  2. Software Development
  3. gstreamer uyvy camera stream not working on voxl2
Scheduled Pinned Locked Moved Software Development
5 Posts 3 Posters 3.6k Views 3 Watching
  • Samuel LehmanS Offline
    Samuel Lehman
    Hello, I have been trying to use gstreamer to stream video from a usb camera that outputs uyvy but I have been unsuccessful. I am connected to the same network as the voxl2 and I am interacting with it through ssh. Running the following command
    gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=UYVY ! videoconvert ! x264enc ! rtph264pay name=pay0 ! udpsink host=192.168.0.149 port=8554
    on the voxl2 and
    gst-launch-1.0  udpsrc port=8554 caps = "application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96" ! rtph264depay ! decodebin ! videoconvert  ! autovideosink
    on my host machine results in the gstreamer on the voxl2 doing nothing and then eventually crashing.
    $ gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=UYVY ! videoconvert ! x264enc ! rtph264pay name=pay0 ! udpsink host=192.168.0.149 port=8554
    Setting pipeline to PAUSED ...
    Pipeline is live and does not need PREROLL ...
    Setting pipeline to PLAYING ...
    New clock: GstSystemClock
    Redistribute latency...
    # it waits here for some time
    ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not read from resource.
    Additional debug info:
    gstv4l2bufferpool.c(1040): gst_v4l2_buffer_pool_poll (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
    poll error 1: Invalid argument (22)
    Execution ended after 0:08:31.639262049
    Setting pipeline to READY ...
    Setting pipeline to NULL ...
    Freeing pipeline ...
    However when I run the same commands on my host machine it works. Does anyone know of a way to get this working?
    • C Offline
      C Offline
      cegeyer
      Try to run this command on the VOXL-2 and see if it outputs anything when streaming from the host to make sure you actually are getting data into the VOXL:
      gst-launch-1.0 udpsrc port=8554 num-buffers=1 ! fakesink dump=true
      I also have issues with decodebin receiving an h264 stream as it uses qtivdec to decode the h264 and outputs video/x-raw(memory:GBM) which I have issues working with. You can try this pipeline to use a different decoder:
      gst-launch-1.0  udpsrc port=8554 caps = "application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96" ! rtph264depay ! h264parse ! omxh264dec ! videoconvert ! autovideosink sync=false
      Samuel LehmanS 1 Reply Last reply
      • C cegeyer
        Samuel Lehman
        @cegeyer when streaming from the host to the voxl using the command you suggested I get
        voxl2:~$ gst-launch-1.0 udpsrc port=8554 num-buffers=1 ! fakesink dump=true
        00000000 (0x7fa0004e80): 80 60 6f 28 47 41 41 80 bc 30 17 35 09 30        .`o(GAA..0.5.0
        Got EOS from element "pipeline0".
        Execution ended after 0:00:00.034007066
        I assume this means I am able to get data into the voxl. When running the second command I get this
        voxl2:~$ gst-launch-1.0  udpsrc port=8554 caps = "application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96" ! rtph264depay ! h264parse ! omxh264dec ! videoconvert ! autovideosink sync=false
        WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0: Could not initialise Xv output
        xvimagesink.c(1773): gst_xv_image_sink_open (): /GstXvImageSink:autovideosink0-actual-sink-xvimage:
        Could not open display (null)
        ERROR: from element /GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0: GStreamer encountered a general supporting library error.
        ../../gst-omx-1.14.4/omx/gstomxvideodec.c(1819): gst_omx_video_dec_loop (): /GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0:
        OpenMAX component in error state Hardware (0x80001009)
        Execution ended after 0:00:07.897981343
        • C Offline
          C Offline
          cegeyer
          How are you logged into the VOXL to get the window? I was able to get it by running ssh -X root@<VOXL IP> from a Linxu host were I was logged in with a display. I don't have any peripheral to get a display directly from the VOXL.
          You can test my method by connecting to the VOXL via ssh -X then running this gst-launch-1.0 videotestsrc ! autovideosink. You should see a window pop up with a test pattern.
          Hopefully that fixes the issue, if not, you can try to switch omxh264dec with avdec_h264 but it will then use CPU instead of GPU
          • C cegeyer
            @cegeyer
            Here is a command to stream video from VOXL2 camera via ssh X forwading. FPS may be limited due to bandwidth (perhaps this is the command you meant in your reference above).
            ssh -X root@<voxl-ip>
            gst-launch-1.0 qtiqmmfsrc camera=0 ! "video/x-raw, width=1280,height=720,framerate=30/1" ! autovideoconvert ! autovideosink
            This should pop up a window with the stream from the camera. Make sure voxl-camera-server is not running if you are testing one of the mipi cameras connected to voxl2.
