  3. flight core v2 compilation
14 Posts 2 Posters 1.7k Views 3 Watching
    @hockey_fan In order to build PX4 for FCv2 we build inside a nuttx docker container (px4io/px4-dev-nuttx-focal:2022-08-12), this is how we do it in CI: https://gitlab.com/voxl-public/voxl-sdk/ci-tools/-/blob/master/pipeline-configs/fc-px4.yml?ref_type=heads#L31
    H Offline
    H Offline
    hockey_fan
    @tom Thanks, I have not used docker before so I'll dive in. At the same time the instructions above are antiquated and also are pulling from a different repository than the subsequent one mentioned. Could the instructions on building flight core v2 be updated in the future to reflect using docker and the alternate repository, thanks.
    • H hockey_fan
      @hockey_fan Can you send a link to the directions you're following?
      H 1 Reply Last reply
        H Offline
        H Offline
        hockey_fan
        @tom https://docs.modalai.com/flight-core-v2-firmware/
        • H hockey_fan
          wrote on last edited by tom
          @hockey_fan Is there a specific reason you're building the flight core firmware yourself and not loading one of our prebuilt binaries?
          Since those instructions are out of date, following them will produce an out of date binary.
          The newest pre-built binary is: http://voxl-packages.modalai.com/dists/fc-v2/staging/modalai_fc-v2_1.14.0-2.0.85.px4
            H Offline
            H Offline
            hockey_fan
            @tom I need to make modifications to the code, that's why I want to build it.
            • H Offline
              H Offline
              hockey_fan
              I'm using the flight core v2 standalone board as a development platform with PX4 before moving on to the voxl2 board environment.
              • H hockey_fan
                @hockey_fan Understood, I recommend doing your development off the tip of our branch instead of modalai-1.13.3:
                https://github.com/modalai/px4-firmware/tree/voxl-dev
                  H Offline
                  H Offline
                  hockey_fan
                  @tom Shall I use the .yml file mentioned at the first comment to build flight core v2, or is there a dockerfile in the repository that will work?
                  • H Offline
                    H Offline
                    hockey_fan
                    I am still very confused on how I should build for flight core v2, and which docker file to use. Which is the git repository needed to get to the ci tools? It is not included in the regular voxl-dev repository.
                    • H hockey_fan
                      #12
                      @hockey_fan I recommend installing voxl-docker on your host machine, this will guide you through installing docker and the voxl-docker repo which makes building voxl packages easier.: https://docs.modalai.com/voxl-docker-and-cross-installation/#how-to-setup-voxl-docker-and-voxl-cross
                      Once done, you'll be able to do the following:
                      move into the px4-firmware directory
                      cd px4-firmware
                      Mount the directory into the docker container (the first time you run this it will download the px4-dev-nuttx-focal docker image to your host machine
                      voxl-docker -i px4io/px4-dev-nuttx-focal:2022-08-12
                      Once in the container:
                      make modalai_fc-v2
                      This will generate the px4 build at px4-firmware/build/modalai_fc-v2_default/modalai_fc-v2_*.px4 which can be accessed inside or outside of the container
                        cd px4-firmware
                        make modalai_fc-v2
                        H Offline
                        H Offline
                        hockey_fan
                        @tom Thanks very much, I got it working, appreciate it.
                        • H hockey_fan
                          @hockey_fan No problem, I'll update the docs page with this info, thank you for pointing this out
