  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. VOXL portal not working
13 Posts 2 Posters 1.7k Views 1 Watching
  • R Offline
    R Offline
    restore
    I have configured a doodle modem and the IP is correct (as shown is voxl-my-ip). When I go to the IP address in a browser, I get an page showing "Index of /" with a blank directory structure.
    We just installed the 1.3 SDK
    • R restore
      wrote on last edited by tom
      @restore You can't use 10.223.0.1 as the IP address when configuring the doodle modem, it is reserved. You'll have to choose a different IP on the 10.223 subnet
      R 1 Reply Last reply
        R Offline
        R Offline
        restore
        @tom I tried the default 10.223.0.100 and 10.223.0.200 and it is has the same result. I get to the same page shown in the image above.
        • R restore
          @restore Are you able to ssh or ping to the voxl via. the doodle network from your host machine?
          Does your host machine have it's own doodle connected?
            R Offline
            R Offline
            restore
            @tom I am able to ssh into VOXL via this IP. I am using the doodle dev board with ethernet to my host machine. I can see the rtsp camera stream, but portal is not working.
            We had this working previously before we upgraded to SDK 1.3 (previously on 1.2)
            • R restore
              @restore What do you see with journalctl -u voxl-portal?
              Can you also post the output of voxl-version?
                R Offline
                R Offline
                restore
                voxl2:/$ journalctl -u voxl-portal
                -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Thu 2023-03-02 13:35:18 UT
                Mar 02 12:58:04 m0054 systemd[1]: Started voxl-portal.
                -- Reboot --
                -- Reboot --
                -- Reboot --
                -- Reboot --
                -- Reboot --
                -- Reboot --
                -- Reboot --
                -- Reboot --
                -- Reboot --
                -- Reboot --
                -- Reboot --
                -- Reboot --
                -- Reboot --
                Mar 02 12:58:58 m0054 voxl-portal[1415]: received SIGTERM
                Mar 02 12:58:58 m0054 voxl-portal[1415]: voxl-portal started up
                Mar 02 12:58:58 m0054 voxl-portal[1415]: e481 1 mongoose.c:3626:mg_iotest
                Mar 02 12:58:58 m0054 systemd[1]: Stopping voxl-portal...
                Mar 02 12:58:58 m0054 systemd[1]: Stopped voxl-portal.
                Mar 02 12:59:07 m0054 systemd[1]: Started voxl-portal.
                -- Reboot --
                Mar 02 13:03:04 m0054 voxl-portal[1429]: received SIGTERM
                Mar 02 13:03:04 m0054 voxl-portal[1429]: voxl-portal started up
                Mar 02 13:03:04 m0054 voxl-portal[1429]: 4a586 1 mongoose.c:3626:mg_iotest
                Mar 02 13:03:04 m0054 systemd[1]: Stopping voxl-portal...
                Mar 02 13:03:04 m0054 systemd[1]: Stopped voxl-portal.
                Mar 02 13:03:04 m0054 systemd[1]: Started voxl-portal.
                -- Reboot --
                Mar 02 13:03:18 m0054 voxl-portal[1415]: received SIGTERM
                Mar 02 13:03:18 m0054 voxl-portal[1415]: voxl-portal started up
                Mar 02 13:03:18 m0054 voxl-portal[1415]: 4dbba 1 mongoose.c:3626:mg_iotest
                Mar 02 13:03:18 m0054 systemd[1]: Stopping voxl-portal...
                Mar 02 13:03:18 m0054 systemd[1]: Stopped voxl-portal.
                Mar 02 13:03:18 m0054 systemd[1]: Started voxl-portal.
                lines 10-47/47 (END)
                voxl-version
                voxl2:/$ voxl-version
                system-image: 1.7.8-M0054-14.1a-perf
                kernel:       #1 SMP PREEMPT Fri May 17 23:29:23 UTC 2024 4.19.125
                hw platform:  M0054
                mach.var:     1.0.0
                voxl-suite:   1.3.0
                Packages:
                Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.3/binary-arm64/
                Last Updated: 2023-03-02 12:58:43
                List:
                libfc-sensor                              1.0.7
                libmodal-cv                               0.5.6
                libmodal-exposure                         0.1.0
                libmodal-pipe                             2.10.0
                libqrb5165-io                             0.4.5
                libvoxl-cci-direct                        0.2.3
                modalai-slpi                              1.1.14
                qrb5165-dfs-server                        0.2.0
                qrb5165-imu-server                        1.0.1
                qrb5165-rangefinder-server                0.1.3
                qrb5165-system-tweaks                     0.2.6
                voxl-bind-spektrum                        0.1.1
                voxl-camera-calibration                   0.5.5
                voxl-camera-server                        1.9.4
                voxl-configurator                         0.6.6
                voxl-cpu-monitor                          0.4.8
                voxl-docker-support                       1.3.1
                voxl-elrs                                 0.2.0
                voxl-esc                                  1.4.3
                voxl-feature-tracker                      0.3.10
                voxl-flow-server                          0.3.6
                voxl-lepton-server                        1.2.1
                voxl-lepton-tracker                       0.0.1
                voxl-logger                               0.4.1
                voxl-mavcam-manager                       0.5.6
                voxl-mavlink-server                       1.4.1
                voxl-modem                                1.1.2
                voxl-mpa-to-ros                           0.3.8
                voxl-mpa-tools                            1.1.6
                voxl-neopixel-manager                     0.0.3
                voxl-open-vins                            0.4.11
                voxl-open-vins-server                     0.2.53
                voxl-opencv                               4.5.5-2
                voxl-portal                               0.6.6
                voxl-px4                                  1.14.0-2.0.73
                voxl-px4-params                           0.4.2
                voxl-qvio-server                          1.0.4
                voxl-remote-id                            0.0.9
                voxl-streamer                             0.7.4
                voxl-suite                                1.3.0
                voxl-tflite-server                        0.3.4
                voxl-utils                                1.4.1
                voxl-uvc-server                           0.1.7
                voxl-vision-hub                           1.8.0
                voxl-vtx                                  1.0.2
                voxl2-io                                  0.0.3
                voxl2-system-image                        1.7.8-r0
                • R restore
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  -- Reboot --
                  voxl-version
                  hw platform:  M0054
                  mach.var:     1.0.0
                  voxl-suite:   1.3.0
                  Packages:
                  List:
                  libfc-sensor                              1.0.7
                  libmodal-cv                               0.5.6
                  libqrb5165-io                             0.4.5
                  modalai-slpi                              1.1.14
                  voxl-elrs                                 0.2.0
                  voxl-esc                                  1.4.3
                  voxl-logger                               0.4.1
                  voxl-modem                                1.1.2
                  voxl-opencv                               4.5.5-2
                  voxl-portal                               0.6.6
                  voxl-streamer                             0.7.4
                  voxl-suite                                1.3.0
                  voxl-utils                                1.4.1
                  voxl-vtx                                  1.0.2
                  voxl2-io                                  0.0.3
                  @restore Is this a custom drone you've developed or one of you development drones?
                    R Offline
                    R Offline
                    restore
                    @tom it is a custom drone
                    Voxl2 and the 4in1 FPV ESC
                    • R restore
                      @restore As a test to try to get you back to a solid starting point, can you try the following:
                      1. Run voxl-configure-sku -w
                      2. Select voxl2-board-only
                      3. Select your camera config, if no cameras select 0
                      4. Press enter to continue.
                      5. Run voxl-configure-mpa
                      6. When the above is finished, reboot drone
                      This should get you into a known good state, you should be able to access voxl-portal and px4 should be running, you can also try connecting to QGC.
                        R Offline
                        R Offline
                        restore
                        @tom we tried that and still have the same behavior. Everything seems to run successfully.
                        • R restore
                          @restore Hmm that shouldn't be the case, I wonder if there is some sort of corrupted file screwing things up.
                          Can you run through the SDK installation again but this time use the ./install.sh -w option? This will wipe the entire file system including the /data partition which is usually untouched.
                          If you have any calibration files in /data you'll want to pull them off before flashing
                            R Offline
                            R Offline
                            restore
                            @tom the full wipe SDK install sorted it out. Thanks
