    voxl-camera-server more exif metadata bugs
    VOXL SDK
    930
    • A
      AndriiHlyvko
      Hi, I wound more bugs in the voxl-camera-server. The final jpeg images that are captured using the snapshot command contain two APP1 Exif sections instead of one. This is essentially because the ProcessSnapshotFrame function incorrectly processes the jpeg metadata (do binary header inspection of the snapshots to see the double APP1 headers). Anyway I am currently working on a bug fix for that. I was wondering if anyone could point me to some information on how the jpeg data actually gets piped into the voxl-camera-server. I found that its using some android "hardware" libraries to set up frame callbacks. So I am wondering if I can just get to raw image data instead of messing with moving around jpeg data.
      Thanks.
      Best, Andrii.
      • Zachary Lowell 0Z
        Zachary Lowell 0 ModalAI Team
        Hi @AndriiHlyvko we do not ever pipe in a JPG - the raw frame gets converted and saved as a jpeg in camera-server.
        The android library does the image encoding to JPG from the raw frame. We pull the raw frame over the snapshot pipe via HAL3 and then we do the JPG conversion from the raw pipe.
        https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blame/dev/src/hal3_camera_mgr.cpp?ref_type=heads#L281 --> Here is where the buffers get allocated
        https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/dev/src/hal3_camera_mgr.cpp?ref_type=heads#L433 --> Here is where we define the parameters of the HAL3 pipe itself that is pulling the raw frames
        https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/dev/src/hal3_camera_mgr.cpp?ref_type=heads#L2585 --> This is where the MPA is created to actually pipe the data, etc.
        Specific to the actual jpg conversion, you are right in that it is abstracted out and we leverage an android library to handle the encoding into JPG, we just calculate the size of the frame and then feed that INTO the jpeg conversion - so the raw frame should be completely accessible to you.
        https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/dev/src/hal3_camera_mgr.cpp?ref_type=heads#L1649 --> if you follow the meta and src_data parameter here, you will see where the raw data is coming in. We do leverage the libexif library after the encoding to unpack it and update the gps data as well - that can be found here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/dev/src/hal3_camera_mgr.cpp?ref_type=heads#L1483
        Let me know if this helps!!
        Zach
        • A
          AndriiHlyvko @Zachary Lowell 0
          @Zachary-Lowell-0 thanks!
          Just to give some context. I am trying to change the camera focal length in the exif data of the jpeg. But because somehow there are two Exif blocks in the jpeg only one is changes and not the other. There should only be one exif data block in the jpeg.
          Here is an example output of the exiftool
          • Zachary Lowell 0Z
            @AndriiHlyvko said in voxl-camera-server more exif metadata bugs:
            Hm that is quite strange - I will do soem debugging - it could be that we are creating a new exif dataset to attach to the jpeg instead of filling the original. Will look more into it while you do as well! Let me know if you figure it out and I will do the same on the post here.
            A 2 Replies Last reply Reply Quote 0
            • A
              @Zachary-Lowell-0 what I did find out is that inside ProcessSnapshotFrame the second Exif block gets created by createExifData and written to the image. This is because the jpeg did contain an exif block (I assume it was created by the android library).
              The correct approach is to edit the already created exif block inside the jpeg. Also the find_jpeg_buffer function is wrong. I assume it tried to look for the start of the jpeg stream but it instead is looking for the SOI marker. The SOI marker and the start of the data section are not the same. The SOI actually marks the file itself as a jpeg type.
              • A
                AndriiHlyvko @AndriiHlyvko
                @AndriiHlyvko an example of jpeg image structure:
                FFD8 (SOI)
                ...  (optional markers like APP0/APP1)
                FFDB (DQT)
                FFC2 (SOF0)  // Progressive DCT
                FFC4 (DHT) // huffman table
                FFDA (SOS)   // First scan
                ...  (compressed image data for first scan)
                FFDA (SOS)   // Second scan
                ...  (compressed image data for second scan)
                FFD9 (EOI)
                • A
                  @Zachary-Lowell-0 I managed to fix the code. Essentially I was updating the already existing jpeg exif block. Here is my solution. Its a little messy cuz I haven't had the time to clean it up. But I tested and it works.
                  Would you guys be interested in pulling in my changes?
                  // Function to create a new tag or update an existing one
                  static ExifEntry* create_or_update_tag(ExifData* exif, ExifIfd ifd, ExifTag tag, ExifFormat fmt, unsigned int size, unsigned int components) {
                      ExifEntry* entry = exif_content_get_entry(exif->ifd[ifd], tag);
                      if (!entry) {
                          // Create a new entry if it doesn't exist
                          printf("Creating entry: %d\n", (int)tag);
                          //entry = exif_entry_new();
                          entry = create_tag(exif, ifd, tag, size);
                          entry->tag = tag;
                          entry->components = components;
                          entry->format = fmt;
                          ///entry->data = (unsigned char*)malloc(size);
                          //exif_content_add_entry(exif->ifd[ifd], entry);
                          ///exif_entry_unref(entry);
                      } else {
                          // Update the existing entry
                          if (entry->size < size) {
                              // If the existing entry size is insufficient, reallocate memory
                              entry->data = (unsigned char*)realloc(entry->data, size);
                              entry->size = size;
                      return entry;
                  void PerCameraMgr::ProcessSnapshotFrame(image_result result)
                      BufferBlock* bufferBlockInfo = bufferGetBufferInfo(&snap_bufferGroup, result.second.buffer);
                      // first write to pipe if subscribed
                      camera_image_metadata_t meta;
                      if(getMeta(result.first, &meta)) {
                          M_WARN("Trying to process encode buffer without metadata\n");
                          return;
                      int start_index = 0;
                      //int start_index2 = 0;
                      uint8_t* src_data = (uint8_t*)bufferBlockInfo->vaddress;
                      //int extractJpgSize = bufferBlockInfo->size;
                      int extractJpgSize = find_jpeg_buffer_size(src_data, bufferBlockInfo->size, &start_index);
                      assert(start_index == 0);
                      //int _extractJpgSize = find_jpeg_buffer(src_data, bufferBlockInfo->size, &start_index2);
                      // find APP1 block start and length
                      size_t prev_exif_block_start_idx = 0;
                      size_t prev_exif_block_size = find_exif_start(src_data, bufferBlockInfo->size, &prev_exif_block_start_idx);
                      if(extractJpgSize == 1){
                          M_ERROR("Real Size of JPEG is incorrect");
                          return;
                      printf("Snapshot jpeg start: %6d len %8d\n", start_index, extractJpgSize);
                  #ifndef APQ8096
                      // Load the EXIF data from the file
                      unsigned char *exif_data;
                      unsigned int exif_data_len;
                      ExifEntry *entry;
                      // can create exif data from raw jpeg image
                      ExifData* exif = exif_data_new_from_data(src_data, extractJpgSize);
                      //ExifData *exif = createExifData();
                      if (exif == nullptr) {
                          printf("Issue getting exif data from origin\n");
                          return;
                      exif_data_fix(exif);
                      //printf("Exif data before mods\n");
                      //exif_data_dump(exif);
                      //printf("End Exif data before mods\n");
                       * @brief Good description of exif format https://www.media.mit.edu/pia/Research/deepview/exif.html
                      ExifByteOrder imageByteOrder = exif_data_get_byte_order(exif); /**< Each camera saves its Exif data in a different byte order */
                      //gps_data_t gps_grabbed_info = grab_gps_info();
                      // Code to add latitude to exif tag
                      entry = create_or_update_tag(exif, EXIF_IFD_GPS, (ExifTag)EXIF_TAG_GPS_LATITUDE_REF, (ExifFormat)EXIF_FORMAT_ASCII, 2*sizeof(char), 1);
                      if (_uav_state.lat_deg >= 0) {
                          memcpy(entry->data, "N", sizeof(char));
                      } else {
                          memcpy(entry->data, "S", sizeof(char));
                          _uav_state.lat_deg *= -1;
                      entry = create_or_update_tag(exif, EXIF_IFD_GPS, (ExifTag)EXIF_TAG_GPS_LATITUDE, (ExifFormat)EXIF_FORMAT_RATIONAL, 3*sizeof(ExifRational), 3);
                      ExifLong degrees_lat = static_cast<ExifLong>(_uav_state.lat_deg);
                      double fractional = (_uav_state.lat_deg - degrees_lat);
                      ExifLong minutes_lat = static_cast<ExifLong>(fractional*60);
                      fractional = (fractional*60) - minutes_lat;
                      double seconds_lat = (fractional * 60);
                      ExifRational degrees_r = { degrees_lat, 1 };
                      ExifRational minutes_r = { minutes_lat, 1 };
                      ExifRational seconds_r = { static_cast<ExifLong>(seconds_lat * 1000000), 1000000 }; // Increased precision for seconds
                      exif_set_rational(entry->data, imageByteOrder, degrees_r);
                      exif_set_rational(entry->data + sizeof(ExifRational), imageByteOrder, minutes_r);
                      exif_set_rational(entry->data + 2 * sizeof(ExifRational), imageByteOrder, seconds_r);
                      // Code to add longitude to exif tag
                      entry = create_or_update_tag(exif, EXIF_IFD_GPS, (ExifTag)EXIF_TAG_GPS_LONGITUDE_REF, (ExifFormat)EXIF_FORMAT_ASCII, 2*sizeof(char), 1);
                      if (_uav_state.lon_deg >= 0) {
                          memcpy(entry->data, "E", sizeof(char));
                      } else {
                          memcpy(entry->data, "W", sizeof(char));
                          _uav_state.lon_deg *= -1;
                      entry = create_or_update_tag(exif, EXIF_IFD_GPS, (ExifTag)EXIF_TAG_GPS_LONGITUDE, (ExifFormat)EXIF_FORMAT_RATIONAL, 3*sizeof(ExifRational), 3);
                      ExifLong degrees_lon = static_cast<ExifLong>(_uav_state.lon_deg);
                      fractional = (_uav_state.lon_deg - degrees_lon);
                      ExifLong minutes_lon = static_cast<ExifLong>(fractional*60);
                      fractional = (fractional*60) - minutes_lon;
                      double seconds_lon = (fractional * 60);
                      degrees_r = { degrees_lon, 1 };
                      minutes_r = { minutes_lon, 1 };
                      seconds_r = { static_cast<ExifLong>(seconds_lon * 1000000), 1000000 }; // Increased precision for seconds
                      // Code to add altitude to exif tag
                      entry = create_or_update_tag(exif, EXIF_IFD_GPS, (ExifTag)EXIF_TAG_GPS_ALTITUDE, (ExifFormat)EXIF_FORMAT_RATIONAL, sizeof(ExifRational), 1);
                      double alt_lon = _uav_state.alt_msl_meters;
                      unsigned int tmp = static_cast<unsigned int>(alt_lon * 1000);
                      exif_set_rational(entry->data, imageByteOrder, (ExifRational){tmp, 1000});
                      entry = create_or_update_tag(exif, EXIF_IFD_GPS, (ExifTag)EXIF_TAG_GPS_ALTITUDE_REF, (ExifFormat)EXIF_FORMAT_BYTE, sizeof(uint8_t), 1);
                      entry->data[0] = 0; /**< 0 for above sea level */
                      // dumping all exif data
                      entry = create_or_update_tag(exif, EXIF_IFD_EXIF, (ExifTag)EXIF_TAG_FOCAL_LENGTH, (ExifFormat)EXIF_FORMAT_RATIONAL, sizeof(ExifRational), 1);
                      ExifRational focal_len_r = {static_cast<ExifLong>(9.99 * 1000000), 1000000};
                      exif_set_rational(entry->data, EXIF_BYTE_ORDER_MOTOROLA, focal_len_r);
                      entry = create_or_update_tag(exif, EXIF_IFD_EXIF, (ExifTag)EXIF_TAG_FNUMBER, (ExifFormat)EXIF_FORMAT_RATIONAL, sizeof(ExifRational), 1);
                      ExifRational f_number_r = {static_cast<ExifLong>(13.6 * 1000000), 1000000};
                      exif_set_rational(entry->data, EXIF_BYTE_ORDER_MOTOROLA, f_number_r);
                      entry = create_or_update_tag(exif, EXIF_IFD_EXIF, (ExifTag)EXIF_TAG_FOCAL_LENGTH_IN_35MM_FILM, (ExifFormat)EXIF_FORMAT_SHORT, sizeof(ExifShort), 1);
                      ExifShort f_35_mm_r = 17;
                      exif_set_short(entry->data, EXIF_BYTE_ORDER_MOTOROLA, f_35_mm_r);
                      exif_data_save_data(exif, &exif_data, &exif_data_len);
                      //printf("Exif data after mods\n");
                      //printf("End Exif data after mods\n");
                      assert(exif_data != NULL);
                  #endif
                      meta.magic_number = CAMERA_MAGIC_NUMBER;
                      meta.width        = snap_width;
                      meta.height       = snap_height;
                      meta.format       = IMAGE_FORMAT_JPG;
                      meta.size_bytes   = extractJpgSize;
                      pipe_server_write_camera_frame(snapshotPipe, meta, &src_data[start_index]);
                      // now, if there is a filename in the queue, write it too
                      if(snapshotQueue.size() != 0){
                          char *filename = snapshotQueue.front();
                          snapshotQueue.pop();
                          M_PRINT("Camera: %s writing snapshot to :\"%s\"\n", name, filename);
                          //WriteSnapshot(bufferBlockInfo, snap_halfmt, filename);
                          FILE* file_descriptor = fopen(filename, "wb");
                          if(! file_descriptor){
                              //Check to see if we were just missing parent directories
                              CreateParentDirs(filename);
                                  M_ERROR("failed to open file descriptor for snapshot save to: %s\n", filename);
                                  return;
                  #ifndef APQ8096
                          // first write the beginning of jpeg and stop where the previous exif APP1 header started
                          // this will include the FFD8 marker
                          printf("Start: 0, end:%lu\n", prev_exif_block_start_idx);
                          if (fwrite(src_data, prev_exif_block_start_idx, 1, file_descriptor) != 1) {
                              fprintf(stderr, "Error writing to file with jpeg %s\n", filename);
                          if (fwrite(exif_header, exif_header_len, 1, file_descriptor) != 1) {
                             fprintf(stderr, "Error writing to file inin exif header %s\n", filename);
                          if (fputc((exif_data_len+2) >> 8, file_descriptor) < 0) {
                             fprintf(stderr, "Error writing to file in big endian order %s\n", filename);
                          if (fputc((exif_data_len+2) & 0xff, file_descriptor) < 0) {
                             fprintf(stderr, "Error writing to file with fputc %s\n", filename);
                          if (fwrite(exif_data, exif_data_len, 1, file_descriptor) != 1) {
                             fprintf(stderr, "Error writing to file with data block %s\n", filename);
                          // next write from the last bits of the prev APP1 block
                          size_t jpeg_start_idx = prev_exif_block_start_idx + prev_exif_block_size;
                          size_t jpeg_size = extractJpgSize - prev_exif_block_size;
                          //size_t jpeg_start_idx = prev_exif_block_start_idx + prev_exif_block_size + (exif_data_len+2+exif_header_len);
                          //size_t jpeg_size = extractJpgSize - prev_exif_block_size + (exif_data_len+2+exif_header_len);
                          printf("Start: %lu, end:%lu\n", jpeg_start_idx, jpeg_size);
                          if (fwrite(src_data + jpeg_start_idx, jpeg_size, 1, file_descriptor) != 1) {
                          free(exif_data);
                          exif_data_unref(exif);
                  tomT Eric KatzfeyE 2 Replies Last reply Reply Quote 1
                    tom admin @AndriiHlyvko
                    @AndriiHlyvko Feel free to fork the repo and create a merge request into the dev branch and the team will review
                      Eric Katzfey ModalAI Team @AndriiHlyvko
                      @AndriiHlyvko Yes, we would definitely like to have those changes, thanks! As Tom stated, please fork the repo and then prepare a pull request.
                      • A
                        AndriiHlyvko @Eric Katzfey
                        @Eric-Katzfey Here is the MR I made for this issue https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/merge_requests/44
                        I also made a few related changes that should allow handling of additional UAV metadata in the images
                          @AndriiHlyvko Thanks! We have merged in those changes.
