  3. Stereo tag detection: WARNING, apriltag roll/pitch out of bounds
14 Posts 2 Posters 3.5k Views 1 Watching
  • A Offline
    afdrus
    wrote on last edited by afdrus
    Hello everyone,
    I am having issues on reading the apriltags flat on the ground from the stereo using a sentinel drone. I keep receiving
    and I noticed that the warning vanished and the tag correction is correctly computed only when I roll the drone by +90/-90 degrees. However, the only thing that I changed is the T_tag_wrt_fixed. Below you can find the config files in question
    -tag_locations
    "locations":    [{
                           "id":   0,
                           "name": "proof0",
                           "loc_type":     "fixed",
                           "size_m":       0.40000,
                           "T_tag_wrt_fixed":      [1.34, -5.61, -1.38],
                           "R_tag_to_fixed":       [[0, -1, 0],
                                                    [1, 0, 0],
                                                    [0, 0, 1]]
    • voxl.-tag-detector:
    "detector_1":   {
                    "enable":       true,
                    "input_pipe":   "stereo_front",
                    "en_fast_mode": true,
                    "n_threads":    1,
                    "en_undistortion":      true,
                    "undistort_scale":      0.899999976158142,
                    "overlay_name": "stereo_tag_overlay",
                    "lens_cal_file":        "/data/modalai/opencv_stereo_front_intrinsics.yml",
                    "skip_n_frames":        5
    • Extrinsics
    	"name":	"Sentinel_V1",
    	"extrinsics":	[{
    			"parent":	"imu_apps",
    			"child":	"tracking",
    			"T_child_wrt_parent":	[0.0273, 0.0067, 0.0182],
    			"RPY_parent_to_child":	[0, 45, 90]
    			"parent":	"body",
    			"child":	"imu_apps",
    			"T_child_wrt_parent":	[0.0583, -0.0067, -0.0360],
    			"RPY_parent_to_child":	[0, 0, 0]
    			"parent":	"body",
    			"child":	"stereo_front_l",
    			"T_child_wrt_parent":	[0.0793, -0.040, -0.0243],
    			"RPY_parent_to_child":	[0, 90, 90]
    			"parent":	"body",
    			"child":	"stereo_rear_l",
    			"T_child_wrt_parent":	[-0.0297, 0.04, 0.0415],
    			"RPY_parent_to_child":	[0, -90, -90]
    			"parent":	"body",
    			"child":	"tof",
    			"T_child_wrt_parent":	[0.078, 0, -0.025],
    			"parent":	"body",
    			"child":	"ground",
    			"T_child_wrt_parent":	[0, 0, 0.058],
    Why does the frame appear to be wrong even though I used the standard rotation parameters that come with the drone?
    A 1 Reply Last reply
    • A afdrus
      Hello everyone,
      -tag_locations
      "locations":    [{
                             "id":   0,
                             "name": "proof0",
                             "size_m":       0.40000,
                                                      [1, 0, 0],
                                                      [0, 0, 1]]
      "detector_1":   {
                      "enable":       true,
                      "n_threads":    1,
                      "skip_n_frames":        5
      • Extrinsics
      	"extrinsics":	[{
      			"parent":	"body",
      			"parent":	"body",
      			"parent":	"body",
      			"parent":	"body",
      			"child":	"tof",
      			"parent":	"body",
      			"child":	"ground",
      afdrus
      Is there someone that can unravel this issue?
      • A afdrus
        afdrus
        The command voxl-vision-px4 -m detects properly the distances between camera and tag, as well as their orientation.
        Also voxl-vision-px4 -l shows the correct pose of the tag in local frame, however the warning keeps being there. These results lead me to think that there seems to be an issue in the relation with the fixed frame, however if I use the same config files and I simply change the detector from any stereo pipe to tracking everything works fine and WARNING, apriltag roll/pitch out of bounds is gone.
        • A afdrus
          afdrus
          Sorry to insist, but I am not able to move forward with this issue, can anyone help?
          • ModeratorM Offline
            Can you please help with which version of software you are using? voxl-vision-px4 has been deprecated. Have you tried with the latest?
            A 2 Replies Last reply
            • ModeratorM Moderator
              afdrus
              @Moderator Thank you for your reply, we are currently using voxl SDK 0.9.5. All the libraries that come with this SDK are up to date. I did not try with the latest version, but the bug should be easy to replicate with a stereo setup on a voxl2.
                afdrus
                @Moderator I just tried the same with SDK 1.0.0 and the result is the same, can't understand which transformation is wrong, could the parameters in the extrinscs.conf be involved?
                • A afdrus
                  afdrus
                  @Moderator Any updates on this issue?
                  • A afdrus
                    afdrus
                    Nothing changed on v1.1.0
                    ModeratorM 1 Reply Last reply
                    • A afdrus
                      @afdrus since the stereo sensors have different orientation than tracking, did you change R_tag_to_fixed ?
                      You can find that error in the source code at this link below. That should help you debug
                      https://gitlab.com/voxl-public/voxl-sdk/services/voxl-vision-hub/-/blob/master/src/geometry.c?ref_type=heads#L613
                        afdrus
                        @Moderator Thank you for your response!
                        I thought that, as the name of the transformation suggest, R_tag_to_fixed did not depend on the orientation of the camera but rather on the orientation between the tag and fixed frame. I would expect to set the camera orientation in the extrinsics.conf file.
                        Hoever if I run voxl-vision-hub --debug_tag_local I get the following
                        ID  0 T_tag_wrt_local -4.74  2.63  0.89  Roll  1.45 Pitch  0.05 Yaw -2.14
                        ID  0 T_tag_wrt_local -4.74  2.63  0.89  Roll  1.39 Pitch  0.04 Yaw -2.16
                        ID  0 T_tag_wrt_local -4.73  2.63  0.89  Roll  1.32 Pitch  0.06 Yaw -2.08
                        ID  0 T_tag_wrt_local -4.74  2.63  0.89  Roll  1.40 Pitch  0.05 Yaw -2.13
                        ID  0 T_tag_wrt_local -4.74  2.64  0.89  Roll  1.40 Pitch  0.04 Yaw -2.14
                        No matter what values I put in extrinsics.conf or in R_tag_to_fixed, the Roll keeps being around 1.4 radians
                        • A afdrus
                          @afdrus OK, you could be right. Hopefully the source code helps? We don't use it in this way, so you may need to modify
                            afdrus
                            @Moderator Thanks to some prints I notice that the issue comes from R_cam_to_imu which always (and only) picks up the parameters from the tracking camera in extrinsics.conf. Regardless of the pipe specified in voxl-tag-detector.conf. Hope this insight might help you in solving the issue in future releases.
                            • A afdrus
                              afdrus
                              I did a very quick and dummy workaround to fix the problem, most of the changes are in geometry.c in the following snippet of code:
                              int geometry_calc_R_T_tag_in_local_frame(int64_t frame_timestamp_ns,
                              										 rc_matrix_t R_tag_to_cam, rc_vector_t T_tag_wrt_cam,
                              										 rc_matrix_t *R_tag_to_local, rc_vector_t *T_tag_wrt_local, char* input_pipe)
                              	// these "correct" values are from the past aligning to the timestamp
                              	static rc_matrix_t correct_R_imu_to_vio = RC_MATRIX_INITIALIZER;
                              	static rc_vector_t correct_T_imu_wrt_vio = RC_VECTOR_INITIALIZER;
                              	int ret = rc_tf_ringbuf_get_tf_at_time(&vio_ringbuf,
                              										   frame_timestamp_ns,
                              										   &correct_R_imu_to_vio,
                              										   &correct_T_imu_wrt_vio);
                              	// fail silently, on catastrophic failure the previous function would have
                              	// printed a message. If ret==-2 that's a soft failure meaning we just don't
                              	// have enough vio data yet, so also return silently.
                              	if (ret < 0)
                              		return -1;
                              	pthread_mutex_lock(&tf_mutex);
                              	// Read extrinsics parameters
                              	int n;
                              	vcc_extrinsic_t t[VCC_MAX_EXTRINSICS_IN_CONFIG];
                              	vcc_extrinsic_t tmp;
                              	// now load in extrinsics
                              	if (vcc_read_extrinsic_conf_file(VCC_EXTRINSICS_PATH, t, &n, VCC_MAX_EXTRINSICS_IN_CONFIG))
                              		return -1;
                              	// Initialize camera matrices
                              	rc_matrix_t R_cam_to_imu_tmp = RC_MATRIX_INITIALIZER;
                              	rc_matrix_t R_cam_to_body = RC_MATRIX_INITIALIZER;
                              	rc_vector_t T_cam_wrt_imu_tmp = RC_VECTOR_INITIALIZER;
                              	rc_vector_t T_cam_wrt_body = RC_VECTOR_INITIALIZER;
                              	rc_vector_zeros(&T_cam_wrt_body, 3);
                              	rc_vector_zeros(&T_cam_wrt_imu_tmp, 3);
                              	rc_matrix_identity(&R_cam_to_imu_tmp, 3);
                              	rc_matrix_identity(&R_cam_to_body, 3);
                              	printf("input_pipe: %s \n", input_pipe);
                              	if (strcmp(input_pipe, "stereo_front") == 0)
                              		// Pick out IMU to Body. config.c already set this up for imu1 so just leave it as is
                              		if (vcc_find_extrinsic_in_array("body", "stereo_front_l", t, n, &tmp))
                              			fprintf(stderr, "ERROR: %s missing body to stereo_front_l, sticking with identity for now\n", VCC_EXTRINSICS_PATH);
                              			return -1;
                              		rc_rotation_matrix_from_tait_bryan(tmp.RPY_parent_to_child[0] * DEG_TO_RAD,
                              										   tmp.RPY_parent_to_child[1] * DEG_TO_RAD,
                              										   tmp.RPY_parent_to_child[2] * DEG_TO_RAD,
                              										   &R_cam_to_body);
                              		rc_vector_from_array(&T_cam_wrt_body, tmp.T_child_wrt_parent, 3);
                              		T_cam_wrt_imu_tmp.d[0] = T_cam_wrt_body.d[0] - T_imu_wrt_body.d[0];
                              		T_cam_wrt_imu_tmp.d[1] = T_cam_wrt_body.d[1] - T_imu_wrt_body.d[1];
                              		T_cam_wrt_imu_tmp.d[2] = T_cam_wrt_body.d[2] - T_imu_wrt_body.d[2];
                              		rc_matrix_multiply(R_body_to_imu, R_cam_to_body, &R_cam_to_imu_tmp);
                              		printf("RPY: \n%5.2f %5.2f %5.2f\n\n",
                              		tmp.RPY_parent_to_child[0], tmp.RPY_parent_to_child[1],tmp.RPY_parent_to_child[2]);
                              		printf("R_cam_to_imu_tmp: \n%5.2f %5.2f %5.2f\n %5.2f %5.2f %5.2f\n %5.2f %5.2f %5.2f\n\n",
                              		R_cam_to_imu_tmp.d[0][0], R_cam_to_imu_tmp.d[0][1], R_cam_to_imu_tmp.d[0][2],
                              		R_cam_to_imu_tmp.d[1][0], R_cam_to_imu_tmp.d[1][1], R_cam_to_imu_tmp.d[1][2],
                              		R_cam_to_imu_tmp.d[2][0], R_cam_to_imu_tmp.d[2][1], R_cam_to_imu_tmp.d[2][2]);
                              		// calculate position of tag wrt local
                              		rc_matrix_times_col_vec(R_cam_to_imu_tmp, T_tag_wrt_cam, T_tag_wrt_local);
                              		rc_vector_sum_inplace(T_tag_wrt_local, T_cam_wrt_imu_tmp);
                              		rc_matrix_times_col_vec_inplace(correct_R_imu_to_vio, T_tag_wrt_local);
                              		rc_vector_sum_inplace(T_tag_wrt_local, correct_T_imu_wrt_vio);
                              		rc_matrix_times_col_vec_inplace(R_vio_to_local, T_tag_wrt_local);
                              		rc_vector_sum_inplace(T_tag_wrt_local, T_vio_ga_wrt_local);
                              		// calculate rotation tag to local
                              		rc_matrix_multiply(R_cam_to_imu_tmp, R_tag_to_cam, R_tag_to_local);
                              		rc_matrix_left_multiply_inplace(correct_R_imu_to_vio, R_tag_to_local);
                              		rc_matrix_left_multiply_inplace(R_vio_to_local, R_tag_to_local);
                              	else if (strcmp(input_pipe, "stereo_rear") == 0)
                              		if (vcc_find_extrinsic_in_array("body", "stereo_rear_l", t, n, &tmp))
                              			fprintf(stderr, "ERROR: %s missing body to stereo_rear_l, sticking with identity for now\n", VCC_EXTRINSICS_PATH);
                              			return -1;
                              										   &R_cam_to_body);
                              	else if (strcmp(input_pipe, "tracking") == 0)
                              		printf("R_cam_to_imu: \n%5.2f %5.2f %5.2f\n %5.2f %5.2f %5.2f\n %5.2f %5.2f %5.2f\n\n",
                              		R_cam_to_imu.d[0][0], R_cam_to_imu.d[0][1], R_cam_to_imu.d[0][2],
                              		R_cam_to_imu.d[1][0], R_cam_to_imu.d[1][1], R_cam_to_imu.d[1][2],
                              		R_cam_to_imu.d[2][0], R_cam_to_imu.d[2][1], R_cam_to_imu.d[2][2]);
                              		rc_matrix_times_col_vec(R_cam_to_imu, T_tag_wrt_cam, T_tag_wrt_local);
                              		rc_vector_sum_inplace(T_tag_wrt_local, T_cam_wrt_imu);
                              		rc_matrix_multiply(R_cam_to_imu, R_tag_to_cam, R_tag_to_local);
                              	printf("\n__________________________________________________________________________\n");
                              	pthread_mutex_unlock(&tf_mutex);
                              	return 0;
                              • K Kessie referenced this topic on
