  3. KDE 4012XF motors with 16 in props
Scheduled Pinned Locked Moved ESCs, Sensors and Accessories
esc
22 Posts 3 Posters 7.4k Views 2 Watching
  • Chase RileyC Chase Riley
    @Alex-Kushleyev Were you able to post the instructions you were talking about? I am waiting on them to run through before I can get out and flight test again.
    @Chase-Riley , I am working on finalizing this.. should be done today within a few hours. I just wanted to double check - are you able to share which motors / props you are using? I just want to make sure the M0134-6 is powerful enough to support them. Also what battery voltage? 4S or 6S?
      Chase RileyC Offline
      Chase Riley
      @Alex-Kushleyev Would rather not share on here. If current draw is your worry I am below a 20 amp peak for each motor so the current 6s ESC should handle them fine. I also have a fan inside the AV blowing directly over the ESC.
        @Chase-Riley , absolutely no problem regarding sharing the motor / propeller specs.
        Alright, i have just posted initial instructions for low-kv motor tuning here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/doc/low_kv_motor_tuning.md . There is also a firmware update version 39 RC11 that you will need to install (this is part of the tuning instructions).
        Please go ahead and work through the procedure. It is quite detailed and goes beyond what is needed just for low-kv motors, but it represents pretty rigorous initial test that should be performed to ensure your motor will operate smoothly under various conditions.
        The parameter file ../voxl-esc-params/low_kv/mn4006_m0134_6_low_kv.xml should be a good start for your application, but do follow the instructions to check / update the params as instructed.
        Please let me know if you run into any issue or need clarification.
        The main idea behind testing new motor/prop combination is to start with "easy" tests and gradually ramp up the scope of test as you look at the data and become confident that it is working well. I would definitely avoid doing things like plugging in a new motor and prop and just going to 100% power command without a ramp :).
        I will be improving / updating the instructions in the coming days and will keep you posted about any major updates.
        Alex KushleyevA Chase RileyC 3 Replies Last reply
          @Chase-Riley , i forgot to mention.. a small fan blowing air over the ESC may not result in much cooling. Airflow from propellers could provide a lot more cooling than a small fan. Please keep an eye on the temperatures of the ESC. After you perform the tuning and calibration, you can run all 4 motors (loaded with propellers) on the bench at hover rpm (rpm needed for your vehicle to hover) for several minutes and look at the ESC temp (it will be printed live in the terminal when you use voxl-esc-spin.py test script.
          • Ideally the ESC temperature should stay below 60-70 C
          • 80C is acceptable
          • 90C is worrisome
          • 100C and above is critical
          ESC should still operate above 125C. The temperature on M0134-6 is measured inside the MCU, so the Mosfets are likely to be even hotter. At that point you will probably run into thermal runaway (the hotter the ESC gets, the faster it will continue to heat up) and eventually mosfets and / or copper traces may burn up.
            Chase Riley
            @Alex-Kushleyev I was able to install the new firmware to the ESC, however when I am trying to upload the new params file ../voxl-esc-params/low_kv/mn4006_m0134_6_low_kv.xml I receive the following error.
            [GCC 8.4.0]
            INFO: Params file name : /usr/share/modalai/voxl-esc-params/low_kv/mn4006_m0134_6_low_kv.xml
            INFO: Params file size : 8365 bytes
            VOXL Platform: M0054
            Detected VOXL2 M0054 or M0104!
            Found previous connection information in .voxl_esc_cache ..
            Prioritizing /dev/slpi-uart-2 @ 250000
            Sending library name request: libslpi_uart_bridge_slpi.so
            INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 250000
            INFO: ESCs detected:
            INFO: ---------------------
            ID: 0, SW: 39, HW: 41: Unknown Board
            ID: 1, SW: 39, HW: 41: Unknown Board
            ID: 2, SW: 39, HW: 41: Unknown Board
            ID: 3, SW: 39, HW: 41: Unknown Board
            ERROR: ESC firmware version 39 is incompatible with params supported by this utility
                   Acceptable ESC firmware versions are:  [38]```
              [GCC 8.4.0]
              @Chase-Riley please use the latest voxl-esc tools from dev branch:
              git clone https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc.git -b dev
              you can clone that directly to voxl2 and just use the python scripts directly (instead of voxl-esc wrapper), since you working on a custom esc tuning.
              Some helpful tips here too : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/recovery.md
                Chase Riley
                @Alex-Kushleyev I made sure to have the latest version and know I can not detect the esc. See below.
                [GCC 8.4.0]
                Found voxl-esc tools bin version: 1.5
                /usr/lib/libvoxl_io.so: undefined symbol: voxl_uart_init_legacy_slpi
                INFO: Scanning for ESC bootloader: /dev/slpi-uart-2, baud: 230400
                WARNING: No ESC(s) detected
                INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 230400
                INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 115200
                ERROR: not all ESCs found
                  [GCC 8.4.0]
                  @Chase-Riley said in KDE 4012XF motors with 16 in props:
                  this error means that you are using relatively old VOXL2 SDK -- the interface for the UART bridge (which connects the DSP uart to CPU) has changed.
                  Are you able to updated the VOXL2 SDK to 1.1.2? and then repeat the procedure using dev branch of voxl-esc ?
                    Chase Riley
                    @Alex-Kushleyev Would rather not update if possible. I have spent months getting everything to work in 1.0. What would be affected if I did make the upgrade? Would I lose any config or param files?
                      @Chase-Riley OK
                      In this case, please try voxl-esc from this commit : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/066b6308611ac162342a716689d1b4ebe82b1a63
                      This is right before the DSP bridge interface changed and it should support firmware 39 in param update:
                      https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/066b6308611ac162342a716689d1b4ebe82b1a63/voxl-esc-tools/voxl-esc-upload-params.py#L58
                      However, still use the firmware and params that i originally posted for the low kv motor tuning
                        @Chase-Riley OK
                        also tag 1.3.2 should work https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tags/v1.3.2
                          Chase Riley
                          @Alex-Kushleyev 1.3.2 seemed to have got the job done. I will let you know if I run in to anymore issues while tuning the esc.
                            @Chase-Riley , great!
                            Now, the tools in latest dev branch have some improvements including plotting. Can you please try one more thing:
                            • use voxl-esc dev branch
                            • replace the following file from v1.3.2, which will allow you to use the old uart bridge interface : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-tools/voxl_serial.py replace with https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/v1.3.2/voxl-esc-tools/voxl_serial.py
                            this will be easier to support
                              @Matthew-Wellner FYI
