    Unable to build ROS python workspace on the RB5 drone
    ROS
    ros rb5
    • P
      Prabhav Gupta
      I am working on a RB5 Drone. I had setup a Python ROS workspace (ROS Melodic) and it was working okay up until a few days ago.
      I had to upgrade the SDK on the drone to the latest available. After that, I have been facing issues with building the workspace.
      This is the error I am facing while running catkin build:
      rb5:~/python_ws$ catkin build obj_det
      /bin/sh: /home/root/python_ws/install/env.sh: Permission denied
      WARNING: Sourced environment from `/home/root/python_ws/install/env.sh` has no environment variables. Something is wrong.
      Profile:                     default
      Extending:             [env] /home/root/catkin_ws/devel:/opt/ros/melodic
      Workspace:                   /home/root/python_ws
      Build Space:        [exists] /home/root/python_ws/build
      Devel Space:        [exists] /home/root/python_ws/devel
      Install Space:      [exists] /home/root/python_ws/install
      Log Space:          [exists] /home/root/python_ws/logs
      Source Space:       [exists] /home/root/python_ws/src
      DESTDIR:            [unused] None
      Devel Space Layout:          linked
      Install Space Layout:        merged
      Additional CMake Args:       -DPYTHON_EXECUTABLE=/usr/bin/python3 -DPYTHON_INCLUDE_DIR=/usr/include/python3.6m -DPYTHON_LIBRARY=/usr/lib/aarch64-linux-gnu/libpython3.6m.so
      Additional Make Args:        None
      Additional catkin Make Args: None
      Internal Make Job Server:    True
      Cache Job Environments:      False
      Whitelisted Packages:        None
      Blacklisted Packages:        None
      Workspace configuration appears valid.
      [build] Found '5' packages in 0.0 seconds.
      Starting  >>> cv_bridge
      _________________________________________________________________________________________________________
      Errors     << cv_bridge:check /home/root/python_ws/logs/cv_bridge/build.check.019.log
      CMake Warning at /usr/share/cmake-3.10/Modules/FindBoost.cmake:1626 (message):
        No header defined for python3; skipping header check
      Call Stack (most recent call first):
        CMakeLists.txt:11 (find_package)
      CMake Error at /home/root/python_ws/src/vision_opencv/cv_bridge/CMakeLists.txt:16 (find_package):
        Could not find a package configuration file provided by "OpenCV" (requested
        version 3) with any of the following names:
          OpenCVConfig.cmake
          opencv-config.cmake
        Add the installation prefix of "OpenCV" to CMAKE_PREFIX_PATH or set
        "OpenCV_DIR" to a directory containing one of the above files.  If "OpenCV"
        provides a separate development package or SDK, be sure it has been
        installed.
      make: *** [cmake_check_build_system] Error 1
      cd /home/root/python_ws/build/cv_bridge; catkin build --get-env cv_bridge | catkin env -si  /usr/bin/make cmake_check_build_system; cd -
      Failed     << cv_bridge:check          [ Exited with code 2 ]
      Failed    <<< cv_bridge                [ 1.5 seconds ]
      Abandoned <<< obj_det                  [ Unrelated job failed ]
      [build] Summary: 0 of 2 packages succeeded.
      [build]   Ignored:   3 packages were skipped or are blacklisted.
      [build]   Warnings:  None.
      [build]   Abandoned: 1 packages were abandoned.
      [build]   Failed:    1 packages failed.
      [build] Runtime: 1.6 seconds total.
      I set this workspace up by following this tutorial on the web: https://medium.com/@beta_b0t/how-to-setup-ros-with-python-3-44a69ca36674
      Any suggestions on what is going wrong here?
      Thanks a lot!
        Eric Katzfey ModalAI Team @Prabhav Gupta
        @Prabhav-Gupta said in Unable to build ROS python workspace on the RB5 drone:
        This error looks suspicious. Does that file exist? Does it have execute permissions set on it?
        P 1 Reply Last reply Reply Quote 0
        • P
          Prabhav Gupta @Eric Katzfey
          I had backed up my ROS workspace using adb pull before flashing the drone and used adb push to reinstate my workspace on the drone. This unfortunately changed up the file permissions for the folders within the workspace.
          I was able to fix this by deleting (using rm -rf) all folders within my ROS workspace except the src (which contains the packages I was working on) and building the packages again.
          I was then faced with the other CMake error visible above -
          OpenCVConfig.cmake
          opencv-config.cmake
          I fixed this by building opencv from source on the drone (following this - https://docs.opencv.org/4.x/d7/d9f/tutorial_linux_install.html)
          After installing opencv, the catrkin build did not return any errors at the time. I do need to check whether my ROS Nodes are working as expected or not. Will update here once I do the same.
          Thank you for your time!
