  2. Software Development
  3. ROS
  4. ROS2 bag /qvio
ROS2 bag /qvio
Scheduled Pinned Locked Moved ROS
4 Posts 3 Posters 611 Views
  • A Offline
    Aapo_Rei
    Hi! I'm using ros2 bag for a project. For now I have successfully recevied and used Imu, image and pointcloud data. Because inaccuracy of imu I would like to use qvio data.
    Is there way of ros2 bag recording qvio?
    /qvio topic publish 2 different messages - PoseStamped and odometry I haven't found any working command for recording qvio. Is there any? I would prefer PoseStamped.
    ModeratorM 1 Reply Last reply
    • A Aapo_Rei
      @Aapo_Rei Hi Aapo, all of the source code is open so folks can extend to suit their needs. We're happy to take merge requests. You could start by looking here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2/-/blob/master/colcon_ws/src/voxl_mpa_to_ros2/src/interface_manager.cpp?ref_type=heads
      • Zachary Lowell 0Z Offline
        Zachary Lowell 0
        @Moderator said in ROS2 bag /qvio:
        @Aapo_Rei I am a bit confused by your question as qvio technically is a position in space or a combination or PoseStamped and Odometry - so what exactly are you trying to record from qvio that is not in the ros2 message?
        A 1 Reply Last reply
          Aapo_Rei
          @Zachary-Lowell-0 Thanks for the reply!
          I ment that I can't record qvio data same way as the other msgs. Trying to record qvio gives me error code like below.
          Still the data can be view like this "ros2 topic echo /qvio geometry_msgs/msg/PoseStamped" And I thought you cloud record this same data, but haven't found a way.
          My question is - is there working way to record ros2 bag for qvio and what is it? I'm asking before I start making ros2 node for that.
