  2. Software Development
  3. GPS-denied Navigation (VIO)
  4. How to tune OpenVins
Scheduled Pinned Locked Moved GPS-denied Navigation (VIO)
11 Posts 4 Posters 3.6k Views 3 Watching
  • K Offline
    K Offline
    Kessie
    We are testing with the new SDK1.14 and the OpenVins implementation.
    The basic test that we're doing is taking off to 1m and staying there.
    What we did see is that out of 50 tests that we did, only 10 were relatively correct. The other ones where going a lot higher.
    Hereby 2 flight logs that you can check :
    Bad flight : https://review.px4.io/plot_app?log=5e809b1e-3473-425c-8d42-9dce0472b1ef
    Good flight :https://review.px4.io/plot_app?log=9fdb3a61-3e4d-4eb2-9b35-10072e665f28
    How can we tune the performance and accuracy of indoor flights?
    Can we get some technical help on this, please?
    • K Kessie
      Cliff WongC Offline
      Cliff WongC Offline
      Cliff Wong
      @Kessie Hi there, can you please post your vio_cams.conf file?
      So far is appears the Quality of the vio data is degrading in both flights, just faster in the bad flight. Is there a reason to sit in the takeoff state (on ground, motors spinning) for 20+ seconds? A scenario like that will create a level of vibration/movement in the cameras where ovins will start to pick up false positive features creating instability. We can increase the threshold for takeoff, but may give an undesirable offset of a origin (0,0,0 maybe 1/2m above the ground for example). You can first try increasing the following values by 50% increments:
      "zupt_max_velocity": 0.03,
      "zupt_noise_multiplier": 1,
      Hence:
      "zupt_max_velocity": 0.045,
      "zupt_noise_multiplier": 1.5,
      And see if that improves.
      K 2 Replies Last reply
      • Cliff WongC Cliff Wong
        Hence:
        K Offline
        K Offline
        Kessie
        wrote on last edited by Kessie
        @Cliff-Wong sure, it is the default for Starling 2 Max:
        "cams": [{
        "enable": true,
        "name": "tracking_front",
        "pipe_for_preview": "tracking_front",
        "pipe_for_tracking": "tracking_front_misp_norm",
        "is_occluded_on_ground": false,
        "imu": "imu_apps",
        "cal_file": "opencv_tracking_front_intrinsics.yml"
        "enable": true,
        "name": "tracking_down",
        "pipe_for_preview": "tracking_down",
        "pipe_for_tracking": "tracking_down_misp_norm",
        "is_occluded_on_ground": true,
        "imu": "imu_apps",
        "cal_file": "opencv_tracking_down_intrinsics.yml"
        We've also tried to only use the front-tracking camera, but with a same result.
        The longer waiting time was because we were checking the number of keypoints and the 6DoF result in ov_overlay before taking off. (Hoping to identify what is the culprit)
        We will try tuning the mentioned parameters
          Hence:
          K Offline
          K Offline
          Kessie
          @Cliff-Wong We have tested further, but we keep getting drift on the Z-axis.
          There are moments that it works OK-ish, but the majority of our tests, the height estimates starts to go down (value goes up) and we have no clue about the reason.
          FYI : We are testing this in a warehouse with plenty of good features and consistent lighting.
          Cliff WongC S 2 Replies Last reply
          • K Kessie
            Cliff WongC Offline
            Cliff WongC Offline
            Cliff Wong
            @Kessie
            Again, longer waiting times on the ground during pre-flight (<2min) will introduce drift either by thermal issues or feature noise.
            To address thermal issues, the IMU is not temperature calibrated from the factory. You can do so by running
            voxl-calibrate-imu-temp
            To address feature noise, you can raise the drone a couple inches above the ground (typically 3 inches).
            If both cases cannot be done in your application, we do offer a blind takeoff feature in ovins, by setting in voxl-open-vins-sever.conf:
            "en_vio_always_on": false
            But note, you will see vio stay 0,0,0 (even if you move the drone) and see any feature points freeze in place as this feature holds the vio state at 0,0,0 until the drone is armed and very slow takeoffs can introduce a static Z offset upto 0.1m.
            • K Kessie
              S Offline
              S Offline
              sssagara
              @Kessie Seconding this. We have a triple tracking Starling 2. Initially, when on SDK 1.3.5, QVIO was barely sufficient for ensure stable flight without drift in conditions that were a bit too bright or dark. We upgraded to SDK 1.4.0 to use OpenVINS and had better luck in our lab, with the quality and features metric as reference that it will have accurate positioning estimates. But as soon as we brought it out to a different test area that is well lit with artificial lighting, it seems like OpenVINS momentarily stalls as soon as the drone is armed (see below pic). Even after letting OpenVINS recover, the height will drift very drastically even when the drone is still on the ground (see below pic). We tried a combination of single, double and triple camera setup. en_vio_always_on doesnt seem to make a difference regardless if its true or false. When we do have to leave the drone on the ground, we manage the temperature by having a dedicated fan pointed at the processor until it is ready to fly.
              For now, we have resorted to going back to a single camera QVIO setup
              • S sssagara
                Cliff WongC Offline
                Cliff WongC Offline
                Cliff Wong
                wrote on last edited by Cliff Wong
                @sssagara HI there, the default feature tracking settings have changed since 1.3.5 as we have found performance degradtion in challenging light conditions. I suggest 2 choices:
                • in voxl-open-vins-server.conf set en_ext_feature_tracker to false (which will increase cpuload may affect your/3rd party applications, ros, etc...)
                  or
                • we urge upgrade to SDK 1.4.1 with its improved feature tracker configuration that will correct these take off issues (preferred)
                We have noticed that sitting unarmed before takeoff, if there are no features (< 3) or features jumping around (3 <-> 12+) when one arms the motors for takeoff: that will cause ovins to drift off due to lack of features (dead reckoning). If you can run a screen record of voxl-portal's ov_overlay screen or run voxl-logger -o and post that log we can confirm that is your issue and can provide necessary steps to correct.
                S 1 Reply Last reply
                    or
                  S Offline
                  S Offline
                  sssagara
                  wrote on last edited by sssagara
                  @Cliff-Wong Hi Cliff, thanks for your reply
                  We have since upgraded to SDK 1.4.2 beta 2. However, before that, in an effort to understand if the problem is a result of bugs in OpenVINS from an outdated SDK version or our algo (that is in docker containers) somehow messing up the odometry (whether by CPU usage or otherwise), I did a clean install to 1.4.0 before slowly installing other packages in steps and testing its ability to position hold using OpenVINS after each step
                  The steps along the way are:
                  • SDK 1.4.0 clean install
                  • Upgrading to SDK 1.4.2 beta 2
                  • Installed ROS Melodic
                  • Installed Docker with 2 running containers
                  • Installed and run MAVROS
                  Some params that might affect the position hold reliability are fixed as such:
                  • EKF2_HGT_REF: Vision
                  • EKF2_RNG_CTRL: Enabled (Conditional)
                  • en_vio_always_on: true
                  • en_ext_feature_tracker: false
                  • Well-lit lab environment
                  I noticed that at all steps, after voxl-reset-vins command is entered, voxl-inspect-vins will always report as STALLED with quality at -1% upon first arming of the drone. This is usually not a problem as the next arm will usually report favourable quality (99%), features (>20) and Z height estimate (at ~0m on ground). However, after the Docker step, I noticed that there was a much higher chance of the Z height exploding in value immediately after the first arming. We're still exploring if the decrease in OpenVINS reliability here is a result of increased CPU usage or other factors
                  Since SDK 1.4.2 beta 2 seems to work for us (for the most part) as of now, while we try to identify if its a problem on our end, is there a way to prevent apt upgrade from upgrading to the next beta version?
                  On a side note, regarding voxl-logger, I tried logging and replaying using voxl-logger. But I can't seem to playback the log (refer to below pic) as it seems like the command is appending an unnecessary '/'. Is this a bug or am I doing something wrong here?
                  • S sssagara
                    S Offline
                    S Offline
                    sssagara
                    @sssagara said in How to tune OpenVins:
                    Hi @Cliff-Wong Scratch whatever I learnt in my previous reply. Just did a flight test a day after I conducted those tests
                    Between my previous successful flight with OpenVINS the day before and today, with environment and lighting conditions remaining the same and the only exception that I bench tested QVIO (by running voxl-configure-open-vins disable and voxl-configure-qvio enable) and then re-enabling OpenVINS again (by voxl-configure-open-vins enable and voxl-configure-qvio disable) and then power cycling, it seemed to have utterly broken OpenVINS
                    Where in my previous day's successful flight with OpenVINS, upon arming the drone and voxl-inspect-vins momentarily showing OpenVINS has stalled but recovering successfully after disarming and re-arming again, the position estimation by OpenVINS is still valid enough for position hold. However, after switching to QVIO and back to OpenVINS, after the first arming, the Z height immediately explodes and putting it into position hold will just result in the drone shooting to the sky
                    I'm not sure if disabling the OpenVINS caused some configuration file to change that made it behave this way. This is even after playing around with params such as en_vio_always_on and is_occluded_on_ground for the downwards facing tracking camera.
                    I tried logging but a bunch of errors came up midway through the logging process. I do have a screen recording of a subsequent flight of QVIO working well and then immediately switching to OpenVINS where it immediately failed. Do let me know who in the team I can send it to privately to have a look at
                    • S sssagara
                      Jetson NanoJ Online
                      Jetson NanoJ Online
                      Jetson Nano
                      Veteran
                      @Cliff-Wong @Kessie
                      I am facing the same error with voxl-open-vins. As soon as I arm the drone, the position is loosing, the drone is drifting , the vio values are drifting. I checked the changes you guys recommended above, it worsened the speed and the drift. when i went to the initial values, the drift was slow and less, still drift was present.
                      Could anyone help me with this problem, how to achieve a better VIO values and no drift in an ideal condition.
                      • Jetson NanoJ Jetson Nano
                        @Cliff-Wong @Kessie
                        Jetson NanoJ Online
                        Jetson NanoJ Online
                        Jetson Nano
                        Veteran
                        @Cliff-Wong @Kessie
                        Guys can you help me out here.
