<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[voxl-camera-server stalls/crash]]></title><description><![CDATA[<p dir="auto"><strong>What hardware are you using?</strong><br />
VOXL2 Mini. Single IMX678 to isolate issues with ModalAI flex cables without extensions. Same configuration as: <a href="https://docs.modalai.com/voxl2-camera-configs/#c-08-hires-only" rel="nofollow ugc">https://docs.modalai.com/voxl2-camera-configs/#c-08-hires-only</a> but with IMX678 on a VOXL2 Mini.</p>
<p dir="auto"><strong>What version of software are you using?</strong></p>
<pre><code>	libmodal-cv                 0.4.0-202309221302
	libmodal-exposure           0.1.0-202310231718
	libmodal-journal            0.2.2-202211021731
	libmodal-json               0.4.3-202209281920
	libmodal-pipe               2.10.0-202311162306
	libqrb5165-io               0.4.3-202312061353
	libvoxl-cci-direct          0.2.1-202309211746
	libvoxl-cutils              0.1.1-202210072352
	mv-voxl                     0.1-r0
	qrb5165-bind                0.1-r0
	qrb5165-dfs-server          0.2.0-202309221318
	qrb5165-imu-server          1.0.1-202312010251
	qrb5165-rangefinder-server  0.1.1
	qrb5165-slpi-test-sig       01-r0
	qrb5165-system-tweaks       0.2.3-202310251528
	qrb5165-tflite              2.8.0-2-202210071637
	voxl-bind-spektrum          0.1.0-202306141409
	voxl-camera-calibration     0.5.3-202311291536
	voxl-camera-server          1.8.9
	voxl-capture                0.0.1-202206110121
	voxl-configurator           0.4.8
	voxl-cpu-monitor            0.4.7-202311071555
	voxl-docker-support         1.3.0-202309201525
	voxl-elrs                   0.1.3-202311081047
	voxl-esc                    1.3.7
	voxl-feature-tracker        0.3.3-202312051209
	voxl-flow-server            0.3.4-202312051140
	voxl-gphoto2-server         0.0.10-202210072352
	voxl-jpeg-turbo             2.1.3-5-202311071550
	voxl-lepton-server          1.2.0-202309051721
	voxl-libgphoto2             0.0.4-202204111958
	voxl-libuvc                 1.0.7-202210072357
	voxl-logger                 0.3.5-202309051053
	voxl-mavcam-manager         0.5.3-202309221714
	voxl-mavlink                0.1.1-202305011701
	voxl-mavlink-server         1.2.1
	voxl-modem                  1.0.8-202310121252
	voxl-mongoose               7.7.0-1-202210072105
	voxl-mpa-to-ros             0.3.7-202310131817
	voxl-mpa-tools              1.1.3-202311151155
	voxl-neopixel-manager       0.0.3-202312061522
	voxl-opencv                 4.5.5-2-202311071601
	voxl-portal                 0.6.3
	voxl-px4                    1.14.0-2.0.62-202312061556
	voxl-px4-imu-server         0.1.2-202205131833
	voxl-px4-params             0.3.3
	voxl-qvio-server            1.0.0-202311221427
	voxl-remote-id              0.0.9-202309191605
	voxl-rtp                    0.0.1-202206101543
	voxl-stitcher               0.0.2-202206161634
	voxl-streamer               0.7.4-202309221610
	voxl-suite                  1.1.2-202312062200
	voxl-tag-detector           0.0.4-202206302112
	voxl-tflite-server          0.3.2
	voxl-utils                  1.3.3-202309221659
	voxl-uvc-server             0.1.6-202311050848
	voxl-vision-hub             1.7.3
	voxl-wifi-broadcast         0.0.10-202206122258
	voxl2-system-image          1.7.1-r0
	voxl2-wlan                  1.0-r0
<p dir="auto"><strong>How have you configured the software? What is the output of voxl-inspect-services<br />
Do you have any logs?</strong><br />
voxl-camera-server -d 0 output:</p>
<pre><code>existing instance of voxl-camera-server found, attempting to stop it
configuration for 1 cameras:
cam #0
    sensor type:         imx678
    isEnabled:           1
    camId:               0
    camId2:              -1
    fps:                 30
    en_rotate:           0
    en_rotate2:          0
    en_preview:          0
    pre_width:           640
    pre_height:          480
    en_raw_preview:      0
    en_small_video:      1
    small_video_width:   1024
    small_video_height:  768
    en_large_video:      1
    large_video_width:   2048
    large_video_height:  1536
    en_snapshot:         1
    snap_width:          3840
    snap_height:         2160
    ae_mode:             isp
    standby_enabled:     0
    decimator:           1
    independent_exposure:0
DEBUG:   ----------- Number of cameras: 1
DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x0034, Sensor Id: 0xA602
GPS server Connected
DEBUG:   Connected to cpu-monitor
DEBUG:   ------ voxl-camera-server: Starting 1 cameras
Starting Camera: hires (id #0)
DEBUG:   Checking Gain limits for Camera: hires
Using gain limits min: 54 max: 8000
DEBUG:   cam ID 0 checking for fmt:   35  w: 1024 h:  768 o:   0
DEBUG:   i:364 fmt: 36 w:3840 h:2160 o:0
VERBOSE: Successfully found configuration match for camera 0: 1024x768
DEBUG:   cam ID 0 checking for fmt:   35  w: 2048 h: 1536 o:   0
VERBOSE: Successfully found configuration match for camera 0: 2048x1536
DEBUG:   cam ID 0 checking for fmt:   33  w: 3840 h: 2160 o:   0
VERBOSE: Successfully found configuration match for camera 0: 3840x2160
VERBOSE: Adding small video stream for camera: 0
VERBOSE: Adding large video stream for camera: 0
VERBOSE: Adding snapshot stream for camera: 0
DEBUG:   Found video encoder usage, removing camera read/write usage
DEBUG:   Converted gralloc flags 0x30022 to GBM flags 0x860000
VERBOSE: Dumping GBM flags
DEBUG:   	Found flag GBM_BO_USAGE_CPU_READ_QTI
DEBUG:   	Found flag GBM_BO_USAGE_CPU_WRITE_QTI
DEBUG:   	Found flag GBM_BO_USAGE_VIDEO_ENCODER_QTI
VERBOSE: Opened GBM fd
VERBOSE: Created GBM device
DEBUG:   Allocated BO with width=1024 height=768 stride=1024 aligned_w=1024 aligned_h=1024 size=1572864 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888
DEBUG:   Available color formats for OMX:
DEBUG:   	Unknown (0x7fa30c06)
DEBUG:   	OMX_QCOM_COLOR_FormatYUV420PackedSemiPlanar32m (0x7fa30c04)
DEBUG:   	OMX_QCOM_COLOR_FormatYVU420SemiPlanar (0x7fa30c00)
DEBUG:   	Unknown (0x7fa30c09)
DEBUG:   	Unknown (0x7fa30c0a)
DEBUG:   	Unknown (0x7fa30c08)
DEBUG:   	Unknown (0x7fa30c07)
DEBUG:   	OMX_COLOR_FormatAndroidOpaque (0x7f000789)
DEBUG:   	OMX_COLOR_FormatYUV420SemiPlanar (0x15)
DEBUG:   Buffer Count Expected: 16
DEBUG:   Buffer Count Actual: 16
DEBUG:   OMX_EventCmdComplete
DEBUG:   Successfully set up pipeline for stream: STREAM_SMALL_VID
DEBUG:   Allocated BO with width=2048 height=1536 stride=2048 aligned_w=2048 aligned_h=1536 size=4718592 flags=0x30022 format=GBM_FORMAT_YCbCr_420_888
DEBUG:   Successfully set up pipeline for stream: STREAM_LARGE_VID
DEBUG:   Converted gralloc flags 0x20003 to GBM flags 0x420000
DEBUG:   	Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI
DEBUG:   Allocated BO with width=24883208 height=1 stride=24883208 aligned_w=24883208 aligned_h=1 size=24883208 flags=0x20003 format=GBM_FORMAT_BLOB
DEBUG:   Successfully set up pipeline for stream: SNAPSHOT
DEBUG:   Started Camera: hires
------ voxl-camera-server: Started 1 of 1 cameras
VERBOSE: Entered thread: cam0-request(tid: 399559)
VERBOSE: Entered thread: cam0-result(tid: 399560)
VERBOSE: added request for small video stream
VERBOSE: Sending request for frame 0 for camera hires for 1 streams
VERBOSE: Received result from HAl3 for frame number 0
VERBOSE: Received 0 buffers from camera hires, partial result:1
VERBOSE: finished sending request for frame 0 for camera hires
VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera hires
VERBOSE: Sending request for frame 1 for camera hires for 1 streams
VERBOSE: finished sending request for frame 1 for camera hires
VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera hires
VERBOSE: Sending request for frame 2 for camera hires for 1 streams
VERBOSE: finished sending request for frame 2 for camera hires
VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera hires
VERBOSE: Sending request for frame 3 for camera hires for 1 streams
VERBOSE: finished sending request for frame 3 for camera hires
VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera hires
VERBOSE: Sending request for frame 4 for camera hires for 1 streams
VERBOSE: Received result from HAl3 for frame number 1
VERBOSE: finished sending request for frame 4 for camera hires
VERBOSE: returning from SendOneCaptureRequest for frame 5 for camera hires
VERBOSE: Sending request for frame 5 for camera hires for 1 streams
VERBOSE: Received result from HAl3 for frame number 2
VERBOSE: Received 0 buffers from camera hires, partial result:2
VERBOSE: Received metadata for frame 0 from camera hires
VERBOSE: 	Timestamp: 2202213421442
VERBOSE: 	Gain: 54
VERBOSE: 	Exposure: 270328
VERBOSE: Received result from HAl3 for frame number 3
VERBOSE: Received 1 buffers from camera hires, partial result:0
VERBOSE: Received output buffer 0 from camera hires
VERBOSE: finished sending request for frame 5 for camera hires
VERBOSE: returning from SendOneCaptureRequest for frame 6 for camera hires
VERBOSE: hires procesing new buffer
VERBOSE: Sending request for frame 6 for camera hires for 1 streams
VERBOSE: Camera: hires processing small vid frame
VERBOSE: Received result from HAl3 for frame number 4
---- SKIP FOR LENGTH -----
VERBOSE: returning from SendOneCaptureRequest for frame 26 for camera hires
VERBOSE: Sending request for frame 26 for camera hires for 1 streams
------ voxl-camera-server: Camera server is now stopping
DEBUG:   	Stopping Camera: hires
<p dir="auto"><strong>Have you looked at the source code? If so, can you point to any potential issues?</strong></p>
<p dir="auto">Have not dug into the camera server source yet. On some vehicles this works fine for hours at a time. On others, this issue pops up consistently. We have swapped cameras, cables, etc.<br />
We thought perhaps it was ripple or other issues to supply. It does seem to happen more frequently when extensions are used, as expected.</p>
<p dir="auto">Perhaps EMI and need for more custom/shorter cables?</p>
]]></description><link>https://forum.modalai.com/topic/3363/voxl-camera-server-stalls-crash</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 00:45:39 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/3363.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Apr 2024 15:50:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to voxl-camera-server stalls/crash on Tue, 30 Apr 2024 20:51:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moderator" aria-label="Profile: Moderator">@<bdi>Moderator</bdi></a> we have tried swapping modules, cameras, and VOXL2(minis)</p>
<p dir="auto">Generally, it is exacerbated by the extension cables.</p>
]]></description><link>https://forum.modalai.com/post/16614</link><guid isPermaLink="true">https://forum.modalai.com/post/16614</guid><dc:creator><![CDATA[Steve Turner]]></dc:creator><pubDate>Tue, 30 Apr 2024 20:51:48 GMT</pubDate></item><item><title><![CDATA[Reply to voxl-camera-server stalls/crash on Sat, 27 Apr 2024 19:31:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/steve-turner" aria-label="Profile: Steve-Turner">@<bdi>Steve-Turner</bdi></a> Hi Steve, have you tried swapping cables and sensor modules? It seems most likely something is worn or loose.</p>
]]></description><link>https://forum.modalai.com/post/16553</link><guid isPermaLink="true">https://forum.modalai.com/post/16553</guid><dc:creator><![CDATA[Moderator]]></dc:creator><pubDate>Sat, 27 Apr 2024 19:31:27 GMT</pubDate></item></channel></rss>
