  4. DSP Tasks Failing Unless mini-dm is Run
21 Posts 3 Posters 8.1k Views 1 Watching
  • E Offline
    E Offline
    ejohnson01
    We are experiencing issues with voxl-px4. We notice on our GCS that we are constantly gaining and loosing rc connection and the mavlink telemetry stream is extremely laggy.
    We seem to be observing strange behavior with tasks running on o observing strange behavior with tasks running on our DSP. If we start PX4 from a cold boot, it never works correctly, and we see sensor timeouts printing on the output of voxl-px4 from the SLPI shown in the console output below.
    Even more strange is that when we plug in a usbc cable to our voxl2 and run mini-dm the problem seems to go away. After mini-dm is run once we are able to stop and start px4 with no issue. Once we power cycle our voxl then the problem returns until we plug in and run mini-dm again.
    We are running a slightly modified version of this commit of px4.
    https://github.com/modalai/px4-firmware/tree/cf055af349bcd7a141640936184e03054863022b
    it is the commit that is tagged in the voxl-px4 sdkv1.1.1 tag.
    this is the voxl2 sku info
    root@microUAS1:~/mav_ws# voxl-inspect-sku
    family code:   MCCA-M0054 (voxl2-board-only)
    compute board: 4 (voxl2)
    hw version:    1
    cam config:    8
    SKU:           MCCA-M0054-C8
    we are also using the voxl2io board which we believe has the legacy firmware (red light with blinking blue light) to communicate with our sbus reciever.
    Do you all have any thoughts on what might be happening here?
    here is what our GCS shows:
    here is the console output from running
    root@microUAS1:~/mav_ws# voxl-px4 -g -n -s
    Found DSP signature file
    [INFO] GR-12L SBUS Reciever Selected
    [INFO] MRO M9N with MAG IST8308 selected
    [INFO] SDP3X airspeed sensor selected
    [INFO] Daemon mode enabled
    GPS=MRO_M9N
    RC=M0065_SBUS
    ESC=VOXL_ESC
    POWER MANAGER=VOXLPM
    DISTANCE SENSOR=NONE
    OSD=DISABLE
    DAEMON_MODE=ENABLE
    SENSOR_CAL=ACTUAL
    EXTRA STEPS:
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    GPS: MRO_M9N
    RC: M0065_SBUS
    ESC: VOXL_ESC
    POWER MANAGER: VOXLPM
    DISTANCE SENSOR: NONE
    OSD: DISABLE
    AISPEED SENSOR: SDP3X
    EXTRA STEPS:
    Running on M0054
    INFO  [parameters] BSON document size 3367 bytes, decoded 3367 bytes (INT32:55, FLOAT:104)
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: >>> ICM42688P this: 3176d110
    INFO  [qshell] qshell return value timestamp: 102630757, local time: 102636903
    INFO  [muorb] SLPI: Register interrupt b21d3164 e61f8ddc 3176d110
    INFO  [muorb] SLPI:
    INFO  [qshell] qshell return value timestamp: 102673513, local time: 102677483
    INFO  [qshell] Send cmd: 'qmc5883l start -R 0 -X -b 1'
    INFO  [muorb] SLPI: qshell gotten: qmc5883l start -R 0 -X -b 1
    INFO  [muorb] SLPI:   arg3 = '0'
    INFO  [muorb] SLPI: qmc5883l #0 on I2C bus 1
    INFO  [muorb] SLPI:  address 0xD
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: qmc5883l start -R 0 -X -b 1
    INFO  [qshell] qshell return value timestamp: 102734319, local time: 102738429
    INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097648
    INFO  [qshell] qshell return value timestamp: 102790110, local time: 102791873
    Looking for ncp5623c RGB LED
    INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
    INFO  [muorb] SLPI:  address 0x38
    INFO  [muorb] SLPI:
    INFO  [qshell] qshell return value timestamp: 102875392, local time: 102878649
    Starting VOXL ESC driver
    INFO  [qshell] Send cmd: 'voxl_esc start'
    INFO  [muorb] SLPI: qshell gotten: voxl_esc start
    INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
    INFO  [muorb] SLPI: Ok executing command: voxl_esc start
    INFO  [muorb] SLPI: Opened UART ESC device
    INFO  [qshell] qshell return value timestamp: 103031754, local time: 103033825
    Attempting to start M0065 SBUS RC driver for original M0065 FW
    INFO  [uORB] Advertising remote topic esc_status
    INFO  [muorb] SLPI: qshell gotten: dsp_sbus start
    INFO  [muorb] SLPI:   arg0 = 'dsp_sbus'
    INFO  [qshell] Send cmd: 'dsp_sbus start'
    INFO  [muorb] SLPI: Creating pthread dsp_sbus_main
    INFO  [muorb] SLPI: Successfully created px4 task PX4_dsp_sbus_main with tid 2097645
    INFO  [muorb] SLPI: Ok executing command: dsp_sbus start
    INFO  [qshell] qshell return value timestamp: 103092449, local time: 103095538
    INFO  [uORB] Advertising remote topic input_rc
    INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
    INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
    INFO  [muorb] SLPI:   arg0 = 'voxlpm'
    INFO  [muorb] SLPI:   arg4 = '2'
    INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
    INFO  [muorb] SLPI: Set i2c address 0x6a, fd 3
    INFO  [muorb] SLPI: Set i2c address 0x44, fd 3
    INFO  [uORB] Advertising remote topic battery_status
    INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
    INFO  [muorb] SLPI:  address 0x44
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
    INFO  [uORB] Advertising remote topic power_monitor
    INFO  [qshell] qshell return value timestamp: 103159043, local time: 103161281
    starting sdp3x
    INFO  [muorb] SLPI: u-blox firmware version: SPG 4.04
    INFO  [muorb] SLPI: u-blox protocol version: 32.01
    INFO  [muorb] SLPI: u-blox module: NEO-M9N
    INFO  [qshell] Send cmd: 'sdp3x start -X -a 0x21 -b 4'
    INFO  [muorb] SLPI: qshell gotten: sdp3x start -X -a 0x21 -b 4
    INFO  [muorb] SLPI:   arg0 = 'sdp3x'
    INFO  [muorb] SLPI:   arg3 = '-a'
    INFO  [muorb] SLPI:   arg4 = '0x21'
    INFO  [muorb] SLPI:   arg6 = '4'
    INFO  [muorb] SLPI: *** I2C Device ID 0x4a2121 4858145
    INFO  [muorb] SLPI: sdp3x #0 on I2C bus 4
    INFO  [muorb] SLPI:  address 0x21
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: sdp3x start -X -a 0x21 -b 4
    INFO  [qshell] qshell return value timestamp: 103212466, local time: 103214889
    INFO  [uORB] Advertising remote topic differential_pressure
    ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_GPS_MASK
    INFO  [uORB] Advertising remote topic sensors_status_mag
    INFO  [qshell] qshell return value timestamp: 103496668, local time: 103505109
    INFO  [uORB] Advertising remote topic airspeed
    INFO  [uORB] Advertising remote topic sensor_gps
    INFO  [qshell] qshell return value timestamp: 103856924, local time: 103862916
    INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
    INFO  [uORB] Advertising remote topic estimator_aid_src_airspeed
    INFO  [qshell] Send cmd: 'mc_pos_control start vtol'
    INFO  [muorb] SLPI: qshell gotten: mc_pos_control start vtol
    INFO  [muorb] SLPI:   arg2 = 'vtol'
    INFO  [muorb] SLPI: Ok executing command: mc_pos_control start vtol
    INFO  [qshell] qshell return value timestamp: 104032898, local time: 104035892
    INFO  [qshell] Send cmd: 'mc_att_control start vtol'
    INFO  [muorb] SLPI: qshell gotten: mc_att_control start vtol
    INFO  [muorb] SLPI: Ok executing command: mc_att_control start vtol
    INFO  [qshell] qshell return value timestamp: 104111040, local time: 104112332
    INFO  [qshell] Send cmd: 'mc_rate_control start vtol'
    INFO  [muorb] SLPI: qshell gotten: mc_rate_control start vtol
    INFO  [muorb] SLPI: Ok executing command: mc_rate_control start vtol
    INFO  [qshell] qshell return value timestamp: 104259148, local time: 104261585
    INFO  [qshell] qshell return value timestamp: 104344496, local time: 104346060
    INFO  [qshell] qshell return value timestamp: 104414886, local time: 104418065
    INFO  [qshell] Send cmd: 'land_detector start vtol'
    INFO  [muorb] SLPI: qshell gotten: land_detector start vtol
    INFO  [muorb] SLPI:   arg0 = 'land_detector'
    INFO  [muorb] SLPI: Ok executing command: land_detector start vtol
    INFO  [qshell] qshell return value timestamp: 104496547, local time: 104497727
    INFO  [uORB] Advertising remote topic vehicle_land_detected
    INFO  [qshell] Send cmd: 'manual_control start'
    INFO  [muorb] SLPI: qshell gotten: manual_control start
    INFO  [muorb] SLPI:   arg0 = 'manual_control'
    INFO  [muorb] SLPI: Ok executing command: manual_control start
    INFO  [uORB] Advertising remote topic manual_control_setpoint
    INFO  [qshell] qshell return value timestamp: 104569964, local time: 104571796
    INFO  [qshell] Send cmd: 'control_allocator start'
    INFO  [muorb] SLPI: qshell gotten: control_allocator start
    INFO  [muorb] SLPI:   arg0 = 'control_allocator'
    INFO  [uORB] Advertising remote topic control_allocator_status
    INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
    INFO  [uORB] Advertising remote topic actuator_motors
    INFO  [uORB] Advertising remote topic actuator_servos
    INFO  [uORB] Advertising remote topic actuator_servos_trim
    INFO  [muorb] SLPI: Ok executing command: control_allocator start
    INFO  [qshell] qshell return value timestamp: 104924910, local time: 104928529
    INFO  [qshell] Send cmd: 'load_mon start'
    INFO  [muorb] SLPI: qshell gotten: load_mon start
    INFO  [muorb] SLPI:   arg0 = 'load_mon'
    INFO  [muorb] SLPI: Ok executing command: load_mon start
    INFO  [uORB] Advertising remote topic cpuload
    INFO  [qshell] qshell return value timestamp: 104994040, local time: 104996985
    INFO  [qshell] Send cmd: 'vtol_att_control start'
    INFO  [muorb] SLPI: qshell gotten: vtol_att_control start
    INFO  [muorb] SLPI:   arg0 = 'vtol_att_control'
    INFO  [uORB] Advertising remote topic flaps_setpoint
    INFO  [uORB] Advertising remote topic spoilers_setpoint
    INFO  [uORB] Advertising remote topic vtol_vehicle_status
    INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
    INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
    INFO  [uORB] Marking DeviceNode(vehicle_thrust_setpoint) as advertised in process_remote_topic
    INFO  [uORB] Marking DeviceNode(vehicle_torque_setpoint) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Ok executing command: vtol_att_control start
    INFO  [qshell] qshell return value timestamp: 105128451, local time: 105136476
    INFO  [qshell] Send cmd: 'fw_rate_control start vtol'
    INFO  [muorb] SLPI: qshell gotten: fw_rate_control start vtol
    INFO  [muorb] SLPI:   arg0 = 'fw_rate_control'
    INFO  [uORB] Marking DeviceNode(rate_ctrl_status) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Ok executing command: fw_rate_control start vtol
    INFO  [qshell] qshell return value timestamp: 105278018, local time: 105281688
    INFO  [qshell] Send cmd: 'fw_att_control start vtol'
    INFO  [muorb] SLPI: qshell gotten: fw_att_control start vtol
    INFO  [muorb] SLPI:   arg0 = 'fw_att_control'
    INFO  [muorb] SLPI: Ok executing command: fw_att_control start vtol
    INFO  [uORB] Advertising remote topic landing_gear_wheel
    INFO  [qshell] qshell return value timestamp: 105379888, local time: 105387644
    INFO  [qshell] Send cmd: 'fw_pos_control start vtol'
    INFO  [muorb] SLPI: qshell gotten: fw_pos_control start vtol
    INFO  [muorb] SLPI:   arg0 = 'fw_pos_control'
    INFO  [uORB] Advertising remote topic actuator_controls_status_1
    INFO  [uORB] Advertising remote topic position_controller_status
    INFO  [uORB] Advertising remote topic position_controller_landing_status
    INFO  [uORB] Advertising remote topic tecs_status
    INFO  [uORB] Advertising remote topic launch_detection_status
    INFO  [uORB] Marking DeviceNode(flaps_setpoint) as advertised in process_remote_topic
    INFO  [uORB] Marking DeviceNode(spoilers_setpoint) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Ok executing command: fw_pos_control start vtol
    INFO  [qshell] qshell return value timestamp: 105719884, local time: 105723062
    INFO  [qshell] Send cmd: 'fw_autotune_attitude_control start vtol'
    INFO  [muorb] SLPI: qshell gotten: fw_autotune_attitude_control start vtol
    INFO  [muorb] SLPI:   arg0 = 'fw_autotune_attitude_control'
    INFO  [uORB] Marking DeviceNode(autotune_attitude_control_status) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Ok executing command: fw_autotune_attitude_control start vtol
    INFO  [qshell] qshell return value timestamp: 105788032, local time: 105790087
    INFO  [qshell] Send cmd: 'airspeed_selector start'
    INFO  [muorb] SLPI: qshell gotten: airspeed_selector start
    INFO  [muorb] SLPI:   arg0 = 'airspeed_selector'
    INFO  [uORB] Advertising remote topic airspeed_validated
    INFO  [uORB] Advertising remote topic airspeed_wind
    INFO  [uORB] Marking DeviceNode(airspeed_wind) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Ok executing command: airspeed_selector start
    INFO  [qshell] qshell return value timestamp: 105909388, local time: 105911596
    INFO  [qshell] Send cmd: 'rc_update start'
    INFO  [muorb] SLPI: qshell gotten: rc_update start
    INFO  [muorb] SLPI:   arg0 = 'rc_update'
    INFO  [muorb] SLPI: Ok executing command: rc_update start
    INFO  [qshell] qshell return value timestamp: 106355536, local time: 106357417
    INFO  [uORB] Advertising remote topic rc_channels
    INFO  [muorb] SLPI: qshell gotten: commander start
    INFO  [qshell] Send cmd: 'commander start'
    INFO  [muorb] SLPI:   arg0 = 'commander'
    INFO  [muorb] SLPI: Creating pthread commander
    INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097639
    INFO  [uORB] Advertising remote topic manual_control_input
    INFO  [uORB] Advertising remote topic manual_control_switches
    INFO  [uORB] Advertising remote topic action_request
    INFO  [muorb] SLPI: Ok executing command: commander start
    INFO  [uORB] Advertising remote topic led_control
    INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
    INFO  [uORB] Advertising remote topic tune_control
    INFO  [qshell] qshell return value timestamp: 106650894, local time: 106653867
    INFO  [uORB] Advertising remote topic event
    INFO  [uORB] Advertising remote topic mavlink_log
    INFO  [muorb] SLPI: Preflight Fail: No connection to the ground control station
    INFO  [uORB] Advertising remote topic health_report
    INFO  [uORB] Advertising remote topic failsafe_flags
    INFO  [uORB] Advertising remote topic actuator_armed
    INFO  [uORB] Advertising remote topic vehicle_control_mode
    INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint_virtual_mc
    INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint_virtual_fw
    INFO  [uORB] Advertising remote topic vehicle_torque_setpoint_virtual_fw
    INFO  [uORB] Advertising remote topic vehicle_torque_setpoint_virtual_mc
    INFO  [uORB] Advertising remote topic vehicle_status
    INFO  [uORB] Advertising remote topic failure_detector_status
    INFO  [uORB] Advertising remote topic mc_virtual_attitude_setpoint
    INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
    INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
    INFO  [uORB] Advertising remote topic vehicle_local_position_setpoint
    INFO  [uORB] Marking DeviceNode(mc_virtual_attitude_setpoint) as advertised in process_remote_topic
    INFO  [qshell] Send cmd: 'flight_mode_manager start'
    INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
    INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
    INFO  [uORB] Advertising remote topic vehicle_command
    INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
    INFO  [qshell] qshell return value timestamp: 106931567, local time: 106935102
    INFO  [uORB] Advertising remote topic trajectory_setpoint
    INFO  [uORB] Advertising remote topic vehicle_constraints
    INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
    /usr/bin/voxl-px4-start: line 234: px4-modal_io_bridge: command not found
    /usr/bin/voxl-px4-start: line 237: microdds_client: command not found
    no dds namespace set
    using DOM ID: 1
    INFO  [muorb] SLPI: Advertising remote topic transponder_report
    INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
    INFO  [uORB] Advertising remote topic actuator_controls_status_0
    INFO  [muorb] SLPI: Advertising remote topic telemetry_status
    INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    INFO  [muorb] SLPI: Advertising remote topic timesync_status
    INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
    INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
    INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
    INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    INFO  [uORB] Marking DeviceNode(mavlink_log) as advertised in process_remote_topic
    ERROR [muorb] SLPI: Accel #0 fail:  TIMEOUT!
    ERROR [muorb] SLPI: MAG #0 failed:  TIMEOUT!
    INFO  [uORB] Marking DeviceNode(landing_gear) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command_ack) as advertised in process_remote_topic
    INFO  [muorb] SLPI: Advertising remote topic ping
    ^C
    PX4 Exiting...
    Exiting NOW.
    • E ejohnson01
      hw version:    1
      cam config:    8
      SKU:           MCCA-M0054-C8
      GPS=MRO_M9N
      RC=M0065_SBUS
      ESC=VOXL_ESC
      OSD=DISABLE
      DAEMON_MODE=ENABLE
      SENSOR_CAL=ACTUAL
      EXTRA STEPS:
      ______  __   __    ___
      | ___ \ \ \ / /   /   |
      | |_/ /  \ V /   / /| |
      |  __/   /   \  / /_| |
      | |     / /^\ \ \___  |
      \_|     \/   \/     |_/
      px4 starting.
      GPS: MRO_M9N
      RC: M0065_SBUS
      ESC: VOXL_ESC
      OSD: DISABLE
      EXTRA STEPS:
      Running on M0054
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      starting sdp3x
      INFO  [muorb] SLPI:
      using DOM ID: 1
      ^C
      PX4 Exiting...
      Exiting NOW.
      @ejohnson01 You said you are running a modified version of voxl-px4. Does this problem still happen with the unmodified version of voxl-px4 that came with the SDK release?
      E 1 Reply Last reply
        E Offline
        E Offline
        ejohnson01
        @Eric-Katzfey that was a good question. today I setup my bench to run the px4 version in sdkv1.1.1 and at first I was unable to recreate the problem.
        After further testing I noticed the behavior happening when we would upload our qgc param file from the previous version. My co-worker and I spent some time and isolated the parameters that were the problem children. For what ever reason the parameters below when uploaded via a QGC file is causing the problem
        1	1	COM_FLTMODE1	-1	6
        1	1	COM_FLTMODE2	1	6
        1	1	COM_FLTMODE3	-1	6
        1	1	COM_FLTMODE4	2	6
        1	1	COM_FLTMODE5	-1	6
        1	1	COM_FLTMODE6	2	6
        I then set the bench back to the stable sdkv1.1.1 version and created a parameter file with only the parameters above and I was able to see the same problem.
        Steps to recreate
        make sure you run all commands over ssh and do not create an adb session.
        • load stable version of px4. (voxl-px4_1.14.0-2.0.59_arm64.deb)
        • remove old parameters by running rm -rf /data/px4/param/*
        • run voxl-px4 once to set the parameters back to default
        • power cycle
        • make sure sbus receiver and controller are powered on and connected.
        • run voxl-px4
        • open up QGC and the problem should be visible
        I honestly have no Idea why uploading these params in particular break px4. we were able to upload all the other params in the file just fine.
        Work around
        We did discover a work around. If we upload all our old params but the ones listed above and then configure them via QGC the problem does not present itself. The super weird thing about this is that I can then download the parameters and diff them vs the old ones and the above parameters will show as identical.
        Also I can not explain why connecting to the voxl with mini-dm once per boot resolves this issue. I did do further testing on though. It seems like if you open up an adb shell it also resolves this issue similar to using mini-dm, which i guess mini-dm works via adb so its probably the debug link that fixes this problem.
        We are able to continue testing using our work around, but I would be very interested to see what the root of this issue is. Let me know if you all are able to recreate and or if you need more information.
        Eric KatzfeyE E 2 Replies Last reply
        • E ejohnson01
          Steps to recreate
          • power cycle
          • run voxl-px4
          Work around
          @ejohnson01 Wow, that's an odd one! Thanks for the update. Not sure when I can get to it but now I am also curious as to why that would cause an issue with px4.
          • E ejohnson01
            Steps to recreate
            • power cycle
            • run voxl-px4
            Work around
            E Offline
            E Offline
            ejohnson01
            @ejohnson01 I realized I messed up the steps to recreate
            Steps to recreate
            power cycle
            run voxl-px4.
            open up QGC
            upload a QGC file with the above listed parameters
            restart voxl-px4 and the problem should be present
            • B Offline
              B Offline
              bhanner-bell
              I just wanted to add some more context to hopefully work towards a solution as @ejohnson01 and I been trying to overcome this issue for the better part of a week now.
              I think that the parameter issue may have been a red herring because we have now been able to reproduce the issue in other ways.
              We were able to find that using px4-uorb top when things are working, yields around ~350kB/s of traffic.
              Whenever we plug in a joystick from QGC or power on a transmitter via SBUS things start going haywire (coincidentally right when the uorb message "manual_control_setpoint" starts getting published). The data rate on uorb top tanks by over half, things start becoming unresponsive, and they don't recover until a PX4 restart.
              Are there ways to profile the PX4 tasks that are running on the SLPI? The Linux side shows ~70% of a single core and mini-dm is showing ~70% utilization of the SLPI when things are going bad (contrasted by, I believe, ~50% on Linux and ~45% on SLPI when things are working).
              I just cant help but think there is some task running either on Linux or on the SLPI that is occupying too many resources or filling a buffer that cant be cleared or something along those lines but we can't find the right tool to profile what's going on.
              • B bhanner-bell
                @bhanner-bell Hmmm, yes, 70% is a bit high. I generally like to see things 60% or lower. There isn't really a good tool to do that kind of profiling. There is a system level profiler included with the Hexagon SDK from Qualcomm that allows you to see how much CPU time each thread is taking. I have used that in the past to help me determine thread priorities. But it would be nice to have a statistical profiler that can tell you which lines of code are running most often. I think it would be possible to create a statistical profiler but it would be a fair amount of work. Without that you will have to use trial and error. Selectively start different drivers and modules to try and determine which ones are consuming the most resources. In normal use the CPU load goes way down after arming the drone and flying. There seems to be a bunch of preflight checking that the commander module does that consumes a lot of time and once the flight starts it no longer runs those checks. A weakness of the DSP is that it doesn't have HW support for floating point numbers so it has to use a software library for floating point operations. Also, the current version of PX4 (our voxl-dev branch) logs CPU load for the DSP. But without a new base DSP system image it will always report 0.1%. If you want to start using that I can provide the debian package that updates the DSP system image with this capability. That way you can see what happens after you arm and fly.
                • B Offline
                  B Offline
                  bhanner-bell
                  Hey @Eric-Katzfey we'd definitely appreciate a new dsp system image to test with.
                  I'm just going to dump some more info here in hopes that it may spark a thought:
                  We've been poking around all day and noticed there have been some recent software updates so I updated another one of our units to the SDK 1.1.1 image with our modified PX4-firmware version (it has added in vtol apps and some drivers for dsp_sbus and other sensors.. we are going to try again with 100% vanilla sdk 1.1.1 to make sure its present there too but we tried once before and experienced the same issues)
                  What I was able to observe when the system starts to become unresponsive is that the RAM consumption starts ballooning. voxl-px4 uses about 92364kb on htop when running normally but once the issue crops up the memory starts to increase and goes on forever until stopped... up into the hundreds of MB range.
                  Based on observed system behavior we believe the ballooning ram is due to a queue of uorb messages piling up. We can move the vehicle and observe many seconds later the output on the QGC AHRS indicator. The longer PX4 runs the longer the delay in the input->response loop.
                  We haven't been able to reliably trigger the fault but it seems significantly harder to trigger the fault if the usb c cable is plugged into the voxl and a host linux machine. Interestingly enough we arent actually running and adb commands or anything like that.. its just connected. With the cable completely disconnected the fault is pretty easy to reproduce: just power up the board and start voxl-px4.. if the radio (or a joystick to QGC) px4 seems to have problems.
                  • B bhanner-bell
                    @bhanner-bell I sent the DSP system image debian package to the both of you in email.
                      @Eric-Katzfey Seems like your email server rejected the email with the attachment.
                        @Eric-Katzfey Try wget https://storage.googleapis.com/modalai_public/forum/modalai-slpi_1.1-12_arm64.deb
                        • B Offline
                          B Offline
                          bhanner-bell
                          wrote on last edited by bhanner-bell
                          #12
                          We were able to update the dsp image and also build voxl-px4 from the sdk-1.1.2 tag.
                          We are able to reproduce this issue with just a joystick connected to QGC (meaning RC in mode set to joystick only and voxl-io board disconnected).
                          When the issue occurs, this is what the cpuload topic shows:
                          Every 0.1s: px4-listener cpuload        m0054: Thu Mar  2 13:11:09 2023
                          TOPIC: cpuload 2 instances
                          Instance 0:
                           cpuload
                              timestamp: 730351047 (59.056290 seconds ago)
                              process_load: 0.86000
                              system_load: 0.86000
                              ram_usage: 0.00000
                              platform: "QURT"
                          Instance 1:
                           cpuload
                              timestamp: 788949259 (0.459716 seconds ago)
                              process_load: 0.52000
                              system_load: 0.12578
                              ram_usage: 0.11849
                              platform: "POSIX"
                          Interesting to note: the timestamp starts to fall behind for most topics published by the QURT side of things...
                          Memory ballooning is still here.
                          • B bhanner-bell
                            Instance 0:
                             cpuload
                                ram_usage: 0.00000
                                platform: "QURT"
                            Instance 1:
                             cpuload
                                ram_usage: 0.11849
                                platform: "POSIX"
                            @bhanner-bell Wow, 86%, that's really high.
                              E Offline
                              E Offline
                              ejohnson01
                              I did a lot of trial and error today. I am 95% sure I just found the problem.
                              First I got my bench in the messed up state. Then I rolled voxl-px4 back to sdk version 1.0.0 and noticed I was not able to recreate the issue. I immediately after ran dpkg -i on the sdk1.1.2 version and it was broken.
                              I then proceeded to binary search test all of the commits between 1.0.0 and 1.1.2. After some time I came to the following commits.
                              b746ab9434b7e4e71f67c9047ea3d3d49de81c00 - working
                              41a57bc30a40c42990995d5b4e8fe72389f66902 - broken
                              I saved these debs so i could switch between them multiple times and sure enough every time I switched to 41a57... I would see link loss issue. as soon as I rolled back to b746a... fixed.
                              here is a link to the changes in 41a...
                              https://github.com/modalai/px4-firmware/commit/41a57bc30a40c42990995d5b4e8fe72389f66902
                              the problem is caused by the removal of this line
                              qshell commander mode manual
                              I then rolled back to the sdk 1.1.2 commit and added qshell commander mode manual back to the start script and sure enough I can no longer recreate the link loss issue. I just figured this out and its almost 6pm on a friday so I have not had time to look into why this might break the rc control, but I suspect something is not getting initialized correctly without that call.
                              I love to help you all recreate this on your end and get to the true root of the issue. Let me know if there is any other information you would like me to provide.
                              • E ejohnson01
                                @ejohnson01 Okay, thanks for tracking that down. The commander used to come up in AUTO_LOITER mode by default which runs the CPU way too high (as you have witnessed) so I had the explicit command in the startup script to put it into manual mode. The commit changes the default mode to MANUAL so that the explicit statement in the startup script is no longer necessary. That seemed to be working for me but doesn't seem to be working in your case for some reason. If you query the commander status when you remove that what mode does it report?
                                  E Offline
                                  E Offline
                                  ejohnson01
                                  As we have done more testing of the system, we have noticed that one of the symptoms of the issue is that the control inputs become laggy. All inputs from the controller are seen on uorb with more and more time delay over time. For instance sometimes we will let the voxl run for a minute and then look at watch -n0 px4-listener manual_control_setpoint and we will not see the corresponding input show up for 30 seconds. The delay gets worse over time. I was under the impression that uorb had a queue size limit, which if the case, it does not seem to be enforced. If the queue lmit was enforce, I would expect to see a maximum delay of the time to process the size of the queue. I see in a lot of places of the code that there are 16 message length queues so a task running a 50 hz should at most see lag of 800ms (16 * 50ms). I think this might imply a more systemic issue as a few minutes ago we saw the cpuload message get over a minute behind in processing.
                                  Does this sound correct to you?
                                  Also, is there any possibility of setting up a call to dig into this issue in more depth?
                                  • E ejohnson01 referenced this topic on
                                    E Offline
                                    E Offline
                                    ejohnson01
                                    When I read this a second time I noticed you told me to check the commander mode. I noticed that when I used the game pad the commander mode was put into POS_HOLD. When this happens it seems to cause the lag to build. If I command the vehicle to switch to STABILIZED or ACRO eventually the system seems to catch up and we see both uorb messages be shown realtime and we can see the HUD update mostly real time as well.
                                    I am guessing the issue has more to do with being in a mode that requires position lock. Interestingly enough, when we have brought the aircraft to the field and booted it with clear view of the sky so that the GPS can get lock, we have seen the aircraft either not have the lag and link loss or have lag and link loss for a few seconds then go away.
                                    You said that you thought mode AUTO_LOITER used too much CPU, do you happen to have any thoughts on which of the modules are using the CPU or where the problem might be originating?
                                    Eric KatzfeyE 4 Replies Last reply
                                    • E ejohnson01
                                      @ejohnson01 We noticed that AUTO_LOITER mode was taking a lot of CPU sort of by accident and switched it to default to MANUAL. I have not gone back to determine what was taking so much time in AUTO_LOITER.
                                      • E ejohnson01
                                        @ejohnson01 I plan to spend some time looking into why POSCTL is taking so much CPU time. AUTO_LOITER hasn't been a very important mode for us but POSCTL certainly is.
                                        • E ejohnson01
                                          @ejohnson01 I have started to look into this and I can recreate the issue. So I'll dig in and see if I can figure out a fix.
