  2. VOXL SDK and Software
  3. IMU stream rate fixed at 10Hz (PX4)
ros
11 Posts 4 Posters 7.1k Views 2 Watching
  • J Offline
    J Offline
    Judoor 0
    I'm using an IMU with PX4 firmware. I attempted to change the stream rate of the IMU data to at least 50Hz, instead of the default 10Hz. However, when I use rosservice /mavros/set_stream_rate or rosservice /mavros/set_message_interval, there is no change.
    Could this be related to MPA, PX4, or another factor?
    Thanks in advance.
    • J Judoor 0
      Thanks in advance.
      Eric KatzfeyE Online
      @Judoor-0 What flight controller are you running this on?
      J 1 Reply Last reply
        J Offline
        J Offline
        Judoor 0
        @Eric-Katzfey I'm using integrated IMU with VOXL2
        • J Judoor 0
          @Judoor-0 I'm not sure what those mavros commands are trying to do. But you can change the rate at which mavlink messages are streamed out of PX4. Take a look at the PX4 startup file /usr/bin/voxl-px4-start and look for the lines like: mavlink stream -u 14556 -s HIGHRES_IMU -r 10. Adding lines like that or modifying the existing ones can change the rates.
          K 1 Reply Last reply
            K Offline
            K Offline
            KLindgren
            @Eric-Katzfey hoping you can share some more insights here.
            I have edited the HIGHRES_IMU line in /usr/bin/voxl-px4-start to set the rate at 500 but the /imu_mavlink rostopic from voxl-mpa-to-ros shows a publish rate of ~137hz. Collected data with voxl logger shows the timing issue is not related to ROS -- do you know what may be causing the dropped imu messages in the mpa pipe?
            voxl-version
            system-image: 1.8.04-M0104-14.1a-perf
            kernel:       #1 SMP PREEMPT Mon Mar 24 21:03:36 UTC 2025 4.19.125
            hw platform:  M0104
            mach.var:     2.0.2
            SKU:          MCCA-M0104-C22-T0-M0-X0-E1
            voxl-suite:   1.5.0
            voxl-px4-start
            #!/bin/sh
            # PX4 commands need the 'px4-' prefix in bash.
            # (px4-alias.sh is expected to be in the PATH)
            . px4-alias.sh
            echo -e "\n*************************"
            echo "AIRFRAME: $AIRFRAME"
            echo "GPS: $GPS"
            echo "RC: $RC"
            echo "ESC: $ESC"
            echo "POWER MANAGER: $POWER_MANAGER"
            echo "AIRSPEED SENSOR: $AIRSPEED_SENSOR"
            echo "DISTANCE SENSOR: $DISTANCE_SENSOR"
            echo "OSD: $OSD"
            echo "ARTIFACT_MODE: $ARTIFACT_MODE"
            echo "EXTRA STEPS:"
            for i in "${EXTRA_STEPS[@]}"
            do
            	echo -e "\t$i"
            done
            echo -e "*************************\n"
            # In order to just exit after starting the uorb / muorb modules define
            # the environment variable MINIMAL_PX4. (e.g. export MINIMAL_PX4=1)
            # This is useful for testing / debug where you may want to start drivers
            # and modules manually from the px4 command shell
            if [ ! -z $MINIMAL_PX4 ]; then
                /bin/echo "Running minimal script"
                exit 0
            fi
            # Figure out what platform we are running on.
            PLATFORM=`/usr/bin/voxl-platform 2> /dev/null`
            RETURNCODE=$?
            if [ $RETURNCODE -ne 0 ]; then
                # If we couldn't get the platform from the voxl-platform utility then check
                # /etc/version to see if there is an M0052 substring in the version string. If so,
                # then we assume that we are on M0052.
                VERSIONSTRING=$(</etc/version)
                M0052SUBSTRING="M0052"
                if [[ "$VERSIONSTRING" == *"$M0052SUBSTRING"* ]]; then
                    PLATFORM="M0052"
                fi
            fi
            # We can only run on M0052, M0054, or M0104 so exit with error if that is not the case
            if [ $PLATFORM = "M0052" ]; then
                /bin/echo "Running on M0052"
            elif [ $PLATFORM = "M0054" ]; then
                /bin/echo "Running on M0054"
            elif [ $PLATFORM = "M0104" ]; then
                /bin/echo "Running on M0104"
            else
                /bin/echo "Error, cannot determine platform!"
                exit 0
            fi
            # Sleep a little here. A lot happens when the uorb and muorb start
            # and we need to make sure that it all completes successfully to avoid
            # any possible race conditions.
            /bin/sleep 1
            param select /data/px4/param/parameters
            # Load in all of the parameters that have been saved in the file
            param load
            # IMU (accelerometer / gyroscope)
            if [ "$PLATFORM" == "M0104" ]; then
                /bin/echo "Starting IMU driver with rotation 12"
                qshell icm42688p start -s -R 12
            else
                /bin/echo "Starting IMU driver with no rotation"
            fi
            # Start Invensense ICP 101xx barometer built on to VOXL 2
            qshell icp101xx start -I -b 5
            qshell temperature_compensation start
            # Auto detect the magnetometer. If one or both of these devices
            # are not connected it will fail but not cause any harm.
            # Rotation 10 = ROLL_180_YAW_90
            /bin/echo "Looking for qmc5883l magnetometer"
            /bin/echo "Looking for ist8310 magnetometer"
            /bin/echo "Looking for ist8308 magnetometer"
            # Rotation 12 = PITCH_180
            qshell ist8308 start -R 12 -X -b 1
            # GPS and magnetometer
            if [ "$GPS" != "NONE" ]; then
            	# On M0052 the GPS driver runs on the apps processor
            	    gps start -d /dev/ttyHS2
            	# On M0054 and M0104 the GPS driver runs on SLPI DSP
            	else
            	    qshell gps start
            	fi
            fi
            # Auto detect an ncp5623c i2c RGB LED. If one isn't connected this will
            # fail but not cause any harm.
            /bin/echo "Looking for ncp5623c RGB LED"
            qshell rgbled_ncp5623c start -X -b 1 -f 400 -a 56
            # We do not change the following parameters but QGC will complain if they aren't
            # being reported as "used" by px4. "Touching" them accomplishes that.
            param touch SYS_AUTOCONFIG
            param touch SDLOG_MODE
            # ESC driver
            if [ "$ESC" == "VOXL_ESC" ]; then
                /bin/echo "Starting VOXL ESC driver"
            	qshell voxl_esc start
            elif [ "$ESC" == "VOXL2_IO_PWM_ESC" ]; then
            	if [ "$RC" == "M0065_SBUS" ]; then
            		/bin/echo "Starting VOXL IO for PWM ESC with SBUS RC"
            		qshell voxl2_io start
            	else
            		/bin/echo "Starting VOXL IO for PWM ESC without SBUS RC"
            		qshell voxl2_io start -e
            	fi
            else
            	/bin/echo "No ESC type specified, not starting an ESC driver"
            fi
            # RC driver
            if [ "$RC" == "FAKE_RC_INPUT" ]; then
                /bin/echo "Starting fake RC driver"
                qshell rc_controller start
            elif [ "$RC" == "CRSF_RAW" ]; then
                /bin/echo "Starting CRSF RC driver"
                qshell crsf_rc start -d 7
            elif [ "$RC" == "CRSF_MAV" ]; then
                /bin/echo "Starting TBS crossfire RC - MAV Mode"
                qshell mavlink_rc_in start -m -p 7 -b 115200
            elif [ "$RC" == "SPEKTRUM" ]; then
                /bin/echo "Starting Spektrum RC"
            	# On M0052 the RC driver runs on the apps processor
                    rc_input start -d /dev/ttyHS1
            	# On M0054 and M0104 the RC driver runs on SLPI DSP
            	else
                    qshell spektrum_rc start
            	fi
            elif [ "$RC" == "GHST" ]; then
                /bin/echo "Starting GHST RC driver"
                qshell ghst_rc start -d 7
            elif [ "$RC" == "M0065_SBUS" ]; then
            		apps_sbus start
            	elif [ "$ESC" != "VOXL2_IO_PWM_ESC" ]; then
                	/bin/echo "Attempting to start M0065 SBUS RC driver for original M0065 FW"
                	qshell dsp_sbus start
            		retVal=$?
            		if [ $retVal -ne 0 ]; then
            	    	/bin/echo "Starting M0065 SBUS RC driver for original M0065 FW failed"
            	    	/bin/echo "Attempting to start M0065 SBUS RC driver for new M0065 FW"
            			qshell voxl2_io start -d -p 7
            		fi
            	else
                	/bin/echo "M0065 SBUS RC driver already started with PWM ESC start"
            	fi
            fi
            if [ "$DISTANCE_SENSOR" == "LIGHTWARE_SF000" ]; then
            	# Make sure to set the parameter SENS_EN_SF0X to 8 for sf000/b sensor
            	qshell lightware_laser_serial start -d 7
            fi
            if [ "$POWER_MANAGER" == "VOXLPM" ]; then
            	# APM power monitor
            	qshell voxlpm start -X -b 2
            fi
            if [ "$AIRSPEED_SENSOR" == "MS4525DO" ]; then
            	qshell ms4525do start -X -b 4
            fi
            # Optional distance sensor on spare i2c
            # qshell vl53l0x start -X -b 4
            # qshell vl53l1x start -X -b 4
            # Start all of the processing modules on DSP
            qshell sensors start
            qshell ekf2 start
            if [ "$AIRFRAME" == "FIXED_WING" ]; then
            	qshell fw_pos_control start
            	qshell fw_att_control start
            	qshell fw_rate_control start
            	qshell airspeed_selector start
            	qshell fw_autotune_attitude_control start
            	qshell land_detector start fixedwing
            elif [ $AIRFRAME = "MULTICOPTER" ]; then
            	qshell mc_pos_control start
            	qshell mc_att_control start
            	qshell mc_rate_control start
            	qshell mc_hover_thrust_estimator start
            	qshell mc_autotune_attitude_control start
            	qshell land_detector start multicopter
            fi
            qshell manual_control start
            qshell control_allocator start
            qshell load_mon start
            # Only start the rc_update module if an actual RC driver
            # is publishing input_rc topics. Otherwise for external RC
            # over Mavlink this isn't needed.
            if [ "$RC" != "EXTERNAL" ]; then
            	qshell rc_update start
            fi
            qshell commander start
            # This is needed for altitude and position hold modes
            qshell flight_mode_manager start
            # Start all of the processing modules on the applications processor
            dataman start
            navigator start
            load_mon start
            # Start microdds_client for ros2 offboard messages from agent over localhost
            microdds_client start -t udp -h 127.0.0.1 -p 8888
            # On M0052 there is only one IMU. So, PX4 needs to
            # publish IMU samples externally for VIO to use.
            	imu_server start
            fi
            # start the onboard fast link to connect to voxl-mavlink-server
            mavlink start -x -u 14556 -o 14557 -r 100000 -n lo -m onboard
            # slow down some of the fastest streams
            mavlink stream -u 14556 -s HIGHRES_IMU -r 500
            mavlink stream -u 14556 -s ATTITUDE -r 100
            mavlink stream -u 14556 -s ATTITUDE_QUATERNION -r 100
            mavlink stream -u 14556 -s GLOBAL_POSITION_INT -r 30
            mavlink stream -u 14556 -s SCALED_PRESSURE -r 10
            # Increase heartbeat rate so VFC can get faster mode updates
            mavlink stream -u 14556 -s HEARTBEAT -r 100
            # start the slow normal mode for voxl-mavlink-server to forward to GCS
            mavlink start -x -u 14558 -o 14559 -r 100000 -n lo
            mavlink boot_complete
            # Optional MSP OSD driver for DJI or HDZero goggles
            # This is only supported on M0054 (with M0125 accessory board)
            if [ "$OSD" == "ENABLE" ] || [ "$OSD" == "DJI" ]; then
                /bin/echo "Starting DJI OSD driver"
                msp_osd start -d /dev/ttyHS1
            elif [ "$PLATFORM" == "M0054" ] && [ "$OSD" == "HDZERO" ] || [ "$OSD" == "DJI_MSP_DP" ]; then
                /bin/echo "Starting $OSD OSD driver for $PLATFORM"
                msp_dp_osd start -d /dev/ttyHS1
            elif [ "$PLATFORM" == "M0104" ] && [ "$OSD" == "HDZERO" ] || [ "$OSD" == "DJI_MSP_DP" ] ; then
            	msp_dp_osd start -d /dev/ttyHS0
            fi
            # Start optional EXTRA_STEPS
            do
            	$i
            done
            if [ "$ARTIFACT_MODE" == "ENABLE" ]; then
            	# Do not start the logger module if we are in artifact mode. Logging
            	# produces a log artifact. If there are currently any saved logs make
            	# sure to delete them now.
            	# Also remove the data manager file that may have saved GPS waypoint information
            	# in it.
            	# Use shred to remove all files so that they cannot be recovered.
            	# shred should be effective on the /data partition since it has this configuration:
            	# /dev/sda8 /data ext4 rw,nosuid,nodev,noatime,discard,noauto_da_alloc,data=ordered 0 0
            	/usr/bin/find /data/px4/log -name "*.ulg" -exec /usr/bin/shred -u -n 7 {} \;
            	/bin/rm -fR /data/px4/log
            	/usr/bin/shred -u -n 7 /data/px4/dataman
                /bin/echo "Artifact mode has been enabled"
            else
            	# Start logging and use timestamps for log files when possible.
            	# Add the "-e" option to start logging immediately. Default is
            	# to log only when armed. Caution must be used with the "-e" option
            	# because if power is removed without stopping the logger gracefully then
            	# the log file may be corrupted.
            	# This is done as the last step because any topics marked as optional will only
            	# be logged if they have been advertised when this is started. By starting it last it
            	# makes sure to see those advertisements as the other modules are starting before it.
            	logger start -t
            fi
            • K KLindgren
              voxl-version
              hw platform:  M0104
              mach.var:     2.0.2
              voxl-suite:   1.5.0
              voxl-px4-start
              #!/bin/sh
              . px4-alias.sh
              echo "GPS: $GPS"
              echo "RC: $RC"
              echo "ESC: $ESC"
              echo "OSD: $OSD"
              echo "EXTRA STEPS:"
              do
              	echo -e "\t$i"
              done
                  exit 0
              fi
              RETURNCODE=$?
                      PLATFORM="M0052"
                  fi
              fi
              else
                  exit 0
              fi
              /bin/sleep 1
              param load
              else
              fi
              	else
              	    qshell gps start
              	fi
              fi
              # ESC driver
              	else
              	fi
              else
              fi
              # RC driver
              	else
              	fi
              		apps_sbus start
              		retVal=$?
              		fi
              	else
              	fi
              fi
              fi
              	# APM power monitor
              fi
              fi
              qshell ekf2 start
              fi
              fi
              dataman start
              navigator start
              load_mon start
              	imu_server start
              fi
              fi
              do
              	$i
              done
              	# in it.
              else
              	logger start -t
              fi
              @KLindgren Why do you think there are dropped messages? That is just the rate that the data is being produced within PX4. The Mavlink HIGHRES_IMU message is constructed based on the internal vehicle_imu topic which publishes at that rate. It is slower than the rate that IMU samples are being generated by the IMU driver.
                Just FYI, It is possible that messages are also getting dropped on the ROS side as well due to the fact that the publisher only has a queue size of 1 : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros/-/blob/master/catkin_ws/src/src/interfaces/imu_interface.cpp?ref_type=heads#L74.
                This has been an issue before (other users reported), but we never updated this. The fix for that should be to increase the queue size (to 10 or so).
                @KLindgren , I know you said that the issue seems to be present in the output of voxl-logger, but there could be another issue with the ROS publisher queue size.
                From the plot, it looks like the base rate of the IMU messages is 200hz (5ms dt), but there are a lot of drops, resulting in dt's > 5ms. I am not sure why, just an observation based on the plot. @Eric-Katzfey , perhaps that's due to limited buffer / bandwidth sending data from the DSP?
                  @Alex-Kushleyev If I log the vehicle_imu topic within PX4 at full rate I see exactly the same distribution of timestamps.
                    K Offline
                    K Offline
                    KLindgren
                    @Alex-Kushleyev, we thankfully came across the ROS publisher queue size limit when debugging IMU1 timing and have since increased the queue size to 25.
                    @Eric-Katzfey, is it possible to get a clean ~200 Hz sampling of data from the px4 imu/imu_mavlink? Even setting HIGHRES_IMU to the low value of 100 produces the distribution of timestamp deltas below.
                    • K KLindgren
                      @KLindgren The problem is that px4 does not generate that data at a constant rate. You can see the code here: https://github.com/modalai/px4-firmware/blob/8147a6476d78a4745058a002857aae8f1fd3b7ef/src/modules/sensors/vehicle_imu/VehicleIMU.cpp#L237. Our fork is based off of an older version of PX4. The latest PX4 code has changed in this area so it's possible it no longer does this.
                        K Offline
                        K Offline
                        KLindgren
                        @Eric-Katzfey got it, thank you for the info.
