  3. m500 is not connecting to QGC or my DX6e controller
m500
17 Posts 3 Posters 2.8k Views 2 Watching
  • S shippwr3ckk
    @tom I reset the file, matched the correct IPv4, and systemctl restarted. I am still not able to connect to QGC. What would be the next troubleshooting step? I have heard that it might have to do something with my batteries? I am honestly lost on what is causing the connection problems.
    S Offline
    S Offline
    shippwr3ckk
    wrote on last edited by shippwr3ckk
    @shippwr3ckk Would a complete factory reset of the drone's software be an option?
    S 1 Reply Last reply
    • S shippwr3ckk
      S Offline
      S Offline
      shippwr3ckk
      @shippwr3ckk My m500 does not also seem to have PX4 installed, is that required? And if so, where do I go to install it correctly?
      ModeratorM 1 Reply Last reply
      • S shippwr3ckk
        @shippwr3ckk the drones all ship preconfigured and flight tested. There is definitely PX4 installed. It's on the flight core portion of the m500 and not on the VOXL. voxl-mavlink-server is used to communicate between the VOXL and the Flight Core
        • ModeratorM Moderator
          S Offline
          S Offline
          shippwr3ckk
          @Moderator Got it. Why is the flight core not responding to the VOXL then? I have everything configured as recommended and I still can't get the drone to register with QGC.
          • S Offline
            S Offline
            shippwr3ckk
            #9
            Update, I still have not been able to connect to the QGC.
            What am I doing that could be causing connection issues?
            How do I properly communicate with the PX4 content with the mavlink-server?
            My WIFI is also not labeled at "VOXL:XXX.XX, etc..", is that an issue?
            • S shippwr3ckk
              @shippwr3ckk If you'd like to get back to a factory state you can download the latest VOXL SDK (1.2.0) and load the SDK using it's /install.sh script
                @tom You can also load your flight core with the latest version of px4 which is contained in the flight-core sub-directory of the SDK tar
                  S Offline
                  S Offline
                  shippwr3ckk
                  Update, I did not do a factory reset. But, I can connect to QGC but it only needed a wifi connection and not the "ssh root@". Do I need to "ssh root@" everytime I need to connect to QGC?
                  As of now, I cannot get the drone to connect to my radio or get it calibrated. It will not respond to any commands the QGC tries to send. Any ideas on what I should do next?
                  • S shippwr3ckk
                    @shippwr3ckk "Do I need to "ssh root@" everytime I need to connect to QGC?" I'm not entirely sure what you're asking here. Can you give some more detail of the process you're having to do to establish a connection to QGC that involves ssh
                      S Offline
                      S Offline
                      shippwr3ckk
                      @tom In the command prompt, while connected to the drone's wifi, I usually put in the "ssh root@_ip_ command. I don't know the full reason to type this but I saw it in the instructions when establishing a pre-flight. I figured it was another connection step when configuring with QGC.
                      • S shippwr3ckk
                        @shippwr3ckk SSH is just a way to access the drone's terminal remotely. It will give you access to the same terminal you get when you connect via USB and use adb shell
                        Running ssh root@DRONE_IP will give you remote access to then run commands. Running just the SSH command alone and then nothing else doesn't really do anything.
                          S Offline
                          S Offline
                          shippwr3ckk
                          @tom Thank you for the info!
                          After messing with it some more, I think it might have to do with the batteries I am using. Because the drone is currently turned on and my laptop is connected to the drone's wifi, but it is no longer connecting to QGC, even with a micro USB connection too.
                          The battery I am using is a "14.8V, 45C, 4S1P, 3300, 4 Cell battery". And it will only read on the QGC when it is around 30-50%.
                          Any ideas what I should try next?
                          • S Offline
                            S Offline
                            shippwr3ckk
