    dpkg nor opkg found on VOXL
    1572
    • Gary HolmgrenG
      Gary Holmgren
        tom admin @Gary Holmgren
        @Gary-Holmgren In what context are you seeing this error? Running ./deploy_to_voxl.sh?
        tomT Gary HolmgrenG 2 Replies Last reply Reply Quote 0
          tom admin @tom
          @tom And do you have ADB connected or are you trying to deploy via SSH?
          • Gary HolmgrenG
            Gary Holmgren @tom
            @tom yes correct I am using ./deploy_to_voxl.sh over ssh
            tomT 2 Replies Last reply Reply Quote 0
              @Gary-Holmgren I'll see if I can replicate
                @Gary-Holmgren Works fine for me 12c9f7b3-4248-401d-a781-323f02bf1cdf-image.png
                I have my VOXL 2 in SoftAP mode, is that what you are doing as well?
                  tom admin @tom
                  @tom And then in docker it works as well: 621a7fc4-49f2-442a-987f-a055f0a470da-image.png
                  Gary HolmgrenG 1 Reply Last reply Reply Quote 0
                  • Gary HolmgrenG
                    Gary Holmgren @tom
                    • Gary HolmgrenG
                      Gary Holmgren @tom
                        @Gary-Holmgren Hmm yeah station mode is working fine for me as well.
                        Are you able to just ssh onto the VOXL normally?
                        Did you happen to change the root user password on VOXL?
                        • Gary HolmgrenG
                          Gary Holmgren @tom
                            @Gary-Holmgren Ah so that would be the issue, the default password of oelinux123 is hard-coded into the deploy_to_voxl.sh script
                            Gary HolmgrenG 1 Reply Last reply Reply Quote 1
                            • Gary HolmgrenG
                              Gary Holmgren @tom
                                @Gary-Holmgren I'm also going to update the help text on that error in our deploy_to_voxl.sh template as the "ERROR neither dpkg nor opkg found on VOXL" is obviously not accurate
