  2. VOXL Dev Drones
  3. VOXL m500 Reference Drone
  4. unable to run Mavros
Scheduled Pinned Locked Moved VOXL m500 Reference Drone
4 Posts 2 Posters 1.4k Views
  • Kiazoa JoaoK Offline
    Kiazoa Joao
    I've been trying to run mavros from inside a docker container, but it does not seem to be communicating with QGC. I keep getting this error message. Can anybody please tell me what I am doing wrong? Thank you.
    ros environment.png run mavros.png voxl-mavlink-server.png voxl-vision-hub.png
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      @Kiazoa-Joao replace localhost_udp_port_number witih 14551 and then restart voxl-vision-hub service via systemctl restart voxl-vision-hub - I am not super familiar with ROS1 and the availability of master IPs and ports, but I believe your ROS_MASTER_IP is correct and your ROS_IP should also be localhost as I am assuming that 192 address is the address of your parent computer.
      Kiazoa JoaoK 2 Replies Last reply
        Kiazoa Joao
        @Zachary-Lowell-0 thank you. I'll try that and let you know if it works.
          Kiazoa Joao
          @Zachary-Lowell-0 thanks for the help. it works now, but it says "no offboard signal". do you have any idea why?
