    gstreamer uyvy camera stream not working on voxl2
    Software Development
    • Samuel LehmanS
      Samuel Lehman
      Hello, I have been trying to use gstreamer to stream video from a usb camera that outputs uyvy but I have been unsuccessful. I am connected to the same network as the voxl2 and I am interacting with it through ssh. Running the following command
      gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=UYVY ! videoconvert ! x264enc ! rtph264pay name=pay0 ! udpsink host=192.168.0.149 port=8554
      on the voxl2 and
      gst-launch-1.0  udpsrc port=8554 caps = "application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96" ! rtph264depay ! decodebin ! videoconvert  ! autovideosink
      on my host machine results in the gstreamer on the voxl2 doing nothing and then eventually crashing.
      $ gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=UYVY ! videoconvert ! x264enc ! rtph264pay name=pay0 ! udpsink host=192.168.0.149 port=8554
      Setting pipeline to PAUSED ...
      Pipeline is live and does not need PREROLL ...
      Setting pipeline to PLAYING ...
      New clock: GstSystemClock
      Redistribute latency...
      # it waits here for some time
      ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not read from resource.
      Additional debug info:
      gstv4l2bufferpool.c(1040): gst_v4l2_buffer_pool_poll (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
      poll error 1: Invalid argument (22)
      Execution ended after 0:08:31.639262049
      Setting pipeline to READY ...
      Setting pipeline to NULL ...
      Freeing pipeline ...
      However when I run the same commands on my host machine it works. Does anyone know of a way to get this working?
      • C
        cegeyer
        Try to run this command on the VOXL-2 and see if it outputs anything when streaming from the host to make sure you actually are getting data into the VOXL:
        gst-launch-1.0 udpsrc port=8554 num-buffers=1 ! fakesink dump=true
        I also have issues with decodebin receiving an h264 stream as it uses qtivdec to decode the h264 and outputs video/x-raw(memory:GBM) which I have issues working with. You can try this pipeline to use a different decoder:
        gst-launch-1.0  udpsrc port=8554 caps = "application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96" ! rtph264depay ! h264parse ! omxh264dec ! videoconvert ! autovideosink sync=false
        Samuel LehmanS 1 Reply Last reply Reply Quote 0
        • Samuel LehmanS
          Samuel Lehman @cegeyer
          @cegeyer when streaming from the host to the voxl using the command you suggested I get
          voxl2:~$ gst-launch-1.0 udpsrc port=8554 num-buffers=1 ! fakesink dump=true
          00000000 (0x7fa0004e80): 80 60 6f 28 47 41 41 80 bc 30 17 35 09 30        .`o(GAA..0.5.0
          Got EOS from element "pipeline0".
          Execution ended after 0:00:00.034007066
          I assume this means I am able to get data into the voxl. When running the second command I get this
          voxl2:~$ gst-launch-1.0  udpsrc port=8554 caps = "application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96" ! rtph264depay ! h264parse ! omxh264dec ! videoconvert ! autovideosink sync=false
          WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0: Could not initialise Xv output
          xvimagesink.c(1773): gst_xv_image_sink_open (): /GstXvImageSink:autovideosink0-actual-sink-xvimage:
          Could not open display (null)
          ERROR: from element /GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0: GStreamer encountered a general supporting library error.
          ../../gst-omx-1.14.4/omx/gstomxvideodec.c(1819): gst_omx_video_dec_loop (): /GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0:
          OpenMAX component in error state Hardware (0x80001009)
          Execution ended after 0:00:07.897981343
          • C
            cegeyer
            How are you logged into the VOXL to get the window? I was able to get it by running ssh -X root@<VOXL IP> from a Linxu host were I was logged in with a display. I don't have any peripheral to get a display directly from the VOXL.
            You can test my method by connecting to the VOXL via ssh -X then running this gst-launch-1.0 videotestsrc ! autovideosink. You should see a window pop up with a test pattern.
            Hopefully that fixes the issue, if not, you can try to switch omxh264dec with avdec_h264 but it will then use CPU instead of GPU
              Alex Kushleyev ModalAI Team @cegeyer
              @cegeyer
              Here is a command to stream video from VOXL2 camera via ssh X forwading. FPS may be limited due to bandwidth (perhaps this is the command you meant in your reference above).
              ssh -X root@<voxl-ip>
              gst-launch-1.0 qtiqmmfsrc camera=0 ! "video/x-raw, width=1280,height=720,framerate=30/1" ! autovideoconvert ! autovideosink
              This should pop up a window with the stream from the camera. Make sure voxl-camera-server is not running if you are testing one of the mipi cameras connected to voxl2.
