  3. Voxl2 Spektrum Receiver error
voxl-2
90 Posts 4 Posters 51.6k Views 3 Watching
    @Chase-Riley As Ben suggested some DSM transmitters may cause it to use a different flavor of the protocol and break the driver code. Is it possible to try a different model of transmitter?
    ben grocholskyB Offline
    ben grocholsky
    @Eric-Katzfey changing to accept 0x01 or 0x02 in rx_buf[1] appears to make my DX7 transmitter work. input_rc -> RC_CHANNELS shows up and starts/stops when powering the transmitter on/off. Any thoughts on if this is an acceptable change?
    } else if (((newbytes != DSM_FRAME_SIZE) || ((rx_buf[1] & 0x0F) != 0x02)) && (! first_correct_frame_received)) {
    to
    } else if (((newbytes != DSM_FRAME_SIZE) || (((rx_buf[1] & 0x0F) != 0x02) && ((rx_buf[1] & 0x0F) != 0x01))) && (! first_correct_frame_received)) {
    INFO  [muorb] SLPI: Spektrum RC: Read no bytes from UART
    INFO  [muorb] SLPI: Spektrum RC: Read 16 bytes from UART
    INFO  [muorb] SLPI: Spektrum RC: DSM message parsed successfully
    INFO  [muorb] SLPI: Spektrum RC: Publishing input_rc
    INFO  [muorb] SLPI: 0xff 0x01 0x06 0x08 0x17 0x42 0x0a 0x00 0x0d 0xfd 0x00 0xa9 0x10 0xaa 0x1b 0x57
    @Chase-Riley if needed, I can send you a deb file that will print out lots of debugs. Not safe for flying but hopefully it could help understanding what's happening.
      @ben-grocholsky Thanks Ben! Yes, and it sure would be nice to see the end of the error line to see what that protocol byte is. Unfortunately it gets truncated in the output. @Chase-Riley do you have the ability to rebuild px4?
      Chase RileyC Offline
      Chase Riley
      @Eric-Katzfey I can certainly try to rebuild px4. Just to confirm this would be done using a docker image (https://gitlab.com/voxl-public/rb5-flight/rb5-flight-px4-build-docker) correct?
      @ben-grocholsky That would be great if you could send me over the deb file to see if we can figure this out.
      • Chase RileyC Chase Riley
        @Chase-Riley Yes, in that Docker. If you can rebuild then you can add Ben's patch and see if that solves your issue. If you cannot figure out how to build I could make a special deb for you to test out.
          Chase Riley
          @Eric-Katzfey I am attempting to rebuild px4, however there is a bit of a learning curve for me. If a custom deb file would be easy for you to throw together I would be willing to test that why I am working through the rebuild process.
          ben grocholskyB 1 Reply Last reply
            ben grocholsky
            @Chase-Riley Here's a debug deb to try while you're working out building custom voxl-px4 voxl-px4_1.14.0-2.0.50_DSMDEBUG_arm64.deb
            It'll print out a bunch of info if you stop the service systemctl stop voxl-px4 and run voxl-px4 manually in a shell. If the 0x01 protocol byte is the issue you're having, then this version will start publishing RC data to uorb/mavlink. Otherwise, at least you'll be able to see what the raw data packets look like.
            • ben grocholskyB ben grocholsky
              Chase Riley
              @ben-grocholsky @Eric-Katzfey My apologies for the delay. I ran voxl-px4 using Ben's custom deb file. Below is a snippet of the data.
              voxl2:/$ voxl-px4
              Found DSP signature file
              [INFO] Daemon mode enabled
              GPS=HOLYBRO
              RC=SPEKTRUM
              POWER MANAGER=VOXLPM
              DISTANCE SENSOR=NONE
              OSD=DISABLE
              DAEMON_MODE=ENABLE
              SENSOR_CAL=ACTUAL
              EXTRA STEPS:
              ______  __   __    ___
              | ___ \ \ \ / /   /   |
              | |_/ /  \ V /   / /| |
              |  __/   /   \  / /_| |
              | |     / /^\ \ \___  |
              \_|     \/   \/     |_/
              px4 starting.
              GPS: HOLYBRO
              RC: SPEKTRUM
              POWER MANAGER: VOXLPM
              DISTANCE SENSOR: NONE
              OSD: DISABLE
              EXTRA STEPS:
              Running on M0054
              INFO  [parameters] BSON document size 3333 bytes, decoded 3333 bytes (INT32:50, FLOAT:104)
              INFO  [muorb] SLPI:
              INFO  [muorb] SLPI: >>> ICM42688P this: 3176eb30
              INFO  [qshell] qshell return value timestamp: 30285270, local time: 30290082
              INFO  [muorb] SLPI: Register interrupt b21d3164 e6205e9c 3176eb30
              INFO  [muorb] SLPI:
              INFO  [qshell] qshell return value timestamp: 30338284, local time: 30340198
              Starting ist8310 magnetometer
              INFO  [muorb] SLPI:
              INFO  [qshell] qshell return value timestamp: 30374600, local time: 30376477
              INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097648
              INFO  [qshell] qshell return value timestamp: 30402693, local time: 30404579
              Starting Holybro LED driver
              INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
              INFO  [muorb] SLPI:  address 0x38
              INFO  [muorb] SLPI:
              INFO  [qshell] qshell return value timestamp: 30457005, local time: 30458459
              INFO  [qshell] Send cmd: 'modal_io start'
              INFO  [muorb] SLPI: qshell gotten: modal_io start
              INFO  [muorb] SLPI:   arg0 = 'modal_io'
              INFO  [muorb] SLPI: Ok executing command: modal_io start
              INFO  [muorb] SLPI: Opened UART ESC device
              INFO  [qshell] qshell return value timestamp: 30550352, local time: 30552275
              Starting Spektrum RC
              INFO  [qshell] Send cmd: 'spektrum_rc start'
              INFO  [muorb] SLPI: qshell gotten: spektrum_rc start
              INFO  [muorb] SLPI:   arg0 = 'spektrum_rc'
              INFO  [muorb] SLPI: Creating pthread spektrum_rc_main
              INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097645
              INFO  [muorb] SLPI: Ok executing command: spektrum_rc start
              INFO  [qshell] qshell return value timestamp: 30599384, local time: 30600883
              INFO  [uORB] Advertising remote topic actuator_outputs_debug
              INFO  [uORB] Advertising remote topic esc_status
              INFO  [muorb] SLPI: 0x00 0x01 0x81 0x56 0x3d 0xba 0x1c 0x0d 0x44 0x00 0x4c 0x00 0x5c 0x00 0x63 0x00
              INFO  [muorb] SLPI: 0x00 0x01 0x0b 0xf5 0x2c 0x00 0x13 0xfe 0x26 0xaa 0x36 0xaa 0x54 0x00 0x65 0x00
              INFO  [muorb] SLPI: 0x00 0x01 0x81 0x56 0x3d 0xba 0x1c 0x0d 0x44 0x00 0x4c 0x00 0x5c 0x00 0x65 0x00
              INFO  [muorb] SLPI: 0x00 0x01 0x0b 0xf5 0x2c 0x00 0x13 0xfe 0x26 0xaa 0x36 0xaa 0x54 0x00 0x67 0x00
              INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
              INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
              INFO  [muorb] SLPI:   arg0 = 'voxlpm'
              INFO  [muorb] SLPI:   arg4 = '2'
              INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
              INFO  [muorb] SLPI: Set i2c address 0x6a, fd 3
              INFO  [muorb] SLPI: Set i2c address 0x44, fd 3
              INFO  [uORB] Advertising remote topic battery_status
              INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
              INFO  [muorb] SLPI:  address 0x44
              INFO  [muorb] SLPI:
              INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
              INFO  [qshell] qshell return value timestamp: 30657353, local time: 30659016
              INFO  [uORB] Advertising remote topic power_monitor
              INFO  [muorb] SLPI: 0x00 0x01 0x0b 0xf5 0x2c 0x00 0x13 0xfe 0x26 0xaa 0x36 0xaa 0x54 0x00 0x61 0x00
              INFO  [muorb] SLPI: 0x00 0x01 0x0b 0xf5 0x2c 0x00 0x13 0xfe 0x26 0xaa 0x36 0xaa 0x54 0x00 0x63 0x00
              INFO  [muorb] SLPI: 0x00 0x01 0x81 0x56 0x3d 0xba 0x1c 0x0d 0x44 0x00 0x4c 0x00 0x5c 0x00 0x67 0x00
              ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_GPS_MASK
              INFO  [muorb] SLPI: 0x00 0x01 0x81 0x56 0x3d 0xba 0x1c 0x0d 0x44 0x00 0x4c 0x00 0x5c 0x00 0x61 0x00
              INFO  [uORB] Advertising remote topic sensors_status_mag
              INFO  [qshell] qshell return value timestamp: 30853798, local time: 30856869
              INFO  [uORB] Advertising remote topic input_rc
              INFO  [qshell] qshell return value timestamp: 31159822, local time: 31165232
              INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
                voxl2:/$ voxl-px4
                GPS=HOLYBRO
                RC=SPEKTRUM
                OSD=DISABLE
                DAEMON_MODE=ENABLE
                SENSOR_CAL=ACTUAL
                EXTRA STEPS:
                ______  __   __    ___
                | ___ \ \ \ / /   /   |
                | |_/ /  \ V /   / /| |
                |  __/   /   \  / /_| |
                | |     / /^\ \ \___  |
                \_|     \/   \/     |_/
                px4 starting.
                GPS: HOLYBRO
                RC: SPEKTRUM
                OSD: DISABLE
                EXTRA STEPS:
                Running on M0054
                INFO  [muorb] SLPI:
                INFO  [muorb] SLPI:
                INFO  [muorb] SLPI:
                INFO  [muorb] SLPI:
                INFO  [muorb] SLPI:
                Chase Riley
                @ben-grocholsky @Eric-Katzfey I attempted to run voxl-px4 again after a power cycle and encountered this error. Similar to the error before but looks to be showing the info that was cut off in the previous deb file.
                voxl2:/$ voxl-px4
                GPS=HOLYBRO
                RC=SPEKTRUM
                OSD=DISABLE
                DAEMON_MODE=ENABLE
                SENSOR_CAL=ACTUAL
                EXTRA STEPS:
                ______  __   __    ___
                | ___ \ \ \ / /   /   |
                | |_/ /  \ V /   / /| |
                |  __/   /   \  / /_| |
                | |     / /^\ \ \___  |
                \_|     \/   \/     |_/
                px4 starting.
                GPS: HOLYBRO
                RC: SPEKTRUM
                OSD: DISABLE
                EXTRA STEPS:
                Running on M0054
                INFO  [muorb] SLPI:
                INFO  [qshell] qshell return value timestamp: 262948496, local time: 262952979
                INFO  [muorb] SLPI:
                INFO  [qshell] qshell return value timestamp: 262991650, local time: 262992261
                INFO  [muorb] SLPI:
                INFO  [qshell] qshell return value timestamp: 263025555, local time: 263026330
                INFO  [qshell] qshell return value timestamp: 263048076, local time: 263048948
                INFO  [muorb] SLPI:
                INFO  [qshell] qshell return value timestamp: 263082514, local time: 263084020
                INFO  [qshell] qshell return value timestamp: 263170284, local time: 263173206
                INFO  [qshell] qshell return value timestamp: 263217799, local time: 263218642
                ERROR [muorb] SLPI: Spektrum RC: Got 6 bytes. Protocol byte is 0x52
                ERROR [muorb] SLPI: Spektrum RC: Got 16 bytes. Protocol byte is 0x00
                INFO  [muorb] SLPI:
                INFO  [qshell] qshell return value timestamp: 263251129, local time: 263253445
                ERROR [muorb] SLPI: Timeout waiting for parameter_server_set_used_response for SENS_MAG_MODE
                INFO  [qshell] qshell return value timestamp: 263462076, local time: 263466609
                INFO  [qshell] qshell return value timestamp: 263750947, local time: 263755362
                INFO  [qshell] qshell return value timestamp: 263841868, local time: 263843014
                INFO  [qshell] qshell return value timestamp: 263905079, local time: 263906174
                INFO  [muorb] SLPI: baudrate set to 9600
                INFO  [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 1
                INFO  [qshell] qshell return value timestamp: 264001370, local time: 264002881
                INFO  [qshell] qshell return value timestamp: 264045767, local time: 264046812
                INFO  [qshell] qshell return value timestamp: 264095634, local time: 264096726
                  voxl2:/$ voxl-px4
                  GPS=HOLYBRO
                  RC=SPEKTRUM
                  OSD=DISABLE
                  DAEMON_MODE=ENABLE
                  SENSOR_CAL=ACTUAL
                  EXTRA STEPS:
                  ______  __   __    ___
                  | ___ \ \ \ / /   /   |
                  | |_/ /  \ V /   / /| |
                  |  __/   /   \  / /_| |
                  | |     / /^\ \ \___  |
                  \_|     \/   \/     |_/
                  px4 starting.
                  GPS: HOLYBRO
                  RC: SPEKTRUM
                  OSD: DISABLE
                  EXTRA STEPS:
                  Running on M0054
                  INFO  [muorb] SLPI:
                  INFO  [muorb] SLPI:
                  INFO  [muorb] SLPI:
                  INFO  [muorb] SLPI:
                  INFO  [muorb] SLPI:
                  ben grocholsky
                  @Chase-Riley In the first of these two runs you were getting 0x01 protocol byte like I see on my DX7 transmitter. In that state with this binary you should see rc_input uorb messages and be able to try the Radio Calibration tool tab on QGroundControl.
                  In the second run you're seeing 0x00 protocol byte and unfortunately I'm not sure what that means.
                  If you can get the first case working repeatedly using one of the voxl-bind-spektrum options -t -f -s then we're on the path to a fix. Which did you use and have you tried them all?
                    Chase Riley
                    @ben-grocholsky I am using a DX8 Transmitter during these test. Would the voxl-bind-spektrum be needed/do anything if I am not using the Spektrum bind board from Modal AI? I currently have the Spektrum receiver hooked directly to J19 on the VOXL2. When I was using SDK .0.9.5 I had the same receiver connected to the VOXL I/O board, and it worked great. Unfortunately the I/O board is not supported in SDK 1.0.0.
                      ben grocholsky
                      @Chase-Riley I didn't realize that had changed in V1.0. If you have access to a an alternative px4 fmu you could use the QGC pairing function to change the spektrum mode connected to that fmu and then plug it back into the voxl2. That could help check if one of the three options is more reliable. I'm not sure why you saw different data packets on a restart. Need to resolve that or try a different transmitter.
                        Chase Riley
                        @ben-grocholsky @Eric-Katzfey I got it to work using by using the DSM2 binding method with another Px4 FMU. I do have a question though. I am now not able to get the actuators tab to show up in QGC for my ModalAI ESC. Would you DEB file have something to do with this? I have checked all my params in QGC and all seems to be correct. This was just the only other variable I could think of and wanted to check. Should I go back to running a standard DEB file? If so where would I find that now that I am running the custom debug one?
                          @Chase-Riley The standard px4 Debian package will set up the data correctly such that the actuators tab will be visible. For SDK 1.0 the packages are all available at http://voxl-packages.modalai.com/dists/qrb5165/sdk-1.0/binary-arm64/. To grab the px4 package use wget http://voxl-packages.modalai.com/dists/qrb5165/sdk-1.0/binary-arm64/voxl-px4_1.14.0-2.0.34_arm64.deb
                            Chase Riley
                            @Eric-Katzfey Unfortunately once I switch back to the standard Debian package the Spektrum error is back. I had it working every power up with the Debian Package from Ben.
                              ben grocholsky
                              wrote on last edited by ben grocholsky
                              #20
                              @Eric-Katzfey the test deb file was just voxl-dev branch with the one line change to accept (0x02|0x01) protocol bytes with the error output shortened below 80 characters + debug print bools and macros in DSM parsing forced on. I can fly that one line change on a Sentinel to look for any unexpected consequences. It'd be great to coordinate on how to get such a change merged into the dev branch and a non-debug deb to Chase.
                                @ben-grocholsky That would be great! Just submit a PR and I can merge it in and then cut a new release.
                                ben grocholskyB Chase RileyC 2 Replies Last reply
                                  ben grocholsky
                                  @Eric-Katzfey https://github.com/modalai/px4-firmware/pull/42
                                    Chase Riley
                                      Chase Riley
                                      @ben-grocholsky @Eric-Katzfey That would be great if I could get this working. How long would this take to get merged?
                                        @Chase-Riley I made version 1.14.0-2.0.54 with the Spektrum RC changes in it. You can get it with wget http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/voxl-px4_1.14.0-2.0.54-202310161035_arm64.deb. Can you try it out and see if it fixes your issue?
                                          Chase Riley
                                          @Eric-Katzfey Spektrum now works with that deb file, however I am not able to get the actuators tab in QGC just like @ben-grocholsky's deb file.
