    RPM control
    VOXL SDK
    4531
    • Jeffrey MaoJ
      Jeffrey Mao
      I was wondering if there was any resources on the newest SDK 1.1.1 to send RPM in C++. I realized in the newest SDK you guys can directly flash the ESC after disabling voxl-px4.
      Previously on other SDK, We were using the following SLPI library, but it is incompatible with the newest SDK.
      voxl-slpi-uart-bridge_1.0.0-202303130921_arm64.deb
      With the following header in C++
      https://gitlab.com/voxl-public/voxl-sdk/core-libs/voxl-slpi-uart-bridge/-/blob/master/apps/inc/voxl_slpi_uart_bridge_interface.h
      To move to ROS2, we updated the SDK, but this sort of connection or library can no longer be installed. I was wondering if there is a new library that we can link too and if it has a similar to header to SLPI bridge that we can link to send RPM commands.
        Alex Kushleyev ModalAI Team @Jeffrey Mao
        @Jeffrey-Mao , we moved the a new api, but the legacy api is also supported, please see updated voxl-serial.py , which is used in voxl-esc tools. Please see the following : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-tools/voxl_serial.py
        The bridge functionality has been included into https://gitlab.com/voxl-public/voxl-sdk/core-libs/libqrb5165-io library which has the cpu side libvoxl_io.so which you should link your cpu application against. there is also the slpi library libslpi_qrb5165_io.so which gets loaded when you initialize the cpu-side library : https://gitlab.com/voxl-public/voxl-sdk/core-libs/libqrb5165-io/-/blob/master/apps/library/src/uart.c?ref_type=heads#L174 .
        You can use the new interface to include in your cpu application : https://gitlab.com/voxl-public/voxl-sdk/core-libs/libqrb5165-io/-/blob/master/apps/library/include/voxl_io/uart.h
        Please let me know if you have any other questions!
        • N
          nbobbili
          Hi Alex,
          We are currently trying to get RPM control working along with the new SDK in ROS2 and have run into a couple issues.
          1. We followed your suggestion and included the UART library onto the drone. After building successfully, we tried sending RPMs through our ROS2 rpm interface and got the error:
          "ERROR:   Received error from ring_buf_push in p_slpi_receive_callback: ERR_NO_SPACE"
          Do you have any suggestions on how we might fix this issue?
          Additionally, we had a question regarding the UART and px4 interfaces.
          2) Is it possible to run both the UART voxl esc and px4 in parallel? Our idea was to disable the px4 ESC driver manually when px4 first starts up but were not able to use the UART successfully, with the error:
          ERROR:   voxl_uart_write: Bus '12' is not initialized
          If you have any insights or suggestions, we would greatly appreciate it.
          Thank you!
          Nishanth
            Alex Kushleyev ModalAI Team @nbobbili
            @nbobbili ,
            Regarding question 2, you cannot use the uart bridge concurrently with PX4 running on the SLPI (DSP). Currently, our interface only supports running once application at a time. I believe previously, you were not using PX4 at all and running custom code on the CPU side, right?
            Regarding question 1,
            • please make sure that px4 is disabled (systemctl disable voxl-px4)
            • if there is still an issue, can you please check if you can use voxl-esc tools (just run voxl-esc scan from voxl2 terminal)
            N 1 Reply Last reply Reply Quote 0
            • N
              nbobbili @Alex Kushleyev
              Regarding question 2, you are right, we did not use px4 before this and ran a custom node on the CPU. But now, we need to do some outdoor flights with GPS, and therefore need the voxl-px4.
              Do you think there is any other way we can do this? For us to be able to get vehicle odometry using GPS without PX4?
              I confirmed that the voxl-px4 is infact disabled and the voxl-esc scan successfully finds 4 ESC's. I wonder if this is related to the voxl_uart_write function call?
              Thank you!
                @nbobbili ,
                You can probably set up PX4 to run entirely on CPU . VOXL2 has an IMU attached directly to CPU (available via voxl-imu-server). You can also hook up a generic GPS unit to UART that is mapped to CPU -- that is all you would need, right? Maybe Mag as well, that would be i2c. Then you can pull off the state estimate from PX4 based on imu/gps/mag..
                Hmm not sure why "ringbuffer" issue. I will need to update the C++ example we had for the slpi bridge to use the new API and test.. I will try to do it soon.
                Another approach would be to include the slpi bridge functionality into PX4 build. it does not exist now, but it could potentially be added.. I will take a look at it.
                  Regarding the ring buffer issue, please double check your code and refer to the voxl-esc python code, which loads the .so and calls the C functions just like you would call from a C++ app:
                  https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-tools/voxl_serial.py?ref_type=heads
                  I suspect that you are not reading data from the uart bridge and the buffer fills with the ESC feedback data. The ESC feedback is requested as part of the ESC commands that you send.
                  Here is the line of code that is printing the error : https://gitlab.com/voxl-public/voxl-sdk/core-libs/libqrb5165-io/-/blob/master/apps/library/src/uart.c?ref_type=heads#L156 -- it is inside the function that receives data from SLPI
                  Finally, what I initially said about including SLPI bridge into PX4, that was just an idea, but it is not a long-term solution, so it will not be implemented. Sorry!
                  • N
                    nbobbili
                    Alex,
                    Regarding the ring buffer issue...
                    We checked our code and the only two functions we use are voxl_uart_init and voxl_uart_write, which from the voxl_serial.py script, we should be find to use.
                    For the voxl_uart_write function, we are currently passing (SLPI_QUP2_UART, tx_buf, packet_length) where
                    uint8_t tx_buf[128];
                    int32_t packet_length = qc_esc_create_rpm_packet4_fb(rpm0, rpm1, rpm2, rpm3, led, led, led, led, cntr, tx_buf, sizeof(tx_buf));
                    Aside from this, we are not interacting with the ESC at all, so the error must be coming from one of these functions being called.
                    Do you have any ideas for us by chance?
                    Thank you for your insights and time!
                      @nbobbili , when you send rpm control packet, this also requests feedback from ESCs, so each ESC will send some data back to VOXL2 (one ESC id at a time).
                      If you do not read from the same serial port that you are writing to, the data coming back from ESCs will fill the RX buffer (in slpi-cpu bridge) and you will get this message of ring buffer full.
                      If you do not wish to parse the ESC feedback data, just read and discard all bytes right after you write the RPM commands.
                      • wilkinsafW
                        wilkinsaf ModalAI Team
                        We were seeing the same issue, but for a different reason.. this is how we fixed it
                        https://www.loom.com/share/72ed330246414d8db0f7d4f1c18999e8
                        We essentially deleted the ips for primary_gcs and secondary_gcs in voxl-mavlink-server
                        wilkinsafW 1 Reply Last reply Reply Quote 0
                        • wilkinsafW
                          wilkinsaf ModalAI Team @wilkinsaf
                          @wilkinsaf For context we are connected to an external flight controller over UART DSP
                          • J
                            jenyeom @Alex Kushleyev
                            @Alex-Kushleyev going back to getting RPM control working on ROS2 and SDK 1.1+...
                            Our current findings:
                            ROS2 Humble with SDK 0.8 and the old library (installed with voxl-slpi-uart-bridge_1.0.0-202303130921_arm64.deb) is working well without any issues.
                            ROS2 Humble with SDK 1.1+ and the new library libvoxl_io.so and new interface (uart.h) has high frequency oscillations when flying the drone.
                            We've tried many things to incldue:
                            1. Updating the crc16.h/c and qc_esc_packet.h/c and other dependent code from:
                              [https://github.com/modalai/px4-firmware/blob/main/src/drivers/actuators/voxl_esc]
                            2. Exhaustive gain tuing 😞
                            3. Delay time analysis within our control stack
                            4. Experiments with different baudrates
                            None of which solved the issue or clarified why we are currently having this issue on SDK 1.1+ with the new SLPI library.
                            Of note, we are using the functions:
                            voxl_uart_init(SLPI_QUP2_UART, 250000, 0.1, 0, 1, 0); to initialize the UART,
                            int32_t packet_length = qc_esc_create_rpm_packet4_fb(rpm0, rpm1, rpm2, rpm3, led, led, led, led, cntr, tx_buf, sizeof(tx_buf), 0); to create packets,
                            and int ret2 = voxl_uart_write(SLPI_QUP2_UART, tx_buf, packet_length); to actually send the rpms.
                            Additionally we are using voxl_uart_flush(SLPI_QUP2_UART); because we were having issues with the ring buffer overflow.
                            We are running everything in ROS2 at 500Hz.
                            Do you have any thoughts on this?
                            Any ideas on what we might try next?
                            Thanks in advance.
                              Alex Kushleyev ModalAI Team @jenyeom
                              @jenyeom,
                              I would recommend somehow logging the timestamps right before and after sensing our the uart packet to the uart bridge. This will give you two things: you can analyze how regular the rpm updates are coming from ROS, and if for some reason the write call takes too long. Also check how long uart flush is taking!
                              If you dont want any esc to send feedback, you can set the esc feedback id to -1, i believe, then you dont need to do uart flush. It should be documented in the packet api source code
                              • J
                                @Alex-Kushleyev thanks for the suggestions!
                                I did some testing logging timestamps today and here is what I've found.
                                There was definitely some additional delay when using the voxl_uart_read_bytes function, so currently I am exclusively running the qc_esc_create_rpm_packet4_fb and voxl_uart_write functions.
                                With those two functions, we are still experiencing high frequency oscillations.
                                Here is what the time differences (dt) look like when sending rpms to the esc:
                                The dt goes up to greater than 0.003 sec every now and then, which is why I think we have oscillation issues as we trying to send rpm commands at 500 Hz.
                                Are these 'spikes' in time something you would expect?
                                We are not currently running any other functions in the rpm callback, only the creation of the packets and writing to the uart.
                                Thanks for your help, Alex.
                                  @jenyeom , you are running your application on the CPU, so there are no real time guarantees. You should set the cpu into perf mode if you are not already doing that (voxl-set-cpu-mode perf). Additionally, if you can increase cpu priority of your ros node, do that. Finally, i would suggest updating the baud rate of the esc to 2Mbit (2000000) from 250k. This will further reduce actuator latency. Change the param in esc params first and then update your ros node to use 2mbit. Finally, it can help, if you have an oscilloscope, to look at tx line from voxl2 to see if there are 500hz on average packets going out or are there frequent gaps that would suggest dropped outgoing packets (for whatever reason).
                                  Jeffrey MaoJ 1 Reply Last reply Reply Quote 0
                                  • Jeffrey MaoJ
                                    Jeffrey Mao @Alex Kushleyev
                                    By the way Alex to add on to this would it be possible for us to acquire a version of the libqrb5165-io that does NOT contain the slpi_uart_bridge portion?
                                    https://gitlab.com/voxl-public/voxl-sdk/core-libs/libqrb5165-io/-/tree/master?ref_type=heads
                                    Or we can have a version that allows us to to old voxl-slpi-uart-bridge_1.0.0-202303130921_arm64.deb on the newest SDK?
                                    I don't believe it is a CPU performance issue because our drone is always in performance mode and has a very high baud rate as recommended and the osccilations in flight. The only way to remove those oscillations is to downgrade the SDK 0.8 and use this library voxl-slpi-uart-bridge_1.0.0-202303130921_arm64.deb to send RPM.
                                    Since the hardware and our own software stack hasn't changed between these runs. I think the problem lies somewhere inside the SDK and the library. If we could simply install the older SDK Uart bridge then I believe that should show where the problem is.
                                    Jeff
                                      @Jeffrey-Mao,
                                      It should be possible. You would need an older slpi firmware image that goes with the older uart bridge. I will check with @Eric-Katzfey . Since you dont use px4 on slpi, i think we may be able to downgrade the slpi image without affecting anything else.
                                      I am curious why you are having performance issues with the latest bridge. I will be back to office on Wednesday and can run some tests using our python and c++ api for the uart bridge.
                                      • J
                                        Just a quick update on this journey...
                                        We completed a full downgrade to SDK 0.8 and still experienced oscillations - so it doesn't seem to be an SDK issue.
                                        The last thing that I can think could be an issue is the updated firmware of the ESC (39) that automatically happens when you update the SDK to 1.1+
                                        Or maybe it was an ESC issue all along..? its hard to say at this point.
                                        In order to track this down, I attempted to downgrade our current ESC to version 36 and had some issues with the baud rate not updating (it seemed to be stuck at a baud rate of 57600). And while updating and checking firmware/parameters, I lost all communication with the ESC.
                                        Here is my post on the ESC page about it:
                                        (https://forum.modalai.com/topic/3310/escs-not-found-esc-bricked)
                                          @jenyeom , there have not been any performance-related changes in the ESC firmware since version 36. The only main change was a change in param structure, if you wanted to use that firmware, you would have to use voxl-esc tools and params from this branch : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/params-v1/voxl-esc-tools.
                                          What could have happened, if you were running older firmware / params before, after the SDK install, the firmware was updated and params as well, and it is possible that ESC params that were installed are not what you needed - that would definitely mess things up.
                                          At this point, i would suggest finding the old ESC params that you were using (i am assuming that you have a custom motor / propeller and you performed the ESC calibration). I can help you updating these params to be compatible with latest firmware (easy).
                                          To recover the ESC to latest firmware, use:
                                          • latest voxl-esc tools from dev branch : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/dev/voxl-esc-tools
                                          • perform voxl-esc-scan.py, it should find all 4 ESCs, potentially running at different uart baud rates
                                          • upgrade firmware to latest using ./voxl-esc-upload-firmware-all.sh , which is a wrapper for voxl-esc-upload-firmware.py . please keep track of which ESCs were updated
                                          • upload latest compatible params (you can use generic params for now) : for example from here https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-params/boards/esc_params_generic_m0134.xml . Later you can update params with your actual tuning results.
                                          • ./voxl-esc-scan.py to scan the escs
                                          • './voxl-esc-verify-params.py` to verify params
                                          • J
                                            Thanks for the quick response.
                                            I was able to upload firmware version 36, but had issues getting the ESC set to the right baud rate, using voxl-esc-upload-params.py. Even though I was giving it 250,000 as the baud rate, it seemed to be stuck at 57600, which may have been a hint that the params were not loading well (after further reading in the forums and modalai documentation).
                                            However, now I cannot even communicate with the ESC.
                                            Here is what I get when I try the voxl-esc-scan.py script:
                                            Could I have bricked the ESC...?
                                            Any idea how I might go about reviving it?
                                            Nothing (uplading firmware or parameter or scanning) seems to work at this point.
                                            Thanks much!
