLPI: arg1 = 'start' INFO [muorb] SLPI: arg2 = '-s' INFO [muorb] SLPI: *** SPI Device ID 0x26000a 2490378 INFO [uORB] Advertising remote topic sensor_accel INFO [uORB] Advertising remote topic sensor_gyro INFO [muorb] SLPI: ICM42688P::probe successful! INFO [muorb] SLPI: on SPI bus 1 INFO [muorb] SLPI: icm42688p #0 on SPI bus 1 INFO [muorb] SLPI: INFO [muorb] SLPI: >>> ICM42688P this: b2600328 INFO [muorb] SLPI: Ok executing command: icm42688p start -s INFO [uORB] Advertising remote topic qshell_retval INFO [muorb] SLPI: >>> ICM42688P this: b2600328 INFO [qshell] qshell return value timestamp: 239538233, local time: 239543342 INFO [muorb] SLPI: >>> ICM42688P this: b2600328 INFO [muorb] SLPI: Register interrupt b214ec48 e61eccdc b2600328 INFO [uORB] Advertising remote topic sensor_gyro_fifo INFO [uORB] Advertising remote topic sensor_accel_fifo INFO [uORB] Advertising remote topic imu_server INFO [qshell] Send cmd: 'icp101xx start -I -b 5' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: icp101xx start -I -b 5 INFO [muorb] SLPI: arg0 = 'icp101xx' INFO [muorb] SLPI: arg1 = 'start' INFO [muorb] SLPI: arg2 = '-I' INFO [muorb] SLPI: arg3 = '-b' INFO [muorb] SLPI: arg4 = '5' INFO [muorb] SLPI: *** I2C Device ID 0xb76329 12018473 INFO [muorb] SLPI: Set up I2C bus mutex for bus 5 INFO [muorb] SLPI: >>> ICM42688P this: b2600328 Connection error: connection reset Connection error: connection reset ERROR [qshell] command timed out ERROR [qshell] Command failed INFO [qshell] Send cmd: 'temperature_compensation start' Connection error: connection reset Connection error: connection reset ERROR [qshell] command timed out ERROR [qshell] Command failed Looking for qmc5883l magnetometer INFO [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1' Connection error: connection reset Connection error: connection reset ERROR [qshell] command timed out ERROR [qshell] Command failed Looking for ist8310 magnetometer INFO [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1' Connection error: connection reset Connection error: connection reset ERROR [qshell] command timed out ERROR [qshell] Command failed Looking for ist8308 magnetometer INFO [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1' Connection error: connection reset Connection error: connection reset ERROR [qshell] command timed out ERROR [qshell] Command failed INFO [qshell] Send cmd: 'gps start' Connection error: connection reset Connection error: connection reset ERROR [qshell] command timed out ERROR [qshell] Command failed Looking for ncp5623c RGB LED INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56' Connection error: connection resetdmesg ouput
[Apr10 07:58] Fatal error on slpi! [ +0.000121] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_0 exceeded processing time limit for library 0xb25d94f8. [ +0.000072] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED. [ +0.001309] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting [ +0.000014] subsys-restart: subsystem_shutdown(): [kworker/u19:0:1866]: Shutting down slpi [ +0.017355] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi [ +0.000147] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service [ +0.000157] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service [ +0.003004] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi [ +0.000777] subsys-restart: subsystem_powerup(): [kworker/u19:0:1866]: Powering up slpi [ +0.001439] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000 [ +0.069556] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset [ +0.062589] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up [ +0.000059] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received [ +0.000130] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.002168] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up [ +0.000008] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:1866]: Restart sequence for slpi completed. [ +0.001835] -1882171928:Entered [ +0.000228] -1882171928:SMD QRTR driver probed [ +0.001453] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service [ +0.000064] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service [ +0.002648] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi [ +0.012758] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3 [ +2.208612] Fatal error on slpi! [ +0.000113] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x65:sns_stream_service.c:436:req_found. [ +0.000061] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED. [ +0.001144] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting [ +0.000016] subsys-restart: subsystem_shutdown(): [kworker/u19:0:1866]: Shutting down slpi [ +0.013085] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030 [ +0.002398] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service [ +0.000087] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service [ +0.000944] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi [ +0.001899] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi [ +0.001040] subsys-restart: subsystem_powerup(): [kworker/u19:0:1866]: Powering up slpi [ +0.000247] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000 [ +0.062107] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset [ +0.061462] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up [ +0.000067] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received [ +0.004727] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up [ +0.000007] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:1866]: Restart sequence for slpi completed. [ +0.004439] -1882171928:Entered [ +0.001177] -1882171928:SMD QRTR driver probed [ +0.003823] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi [ +0.001216] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service [ +0.000035] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service [ +0.008403] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3 -
[Apr10 07:58] Fatal error on slpi! [ +0.000121] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:UTMR_CLNT_1:0x1078:sns_thread_manager.c:497:SNS_SEE_P_0 exceeded processing time limit for library 0xb25d94f8. [ +0.000072] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED. [ +0.001309] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting [ +0.000014] subsys-restart: subsystem_shutdown(): [kworker/u19:0:1866]: Shutting down slpi [ +0.017355] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi [ +0.000147] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service [ +0.000157] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service [ +0.003004] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi [ +0.000777] subsys-restart: subsystem_powerup(): [kworker/u19:0:1866]: Powering up slpi [ +0.001439] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000 [ +0.069556] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset [ +0.062589] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up [ +0.000059] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received [ +0.000130] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30040 [ +0.002168] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up [ +0.000008] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:1866]: Restart sequence for slpi completed. [ +0.001835] -1882171928:Entered [ +0.000228] -1882171928:SMD QRTR driver probed [ +0.001453] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service [ +0.000064] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service [ +0.002648] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi [ +0.012758] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3 [ +2.208612] Fatal error on slpi! [ +0.000113] slpi subsystem failure reason: err_qdi.c:1079:EF:sensor_process:0x1:SNS_SEE_I_0:0x65:sns_stream_service.c:436:req_found. [ +0.000061] subsys-restart: subsystem_restart_dev(): Restart sequence requested for slpi, restart_level = RELATED. [ +0.001144] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is restarting [ +0.000016] subsys-restart: subsystem_shutdown(): [kworker/u19:0:1866]: Shutting down slpi [ +0.013085] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30030 [ +0.002398] coresight-remote-etm soc:ssc_etm0: Connection disconnected between QMI handle and 8 service [ +0.000087] sysmon-qmi: ssctl_del_server: Connection lost between QMI handle and slpi's SSCTL service [ +0.000944] adsprpc: fastrpc_rpmsg_remove: closed rpmsg channel of slpi [ +0.001899] adsprpc: fastrpc_restart_notifier_cb: received RAMDUMP notification for slpi [ +0.001040] subsys-restart: subsystem_powerup(): [kworker/u19:0:1866]: Powering up slpi [ +0.000247] subsys-pil-tz 5c00000.qcom,ssc: slpi: loading from 0x0000000088c00000 to 0x000000008a600000 [ +0.062107] subsys-pil-tz 5c00000.qcom,ssc: slpi: Brought out of reset [ +0.061462] subsys-pil-tz 5c00000.qcom,ssc: Subsystem error monitoring/handling services are up [ +0.000067] subsys-pil-tz 5c00000.qcom,ssc: slpi: Power/Clock ready interrupt received [ +0.004727] adsprpc: fastrpc_restart_notifier_cb: slpi subsystem is up [ +0.000007] subsys-restart: subsystem_restart_wq_func(): [kworker/u19:0:1866]: Restart sequence for slpi completed. [ +0.004439] -1882171928:Entered [ +0.001177] -1882171928:SMD QRTR driver probed [ +0.003823] adsprpc: fastrpc_rpmsg_probe: opened rpmsg channel for slpi [ +0.001216] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and slpi's SSCTL service [ +0.000035] coresight-remote-etm soc:ssc_etm0: Connection established between QMI handle and 8 service [ +0.008403] diag: In diag_send_peripheral_buffering_mode, buffering flag not set for 3@astro_phil I think then that there must be some sort of hardware issue. Probably time to RMA the board. http://modalai.com/rma
Okay, then I'm gonna do that. Thanks for the assist.
