  2. Software Development
  3. ROS
  4. Unable to build ROS python workspace on the RB5 drone
Scheduled Pinned Locked Moved ROS
rosrb5
3 Posts 2 Posters 1.6k Views 1 Watching
  • P Offline
    P Offline
    Prabhav Gupta
    I am working on a RB5 Drone. I had setup a Python ROS workspace (ROS Melodic) and it was working okay up until a few days ago.
    I had to upgrade the SDK on the drone to the latest available. After that, I have been facing issues with building the workspace.
    This is the error I am facing while running catkin build:
    rb5:~/python_ws$ catkin build obj_det
    /bin/sh: /home/root/python_ws/install/env.sh: Permission denied
    WARNING: Sourced environment from `/home/root/python_ws/install/env.sh` has no environment variables. Something is wrong.
    Profile:                     default
    Extending:             [env] /home/root/catkin_ws/devel:/opt/ros/melodic
    Workspace:                   /home/root/python_ws
    Build Space:        [exists] /home/root/python_ws/build
    Devel Space:        [exists] /home/root/python_ws/devel
    Install Space:      [exists] /home/root/python_ws/install
    Log Space:          [exists] /home/root/python_ws/logs
    Source Space:       [exists] /home/root/python_ws/src
    DESTDIR:            [unused] None
    Devel Space Layout:          linked
    Install Space Layout:        merged
    Additional CMake Args:       -DPYTHON_EXECUTABLE=/usr/bin/python3 -DPYTHON_INCLUDE_DIR=/usr/include/python3.6m -DPYTHON_LIBRARY=/usr/lib/aarch64-linux-gnu/libpython3.6m.so
    Additional Make Args:        None
    Additional catkin Make Args: None
    Internal Make Job Server:    True
    Cache Job Environments:      False
    Whitelisted Packages:        None
    Blacklisted Packages:        None
    Workspace configuration appears valid.
    [build] Found '5' packages in 0.0 seconds.
    Starting  >>> cv_bridge
    _________________________________________________________________________________________________________
    Errors     << cv_bridge:check /home/root/python_ws/logs/cv_bridge/build.check.019.log
    CMake Warning at /usr/share/cmake-3.10/Modules/FindBoost.cmake:1626 (message):
      No header defined for python3; skipping header check
    Call Stack (most recent call first):
      CMakeLists.txt:11 (find_package)
    CMake Error at /home/root/python_ws/src/vision_opencv/cv_bridge/CMakeLists.txt:16 (find_package):
      Could not find a package configuration file provided by "OpenCV" (requested
      version 3) with any of the following names:
        OpenCVConfig.cmake
        opencv-config.cmake
      Add the installation prefix of "OpenCV" to CMAKE_PREFIX_PATH or set
      "OpenCV_DIR" to a directory containing one of the above files.  If "OpenCV"
      provides a separate development package or SDK, be sure it has been
      installed.
    make: *** [cmake_check_build_system] Error 1
    cd /home/root/python_ws/build/cv_bridge; catkin build --get-env cv_bridge | catkin env -si  /usr/bin/make cmake_check_build_system; cd -
    Failed     << cv_bridge:check          [ Exited with code 2 ]
    Failed    <<< cv_bridge                [ 1.5 seconds ]
    Abandoned <<< obj_det                  [ Unrelated job failed ]
    [build] Summary: 0 of 2 packages succeeded.
    [build]   Ignored:   3 packages were skipped or are blacklisted.
    [build]   Warnings:  None.
    [build]   Abandoned: 1 packages were abandoned.
    [build]   Failed:    1 packages failed.
    [build] Runtime: 1.6 seconds total.
    I set this workspace up by following this tutorial on the web: https://medium.com/@beta_b0t/how-to-setup-ros-with-python-3-44a69ca36674
    Any suggestions on what is going wrong here?
    Thanks a lot!
    • P Prabhav Gupta
      Profile:                     default
          OpenCVConfig.cmake
          opencv-config.cmake
        installed.
      Thanks a lot!
      Eric KatzfeyE Online
      @Prabhav-Gupta said in Unable to build ROS python workspace on the RB5 drone:
      This error looks suspicious. Does that file exist? Does it have execute permissions set on it?
      P 1 Reply Last reply
        P Offline
        P Offline
        Prabhav Gupta
        I had backed up my ROS workspace using adb pull before flashing the drone and used adb push to reinstate my workspace on the drone. This unfortunately changed up the file permissions for the folders within the workspace.
        I was able to fix this by deleting (using rm -rf) all folders within my ROS workspace except the src (which contains the packages I was working on) and building the packages again.
        I was then faced with the other CMake error visible above -
        OpenCVConfig.cmake
        opencv-config.cmake
        I fixed this by building opencv from source on the drone (following this - https://docs.opencv.org/4.x/d7/d9f/tutorial_linux_install.html)
        After installing opencv, the catrkin build did not return any errors at the time. I do need to check whether my ROS Nodes are working as expected or not. Will update here once I do the same.
        Thank you for your time!
