  4. Qualcomm Flight RB5 stuck in fastboot
10 Posts 3 Posters 1.5k Views 2 Watching
  • R Offline
    R Offline
    royb
    Hi devs, I've been working with the Qualcomm Flight RB5 drone (with VOXL SDK) for a few weeks, but it has suddenly given out. I suspect it may have been due to overheating, but am not entirely sure.
    Since then it seems to always be stuck in fastboot. To rule out the influence of the peripheral boards, I've extracted the Qualcomm Flight RB5 mainboard and Thundercomm RB5 SOM from the drone, but with the same result. Finally, I followed the "Unbricking your VOXL 2" instructions in the docs, for which I used the "RB5 Flight QDL Image 9.1_QUP10" image. After successfully flashing the hardware and rebooting, the system still gets stuck in fastboot. In particular, lsusb lists the board as:
    Bus 004 Device 118: ID 18d1:d00d Google Inc. Xiaomi Mi/Redmi 2 (fastboot)
    And fastboot devices lists the board as:
    ffbb5e0c	fastboot
    Finally, after flashing it, I can visually see the board rebooting 7 times on startup. This seems to be in line with the slot-retry-count:b value when running fastboot getvar all:
    (bootloader) parallel-download-flash:yes
    (bootloader) hw-revision:20001
    (bootloader) unlocked:yes
    (bootloader) off-mode-charge:0
    (bootloader) charger-screen-enabled:0
    (bootloader) battery-soc-ok:yes
    (bootloader) battery-voltage:3832
    (bootloader) version-baseband:
    (bootloader) version-bootloader:
    (bootloader) erase-block-size: 0x1000
    (bootloader) logical-block-size: 0x1000
    (bootloader) variant:QRB UFS
    (bootloader) partition-type:mdm1m9kefsc:raw
    (bootloader) partition-size:mdm1m9kefsc: 0x1000
    (bootloader) partition-type:ssd:raw
    (bootloader) partition-size:ssd: 0x2000
    (bootloader) has-slot:modem:yes
    (bootloader) has-slot:system:no
    (bootloader) current-slot:a
    (bootloader) has-slot:boot:yes
    (bootloader) slot-retry-count:b:7
    (bootloader) slot-unbootable:b:no
    (bootloader) slot-successful:b:no
    (bootloader) slot-retry-count:a:0
    (bootloader) slot-unbootable:a:yes
    (bootloader) slot-successful:a:no
    (bootloader) slot-count:2
    (bootloader) secure:no
    (bootloader) serialno:ffbb5e0c
    (bootloader) product:
    (bootloader) max-download-size:805306368
    (bootloader) kernel:uefi
    Does anyone have any other ideas on what to try?
    VinnyV 1 Reply Last reply
    • R royb
      ffbb5e0c	fastboot
      Hi @royb
      We've never seen any of our devices show us as "Bus 004 Device 118: ID 18d1:d00d Google Inc. Xiaomi Mi/Redmi 2 (fastboot)"
      That is either a serious corruption of the flash, or some wrong files are being loaded up during the unbricking.
      Can you please double check your unbricking procedure and be sure to follow everything step-by-step?
      https://docs.modalai.com/Qualcomm-Flight-RB5-QDL/
      R 1 Reply Last reply
      • VinnyV Vinny
        Hi @royb
        R Offline
        R Offline
        royb
        Hi @Vinny, I just closely followed the instructions you referenced, but with the same result.
        I'm using the exact same (latest) QDL image as in the instructions, which gets flashed successfully. After reboot, it still shows up as ID 18d1:d00d Google Inc. Xiaomi Mi/Redmi 2 (fastboot) however. I nevertheless went on to flash the RB5 SDK 1.1.2, which also seems to successfully finish, but after rebooting it still won't get out of fastboot.
        Is there some way to check if the flashed QDL image on the device is corrupted? And are there any other options?
        • R royb
          HI @royb
          Need to pull in someone from software here, I was just trying to ensure the basics were covered. Seems like you had that verified.
          • VinnyV Vinny
            HI @royb
            R Offline
            R Offline
            royb
            Hi @Vinny and @tom, do you have any updates on this problem by any chance?
            • R royb
              @royb Just to confirm, you've already run through the unbricking process using the QDL program?
                R Offline
                R Offline
                royb
                Hi @tom,
                Yes that's right. I followed the instructions linked by @Vinny and used the QDL image for the Qualcomm Flight RB5 with the name "RB5 Flight QDL Image 9.1_QUP10" from the developer.modalai.com repository. Is this indeed the right image? Or do I need the "VOXL2 QDL Image 14.1a_1.7.8" image by any chance?
                Following those instructions, the result is as I described in my earlier comments.
                • R royb
                  Hi @tom,
                  wrote on last edited by tom
                  @royb You used the correct one.
                  I think you've followed the exact process I would've recommended. Unfortunately I don't have any further debugging steps to suggest and I would recommend filing an RMA for this drone: https://www.modalai.com/pages/rma
                    R Offline
                    R Offline
                    royb
                    Hi @tom,
                    Thanks for looking into this.
                    Do you think this is just something to do with the Thundercomm C5165 SOM or may it be affected by the Flight RB5 mainboard? So if I were to switch out the current SOM for a new one, should it be fixed?
                    • R royb
                      Hi @tom,
                      @royb If you have another SOM sitting around it wouldn't hurt to try
