VOXL2/ROS2 Drone Runs Figure 8 Offboard Program Instead of My Program
@claw You'll need to change the parameter COM_RC_OVERRIDE to also allow overriding offboard mode.
Reference link : https://docs.px4.io/main/en/advanced_config/parameter_reference.html#COM_RC_OVERRIDE
@Kessie Hi again, we just changed COM_RC_OVERRIDE to allow for overriding offboard mode and we were able to cut the motors while the drone was operating in offboard mode. We modified the PX4 ROS 2 Offboard Control Example code to only enable offboard mode and arm the drone, but we noticed that once the drone armed, it had a lot of throttle. I'm guessing there is a setting maybe in QGroundControl to modify the throttle somehow, or is there another way to fix this?
I just ran into another problem where I believe after running "voxl-configure-microdds" again, it seems some of my changes were reset as I noticed "offboard_mode" defaulted back to "figure_eight" while looking in the vision-hub config file. However, I did notice that my changes with the node publishers were not changed.
I thought I have reverted everything to how it was before, but the drone is now back to not flying at all. I also noticed that my list of ros2 topics has also shrunk down as well.
@GlennTee said in VOXL2/ROS2 Drone Runs Figure 8 Offboard Program Instead of My Program:
This likely means that those topics got populated from the offboard script not the px4-ros bridge. Could you check that voxl-microdds-agent is running when you see this happen.
Check with "voxl-inspect-services"
@teddy-zaremba Hi, I just checked using that command and it appears the agent is enabled, but it is not running.
@GlennTee Can you run the command "voxl-microdds-agent" and share your output please?
@teddy-zaremba said in VOXL2/ROS2 Drone Runs Figure 8 Offboard Program Instead of My Program:
This is what I get:
This is what I get:
@GlennTee This looks fine to me if it's not running I'd suggest just restarting the service via "systemctl restart voxl-microdds-agent" and then double check that it's running with "voxl-inspect-services"
@teddy-zaremba Your help is very much appreciated.
Ok, so some of the confusion was related to editing the Python example, but it's actually running the cpp code. With that corrected, it shows all of the expected topics in the "ros2 topic list" and the code sends the arm command to the correct topic according to "ros2 topic echo /uav_4/fmu/in/vehicle_command", however, the Starling doesn't arm. We're trusting the example code as to the data structure that is actually populated and sent to that topic. Is there a reference as to what that should be?
@claw said in VOXL2/ROS2 Drone Runs Figure 8 Offboard Program Instead of My Program:
@claw what code are you referring to? The ros2 figure 8 code is written in python:
voxl-mpa-to-ros2 itself is written in CPP, but this node specific is in python as it can be either. With the DDS running, you do not need the voxl-mpa-to-ros2 code running as that just converts MPA to ros2, but regardless you dont need that running if the goal is just to publish to the dds via this ros2 node. How are you executing this?
ros2 run voxl_offboard_figure8 voxl_offboard_figure8? -
ros2 run voxl_offboard_figure8 voxl_offboard_figure8?@Zachary-Lowell-0 Hi, the code we are referring to is from an example on the PX4 website, where the drone should engage in offboard mode, arm, ascend a desired height, and wait. The link to that is here: https://docs.px4.io/main/en/ros2/offboard_control.html
We are trying to run this program on our Starling drone, and the line we are running to execute the program is "ros2 run px4_ros_com offboard_control"
With the changes made, we now see that the arm command is being sent to the correct topic, but the drone continues to not arm.
@GlennTee Good news! The program now runs, turns out I needed to add the .py extension to the file name when calling the run command, so it should be "ros2 run px4_ros_com offboard_control.py"
However, we experienced a lot of errors while running. The drone did arm (But only would do every even numbered attempt for some reason), however it did not fly. I'm working now to debug these errors.
