  3. Voxl2 Spektrum Receiver error
voxl-2
90 Posts 4 Posters 51.6k Views 3 Watching
    @ben-grocholsky Thanks Ben! Yes, and it sure would be nice to see the end of the error line to see what that protocol byte is. Unfortunately it gets truncated in the output. @Chase-Riley do you have the ability to rebuild px4?
    Chase RileyC Offline
    Chase Riley
    @Eric-Katzfey I can certainly try to rebuild px4. Just to confirm this would be done using a docker image (https://gitlab.com/voxl-public/rb5-flight/rb5-flight-px4-build-docker) correct?
    @ben-grocholsky That would be great if you could send me over the deb file to see if we can figure this out.
    • Chase RileyC Chase Riley
      Eric KatzfeyE Online
      @Chase-Riley Yes, in that Docker. If you can rebuild then you can add Ben's patch and see if that solves your issue. If you cannot figure out how to build I could make a special deb for you to test out.
        Chase Riley
        @Eric-Katzfey I am attempting to rebuild px4, however there is a bit of a learning curve for me. If a custom deb file would be easy for you to throw together I would be willing to test that why I am working through the rebuild process.
        ben grocholskyB 1 Reply Last reply
          ben grocholskyB Offline
          ben grocholsky
          @Chase-Riley Here's a debug deb to try while you're working out building custom voxl-px4 voxl-px4_1.14.0-2.0.50_DSMDEBUG_arm64.deb
          It'll print out a bunch of info if you stop the service systemctl stop voxl-px4 and run voxl-px4 manually in a shell. If the 0x01 protocol byte is the issue you're having, then this version will start publishing RC data to uorb/mavlink. Otherwise, at least you'll be able to see what the raw data packets look like.
          • ben grocholskyB ben grocholsky
            Chase Riley
            @ben-grocholsky @Eric-Katzfey My apologies for the delay. I ran voxl-px4 using Ben's custom deb file. Below is a snippet of the data.
            voxl2:/$ voxl-px4
            Found DSP signature file
            [INFO] Daemon mode enabled
            GPS=HOLYBRO
            RC=SPEKTRUM
            POWER MANAGER=VOXLPM
            DISTANCE SENSOR=NONE
            OSD=DISABLE
            DAEMON_MODE=ENABLE
            SENSOR_CAL=ACTUAL
            EXTRA STEPS:
            ______  __   __    ___
            | ___ \ \ \ / /   /   |
            | |_/ /  \ V /   / /| |
            |  __/   /   \  / /_| |
            | |     / /^\ \ \___  |
            \_|     \/   \/     |_/
            px4 starting.
            GPS: HOLYBRO
            RC: SPEKTRUM
            POWER MANAGER: VOXLPM
            DISTANCE SENSOR: NONE
            OSD: DISABLE
            EXTRA STEPS:
            Running on M0054
            INFO  [parameters] BSON document size 3333 bytes, decoded 3333 bytes (INT32:50, FLOAT:104)
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI: >>> ICM42688P this: 3176eb30
            INFO  [qshell] qshell return value timestamp: 30285270, local time: 30290082
            INFO  [muorb] SLPI: Register interrupt b21d3164 e6205e9c 3176eb30
            INFO  [muorb] SLPI:
            INFO  [qshell] qshell return value timestamp: 30338284, local time: 30340198
            Starting ist8310 magnetometer
            INFO  [muorb] SLPI:
            INFO  [qshell] qshell return value timestamp: 30374600, local time: 30376477
            INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097648
            INFO  [qshell] qshell return value timestamp: 30402693, local time: 30404579
            Starting Holybro LED driver
            INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
            INFO  [muorb] SLPI:  address 0x38
            INFO  [muorb] SLPI:
            INFO  [qshell] qshell return value timestamp: 30457005, local time: 30458459
            INFO  [qshell] Send cmd: 'modal_io start'
            INFO  [muorb] SLPI: qshell gotten: modal_io start
            INFO  [muorb] SLPI:   arg0 = 'modal_io'
            INFO  [muorb] SLPI: Ok executing command: modal_io start
            INFO  [muorb] SLPI: Opened UART ESC device
            INFO  [qshell] qshell return value timestamp: 30550352, local time: 30552275
            Starting Spektrum RC
            INFO  [qshell] Send cmd: 'spektrum_rc start'
            INFO  [muorb] SLPI: qshell gotten: spektrum_rc start
            INFO  [muorb] SLPI:   arg0 = 'spektrum_rc'
            INFO  [muorb] SLPI: Creating pthread spektrum_rc_main
            INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097645
            INFO  [muorb] SLPI: Ok executing command: spektrum_rc start
            INFO  [qshell] qshell return value timestamp: 30599384, local time: 30600883
            INFO  [muorb] SLPI: Spektrum RC: Read no bytes from UART
            INFO  [uORB] Advertising remote topic actuator_outputs_debug
            INFO  [uORB] Advertising remote topic esc_status
            INFO  [muorb] SLPI: Spektrum RC: Read 16 bytes from UART
            INFO  [muorb] SLPI: 0x00 0x01 0x81 0x56 0x3d 0xba 0x1c 0x0d 0x44 0x00 0x4c 0x00 0x5c 0x00 0x63 0x00
            INFO  [muorb] SLPI: 0x00 0x01 0x0b 0xf5 0x2c 0x00 0x13 0xfe 0x26 0xaa 0x36 0xaa 0x54 0x00 0x65 0x00
            INFO  [muorb] SLPI: 0x00 0x01 0x81 0x56 0x3d 0xba 0x1c 0x0d 0x44 0x00 0x4c 0x00 0x5c 0x00 0x65 0x00
            INFO  [muorb] SLPI: 0x00 0x01 0x0b 0xf5 0x2c 0x00 0x13 0xfe 0x26 0xaa 0x36 0xaa 0x54 0x00 0x67 0x00
            INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
            INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
            INFO  [muorb] SLPI:   arg0 = 'voxlpm'
            INFO  [muorb] SLPI:   arg4 = '2'
            INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
            INFO  [muorb] SLPI: Set i2c address 0x6a, fd 3
            INFO  [muorb] SLPI: Set i2c address 0x44, fd 3
            INFO  [uORB] Advertising remote topic battery_status
            INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
            INFO  [muorb] SLPI:  address 0x44
            INFO  [muorb] SLPI:
            INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
            INFO  [qshell] qshell return value timestamp: 30657353, local time: 30659016
            INFO  [uORB] Advertising remote topic power_monitor
            INFO  [muorb] SLPI: 0x00 0x01 0x0b 0xf5 0x2c 0x00 0x13 0xfe 0x26 0xaa 0x36 0xaa 0x54 0x00 0x61 0x00
            INFO  [muorb] SLPI: 0x00 0x01 0x0b 0xf5 0x2c 0x00 0x13 0xfe 0x26 0xaa 0x36 0xaa 0x54 0x00 0x63 0x00
            INFO  [muorb] SLPI: 0x00 0x01 0x81 0x56 0x3d 0xba 0x1c 0x0d 0x44 0x00 0x4c 0x00 0x5c 0x00 0x67 0x00
            ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_GPS_MASK
            INFO  [muorb] SLPI: 0x00 0x01 0x81 0x56 0x3d 0xba 0x1c 0x0d 0x44 0x00 0x4c 0x00 0x5c 0x00 0x61 0x00
            INFO  [uORB] Advertising remote topic sensors_status_mag
            INFO  [qshell] qshell return value timestamp: 30853798, local time: 30856869
            INFO  [muorb] SLPI: Spektrum RC: DSM message parsed successfully
            INFO  [uORB] Advertising remote topic input_rc
            INFO  [muorb] SLPI: Spektrum RC: Publishing input_rc
            INFO  [qshell] qshell return value timestamp: 31159822, local time: 31165232
            INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
              voxl2:/$ voxl-px4
              GPS=HOLYBRO
              RC=SPEKTRUM
              OSD=DISABLE
              DAEMON_MODE=ENABLE
              SENSOR_CAL=ACTUAL
              EXTRA STEPS:
              ______  __   __    ___
              | ___ \ \ \ / /   /   |
              | |_/ /  \ V /   / /| |
              |  __/   /   \  / /_| |
              | |     / /^\ \ \___  |
              \_|     \/   \/     |_/
              px4 starting.
              GPS: HOLYBRO
              RC: SPEKTRUM
              OSD: DISABLE
              EXTRA STEPS:
              Running on M0054
              INFO  [muorb] SLPI:
              INFO  [muorb] SLPI:
              INFO  [muorb] SLPI:
              INFO  [muorb] SLPI:
              INFO  [muorb] SLPI:
              Chase Riley
              @ben-grocholsky @Eric-Katzfey I attempted to run voxl-px4 again after a power cycle and encountered this error. Similar to the error before but looks to be showing the info that was cut off in the previous deb file.
              voxl2:/$ voxl-px4
              GPS=HOLYBRO
              RC=SPEKTRUM
              OSD=DISABLE
              DAEMON_MODE=ENABLE
              SENSOR_CAL=ACTUAL
              EXTRA STEPS:
              ______  __   __    ___
              | ___ \ \ \ / /   /   |
              | |_/ /  \ V /   / /| |
              |  __/   /   \  / /_| |
              | |     / /^\ \ \___  |
              \_|     \/   \/     |_/
              px4 starting.
              GPS: HOLYBRO
              RC: SPEKTRUM
              OSD: DISABLE
              EXTRA STEPS:
              Running on M0054
              INFO  [muorb] SLPI:
              INFO  [qshell] qshell return value timestamp: 262948496, local time: 262952979
              INFO  [muorb] SLPI:
              INFO  [qshell] qshell return value timestamp: 262991650, local time: 262992261
              INFO  [muorb] SLPI:
              INFO  [qshell] qshell return value timestamp: 263025555, local time: 263026330
              INFO  [qshell] qshell return value timestamp: 263048076, local time: 263048948
              INFO  [muorb] SLPI:
              INFO  [qshell] qshell return value timestamp: 263082514, local time: 263084020
              INFO  [qshell] qshell return value timestamp: 263170284, local time: 263173206
              INFO  [qshell] qshell return value timestamp: 263217799, local time: 263218642
              ERROR [muorb] SLPI: Spektrum RC: Got 6 bytes. Protocol byte is 0x52
              ERROR [muorb] SLPI: Spektrum RC: Got 16 bytes. Protocol byte is 0x00
              INFO  [muorb] SLPI:
              INFO  [qshell] qshell return value timestamp: 263251129, local time: 263253445
              ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_MAG_MODE
              INFO  [qshell] qshell return value timestamp: 263462076, local time: 263466609
              INFO  [qshell] qshell return value timestamp: 263750947, local time: 263755362
              INFO  [qshell] qshell return value timestamp: 263841868, local time: 263843014
              INFO  [qshell] qshell return value timestamp: 263905079, local time: 263906174
              INFO  [muorb] SLPI: baudrate set to 9600
              INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 1
              INFO  [qshell] qshell return value timestamp: 264001370, local time: 264002881
              INFO  [qshell] qshell return value timestamp: 264045767, local time: 264046812
              INFO  [qshell] qshell return value timestamp: 264095634, local time: 264096726
                voxl2:/$ voxl-px4
                GPS=HOLYBRO
                RC=SPEKTRUM
                OSD=DISABLE
                DAEMON_MODE=ENABLE
                SENSOR_CAL=ACTUAL
                EXTRA STEPS:
                ______  __   __    ___
                | ___ \ \ \ / /   /   |
                | |_/ /  \ V /   / /| |
                |  __/   /   \  / /_| |
                | |     / /^\ \ \___  |
                \_|     \/   \/     |_/
                px4 starting.
                GPS: HOLYBRO
                RC: SPEKTRUM
                OSD: DISABLE
                EXTRA STEPS:
                Running on M0054
                INFO  [muorb] SLPI:
                INFO  [muorb] SLPI:
                INFO  [muorb] SLPI:
                INFO  [muorb] SLPI:
                INFO  [muorb] SLPI:
                ben grocholsky
                @Chase-Riley In the first of these two runs you were getting 0x01 protocol byte like I see on my DX7 transmitter. In that state with this binary you should see rc_input uorb messages and be able to try the Radio Calibration tool tab on QGroundControl.
                In the second run you're seeing 0x00 protocol byte and unfortunately I'm not sure what that means.
                If you can get the first case working repeatedly using one of the voxl-bind-spektrum options -t -f -s then we're on the path to a fix. Which did you use and have you tried them all?
                  Chase Riley
                  @ben-grocholsky I am using a DX8 Transmitter during these test. Would the voxl-bind-spektrum be needed/do anything if I am not using the Spektrum bind board from Modal AI? I currently have the Spektrum receiver hooked directly to J19 on the VOXL2. When I was using SDK .0.9.5 I had the same receiver connected to the VOXL I/O board, and it worked great. Unfortunately the I/O board is not supported in SDK 1.0.0.
                    ben grocholsky
                    @Chase-Riley I didn't realize that had changed in V1.0. If you have access to a an alternative px4 fmu you could use the QGC pairing function to change the spektrum mode connected to that fmu and then plug it back into the voxl2. That could help check if one of the three options is more reliable. I'm not sure why you saw different data packets on a restart. Need to resolve that or try a different transmitter.
                      Chase Riley
                      @ben-grocholsky @Eric-Katzfey I got it to work using by using the DSM2 binding method with another Px4 FMU. I do have a question though. I am now not able to get the actuators tab to show up in QGC for my ModalAI ESC. Would you DEB file have something to do with this? I have checked all my params in QGC and all seems to be correct. This was just the only other variable I could think of and wanted to check. Should I go back to running a standard DEB file? If so where would I find that now that I am running the custom debug one?
                        @Chase-Riley The standard px4 Debian package will set up the data correctly such that the actuators tab will be visible. For SDK 1.0 the packages are all available at http://voxl-packages.modalai.com/dists/qrb5165/sdk-1.0/binary-arm64/. To grab the px4 package use wget http://voxl-packages.modalai.com/dists/qrb5165/sdk-1.0/binary-arm64/voxl-px4_1.14.0-2.0.34_arm64.deb
                          Chase Riley
                          @Eric-Katzfey Unfortunately once I switch back to the standard Debian package the Spektrum error is back. I had it working every power up with the Debian Package from Ben.
                            ben grocholsky
                            wrote on last edited by ben grocholsky
                            #20
                            @Eric-Katzfey the test deb file was just voxl-dev branch with the one line change to accept (0x02|0x01) protocol bytes with the error output shortened below 80 characters + debug print bools and macros in DSM parsing forced on. I can fly that one line change on a Sentinel to look for any unexpected consequences. It'd be great to coordinate on how to get such a change merged into the dev branch and a non-debug deb to Chase.
                              @ben-grocholsky That would be great! Just submit a PR and I can merge it in and then cut a new release.
                              ben grocholskyB Chase RileyC 2 Replies Last reply
                                ben grocholsky
                                @Eric-Katzfey https://github.com/modalai/px4-firmware/pull/42
                                  Chase Riley
                                    Chase Riley
                                    @ben-grocholsky @Eric-Katzfey That would be great if I could get this working. How long would this take to get merged?
                                      @Chase-Riley I made version 1.14.0-2.0.54 with the Spektrum RC changes in it. You can get it with wget http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.14.0-2.0.54-202310161035_arm64.deb. Can you try it out and see if it fixes your issue?
                                        Chase Riley
                                        @Eric-Katzfey Spektrum now works with that deb file, however I am not able to get the actuators tab in QGC just like @ben-grocholsky's deb file.
                                          @Chase-Riley Okay, glad that Spektrum is now working. Can you create a new post for the actuator tab issue. That is something completely different than the Spektrum RC issue. Thanks!
