  3. VOXL-ESC (output) + VOXL IO (output)
3 Posts 3 Posters 672 Views 2 Watching
  • V Offline
    V Offline
    valvarez
    Hello everyone.
    Is it possible to use the ESC that comes by default in the SENTINEL and at the same time the IO Board to connect a deploy servo?
    When I put ESC=VOXL_ESC in the voxl-px4.conf the motors work but not the IO Board.
    When I put ESC=VOXL2_IO_PWM_ESC the motors do not work but there is a connection with the IO Board (at least the connection).
    Is there no way to have the drone motors act through J18 on the VOXL 2 and the servos output through J19 on the IO Board?
    If it is not possible I see that the VOXL 4 in 1 ESC has a connector (J3) with PWM input and output. Is it possible to use it?
    If it is not possible either, having the SENTINEL HARDWARE, how is it possible to install a servo or any deployment device to be commanded from MAVSDK?
    First of all, I apologize for how active I have been in the forum, and I appreciate the answers you have given me, but it is a bit urgent for me and I am facing some adversities.
    Thank you so much.
    • V valvarez
      Hello everyone.
      Thank you so much.
      @valvarez This is not a configuration we have ever tried. It may work but you will need to make some changes. First of all you need to start both the ESC driver and the IO board driver and each needs to have their PX4 parameters set appropriately. In order to start both drivers you will need to modify /usr/bin/voxl-px4-start to start the drivers you need on the correct ports.
        @valvarez , i believe i have previously tried VOXL_ESC + VOXL2 IO drivers running at the same time and it worked. You just have two output interfaces that you can configure and test via GCS.
        As Eric mentioned, you just need to make sure you configure the two drivers to start together and to connect to the correct ports (and baud rates).
        Regarding outputting PWM from VOXL_ESC, there is a way to make it work. We do not have the PWM ports on the ESC exposed as normal PWM outputs in PX4, but you can use a special tool / command on voxl2, which will send message to the ESC (via PX4) and control the PWM port:
        https://gitlab.com/voxl-public/voxl-sdk/services/voxl-io-server/-/blob/master/tools/voxl-send-esc-pwm-cmd.c (which is also part of our SDK) .
        voxl2:/$ voxl-send-esc-pwm-cmd -h
        Tool to send command a VOXL ESC to make it output a PWM signal
        If timeout is disabled (default) then the esc will keep sending the same
        pwm command even after this program exits. If enabled, the signal will stop
        after 0.5s. Oneshot mode will automatically exit this program after one message
        is sent to the esc, otherwise it will keep going untill you hit ctrl-C
        ESC_PIN_M0129_AUX0           2
        ESC_PIN_M0129_AUX1         258
        ESC_PIN_M0129_AUX2         514
        ESC_PIN_M0129_AUX3         770
        ESC_PIN_M0129_AUX_REG_EN     6
        ESC_PIN_M0129_AUX_REG_ADJ   22
        ESC_PIN_M0138_VTX_REG       80
        ESC_PIN_M0138_RGB_OUT       24
        ESC_PIN_M0138_AUX0           2
        ESC_PIN_M0138_AUX1         770
        ESC_PIN_M0138_AUX_REG_EN    12
        ESC_PIN_M0138_AUX_REG_ADJ   11
        D0008_V5_LIGHT_BAR_PIN       2
        D0008_V5_PAYLOAD_PIN_0     770
        D0008_V5_PAYLOAD_PIN_1      24
        -h, --help                  print this help message
        -o, --one-shot              only send one command then quit,
                                      not to be confused with short duration 125us oneshot mode
        -p, --pin {pin}             output pin
        -t, --timeout               enable 0.5s timeout, otherwise pwm will continue indefinitely
        -w, --width {val}           pulse width microseconds (default 1500)
        typical use: voxl-send-esc-pwm-cmd -p 2 -t -w 1500
        You will need to provide the pin number. See the usage helps, which provides the pin mapping (look at pins for M0129 ESC, but pwm pins are the same on M0117, M0134 ESCs as well). For a simple test, you can use pin=2 (meaning this will control Pin A2 on ESC ID 0 🙂 ), which should control the PWM0 output on your ESC. The 4 PWM outputs on the ESC are each connected to A2 port of the corresponding microcontroller, responsible for each ESC ID. The pin mapping is also documented here : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-io-server/-/blob/master/lib/modal_io.h?ref_type=heads#L66
