    Masking qVio
    2145
    • D
      droen8
      Hello Voxl Team,
      During testing my drone prototype which has about 2m diameter I've seen that the VIO seems to be detecting features on the drone arms etc. what makes loss of VIO quality by sticking points on a moving drone through the tracking sensor.
      In that case I've decided to mask disturbing elements to let the computing power takes place in free space out of the drone.
      I have tried to add mask trough config as this changes suggest https://gitlab.com/voxl-public/voxl-sdk/services/voxl-qvio-server/-/commit/c20b35e19f8fb289d272877648fd77e1afc7810c but It's not working I have used example mask I put in /etc/modalai/mask.pgm. I have tried to hardcode mask file path in code and rebuild voxl-qvio-server but without success.
      https://ibb.co/MVV6KJB
      Regards
        Alex Kushleyev ModalAI Team @droen8
        @droen8 , please review this post, the mask should work.
        https://forum.modalai.com/topic/2551/add-mask-file-to-qvio-algorithm
        You should try the example mask from this location : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-qvio-server/-/blob/master/misc/mask_example_160x120.pgm and in this test case, you should observe half of image not finding any new features (easiest to check without moving). If features are found in unmasked region, the will be tracked through the whole image after that.
        If the mask is not working, then either the mask format is not correct or the mask file is not found. What camera are you using for QVIO?
        • D
          droen8
          Hi @Alex-Kushleyev,
          I am using ov7251 for tracking. I think I have made everything as described but it's still not working.
          https://ibb.co/XyDGG7w
          https://ibb.co/WkSDC2V
          https://ibb.co/6X5N6YV
          Regards
            @droen8 , quick question, did you move the camera after starting vio or has it been stationary?
            Can you please try again by pointing the camera at a feature rich environment to make sure that top and bottom have many features and do not move the camera after you start qvio. I just want to double check.
            Also, something to check, if you provide an incorrect file name in qvio (or rename your mask), do you get a warning from qvio server saying that the file could not be loaded?
            • D
              droen8 @Alex Kushleyev
              Yes I have tried multiple times, the screenshoot was taken after few restarts of voxl-qvio-server. It's for sure not using a mask.
              I have tried renaming mask and I have not seen any errors when mask do not exist in provided path. I have tried to display printf("Mask file name = %s \n", staticMaskFileName); in _hard_reset function and the path is displayed properely. I do not have idea how can I debug this issue.
              With existing file in mask_file_path:
              Renamed file:
              After renaming to ...maskWrongFilename.pgm :
                @droen8 , i believe there is a special command that silences the output of QVIO during initialization:
                https://gitlab.com/voxl-public/voxl-sdk/services/voxl-qvio-server/-/blob/master/server/main.cpp?ref_type=heads#L368
                Please try to remove that wrapper SILENT_STD around the mvVISLAM_Initialize call and see if you get any messages about the mask file (when it has correct or incorrect file name).
                Sorry, there is no good way to debug this, but hopefully this will provide more information.
                • D
                  @Alex-Kushleyev thank you, I have not noticed that init function is wrapped. Now I can see that path is relative to /home/root
                  I will try in few if it's working but it will for sure 🙂 There is another error with Configuration.SF.xml should I have It in mind?
                  Alex KushleyevA D 2 Replies Last reply Reply Quote 0
                    @droen8 ,
                    Oh yes... you found the issue.
                    I believe the other error (Configuration.SF.xml) is OK, we never used that file, so the configuration is passed via the mvVISLAM_Initialize call.
                    I'll discuss with the team how to fix this path issue for the mask file
                    • D
                      droen8 @droen8
                      • D
                        @Alex-Kushleyev It is not complaining about mask opening fail now but It is still not working:
                        Voxl is stationary and I have tried reseting qvio:
                        //edit the relativity of a path was due to me running voxl-qvio-server from there. When I run It as a service It is using absolute paths now. But still not working with repository example mask nor with my own mask.
                          @droen8 , it looks like the mask file that I shared is not working. I did some digging and found that there is a formatting issue. if you open the pgm file with vi, you can see:
                          P5 160 120 255
                          but it should be:
                          P5
                          160 120
                          255
                          I am not sure how this happened.
                          I used vi to fix the sample mask, can you please try it? https://storage.googleapis.com/modalai_public/temp/voxl2-misc-packages/mask_example_160x120_fixed.pgm . Also, can you inspect the mask that you created? The PGM file should have the header above and then 8-bit mask entries where white (255) being where NO features should be found and black (0) where ok to have features.
                          • D
                            @Alex-Kushleyev said in Masking qVio:
                            P5
                            160 120
                            255
                            It is working now thanks. I have created mask in monochrome bmp and then used online tool to convert it into pgm but output had wrong header:
                            P5
                            160 120
                            I have used gimp now and exported with .pgm (binary) and it's working 😄
                            I put a preview mask on output image.
                            • Gary HolmgrenG Gary Holmgren referenced this topic on
