  2. VOXL SDK and Software
  3. px4 service issue
px4 service issue
voxl-sdk
9 Posts 4 Posters 1.7k Views 2 Watching
  • G Offline
    G Offline
    giladWDS
    I have an issue with the px4 service where the px4 service starts at stop status on the drone boot. In my short time debugging this I looked at the body of the service and I see it requires another service to end:
    [Unit]
    Description=px4
    After=sscrpcd.service
    Requires=sscrpcd.service
    [Service]
    ExecStartPre=/bin/sleep 2
    ExecStart=/usr/bin/voxl-px4
    Restart=on-failure
    [Install]
    WantedBy=multi-user.target
    but I can't find this service on the system nor can I find it online.
    Am I missing something?
    I would love some help with this.
    • G giladWDS
      [Unit]
      Description=px4
      [Service]
      Restart=on-failure
      [Install]
      @giladWDS I'm not sure I understand what you mean by "starts at stop status". Can you explain the issue? And what service can't you find? sscrpcd.service?
      voxl2:/$ sudo find . -name sscrpcd.service
      ./lib/systemd/system/multi-user.target.wants/sscrpcd.service
      ./lib/systemd/system/sscrpcd.service
      find: './sys/kernel/slab': Input/output error
      ./sys/fs/cgroup/pids/system.slice/sscrpcd.service
      ./sys/fs/cgroup/devices/system.slice/sscrpcd.service
      ./sys/fs/cgroup/systemd/system.slice/sscrpcd.service
      ./sys/fs/cgroup/unified/system.slice/sscrpcd.service
      G 1 Reply Last reply
        G Offline
        G Offline
        giladWDS
        never knew that there are services outside of /etc/systemd/system
        and systemctl status voxl-px4 gives disable. I will bring the full argument as soon as I have access to the machine
        • G giladWDS
          @giladWDS To enable it just enter systemctl enable voxl-px4
            G Offline
            G Offline
            giladWDS
            I did. The issue is that the drone is supposed to be autonomous at the end. and I would like to avoid constantly checking whether the px4 service is alive or not.
            from my understanding the service is supposed to be alive on boot so it seems to be a bag that I would want to fix.
            • G giladWDS
              @giladWDS Okay, so the issue is that the service starts but px4 is not actually running? Can you include the output of the command systemctl status -l voxl-px4? And also journalctl -b -u voxl-px4?
              ben grocholskyB 1 Reply Last reply
                ben grocholskyB Offline
                ben grocholsky
                @Eric-Katzfey I saw a similar symptom last Friday on a voxl2 that seemed to have a corrupt partition for /dev/sda8.
                Flashing to 1.3.5 wrote /data to / without sda8 mounted.
                voxl-px4 failed depending on sscrpcd.service which failed depending on data.mount
                voxl2:/$ mount /dev/disk/by-partlabel/userdata /data
                mount: /data: wrong fs type, bad option, bad superblock on /dev/sda8, missing codepage or helper program, or other error.
                voxl2:/$ fsck.ext4 /dev/sda8
                e2fsck 1.44.3 (10-July-2018)
                ext2fs_open2: Bad magic number in super-block
                fsck.ext4: Superblock invalid, trying backup blocks...
                fsck.ext4: Bad magic number in super-block while trying to open /dev/sda8
                voxl2:/$ fdisk -l |grep sda8
                The backup GPT table is corrupt, but the primary appears OK, so that will be used.
                /dev/sda8 41480 16818695 16777216 64G unknown
                Reflashing with ./install.sh --wipe-persistent fixed sda8 and made everything work.
                @giladWDS could be worth checking /dev/sda8 is being mounted as /data without any errors.
                • ben grocholskyB ben grocholsky
                  @ben-grocholsky This is very interesting, not something I've seen before. Out of curiosity what OS on your host machine are you using for the flashing process?
                    ben grocholsky
                    @tom that was from ubuntu 20.04. Looking back up the terminal history I see the install script stopped at:
                    [ERROR] missing /data/modalai/sku.txt
                    [ERROR] please run voxl-configure-sku to make a new one
                    and didn't run the next setup steps. I didn't realize the flashing failed until seeing voxl-px4 couldn't start. And digging into that found this thread.
