  3. Gstreamer error: Streaming video to QGC over LTE
21 Posts 4 Posters 7.8k Views 1 Watching
    Hi @Rawdha-R I think there is just an interface error you are doing incorrectly with your tailscale setup.
    I am able to connect over both 4g and 5g via tailscale to both PX4 from QGC and to VLC from voxl-streamer.
    Screenshot 2024-10-07 at 3.37.19 PM.jpg Screenshot 2024-10-07 at 3.37.26 PM.jpg
    What services do you have running on your voxl2? Do you have voxl-camera-server and voxl-streamer both configured? Are both the voxl2 and the parent computer you are trying to view the stream with both on the same VPN on tailscale? Can you ping the voxl2 from the parent computer over tailscale and vice versa?
    Rawdha RR Offline
    Rawdha RR Offline
    Rawdha R
    wrote on last edited by Rawdha R
    @Zachary-Lowell-0
    @tom @groupo
    The setup is working well. I successfully pinged both the VOXL drone and the parent computer:
    Additionally, I managed to stream using MVP, and it functioned:
    As for the wwan0, I have confirmed that an IP address is displayed:
    Both voxl-streamer and voxl-camera-server is enabled and running:
    However, I'm still encountering some difficulties with streaming on VLC and QGroundControl (QGC). I've installed the necessary GStreamer dependencies, but I continue to receive errors when attempting to stream on both platforms.
    I have following the instructions in this link to install gstreamer properly:
    https://gstreamer.freedesktop.org/documentation/installing/on-linux.html?gi-language=c
    P.S: I'm using Ubuntu 22.04.5 LTS
    • Rawdha RR Rawdha R
      @Zachary-Lowell-0
      @tom @groupo
      @Rawdha-R Can you try adding tailscale0 to the top of the list in /etc/modalai/network_interface_preferences.txt and power cycling your voxl?
        @tom Like this:
        # List the order of priority of network interfaces here.
        # Top is most important
        # Bottom is least important
        tailscale0
        tun0
        eth0
        usb0
        wlan0
        wwan0
        # end
        • Zachary Lowell 0Z Offline
          Zachary Lowell 0
          @Rawdha-R please go into voxl-streamer config /etc/modalai/voxl-streamer.conf and change the auto ip to false and then change the url to match the IP address of that in your tailscale IP. I believe what is happening right now is voxl streamer might be prioritizing a different IP as Tom mentioned above.
          Zach
          Rawdha RR 1 Reply Last reply
            Zach
            Rawdha RR Offline
            Rawdha RR Offline
            Rawdha R
            @Zachary-Lowell-0 @tom
            I have configured Tailscale as a priority network:
            While setting up the voxl-streamer (located at /etc/modalai/voxl-streamer.conf) with the new URL, I noticed that the parameters auto_ip and url were missing:
            I have added both parameters, setting auto_ip to false and updating the url with the Tailscale IP address and I checked the voxl-streamer and found that the stream value is still showing as 127.0.0.1:
            After these adjustments and power cycling the device, Additionally, I attempted to check the connection in QGroundControl and VLC, but I'm encountering some errors:
              Zachary Lowell 0
              @Rawdha-R those parameters are in voxl-mavcam-manager.conf not voxl-streamer. Apologies for mispeaking. Please remove those from voxl-streamer as it is most likley causing it to crash and then restart voxl-streamer and voxl-mavcam-manager.
                Rawdha RR Offline
                Rawdha RR Offline
                Rawdha R
                @Zachary-Lowell-0
                No worries, I reverted the voxl-streamer configuration to its original settings, restarted it, then updated and restarted voxl-mavcam-manager.conf.
                Afterwards, I attempted to set the RTSP stream to the specific IP address:
                When I checked voxl-streamer, the output showed the following:
                This is the errors that I got from Qground:
                  @Zachary-Lowell-0
                  @Rawdha-R Are you able to pull up the stream in something like VLC? Trying to determine if it is indeed a QGC issue
                    Rawdha RR Offline
                    Rawdha RR Offline
                    Rawdha R
                    No, I’m not able to pull up the stream in VLC, I’m getting this error:
                      @Rawdha-R Do you have this same issue if you try to stream over just wifi with no vpn?
                      Rawdha RR 2 Replies Last reply
                        Rawdha RR Offline
                        Rawdha RR Offline
                        Rawdha R
                        I think I need a wifi dongle for it and I haven’t tried it with wifi.
                        • groupoG Offline
                          groupoG Offline
                          groupo
                          wrote on last edited by groupo
                          #18
                          I am also having issues now seeing my stream in VLC. It works as expected in QGC but I get similar errors to @Rawdha-R.
                          I had this working before in August, in fact I reverted from 13.3. to 1.3.0 just to see if that was an issue, but it persists. I will include some screenshots of my process below Screenshot from 2024-10-24 10-56-12.png
                          You can see in the next screenshot below that the video is being received by QGC
                          @tom wwan0 is in my network interface file, the default URI is set to that of the cellular modem, but of course auto_ip is set to true as well. Voxl-my-ip returns that of the cellular modem. I am a little confused though about how the config of mavcam-manager determines the behavior of voxl-streamer. In the diagram on the docs they seem decoupled.
                          I have included the verbose vlc log at the end of this file as well.
                          -- logger module started --
                          main debug: VLC media player - 3.0.16 Vetinari
                          main debug: Copyright © 1996-2021 the VideoLAN team
                          main debug: revision 3.0.13-8-g41878ff4f2
                          main debug: configured with ./configure  '--build=x86_64-linux-gnu' '--prefix=/usr' '--includedir=${prefix}/include' '--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--sysconfdir=/etc' '--localstatedir=/var' '--disable-option-checking' '--disable-silent-rules' '--libdir=${prefix}/lib/x86_64-linux-gnu' '--runstatedir=/run' '--disable-maintainer-mode' '--disable-dependency-tracking' '--disable-debug' '--config-cache' '--disable-update-check' '--enable-fast-install' '--docdir=/usr/share/doc/vlc' '--with-binary-version=3.0.16-1build7' '--enable-a52' '--enable-aa' '--enable-aribsub' '--enable-avahi' '--enable-bluray' '--enable-caca' '--enable-chromaprint' '--enable-chromecast' '--enable-dav1d' '--enable-dbus' '--enable-dca' '--enable-dvbpsi' '--enable-dvdnav' '--enable-faad' '--enable-flac' '--enable-fluidsynth' '--enable-freetype' '--enable-fribidi' '--enable-gles2' '--enable-gnutls' '--enable-harfbuzz' '--enable-jack' '--enable-kate' '--enable-libass' '--enable-libmpeg2' '--enable-libxml2' '--enable-lirc' '--enable-mad' '--enable-matroska' '--enable-mod' '--enable-mpc' '--enable-mpg123' '--enable-mtp' '--enable-ncurses' '--enable-notify' '--enable-ogg' '--enable-opus' '--enable-pulse' '--enable-qt' '--enable-realrtsp' '--enable-samplerate' '--enable-sdl-image' '--enable-sftp' '--enable-shine' '--enable-shout' '--enable-skins2' '--enable-sndio' '--enable-soxr' '--enable-spatialaudio' '--enable-speex' '--enable-svg' '--enable-svgdec' '--enable-taglib' '--enable-theora' '--enable-twolame' '--enable-upnp' '--enable-vdpau' '--enable-vnc' '--enable-vorbis' '--enable-x264' '--enable-x265' '--enable-zvbi' '--with-kde-solid=/usr/share/solid/actions/' '--disable-aom' '--disable-crystalhd' '--disable-d3d11va' '--disable-decklink' '--disable-directx' '--disable-dsm' '--disable-dxva2' '--disable-fdkaac' '--disable-fluidlite' '--disable-freerdp' '--disable-goom' '--disable-gst-decode' '--disable-libtar' '--disable-live555' '--disable-macosx' '--disable-macosx-avfoundation' '--disable-macosx-qtkit' '--disable-mfx' '--disable-microdns' '--disable-opencv' '--disable-projectm' '--disable-schroedinger' '--disable-sparkle' '--disable-srt' '--disable-telx' '--disable-vpx' '--disable-vsxu' '--disable-wasapi' '--enable-alsa' '--enable-dc1394' '--enable-dv1394' '--enable-libplacebo' '--enable-linsys' '--enable-nfs' '--enable-udev' '--enable-v4l2' '--enable-wayland' '--enable-libva' '--enable-vcd' '--enable-smbclient' '--disable-oss' '--enable-mmx' '--enable-sse' '--disable-neon' '--disable-altivec' '--disable-omxil' 'build_alias=x86_64-linux-gnu' 'CFLAGS=-g -O2 -ffile-prefix-map=/build/vlc-hoXXw1/vlc-3.0.16=. -flto=auto -ffat-lto-objects -flto=auto -ffat-lto-objects -fstack-protector-strong -Wformat -Werror=format-security ' 'LDFLAGS=-Wl,-Bsymbolic-functions -flto=auto -ffat-lto-objects -flto=auto -Wl,-z,relro -Wl,-z,now' 'CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2' 'CXXFLAGS=-g -O2 -ffile-prefix-map=/build/vlc-hoXXw1/vlc-3.0.16=. -flto=auto -ffat-lto-objects -flto=auto -ffat-lto-objects -fstack-protector-strong -Wformat -Werror=format-security ' 'OBJCFLAGS=-g -O2 -ffile-prefix-map=/build/vlc-hoXXw1/vlc-3.0.16=. -flto=auto -ffat-lto-objects -flto=auto -ffat-lto-objects -fstack-protector-strong -Wformat -Werror=format-security'
                          main debug: searching plug-in modules
                          main debug: loading plugins cache file /usr/lib/x86_64-linux-gnu/vlc/plugins/plugins.dat
                          main debug: recursively browsing `/usr/lib/x86_64-linux-gnu/vlc/plugins'
                          main debug: plug-ins loaded: 519 modules
                          main debug: opening config file (/home/welchj/.config/vlc/vlcrc)
                          main debug: looking for logger module matching "any": 4 candidates
                          file debug: opening logfile `/home/welchj/vlc-log.txt'
                          main debug: using logger module "file"
                          main debug: translation test: code is "C"
                          main debug: looking for keystore module matching "memory": 4 candidates
                          main debug: using keystore module "memory"
                          main debug: CPU has capabilities MMX MMXEXT SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 AVX AVX2 FPU
                          main debug: Creating an input for 'Media Library'
                          main debug: Input is a meta file: disabling unneeded options
                          main debug: using timeshift granularity of 50 MiB
                          main debug: using default timeshift path
                          main debug: `file/directory:///home/welchj/.local/share/vlc/ml.xspf' gives access `file' demux `directory' path `/home/welchj/.local/share/vlc/ml.xspf'
                          main debug: creating demux: access='file' demux='directory' location='/home/welchj/.local/share/vlc/ml.xspf' file='/home/welchj/.local/share/vlc/ml.xspf'
                          main debug: looking for access_demux module matching "file": 18 candidates
                          main debug: no access_demux modules matched
                          main debug: creating access: file:///home/welchj/.local/share/vlc/ml.xspf
                          main debug:  (path: /home/welchj/.local/share/vlc/ml.xspf)
                          main debug: looking for access module matching "file": 29 candidates
                          main debug: using access module "filesystem"
                          main debug: looking for stream_filter module matching "prefetch,cache_read": 26 candidates
                          cache_read debug: Using stream method for AStream*
                          cache_read debug: starting pre-buffering
                          cache_read debug: received first data after 0 ms
                          cache_read debug: pre-buffering done 296 bytes in 0s - 13139 KiB/s
                          main debug: using stream_filter module "cache_read"
                          main debug: looking for stream_filter module matching "any": 26 candidates
                          playlist debug: using XSPF playlist reader
                          main debug: using stream_filter module "playlist"
                          main debug: stream filter added to 0x5abe03deb8d0
                          main debug: no stream_filter modules matched
                          main debug: looking for stream_directory module matching "any": 1 candidates
                          main debug: no stream_directory modules matched
                          main debug: attachment of directory-extractor failed for file:///home/welchj/.local/share/vlc/ml.xspf
                          main debug: looking for stream_filter module matching "record": 26 candidates
                          main debug: using stream_filter module "record"
                          main debug: looking for demux module matching "directory": 54 candidates
                          main debug: using demux module "directory"
                          main debug: looking for meta reader module matching "any": 2 candidates
                          lua debug: Trying Lua scripts in /home/welchj/.local/share/vlc/lua/meta/reader
                          lua debug: Trying Lua scripts in /usr/lib/x86_64-linux-gnu/vlc/lua/meta/reader
                          lua debug: Trying Lua playlist script /usr/lib/x86_64-linux-gnu/vlc/lua/meta/reader/filename.luac
                          lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
                          main debug: no meta reader modules matched
                          main debug: `file/directory:///home/welchj/.local/share/vlc/ml.xspf' successfully opened
                          main debug: looking for xml reader module matching "any": 1 candidates
                          main debug: using xml reader module "xml"
                          main debug: EOF reached
                          main debug: removing module "directory"
                          main debug: removing module "record"
                          main debug: removing module "playlist"
                          main debug: removing module "cache_read"
                          main debug: removing module "filesystem"
                          main debug: creating audio output
                          main debug: looking for audio output module matching "any": 6 candidates
                          vlcpulse debug: using library version 15.99.0
                          vlcpulse debug:  (compiled with version 15.99.0, protocol 35)
                          vlcpulse debug: connected locally to /run/user/1004/pulse/native as client #23
                          vlcpulse debug: using protocol 35, server protocol 35
                          pulse debug: adding sink 1: alsa_output.pci-0000_00_1f.3.analog-stereo (Built-in Audio Analog Stereo)
                          main debug: using audio output module "pulse"
                          main debug: keeping audio output
                          main debug: looking for interface module matching "dbus,none": 19 candidates
                          dbus debug: listening on dbus as: org.mpris.MediaPlayer2.vlc
                          main debug: using interface module "dbus"
                          main debug: looking for interface module matching "hotkeys,none": 19 candidates
                          main debug: using interface module "hotkeys"
                          main debug: looking for interface module matching "globalhotkeys,none": 19 candidates
                          main debug: using interface module "xcb_hotkeys"
                          main: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
                          main debug: looking for interface module matching "any": 19 candidates
                          dbus debug: Getting All properties
                          main debug: looking for extension module matching "any": 1 candidates
                          lua debug: Opening Lua Extension module
                          lua debug: Trying Lua scripts in /home/welchj/.local/share/vlc/lua/extensions
                          lua debug: Trying Lua scripts in /usr/lib/x86_64-linux-gnu/vlc/lua/extensions
                          lua debug: Trying Lua playlist script /usr/lib/x86_64-linux-gnu/vlc/lua/extensions/VLSub.luac
                          lua debug: Scanning Lua script /usr/lib/x86_64-linux-gnu/vlc/lua/extensions/VLSub.luac
                          lua debug: Script /usr/lib/x86_64-linux-gnu/vlc/lua/extensions/VLSub.luac has the following capability flags: 0x5
                          lua debug: Trying Lua scripts in /usr/share/vlc/lua/extensions
                          main debug: using extension module "lua"
                          main debug: using interface module "qt"
                          main: playlist is empty
                          main debug: nothing to play
                          main debug: processing request item: rtsp://10.0.1.1:8900/live, node: Playlist, skip: 0
                          main debug: rebuilding array of current - root Playlist
                          main debug: rebuild done - 1 items, index 0
                          main debug: starting playback of new item
                          main debug: resyncing on rtsp://10.0.1.1:8900/live
                          main debug: rtsp://10.0.1.1:8900/live is at 0
                          main debug: creating new input thread
                          main debug: Creating an input for 'rtsp://10.0.1.1:8900/live'
                          main debug: requesting art for new input thread
                          main debug: `rtsp://10.0.1.1:8900/live' gives access `rtsp' demux `any' path `10.0.1.1:8900/live'
                          main debug: creating demux: access='rtsp' demux='any' location='10.0.1.1:8900/live' file='(null)'
                          main debug: looking for access_demux module matching "rtsp": 18 candidates
                          main debug: creating access: rtsp://10.0.1.1:8900/live
                          main debug: looking for access module matching "rtsp": 29 candidates
                          main debug: looking for meta fetcher module matching "any": 1 candidates
                          lua debug: Trying Lua scripts in /home/welchj/.local/share/vlc/lua/meta/fetcher
                          lua debug: Trying Lua scripts in /usr/lib/x86_64-linux-gnu/vlc/lua/meta/fetcher
                          lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/fetcher
                          main debug: no meta fetcher modules matched
                          main debug: looking for art finder module matching "any": 2 candidates
                          satip debug: try to open 'rtsp://10.0.1.1:8900/live'
                          satip debug: connect to host '10.0.1.1'
                          main debug: net: connecting to 10.0.1.1 port 8900
                          lua debug: Trying Lua scripts in /home/welchj/.local/share/vlc/lua/meta/art
                          lua debug: Trying Lua scripts in /usr/lib/x86_64-linux-gnu/vlc/lua/meta/art
                          lua debug: Trying Lua playlist script /usr/lib/x86_64-linux-gnu/vlc/lua/meta/art/00_musicbrainz.luac
                          lua debug: skipping script (unmatched scope) /usr/lib/x86_64-linux-gnu/vlc/lua/meta/art/00_musicbrainz.luac
                          lua debug: Trying Lua playlist script /usr/lib/x86_64-linux-gnu/vlc/lua/meta/art/01_googleimage.luac
                          lua debug: skipping script (unmatched scope) /usr/lib/x86_64-linux-gnu/vlc/lua/meta/art/01_googleimage.luac
                          lua debug: Trying Lua playlist script /usr/lib/x86_64-linux-gnu/vlc/lua/meta/art/02_frenchtv.luac
                          lua debug: skipping script (unmatched scope) /usr/lib/x86_64-linux-gnu/vlc/lua/meta/art/02_frenchtv.luac
                          lua debug: Trying Lua playlist script /usr/lib/x86_64-linux-gnu/vlc/lua/meta/art/03_lastfm.luac
                          lua debug: skipping script (unmatched scope) /usr/lib/x86_64-linux-gnu/vlc/lua/meta/art/03_lastfm.luac
                          lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/art
                          main debug: no art finder modules matched
                          main debug: connection succeeded (socket = 45)
                          main debug: net: opening 0.0.0.0 datagram port 9322
                          main debug: net: opening 0.0.0.0 datagram port 9323
                          qt debug: IM: Setting an input
                          satip error: Failed to play RTSP session
                          satip error: Failed to teardown RTSP session
                          main debug: connection succeeded (socket = 44)
                          access_realrtsp warning: Cseq mismatch, got 1, assumed 0
                          access_realrtsp debug: rtsp connected
                          access_realrtsp warning: only real/helix rtsp servers supported for now
                          main debug: no access modules matched
                          main debug: dead input
                          qt debug: IM: Deleting the input
                          main debug: changing item without a request (current 0/1)
                          main debug: rebuild done - 2 items, index 1
                          main debug: rtsp://10.0.1.1:8900/live is at 1
                          main error: connection failed: Connection refused
                          satip error: Failed to connect to RTSP server 10.0.1.1:8900
                          access_realrtsp error: cannot connect to 10.0.1.1:8900
                          access_realrtsp debug: could not connect to: 10.0.1.1:8900/live
                          main debug: changing item without a request (current 1/2)
                          • groupoG Offline
                            groupoG Offline
                            groupo
                            @Rawdha-R @tom
                            SO, I used ffplay and was able to see the stream successfully. A quick google about vlc/rtsp brought up many issues in the community after some recent updates. I am not sure how I was able to do this before and cannot now, but I did find a fix for windows
                            https://www.reddit.com/r/reolink/comments/yzhlxp/found_a_solution_for_rtsp_blackno_video_in_vlc/#:~:text=In VLC%2C under the Tools,video stream in VLC player.
                            In case that link is ever deleted, I will paste the instructions here
                            "In VLC, under the Tools menu, go to Preferences (or Ctrl+p), open the Input/Codecs tab, and at the bottom in the Network area, the selection for "live555 stream transport" should be moved from "HTTP (default)" to "RTP over RTSP (TCP)". This worked, I can now view the video stream in VLC player."
                            This resolves the RTSP stream for windows. Those config options are not available in the linux version of VLC but I did see some config options you can build VLC with. I did not venture too far down that path
                              Rawdha RR Offline
                              Rawdha RR Offline
                              Rawdha R
                              #20
                              The issue still persists for me. Do you think my setup could be causing the problem? I have an M1 Mac processor, and I'm using a virtual machine with UTM(Visualizer). Could that be causing any limitations? Should I try a different setup, and do you have any recommendations?
                                Rawdha RR Offline
                                Rawdha RR Offline
                                Rawdha R
                                P.S. I am currently working with the Drone Sentinel VOXL 2 and the drone is connected via LTE but without Wi-Fi, because there is no wifi dongle.
