    support for septentrio GNSS / GPS receiver modules
    633
    • R
      ravi
      @Moderator
      We want to use a septentrio GNSS / GPS receiver module with VOXL2.
      seems it needs some driver update: https://docs.px4.io/main/en/gps_compass/septentrio.html
      VOXL-PX4 is using "voxl-dev" px4-firmware which doesn't have gnss/septentrio support yet.
      Which is already available in the "main" branch of px4-firmware: https://github.com/modalai/px4-firmware/tree/main/src/drivers/gnss/septentrio.
      can I get any info on when we can get it Or brief details like how I can add and build it?
      and add support.
      Thank you.
        Eric Katzfey ModalAI Team @ravi
        @ravi You can try with PX4 version 1.15.2. We have that package available for VOXL 2 here: http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-mainline-px4_1.15.2-202502041627_arm64.deb
        • R
          ravi @Eric Katzfey
          Hi
          I tried to install px4 deb but getting error.
          I also tried disabling px4 service and install. but getting same error.
          Error is as below.
          voxl2:~$ sudo dpkg -i voxl-mainline-px4_1.15.2-202502041627_arm64.deb
          (Reading database ... 105295 files and directories currently installed.)
          Preparing to unpack voxl-mainline-px4_1.15.2-202502041627_arm64.deb ...
          Unpacking voxl-mainline-px4 (1.15.2-202502041627) ...
          dpkg: error processing archive voxl-mainline-px4_1.15.2-202502041627_arm64.deb (--install):
           trying to overwrite '/data/px4/etc/extras/actuators.json.xz', which is also in package voxl-px4 1.14.0-2.0.85
          dpkg-deb (subprocess): decompressing archive member: lzma write error: Broken pipe
          dpkg-deb (subprocess): cannot copy archive member from 'voxl-mainline-px4_1.15.2-202502041627_arm64.deb' to decompressor pipe: failed to write (Broken pipe)
          dpkg-deb: error: <decompress> subprocess returned error exit status 2
          Errors were encountered while processing:
            @ravi Can you try with force? For example: dpkg --force-all -i voxl-mainline-px4_1.15.2-202502041627_arm64.deb
            • R
              ravi @Eric Katzfey
              Yes, seems working. no error.
              Thanks.
              • R
                ravi @ravi
                HI, this seems mainline px4 build has no support for septentrio GNSS drive.
                I tried to enable from px4-firmware config.
                CONFIG_DRIVERS_GNSS_SEPTENTRIO=y
                But getting error as below. Can you look into it and suggest the solution?
                root@5367fe896de8:/usr/local/workspace# ./build.sh
                + echo '*** Starting build ***'
                + source /home/build-env.sh
                ++ source /home/4.1.0.4/setup_sdk_env.source
                +++ '[' -n '' ']'
                +++ echo ''
                +++ echo Setting up the Hexagon SDK environment locally
                +++++ dirname /home/4.1.0.4/setup_sdk_env.source
                ++++ cd /home/4.1.0.4
                ++++ pwd
                +++ DIR=/home/4.1.0.4
                +++ export HEXAGON_SDK_ROOT=/home/4.1.0.4
                +++ HEXAGON_SDK_ROOT=/home/4.1.0.4
                +++ '[' -n '' ']'
                +++ export ANDROID_ROOT_DIR=/home/4.1.0.4/tools/android-ndk-r19c
                +++ ANDROID_ROOT_DIR=/home/4.1.0.4/tools/android-ndk-r19c
                +++ export QNX_HOST=/home/4.1.0.4/tools/qnx/qnx_700/host/linux/x86_64/
                +++ QNX_HOST=/home/4.1.0.4/tools/qnx/qnx_700/host/linux/x86_64/
                +++ export QNX_TARGET=/home/4.1.0.4/tools/qnx/qnx_700/target/qnx7/
                +++ QNX_TARGET=/home/4.1.0.4/tools/qnx/qnx_700/target/qnx7/
                +++ echo HEXAGON_SDK_ROOT is : /home/4.1.0.4
                +++ export SDK_SETUP_ENV=Done
                +++ SDK_SETUP_ENV=Done
                +++ export LD_LIBRARY_PATH=:/home/4.1.0.4/tools/libusb/
                +++ LD_LIBRARY_PATH=:/home/4.1.0.4/tools/libusb/
                +++ export DEFAULT_HEXAGON_TOOLS_ROOT=/home/4.1.0.4/tools/HEXAGON_Tools/8.4.05
                +++ DEFAULT_HEXAGON_TOOLS_ROOT=/home/4.1.0.4/tools/HEXAGON_Tools/8.4.05
                +++ export DEFAULT_DSP_ARCH=v65
                +++ DEFAULT_DSP_ARCH=v65
                +++ export DEFAULT_BUILD=ReleaseG
                +++ DEFAULT_BUILD=ReleaseG
                +++ export DEFAULT_HLOS_ARCH=64
                +++ DEFAULT_HLOS_ARCH=64
                +++ export DEFAULT_TOOLS_VARIANT=toolv84
                +++ DEFAULT_TOOLS_VARIANT=toolv84
                +++ export DEFAULT_NO_QURT_INC=1
                +++ DEFAULT_NO_QURT_INC=1
                +++ export DEFAULT_TREE=1
                +++ DEFAULT_TREE=1
                +++ export CMAKE_ROOT_PATH=/home/4.1.0.4/tools/utils/cmake-3.17.0-Linux-x86_64
                +++ CMAKE_ROOT_PATH=/home/4.1.0.4/tools/utils/cmake-3.17.0-Linux-x86_64
                +++ echo 'Setting up the QAIC binary for the platform'
                +++ make -C /home/4.1.0.4/ipc/fastrpc/qaic/
                make: Entering directory '/home/4.1.0.4/ipc/fastrpc/qaic'
                make: 'bin/qaic' is up to date.
                make: Leaving directory '/home/4.1.0.4/ipc/fastrpc/qaic'
                +++ '[' -d /home/4.1.0.4/tools/android-ndk-r19c ']'
                +++ echo 'Could not find Androd ndk at /home/4.1.0.4/tools/android-ndk-r19c'
                +++ export WARNING=1
                +++ WARNING=1
                +++ '[' -d /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05 ']'
                +++ true
                +++ '[' -n 1 ']'
                +++ echo ''
                +++ echo 'Please refer to /home/4.1.0.4/docs/tools/setup.html for installing the missed components'
                +++ echo ''
                ++ export ARM_CROSS_GCC_ROOT=/home/4.1.0.4/tools/linaro64
                ++ ARM_CROSS_GCC_ROOT=/home/4.1.0.4/tools/linaro64
                ++ export HEXAGON_ARM_SYSROOT=/home/4.1.0.4/tools/linaro64/aarch64-linux-gnu/libc
                ++ HEXAGON_ARM_SYSROOT=/home/4.1.0.4/tools/linaro64/aarch64-linux-gnu/libc
                ++ export HEXAGON_TOOLS_ROOT=/home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools
                ++ HEXAGON_TOOLS_ROOT=/home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools
                + export PATH=/home/4.1.0.4/tools/linaro64/bin:/home/4.1.0.4/tools/linaro64/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
                + PATH=/home/4.1.0.4/tools/linaro64/bin:/home/4.1.0.4/tools/linaro64/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
                + APPS_BUILD=ON
                + SLPI_BUILD=ON
                + DEPS_BUILD=ON
                + getopts asd flag
                + cd px4-firmware
                + '[' ON == ON ']'
                + echo '*** Starting dependencies build ***'
                + ./boards/modalai/voxl2/scripts/build-deps.sh
                -- The C compiler identification is GNU 7.5.0
                -- The CXX compiler identification is GNU 9.4.0
                -- Check for working C compiler: /home/4.1.0.4/tools/linaro64/bin/aarch64-linux-gnu-gcc
                -- Check for working C compiler: /home/4.1.0.4/tools/linaro64/bin/aarch64-linux-gnu-gcc -- works
                -- Check for working CXX compiler: /usr/bin/c++
                -- Check for working CXX compiler: /usr/bin/c++ -- works
                -- Configuring done
                -- Generating done
                -- Build files have been written to: /usr/local/workspace/px4-firmware/boards/modalai/voxl2/libfc-sensor-api/build
                Scanning dependencies of target fc_sensor
                [ 50%] Building C object CMakeFiles/fc_sensor.dir/src/fc_sensor_stub.c.o
                [100%] Linking C shared library libfc_sensor.so
                [100%] Built target fc_sensor
                + echo '*** End of dependencies build ***'
                + '[' ON == ON ']'
                + echo '*** Starting apps processor build ***'
                + make modalai_voxl2
                -- PX4_GIT_TAG: v1.16.0-alpha2-379-g5fb810a5ea
                -- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.10", minimum required is "3")
                -- PX4 config file: /usr/local/workspace/px4-firmware/boards/modalai/voxl2/default.px4board
                -- PLATFORM posix
                -- LINUX_TARGET y
                -- TOOLCHAIN aarch64-linux-gnu
                -- ROMFSROOT px4fmu_common
                -- ROOT_PATH /data/px4
                -- PARAM_FILE /fs/mtd_params
                -- PX4 config: modalai_voxl2_default
                -- PX4 platform: posix
                -- PX4 lockstep: disabled
                -- The CXX compiler identification is GNU 7.5.0
                -- The ASM compiler identification is GNU
                -- Found assembler: /home/4.1.0.4/tools/linaro64/bin/aarch64-linux-gnu-gcc
                -- Check for working CXX compiler: /home/4.1.0.4/tools/linaro64/bin/aarch64-linux-gnu-g++
                -- Check for working CXX compiler: /home/4.1.0.4/tools/linaro64/bin/aarch64-linux-gnu-g++ -- works
                -- cmake build type: RelWithDebInfo
                -- ccache enabled (export CCACHE_DISABLE=1 to disable)
                -- Skipping pwm file path /usr/local/workspace/px4-firmware/src/drivers/linux_pwm_out/module.yaml for VOXL2
                -- Skipping pwm file path /usr/local/workspace/px4-firmware/src/drivers/pca9685_pwm_out/module.yaml for VOXL2
                -- Skipping pwm file path /usr/local/workspace/px4-firmware/src/drivers/pwm_out/module.yaml for VOXL2
                -- Skipping pwm file path /usr/local/workspace/px4-firmware/src/modules/simulation/pwm_out_sim/module_hil.yaml for VOXL2
                -- Skipping pwm file path /usr/local/workspace/px4-firmware/src/modules/simulation/pwm_out_sim/module_sim.yaml for VOXL2
                -- Skipping spacecraft file path /usr/local/workspace/px4-firmware/src/modules/spacecraft/module.yaml for VOXL2
                -- ROMFS: ROMFS/px4fmu_common
                Architecture:  amd64
                ==> CPACK_INSTALL_PREFIX = @DEB_INSTALL_PREFIX@
                -- Configuring done
                -- Generating done
                -- Build files have been written to: /usr/local/workspace/px4-firmware/build/modalai_voxl2_default
                [1/626] git submodule src/modules/uxrce_dds_client/Micro-XRCE-DDS-Client
                [4/626] git submodule src/drivers/gps/devices
                [9/626] git submodule src/modules/mavlink/mavlink
                [54/626] Performing configure step for 'libmicroxrceddsclient_project'
                -- libmicroxrceddsclient_project configure command succeeded.  See also /usr/local/workspace/px4-firmware/build/modalai_voxl2_default/src/modules/uxrce_dds_client/src/libmicroxrceddsclient_project-stamp/libmicroxrceddsclient_project-configure-*.log
                [103/626] Performing build step for 'libmicroxrceddsclient_project'
                -- libmicroxrceddsclient_project build command succeeded.  See also /usr/local/workspace/px4-firmware/build/modalai_voxl2_default/src/modules/uxrce_dds_client/src/libmicroxrceddsclient_project-stamp/libmicroxrceddsclient_project-build-*.log
                [284/626] Performing install step for 'libmicroxrceddsclient_project'
                -- libmicroxrceddsclient_project install command succeeded.  See also /usr/local/workspace/px4-firmware/build/modalai_voxl2_default/src/modules/uxrce_dds_client/src/libmicroxrceddsclient_project-stamp/libmicroxrceddsclient_project-install-*.log
                [381/626] Building CXX object src/drivers/gnss/septentrio/CMakeFiles/driver__septentrio.dir/septentrio.cpp.o
                FAILED: src/drivers/gnss/septentrio/CMakeFiles/driver__septentrio.dir/septentrio.cpp.o
                /usr/bin/ccache /home/4.1.0.4/tools/linaro64/bin/aarch64-linux-gnu-g++  -DCONFIG_ARCH_BOARD_MODALAI_VOXL2 -DMODULE_NAME=\"septentrio\" -DPX4_MAIN=septentrio_app_main -D__CUSTOM_FILE_IO__ -D__PX4_LINUX -D__PX4_POSIX -D__STDC_FORMAT_MACROS -Dnoreturn_function="__attribute__((noreturn))" -I../../boards/modalai/voxl2/src -I../../platforms/posix/src/px4/common/include -I. -Isrc/lib -I../../platforms/posix/src/px4/generic/generic/include -I../../platforms/common -I../../platforms/common/include -I../../src -I../../src/include -I../../src/lib -I../../src/lib/matrix -I../../src/modules -I../../platforms/posix/include -I../../boards/modalai/voxl2/libfc-sensor-api/inc -Iexternal/Install/include -O2 -g -DNDEBUG -fPIC   -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=always -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -Wreorder -Wno-overloaded-virtual -fno-rtti -DSEP_LOG_ERROR -std=gnu++14 -MD -MT src/drivers/gnss/septentrio/CMakeFiles/driver__septentrio.dir/septentrio.cpp.o -MF src/drivers/gnss/septentrio/CMakeFiles/driver__septentrio.dir/septentrio.cpp.o.d -o src/drivers/gnss/septentrio/CMakeFiles/driver__septentrio.dir/septentrio.cpp.o -c ../../src/drivers/gnss/septentrio/septentrio.cpp
                In file included from ../../src/drivers/gnss/septentrio/sbf/decoder.h:46:0,
                                 from ../../src/drivers/gnss/septentrio/septentrio.h:63,
                                 from ../../src/drivers/gnss/septentrio/septentrio.cpp:44:
                ../../src/drivers/gnss/septentrio/sbf/messages.h:101:21: error: 'septentrio::sbf::Header::id_number' is too small to hold all values of 'enum class septentrio::sbf::BlockID' [-Werror]
                  BlockID id_number: 13;
                compilation terminated due to -Wfatal-errors.
                cc1plus: all warnings being treated as errors
                [384/626] Building CXX object src/drivers/gnss/septentrio/CMakeFiles/driver__septentrio.dir/sbf/decoder.cpp.o
                FAILED: src/drivers/gnss/septentrio/CMakeFiles/driver__septentrio.dir/sbf/decoder.cpp.o
                /usr/bin/ccache /home/4.1.0.4/tools/linaro64/bin/aarch64-linux-gnu-g++  -DCONFIG_ARCH_BOARD_MODALAI_VOXL2 -DMODULE_NAME=\"septentrio\" -DPX4_MAIN=septentrio_app_main -D__CUSTOM_FILE_IO__ -D__PX4_LINUX -D__PX4_POSIX -D__STDC_FORMAT_MACROS -Dnoreturn_function="__attribute__((noreturn))" -I../../boards/modalai/voxl2/src -I../../platforms/posix/src/px4/common/include -I. -Isrc/lib -I../../platforms/posix/src/px4/generic/generic/include -I../../platforms/common -I../../platforms/common/include -I../../src -I../../src/include -I../../src/lib -I../../src/lib/matrix -I../../src/modules -I../../platforms/posix/include -I../../boards/modalai/voxl2/libfc-sensor-api/inc -Iexternal/Install/include -O2 -g -DNDEBUG -fPIC   -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fmerge-all-constants -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=always -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -Wreorder -Wno-overloaded-virtual -fno-rtti -DSEP_LOG_ERROR -std=gnu++14 -MD -MT src/drivers/gnss/septentrio/CMakeFiles/driver__septentrio.dir/sbf/decoder.cpp.o -MF src/drivers/gnss/septentrio/CMakeFiles/driver__septentrio.dir/sbf/decoder.cpp.o.d -o src/drivers/gnss/septentrio/CMakeFiles/driver__septentrio.dir/sbf/decoder.cpp.o -c ../../src/drivers/gnss/septentrio/sbf/decoder.cpp
                                 from ../../src/drivers/gnss/septentrio/sbf/decoder.cpp:42:
                [386/626] Building CXX object src/drivers/actuators/voxl_esc/CMakeFiles/drivers__actuators__voxl_esc.dir/voxl_esc.cpp.o
                ninja: build stopped: subcommand failed.
                make: *** [Makefile:232: modalai_voxl2] Error 1
                + cat build/modalai_voxl2_default/src/lib/version/build_git_version.h
                /* Auto Magically Generated file */
                /* Do not edit! */
                #pragma once
                #define PX4_GIT_VERSION_STR "5fb810a5ea0bf6c8d9e0f69251a44ad8e3d4b2ce"
                #define PX4_GIT_VERSION_BINARY 0x5fb810a5ea0bf6c8
                #define PX4_GIT_TAG_STR "v1.16.0-alpha2-379-g5fb810a5ea"
                #define PX4_GIT_BRANCH_NAME ""
                #define PX4_GIT_OEM_VERSION_STR  ""
                #define PX4_GIT_TAG_OR_BRANCH_NAME "main" // special variable: git tag, release or main branch
                #define MAVLINK_LIB_GIT_VERSION_STR  "8690e10164da864d7d36a3daad5547662e7a4103"
                #define MAVLINK_LIB_GIT_VERSION_BINARY 0x8690e10164da864d
                #define NUTTX_GIT_VERSION_STR  "205b3100f8f63944a45faa5cfb5d3f86e904ee59"
                #define NUTTX_GIT_VERSION_BINARY 0x205b3100f8f63944
                #define NUTTX_GIT_TAG_STR  "v11.0.0"
                + echo '*** End of apps processor build ***'
                + '[' ON == ON ']'
                + echo '*** Starting qurt slpi build ***'
                + make modalai_voxl2-slpi
                -- PX4 config file: /usr/local/workspace/px4-firmware/boards/modalai/voxl2-slpi/default.px4board
                -- PLATFORM qurt
                -- TOOLCHAIN qurt
                -- ROOT_PATH /fs/microsd
                -- PX4 config: modalai_voxl2-slpi_default
                -- PX4 platform: qurt
                -- The CXX compiler identification is Clang 10.0.0
                -- The C compiler identification is Clang 10.0.0
                -- The ASM compiler identification is unknown
                -- Found assembler: /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang
                -- Check for working CXX compiler: /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang++
                -- Check for working CXX compiler: /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang++ -- works
                -- Detecting CXX compiler ABI info - failed
                -- Check for working C compiler: /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang
                -- Check for working C compiler: /home/4.1.0.4/tools/HEXAGON_Tools/8.4.05/Tools/bin/hexagon-clang -- works
                -- Detecting C compiler ABI info - failed
                -- Warning: Did not find file Compiler/-ASM
                -- Mavlink include directory: /usr/local/workspace/px4-firmware/../build/modalai_voxl2_default/mavlink/standard
                -- Mavlink include directory: /usr/local/workspace/px4-firmware/../build/modalai_voxl2_default/mavlink/common
                Architecture:  amd64
                -- Configuring done
                -- Generating done
                -- Build files have been written to: /usr/local/workspace/px4-firmware/build/modalai_voxl2-slpi_default
                [0/746] git submodule src/drivers/gps/devices
                [746/746] Linking CXX shared library platforms/qurt/libpx4.so
                + cat build/modalai_voxl2-slpi_default/src/lib/version/build_git_version.h
                cat: build/modalai_voxl2-slpi_default/src/lib/version/build_git_version.h: No such file or directory
                + echo '*** End of qurt slpi build ***'
                + cd -
                ++ stat -c %u .git/modules/px4-firmware
                + USER=1000
                + echo 'User ID is 1000'
                User ID is 1000
                + chown -R 1000 .git/modules/px4-firmware
                ++ stat -c %g .git/modules/px4-firmware
                + GROUP=1000
                + echo 'Group ID is 1000'
                Group ID is 1000
                + chgrp -R 1000 .git/modules/px4-firmware
                + echo '*** End of build ***'
                Thank you.
                  @ravi said in support for septentrio GNSS / GPS receiver modules:
                  Seems like the compiler doesn't like that code. See: https://stackoverflow.com/questions/36005063/gcc-suppress-warning-too-small-to-hold-all-values-of
                    Eric Katzfey ModalAI Team @Eric Katzfey
                    @Eric-Katzfey The code would have to be changed to something the compiler can deal with.
                      @Eric-Katzfey Or update to a newer compiler. I just tried this one: https://developer.arm.com/-/media/Files/downloads/gnu/14.2.rel1/binrel/arm-gnu-toolchain-14.2.rel1-x86_64-aarch64-none-linux-gnu.tar.xz and it fixes that issue. But then it fails on a couple of other issue in septentrio.cpp that are easy to fix. So the solution is probably to upgrade the compiler and then fix the new reported errors in septentrio.cpp.
