    Voxl2 Spektrum Receiver error
    29879
    • Chase RileyC
      Chase Riley
      I am currently working on a custom frame with a Voxl2 running SDK 1.0.0. I am currently have a issue with integration of a Spektrum Satellite Receiver (Model # SPM9745). The receiver is bound to the transmitter and has the solid red light on the receiver and seems to be functioning fine , however I am not able to calibrate in QGC. QGC does not detect that there is any RC channels.
      I have the receiver pinned directly into J19 and have followed the pinout shown at (https://docs.modalai.com/voxl2-rc-configs/).
      Below is the error I see when running voxl-px4. The error will just repeat it self indefinitely. I am hoping someone from the Dev team will be able to help me troubleshoot this issue.
      voxl2:/$ voxl-px4
      Found DSP signature file
      [INFO] Daemon mode enabled
      GPS=HOLYBRO
      RC=SPEKTRUM
      OSD=DISABLE
      DAEMON_MODE=ENABLE
      SENSOR_CAL=ACTUAL
      EXTRA STEPS:
      ______  __   __    ___
      | ___ \ \ \ / /   /   |
      | |_/ /  \ V /   / /| |
      |  __/   /   \  / /_| |
      | |     / /^\ \ \___  |
      \_|     \/   \/     |_/
      px4 starting.
      GPS: HOLYBRO
      RC: SPEKTRUM
      OSD: DISABLE
      EXTRA STEPS:
      Running on M0054
      INFO  [parameters] BSON document size 3360 bytes, decoded 3360 bytes (INT32:54, FLOAT:102)
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI: >>> ICM42688P this: 3176e4a0
      INFO  [qshell] qshell return value timestamp: 65463876, local time: 65468142
      INFO  [muorb] SLPI: Register interrupt b21d3164 e620e69c 3176e4a0
      INFO  [muorb] SLPI:
      INFO  [qshell] qshell return value timestamp: 66522608, local time: 66524076
      Starting Holybro magnetometer
      INFO  [muorb] SLPI:
      INFO  [qshell] qshell return value timestamp: 66576742, local time: 66578405
      INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097648
      INFO  [qshell] qshell return value timestamp: 66599884, local time: 66600724
      Starting Holybro LED driver
      INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
      INFO  [muorb] SLPI:  address 0x38
      INFO  [muorb] SLPI:
      INFO  [qshell] qshell return value timestamp: 66641991, local time: 66644114
      INFO  [qshell] Send cmd: 'modal_io start'
      INFO  [muorb] SLPI: qshell gotten: modal_io start
      INFO  [muorb] SLPI:   arg0 = 'modal_io'
      INFO  [muorb] SLPI: Ok executing command: modal_io start
      INFO  [muorb] SLPI: Opened UART ESC device
      INFO  [qshell] qshell return value timestamp: 66747643, local time: 66749765
      INFO  [uORB] Advertising remote topic actuator_outputs_debug
      INFO  [uORB] Advertising remote topic esc_status
      Starting Spektrum RC
      INFO  [muorb] SLPI: qshell gotten: spektrum_rc start
      INFO  [qshell] Send cmd: 'spektrum_rc start'
      INFO  [muorb] SLPI:   arg0 = 'spektrum_rc'
      INFO  [muorb] SLPI: Creating pthread spektrum_rc_main
      INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097645
      INFO  [muorb] SLPI: Ok executing command: spektrum_rc start
      INFO  [qshell] qshell return value timestamp: 67802724, local time: 67805895
      ERROR [muorb] SLPI: Spektrum RC: Read something other than correct DSM frame on read. Got 16 bytes. Protoco
        Eric Katzfey ModalAI Team @Chase Riley
        @Chase-Riley We use these receivers and haven't had an issue with them. The error message indicates it is getting 16 bytes at a time which matches the protocol specification. But it is not able to parse the protocol from that 16 bytes. That could either indicate a misalignment of some sort or a corruption of the data. Are you able to look at the TX line coming out of the 9745 on an oscilloscope? The error message is getting cutoff at the end. It should also be reporting the value of the protocol byte. It would be nice to see that. There is a verbose mode for the driver which will pront out more diagnostic information. You need to add the -v option to the start command (qshell spektrum_rc start) in the startup file /usr/bin/voxl-px4-start and then it will print out more information.
        Chase RileyC ben grocholskyB 2 Replies Last reply Reply Quote 0
        • Chase RileyC
          Chase Riley @Eric Katzfey
          @Eric-Katzfey Unfortunately I do not have access to a Oscope right now. I added in the "-v " option to the command as you recommended and have included the results below.
          voxl-px4
          GPS=HOLYBRO
          RC=SPEKTRUM
          OSD=DISABLE
          DAEMON_MODE=ENABLE
          SENSOR_CAL=ACTUAL
          EXTRA STEPS:
          ______  __   __    ___
          | ___ \ \ \ / /   /   |
          | |_/ /  \ V /   / /| |
          |  __/   /   \  / /_| |
          | |     / /^\ \ \___  |
          \_|     \/   \/     |_/
          px4 starting.
          GPS: HOLYBRO
          RC: SPEKTRUM
          OSD: DISABLE
          EXTRA STEPS:
          Running on M0054
          INFO  [muorb] SLPI:
          INFO  [muorb] SLPI: >>> ICM42688P this: 3176e490
          INFO  [qshell] qshell return value timestamp: 233627807, local time: 233632162
          INFO  [muorb] SLPI: Register interrupt b21d3164 e620e69c 3176e490
          INFO  [muorb] SLPI:
          INFO  [qshell] qshell return value timestamp: 234681842, local time: 234684609
          INFO  [muorb] SLPI:
          INFO  [qshell] qshell return value timestamp: 234737029, local time: 234738986
          INFO  [qshell] qshell return value timestamp: 234763793, local time: 234766056
          INFO  [muorb] SLPI:
          INFO  [qshell] qshell return value timestamp: 234817829, local time: 234819191
          INFO  [qshell] qshell return value timestamp: 234921070, local time: 234923227
          INFO  [qshell] Send cmd: 'spektrum_rc start -v'
          INFO  [muorb] SLPI: qshell gotten: spektrum_rc start -v
          INFO  [muorb] SLPI:   arg2 = '-v'
          INFO  [muorb] SLPI: Ok executing command: spektrum_rc start -v
          INFO  [muorb] SLPI: Spektrum RC: Enabling verbose mode
          INFO  [muorb] SLPI: Spektrum RC: dsm_init succeeded
          INFO  [qshell] qshell return value timestamp: 235978442, local time: 235980066
          INFO  [muorb] SLPI: Spektrum RC: Read no bytes from UART
          ERROR [muorb] SLPI: Spektrum RC: Read something other than correct DSM frame on read. Got 16 bytes. Protoco```
          • ben grocholskyB
            ben grocholsky @Eric Katzfey
            @Eric-Katzfey I've seen a similar issue with a DX7 transmitter paired to an off the shelf Sentinel. The binding worked but no data made it through the dsm parser. In that case the packets looked like:
            INFO  [muorb] SLPI: 0x1c 0x01 0x04 0xb4 0x15 0xf0 0x09 0xfe 0x0d 0xfe 0x01 0xc2 0x13 0x56 0x1b 0x57
            INFO  [muorb] SLPI: 0x1c 0x01 0x06 0xef 0x15 0xf0 0x0a 0x2f 0x0d 0xfe 0x01 0xc2 0x13 0x56 0x1b 0x57
            INFO  [muorb] SLPI: 0x1c 0x01 0x04 0xc6 0x15 0xf0 0x09 0x0f 0x0d 0xfe 0x01 0xc2 0x13 0x56 0x1b 0x57
            INFO  [muorb] SLPI: 0x1c 0x01 0x04 0xe3 0x15 0xf0 0x0b 0x04 0x0d 0xfe 0x01 0xc2 0x13 0x56 0x1b 0x57
            INFO  [muorb] SLPI: 0x1c 0x01 0x07 0x56 0x15 0xf0 0x09 0xd7 0x0d 0xfe 0x01 0xc2 0x13 0x56 0x1b 0x57
            INFO  [muorb] SLPI: 0x1c 0x01 0x05 0x51 0x15 0xf0 0x08 0xa7 0x0d 0xfe 0x01 0xc2 0x13 0x56 0x1b 0x57
            This line of the code never sees rx_buf[1] 0x02 bit high and first_correct_frame_received never goes true.
            I'm not familiar enough with DSM to recommend a safe fix. (a minor change to the line above made data flow but was not robust when power cycling the transmitter...) Just confirming I've seen some spektrum transmitter hardware not work with the voxl2 parser.
              Eric Katzfey ModalAI Team @ben grocholsky
              @ben-grocholsky Thanks Ben! Yes, and it sure would be nice to see the end of the error line to see what that protocol byte is. Unfortunately it gets truncated in the output. @Chase-Riley do you have the ability to rebuild px4?
              Chase RileyC 1 Reply Last reply Reply Quote 0
                @Chase-Riley As Ben suggested some DSM transmitters may cause it to use a different flavor of the protocol and break the driver code. Is it possible to try a different model of transmitter?
                ben grocholskyB 1 Reply Last reply Reply Quote 0
                • ben grocholskyB
                  @Eric-Katzfey changing to accept 0x01 or 0x02 in rx_buf[1] appears to make my DX7 transmitter work. input_rc -> RC_CHANNELS shows up and starts/stops when powering the transmitter on/off. Any thoughts on if this is an acceptable change?
                  } else if (((newbytes != DSM_FRAME_SIZE) || ((rx_buf[1] & 0x0F) != 0x02)) && (! first_correct_frame_received)) {
                  to
                  } else if (((newbytes != DSM_FRAME_SIZE) || (((rx_buf[1] & 0x0F) != 0x02) && ((rx_buf[1] & 0x0F) != 0x01))) && (! first_correct_frame_received)) {
                  INFO  [muorb] SLPI: Spektrum RC: Read 16 bytes from UART
                  INFO  [muorb] SLPI: Spektrum RC: DSM message parsed successfully
                  INFO  [muorb] SLPI: Spektrum RC: Publishing input_rc
                  INFO  [muorb] SLPI: 0xff 0x01 0x06 0x08 0x17 0x42 0x0a 0x00 0x0d 0xfd 0x00 0xa9 0x10 0xaa 0x1b 0x57
                  @Chase-Riley if needed, I can send you a deb file that will print out lots of debugs. Not safe for flying but hopefully it could help understanding what's happening.
                  • Chase RileyC
                    @Eric-Katzfey I can certainly try to rebuild px4. Just to confirm this would be done using a docker image (https://gitlab.com/voxl-public/rb5-flight/rb5-flight-px4-build-docker) correct?
                    @ben-grocholsky That would be great if you could send me over the deb file to see if we can figure this out.
                      @Chase-Riley Yes, in that Docker. If you can rebuild then you can add Ben's patch and see if that solves your issue. If you cannot figure out how to build I could make a special deb for you to test out.
                      • Chase RileyC
                        @Eric-Katzfey I am attempting to rebuild px4, however there is a bit of a learning curve for me. If a custom deb file would be easy for you to throw together I would be willing to test that why I am working through the rebuild process.
                        • ben grocholskyB
                          ben grocholsky @Chase Riley
                          @Chase-Riley Here's a debug deb to try while you're working out building custom voxl-px4 voxl-px4_1.14.0-2.0.50_DSMDEBUG_arm64.deb
                          It'll print out a bunch of info if you stop the service systemctl stop voxl-px4 and run voxl-px4 manually in a shell. If the 0x01 protocol byte is the issue you're having, then this version will start publishing RC data to uorb/mavlink. Otherwise, at least you'll be able to see what the raw data packets look like.
                          • Chase RileyC
                            Chase Riley @ben grocholsky
                            @ben-grocholsky @Eric-Katzfey My apologies for the delay. I ran voxl-px4 using Ben's custom deb file. Below is a snippet of the data.
                            voxl2:/$ voxl-px4
                            GPS=HOLYBRO
                            RC=SPEKTRUM
                            POWER MANAGER=VOXLPM
                            DISTANCE SENSOR=NONE
                            OSD=DISABLE
                            DAEMON_MODE=ENABLE
                            SENSOR_CAL=ACTUAL
                            EXTRA STEPS:
                            ______  __   __    ___
                            | ___ \ \ \ / /   /   |
                            | |_/ /  \ V /   / /| |
                            |  __/   /   \  / /_| |
                            | |     / /^\ \ \___  |
                            \_|     \/   \/     |_/
                            px4 starting.
                            GPS: HOLYBRO
                            RC: SPEKTRUM
                            POWER MANAGER: VOXLPM
                            DISTANCE SENSOR: NONE
                            OSD: DISABLE
                            EXTRA STEPS:
                            Running on M0054
                            INFO  [parameters] BSON document size 3333 bytes, decoded 3333 bytes (INT32:50, FLOAT:104)
                            INFO  [muorb] SLPI:
                            INFO  [muorb] SLPI: >>> ICM42688P this: 3176eb30
                            INFO  [qshell] qshell return value timestamp: 30285270, local time: 30290082
                            INFO  [muorb] SLPI: Register interrupt b21d3164 e6205e9c 3176eb30
                            INFO  [muorb] SLPI:
                            INFO  [qshell] qshell return value timestamp: 30338284, local time: 30340198
                            Starting ist8310 magnetometer
                            INFO  [muorb] SLPI:
                            INFO  [qshell] qshell return value timestamp: 30374600, local time: 30376477
                            INFO  [qshell] qshell return value timestamp: 30402693, local time: 30404579
                            INFO  [muorb] SLPI:
                            INFO  [qshell] qshell return value timestamp: 30457005, local time: 30458459
                            INFO  [qshell] qshell return value timestamp: 30550352, local time: 30552275
                            INFO  [qshell] qshell return value timestamp: 30599384, local time: 30600883
                            INFO  [muorb] SLPI: 0x00 0x01 0x81 0x56 0x3d 0xba 0x1c 0x0d 0x44 0x00 0x4c 0x00 0x5c 0x00 0x63 0x00
                            INFO  [muorb] SLPI: 0x00 0x01 0x0b 0xf5 0x2c 0x00 0x13 0xfe 0x26 0xaa 0x36 0xaa 0x54 0x00 0x65 0x00
                            INFO  [muorb] SLPI: 0x00 0x01 0x81 0x56 0x3d 0xba 0x1c 0x0d 0x44 0x00 0x4c 0x00 0x5c 0x00 0x65 0x00
                            INFO  [muorb] SLPI: 0x00 0x01 0x0b 0xf5 0x2c 0x00 0x13 0xfe 0x26 0xaa 0x36 0xaa 0x54 0x00 0x67 0x00
                            INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
                            INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                            INFO  [muorb] SLPI:   arg0 = 'voxlpm'
                            INFO  [muorb] SLPI:   arg4 = '2'
                            INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
                            INFO  [muorb] SLPI: Set i2c address 0x6a, fd 3
                            INFO  [muorb] SLPI: Set i2c address 0x44, fd 3
                            INFO  [uORB] Advertising remote topic battery_status
                            INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
                            INFO  [muorb] SLPI:  address 0x44
                            INFO  [muorb] SLPI:
                            INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
                            INFO  [qshell] qshell return value timestamp: 30657353, local time: 30659016
                            INFO  [uORB] Advertising remote topic power_monitor
                            INFO  [muorb] SLPI: 0x00 0x01 0x0b 0xf5 0x2c 0x00 0x13 0xfe 0x26 0xaa 0x36 0xaa 0x54 0x00 0x61 0x00
                            INFO  [muorb] SLPI: 0x00 0x01 0x0b 0xf5 0x2c 0x00 0x13 0xfe 0x26 0xaa 0x36 0xaa 0x54 0x00 0x63 0x00
                            INFO  [muorb] SLPI: 0x00 0x01 0x81 0x56 0x3d 0xba 0x1c 0x0d 0x44 0x00 0x4c 0x00 0x5c 0x00 0x67 0x00
                            ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_GPS_MASK
                            INFO  [muorb] SLPI: 0x00 0x01 0x81 0x56 0x3d 0xba 0x1c 0x0d 0x44 0x00 0x4c 0x00 0x5c 0x00 0x61 0x00
                            INFO  [uORB] Advertising remote topic sensors_status_mag
                            INFO  [qshell] qshell return value timestamp: 30853798, local time: 30856869
                            INFO  [uORB] Advertising remote topic input_rc
                            INFO  [qshell] qshell return value timestamp: 31159822, local time: 31165232
                            INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
                            • Chase RileyC
                              Chase Riley @Chase Riley
                              @ben-grocholsky @Eric-Katzfey I attempted to run voxl-px4 again after a power cycle and encountered this error. Similar to the error before but looks to be showing the info that was cut off in the previous deb file.
                              voxl2:/$ voxl-px4
                              GPS=HOLYBRO
                              RC=SPEKTRUM
                              OSD=DISABLE
                              DAEMON_MODE=ENABLE
                              SENSOR_CAL=ACTUAL
                              EXTRA STEPS:
                              ______  __   __    ___
                              | ___ \ \ \ / /   /   |
                              | |_/ /  \ V /   / /| |
                              |  __/   /   \  / /_| |
                              | |     / /^\ \ \___  |
                              \_|     \/   \/     |_/
                              px4 starting.
                              GPS: HOLYBRO
                              RC: SPEKTRUM
                              OSD: DISABLE
                              EXTRA STEPS:
                              Running on M0054
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 262948496, local time: 262952979
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 262991650, local time: 262992261
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 263025555, local time: 263026330
                              INFO  [qshell] qshell return value timestamp: 263048076, local time: 263048948
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 263082514, local time: 263084020
                              INFO  [qshell] qshell return value timestamp: 263170284, local time: 263173206
                              INFO  [qshell] qshell return value timestamp: 263217799, local time: 263218642
                              ERROR [muorb] SLPI: Spektrum RC: Got 6 bytes. Protocol byte is 0x52
                              ERROR [muorb] SLPI: Spektrum RC: Got 16 bytes. Protocol byte is 0x00
                              INFO  [muorb] SLPI:
                              INFO  [qshell] qshell return value timestamp: 263251129, local time: 263253445
                              ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_MAG_MODE
                              INFO  [qshell] qshell return value timestamp: 263462076, local time: 263466609
                              INFO  [qshell] qshell return value timestamp: 263750947, local time: 263755362
                              INFO  [qshell] qshell return value timestamp: 263841868, local time: 263843014
                              INFO  [qshell] qshell return value timestamp: 263905079, local time: 263906174
                              INFO  [muorb] SLPI: baudrate set to 9600
                              INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 1
                              INFO  [qshell] qshell return value timestamp: 264001370, local time: 264002881
                              INFO  [qshell] qshell return value timestamp: 264045767, local time: 264046812
                              INFO  [qshell] qshell return value timestamp: 264095634, local time: 264096726
                              • ben grocholskyB
                                @Chase-Riley In the first of these two runs you were getting 0x01 protocol byte like I see on my DX7 transmitter. In that state with this binary you should see rc_input uorb messages and be able to try the Radio Calibration tool tab on QGroundControl.
                                In the second run you're seeing 0x00 protocol byte and unfortunately I'm not sure what that means.
                                If you can get the first case working repeatedly using one of the voxl-bind-spektrum options -t -f -s then we're on the path to a fix. Which did you use and have you tried them all?
                                • Chase RileyC
                                  @ben-grocholsky I am using a DX8 Transmitter during these test. Would the voxl-bind-spektrum be needed/do anything if I am not using the Spektrum bind board from Modal AI? I currently have the Spektrum receiver hooked directly to J19 on the VOXL2. When I was using SDK .0.9.5 I had the same receiver connected to the VOXL I/O board, and it worked great. Unfortunately the I/O board is not supported in SDK 1.0.0.
                                  • ben grocholskyB
                                    @Chase-Riley I didn't realize that had changed in V1.0. If you have access to a an alternative px4 fmu you could use the QGC pairing function to change the spektrum mode connected to that fmu and then plug it back into the voxl2. That could help check if one of the three options is more reliable. I'm not sure why you saw different data packets on a restart. Need to resolve that or try a different transmitter.
                                    • Chase RileyC
                                      @ben-grocholsky @Eric-Katzfey I got it to work using by using the DSM2 binding method with another Px4 FMU. I do have a question though. I am now not able to get the actuators tab to show up in QGC for my ModalAI ESC. Would you DEB file have something to do with this? I have checked all my params in QGC and all seems to be correct. This was just the only other variable I could think of and wanted to check. Should I go back to running a standard DEB file? If so where would I find that now that I am running the custom debug one?
                                        @Chase-Riley The standard px4 Debian package will set up the data correctly such that the actuators tab will be visible. For SDK 1.0 the packages are all available at http://voxl-packages.modalai.com/dists/qrb5165/sdk-1.0/binary-arm64/. To grab the px4 package use wget http://voxl-packages.modalai.com/dists/qrb5165/sdk-1.0/binary-arm64/voxl-px4_1.14.0-2.0.34_arm64.deb
                                        • Chase RileyC
                                          @Eric-Katzfey Unfortunately once I switch back to the standard Debian package the Spektrum error is back. I had it working every power up with the Debian Package from Ben.
                                          • ben grocholskyB
                                            @Eric-Katzfey the test deb file was just voxl-dev branch with the one line change to accept (0x02|0x01) protocol bytes with the error output shortened below 80 characters + debug print bools and macros in DSM parsing forced on. I can fly that one line change on a Sentinel to look for any unexpected consequences. It'd be great to coordinate on how to get such a change merged into the dev branch and a non-debug deb to Chase.
