  3. voxl-camera-server stalls/crash
3 Posts 2 Posters 841 Views
  • Steve TurnerS Offline
    Steve Turner
    What hardware are you using?
    VOXL2 Mini. Single IMX678 to isolate issues with ModalAI flex cables without extensions. Same configuration as: https://docs.modalai.com/voxl2-camera-configs/#c-08-hires-only but with IMX678 on a VOXL2 Mini.
    What version of software are you using?
    	libmodal-cv                 0.4.0-202309221302
    	libmodal-exposure           0.1.0-202310231718
    	libmodal-journal            0.2.2-202211021731
    	libmodal-json               0.4.3-202209281920
    	libmodal-pipe               2.10.0-202311162306
    	libqrb5165-io               0.4.3-202312061353
    	libvoxl-cci-direct          0.2.1-202309211746
    	libvoxl-cutils              0.1.1-202210072352
    	mv-voxl                     0.1-r0
    	qrb5165-bind                0.1-r0
    	qrb5165-dfs-server          0.2.0-202309221318
    	qrb5165-imu-server          1.0.1-202312010251
    	qrb5165-rangefinder-server  0.1.1
    	qrb5165-slpi-test-sig       01-r0
    	qrb5165-system-tweaks       0.2.3-202310251528
    	qrb5165-tflite              2.8.0-2-202210071637
    	voxl-bind-spektrum          0.1.0-202306141409
    	voxl-camera-calibration     0.5.3-202311291536
    	voxl-camera-server          1.8.9
    	voxl-capture                0.0.1-202206110121
    	voxl-configurator           0.4.8
    	voxl-cpu-monitor            0.4.7-202311071555
    	voxl-docker-support         1.3.0-202309201525
    	voxl-elrs                   0.1.3-202311081047
    	voxl-esc                    1.3.7
    	voxl-feature-tracker        0.3.3-202312051209
    	voxl-flow-server            0.3.4-202312051140
    	voxl-gphoto2-server         0.0.10-202210072352
    	voxl-jpeg-turbo             2.1.3-5-202311071550
    	voxl-lepton-server          1.2.0-202309051721
    	voxl-libgphoto2             0.0.4-202204111958
    	voxl-libuvc                 1.0.7-202210072357
    	voxl-logger                 0.3.5-202309051053
    	voxl-mavcam-manager         0.5.3-202309221714
    	voxl-mavlink                0.1.1-202305011701
    	voxl-mavlink-server         1.2.1
    	voxl-modem                  1.0.8-202310121252
    	voxl-mongoose               7.7.0-1-202210072105
    	voxl-mpa-to-ros             0.3.7-202310131817
    	voxl-mpa-tools              1.1.3-202311151155
    	voxl-neopixel-manager       0.0.3-202312061522
    	voxl-opencv                 4.5.5-2-202311071601
    	voxl-portal                 0.6.3
    	voxl-px4                    1.14.0-2.0.62-202312061556
    	voxl-px4-imu-server         0.1.2-202205131833
    	voxl-px4-params             0.3.3
    	voxl-qvio-server            1.0.0-202311221427
    	voxl-remote-id              0.0.9-202309191605
    	voxl-rtp                    0.0.1-202206101543
    	voxl-stitcher               0.0.2-202206161634
    	voxl-streamer               0.7.4-202309221610
    	voxl-suite                  1.1.2-202312062200
    	voxl-tag-detector           0.0.4-202206302112
    	voxl-tflite-server          0.3.2
    	voxl-utils                  1.3.3-202309221659
    	voxl-uvc-server             0.1.6-202311050848
    	voxl-vision-hub             1.7.3
    	voxl-wifi-broadcast         0.0.10-202206122258
    	voxl2-system-image          1.7.1-r0
    	voxl2-wlan                  1.0-r0
    How have you configured the software? What is the output of voxl-inspect-services
    Do you have any logs?
    voxl-camera-server -d 0 output:
    configuration for 1 cameras:
    cam #0
        sensor type:         imx678
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          0
        pre_width:           640
        pre_height:          480
        en_raw_preview:      0
        en_small_video:      1
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      1
        large_video_width:   2048
        large_video_height:  1536
        en_snapshot:         1
        snap_width:          3840
        snap_height:         2160
        ae_mode:             isp
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
    DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x0034, Sensor Id: 0xA602
    GPS server Connected
    DEBUG:   Connected to cpu-monitor
    DEBUG:   ------ voxl-camera-server: Starting 1 cameras
    Starting Camera: hires (id #0)
    DEBUG:   Checking Gain limits for Camera: hires
    DEBUG:   cam ID 0 checking for fmt:   35  w: 1024 h:  768 o:   0
    DEBUG:   i:364 fmt: 36 w:3840 h:2160 o:0
    VERBOSE: Successfully found configuration match for camera 0: 1024x768
    DEBUG:   cam ID 0 checking for fmt:   35  w: 2048 h: 1536 o:   0
    VERBOSE: Successfully found configuration match for camera 0: 2048x1536
    DEBUG:   cam ID 0 checking for fmt:   33  w: 3840 h: 2160 o:   0
    VERBOSE: Successfully found configuration match for camera 0: 3840x2160
    VERBOSE: Adding small video stream for camera: 0
    VERBOSE: Adding large video stream for camera: 0
    VERBOSE: Adding snapshot stream for camera: 0
    DEBUG:   Found video encoder usage, removing camera read/write usage
    DEBUG:   Converted gralloc flags 0x30022 to GBM flags 0x860000
    VERBOSE: Dumping GBM flags
    DEBUG:   	Found flag GBM_BO_USAGE_CPU_READ_QTI
    DEBUG:   	Found flag GBM_BO_USAGE_CPU_WRITE_QTI
    DEBUG:   	Found flag GBM_BO_USAGE_VIDEO_ENCODER_QTI
    VERBOSE: Opened GBM fd
    VERBOSE: Created GBM device
    DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888
    DEBUG:   Available color formats for OMX:
    DEBUG:   	Unknown (0x7fa30c06)
    DEBUG:   	OMX_QCOM_COLOR_FormatYUV420PackedSemiPlanar32m (0x7fa30c04)
    DEBUG:   	OMX_QCOM_COLOR_FormatYVU420SemiPlanar (0x7fa30c00)
    DEBUG:   	Unknown (0x7fa30c09)
    DEBUG:   	Unknown (0x7fa30c0a)
    DEBUG:   	Unknown (0x7fa30c08)
    DEBUG:   	Unknown (0x7fa30c07)
    DEBUG:   	OMX_COLOR_FormatAndroidOpaque (0x7f000789)
    DEBUG:   	OMX_COLOR_FormatYUV420SemiPlanar (0x15)
    DEBUG:   Buffer Count Expected: 16
    DEBUG:   Buffer Count Actual: 16
    DEBUG:   OMX_EventCmdComplete
    DEBUG:   Successfully set up pipeline for stream: STREAM_SMALL_VID
    DEBUG:   Allocated BO with width=2048 height=1536 stride=2048 aligned_w=2048 aligned_h=1536 size=4718592 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888
    DEBUG:   Successfully set up pipeline for stream: STREAM_LARGE_VID
    DEBUG:   Converted gralloc flags 0x20003 to GBM flags 0x420000
    DEBUG:   Allocated BO with width=24883208 height=1 stride=24883208 aligned_w=24883208 aligned_h=1 size=24883208 flags=0x20003 format=GBM_FORMAT_BLOB
    DEBUG:   Successfully set up pipeline for stream: SNAPSHOT
    DEBUG:   Started Camera: hires
    ------ voxl-camera-server: Started 1 of 1 cameras
    VERBOSE: Entered thread: cam0-request(tid: 399559)
    VERBOSE: Entered thread: cam0-result(tid: 399560)
    VERBOSE: added request for small video stream
    VERBOSE: Sending request for frame 0 for camera hires for 1 streams
    VERBOSE: Received 0 buffers from camera hires, partial result:1
    VERBOSE: finished sending request for frame 0 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera hires
    VERBOSE: Sending request for frame 1 for camera hires for 1 streams
    VERBOSE: finished sending request for frame 1 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera hires
    VERBOSE: Sending request for frame 2 for camera hires for 1 streams
    VERBOSE: finished sending request for frame 2 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera hires
    VERBOSE: Sending request for frame 3 for camera hires for 1 streams
    VERBOSE: finished sending request for frame 3 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera hires
    VERBOSE: Sending request for frame 4 for camera hires for 1 streams
    VERBOSE: finished sending request for frame 4 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 5 for camera hires
    VERBOSE: Sending request for frame 5 for camera hires for 1 streams
    VERBOSE: Received result from HAl3 for frame number 2
    VERBOSE: Received 0 buffers from camera hires, partial result:2
    VERBOSE: Received metadata for frame 0 from camera hires
    VERBOSE: 	Timestamp: 2202213421442
    VERBOSE: 	Gain: 54
    VERBOSE: 	Exposure: 270328
    VERBOSE: Received result from HAl3 for frame number 3
    VERBOSE: Received 1 buffers from camera hires, partial result:0
    VERBOSE: Received output buffer 0 from camera hires
    VERBOSE: finished sending request for frame 5 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 6 for camera hires
    VERBOSE: hires procesing new buffer
    VERBOSE: Sending request for frame 6 for camera hires for 1 streams
    VERBOSE: Camera: hires processing small vid frame
    VERBOSE: Received result from HAl3 for frame number 4
    ---- SKIP FOR LENGTH -----
    VERBOSE: returning from SendOneCaptureRequest for frame 26 for camera hires
    VERBOSE: Sending request for frame 26 for camera hires for 1 streams
    ------ voxl-camera-server: Camera server is now stopping
    DEBUG:   	Stopping Camera: hires
    Have you looked at the source code? If so, can you point to any potential issues?
    Have not dug into the camera server source yet. On some vehicles this works fine for hours at a time. On others, this issue pops up consistently. We have swapped cameras, cables, etc.
    We thought perhaps it was ripple or other issues to supply. It does seem to happen more frequently when extensions are used, as expected.
    Perhaps EMI and need for more custom/shorter cables?
    ModeratorM 1 Reply Last reply
    • Steve TurnerS Steve Turner
      	mv-voxl                     0.1-r0
      	qrb5165-bind                0.1-r0
      	voxl-esc                    1.3.7
      	voxl-portal                 0.6.3
      	voxl2-wlan                  1.0-r0
      cam #0
          sensor type:         imx678
          isEnabled:           1
          camId:               0
          camId2:              -1
          fps:                 30
          en_rotate:           0
          en_rotate2:          0
          en_preview:          0
          pre_width:           640
          pre_height:          480
          en_raw_preview:      0
          en_small_video:      1
          en_large_video:      1
          en_snapshot:         1
          snap_width:          3840
          snap_height:         2160
          ae_mode:             isp
          standby_enabled:     0
          decimator:           1
      VERBOSE: 	Gain: 54
      @Steve-Turner Hi Steve, have you tried swapping cables and sensor modules? It seems most likely something is worn or loose.
      Steve TurnerS 1 Reply Last reply
      • ModeratorM Moderator
        Steve Turner
        @Moderator we have tried swapping modules, cameras, and VOXL2(minis)
        Generally, it is exacerbated by the extension cables.
