    VOXL portal not working
    1022
    • R
      restore
      I have configured a doodle modem and the IP is correct (as shown is voxl-my-ip). When I go to the IP address in a browser, I get an page showing "Index of /" with a blank directory structure.
      We just installed the 1.3 SDK
        tom admin @restore
        @restore You can't use 10.223.0.1 as the IP address when configuring the doodle modem, it is reserved. You'll have to choose a different IP on the 10.223 subnet
        • R
          restore @tom
          @tom I tried the default 10.223.0.100 and 10.223.0.200 and it is has the same result. I get to the same page shown in the image above.
            tom admin @restore
            @restore Are you able to ssh or ping to the voxl via. the doodle network from your host machine?
            Does your host machine have it's own doodle connected?
            • R
              restore @tom
              @tom I am able to ssh into VOXL via this IP. I am using the doodle dev board with ethernet to my host machine. I can see the rtsp camera stream, but portal is not working.
              We had this working previously before we upgraded to SDK 1.3 (previously on 1.2)
                tom admin @restore
                @restore What do you see with journalctl -u voxl-portal?
                Can you also post the output of voxl-version?
                • R
                  restore @tom
                  voxl2:/$ journalctl -u voxl-portal
                  -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Thu 2023-03-02 13:35:18 UT
                  Mar 02 12:58:04 m0054 systemd[1]: Started voxl-portal.
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  Mar 02 12:58:58 m0054 voxl-portal[1415]: received SIGTERM
                  Mar 02 12:58:58 m0054 voxl-portal[1415]: voxl-portal started up
                  Mar 02 12:58:58 m0054 voxl-portal[1415]: e481 1 mongoose.c:3626:mg_iotest
                  Mar 02 12:58:58 m0054 systemd[1]: Stopping voxl-portal...
                  Mar 02 12:58:58 m0054 systemd[1]: Stopped voxl-portal.
                  Mar 02 12:59:07 m0054 systemd[1]: Started voxl-portal.
                  -- Reboot --
                  Mar 02 13:03:04 m0054 voxl-portal[1429]: received SIGTERM
                  Mar 02 13:03:04 m0054 voxl-portal[1429]: voxl-portal started up
                  Mar 02 13:03:04 m0054 voxl-portal[1429]: 4a586 1 mongoose.c:3626:mg_iotest
                  Mar 02 13:03:04 m0054 systemd[1]: Stopping voxl-portal...
                  Mar 02 13:03:04 m0054 systemd[1]: Stopped voxl-portal.
                  Mar 02 13:03:04 m0054 systemd[1]: Started voxl-portal.
                  -- Reboot --
                  Mar 02 13:03:18 m0054 voxl-portal[1415]: received SIGTERM
                  Mar 02 13:03:18 m0054 voxl-portal[1415]: voxl-portal started up
                  Mar 02 13:03:18 m0054 voxl-portal[1415]: 4dbba 1 mongoose.c:3626:mg_iotest
                  Mar 02 13:03:18 m0054 systemd[1]: Stopping voxl-portal...
                  Mar 02 13:03:18 m0054 systemd[1]: Stopped voxl-portal.
                  Mar 02 13:03:18 m0054 systemd[1]: Started voxl-portal.
                  lines 10-47/47 (END)
                  voxl-version
                  voxl2:/$ voxl-version
                  system-image: 1.7.8-M0054-14.1a-perf
                  kernel:       #1 SMP PREEMPT Fri May 17 23:29:23 UTC 2024 4.19.125
                  hw platform:  M0054
                  mach.var:     1.0.0
                  voxl-suite:   1.3.0
                  Packages:
                  Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.3/binary-arm64/
                  Last Updated: 2023-03-02 12:58:43
                  List:
                  libfc-sensor                              1.0.7
                  libmodal-cv                               0.5.6
                  libmodal-exposure                         0.1.0
                  libmodal-pipe                             2.10.0
                  libqrb5165-io                             0.4.5
                  libvoxl-cci-direct                        0.2.3
                  modalai-slpi                              1.1.14
                  qrb5165-dfs-server                        0.2.0
                  qrb5165-imu-server                        1.0.1
                  qrb5165-rangefinder-server                0.1.3
                  qrb5165-system-tweaks                     0.2.6
                  voxl-bind-spektrum                        0.1.1
                  voxl-camera-calibration                   0.5.5
                  voxl-camera-server                        1.9.4
                  voxl-configurator                         0.6.6
                  voxl-cpu-monitor                          0.4.8
                  voxl-docker-support                       1.3.1
                  voxl-elrs                                 0.2.0
                  voxl-esc                                  1.4.3
                  voxl-feature-tracker                      0.3.10
                  voxl-flow-server                          0.3.6
                  voxl-lepton-server                        1.2.1
                  voxl-lepton-tracker                       0.0.1
                  voxl-logger                               0.4.1
                  voxl-mavcam-manager                       0.5.6
                  voxl-mavlink-server                       1.4.1
                  voxl-modem                                1.1.2
                  voxl-mpa-to-ros                           0.3.8
                  voxl-mpa-tools                            1.1.6
                  voxl-neopixel-manager                     0.0.3
                  voxl-open-vins                            0.4.11
                  voxl-open-vins-server                     0.2.53
                  voxl-opencv                               4.5.5-2
                  voxl-portal                               0.6.6
                  voxl-px4                                  1.14.0-2.0.73
                  voxl-px4-params                           0.4.2
                  voxl-qvio-server                          1.0.4
                  voxl-remote-id                            0.0.9
                  voxl-streamer                             0.7.4
                  voxl-suite                                1.3.0
                  voxl-tflite-server                        0.3.4
                  voxl-utils                                1.4.1
                  voxl-uvc-server                           0.1.7
                  voxl-vision-hub                           1.8.0
                  voxl-vtx                                  1.0.2
                  voxl2-io                                  0.0.3
                  voxl2-system-image                        1.7.8-r0
                    tom admin @restore
                    @restore Is this a custom drone you've developed or one of you development drones?
                    • R
                      restore @tom
                      @tom it is a custom drone
                      Voxl2 and the 4in1 FPV ESC
                        tom admin @restore
                        @restore As a test to try to get you back to a solid starting point, can you try the following:
                        1. Run voxl-configure-sku -w
                        2. Select voxl2-board-only
                        3. Select your camera config, if no cameras select 0
                        4. Press enter to continue.
                        5. Run voxl-configure-mpa
                        6. When the above is finished, reboot drone
                        This should get you into a known good state, you should be able to access voxl-portal and px4 should be running, you can also try connecting to QGC.
                        • R
                          restore @tom
                          @tom we tried that and still have the same behavior. Everything seems to run successfully.
                            tom admin @restore
                            @restore Hmm that shouldn't be the case, I wonder if there is some sort of corrupted file screwing things up.
                            Can you run through the SDK installation again but this time use the ./install.sh -w option? This will wipe the entire file system including the /data partition which is usually untouched.
                            If you have any calibration files in /data you'll want to pull them off before flashing
                            • R
                              restore @tom
                              @tom the full wipe SDK install sorted it out. Thanks
