  2. VOXL Dev Drones
  3. Starling & Starling 2
  4. Starling 2 Max V2; SDK 1.4.0; camera-server and VOXL-Portal
3 Posts 2 Posters 805 Views 3 Watching
  • J Offline
    J Offline
    JoeC
    Hello, Bottom Line: I was unable to access cameras in voxl-portal after a fresh flashing of SDK 1.4.0 on a new Starling 2 Max V2; required for intrinsics calibration. Further digging showed errors related to the "server disconnecting" regularly appear with 'voxl-inspect-cameras -a'. Errors are:
    ERROR in pipe_client_open opening request pipe: No such device or address
    <similar lines...>
    SKU setting is:
    family code: MRB-D0012 (starling-2-max)
    compute board: 4 (voxl2)
    hw version: 2
    cam config: 29
    modem config: 11 (Microhard v2, pMDDL2450(M0048))
    tx config: 9 (ghost)
    extras config: 0 (none)
    SKU: MRB-D0012-4-V2-C29-T9-M11-X0
    I note that using 'voxl-inspect-cam tracking_down' or other camera requests appear to work; I went up to listing 4 cameras at once. Could it be that the bus is saturated with too many cameras?
    Are there other diagnostics that can be run to nail down what's going on? The physical configuration is unchanged from a stock vehicle.
    • J JoeC
      <similar lines...>
      SKU setting is:
      hw version: 2
      cam config: 29
      Hello @JoeC , this may be related to an issue mentioned in the following thread. please take a look
      Link Preview Image
      VOXL portal wont display live camera feeds after SDK 1.4.0 upgrade
      Hi, I have the ar0144 tracking as well as the imx214 setup with VOXL 2 and they worked perfect on SDK 1.3.5 in the portal I could see there stream live. Howe...
      favicon
      ModalAI Forum (forum.modalai.com)
      J 1 Reply Last reply
        Link Preview Image
        favicon
        J Offline
        J Offline
        JoeC
        @Alex-Kushleyev Hi Alex, Thanks! Yes, that was exactly the problem. I switched to the dev branch using 'voxl-configure-pkg-config', downloaded the latest voxl-portal ('apt get update && apt install voxl-portal'), and then switched back to the 1.4.0 pkg. Voxl-Portal works just fine now.
