    voxl-dfs-server Crashes
    Sentinel
    • E
      esaldiran
      Hello everyone,
      I have sentinel drone and upgraded to SDK 1.0 while following the documentation. The board and services details are as follow.
      voxl2:/$ voxl-inspect-sku
      family code:   MRB-D0006 (sentinel)
      compute board: 4 (voxl2)
      hw version:    1
      cam config:    11
      SKU:           MRB-D0006-4-V1-C11
      voxl2:/$ voxl-version
      system-image: 1.6.2-M0054-14.1a-perf
      kernel:       #1 SMP PREEMPT Fri May 19 22:19:33 UTC 2023 4.19.125
      hw version:   M0054
      voxl-suite:   1.0.0
      Packages:
      Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.0/binary-arm64/
      Last Updated: 2023-03-02 12:58:27
      List:
      	libmodal-cv              0.3.2
      	libmodal-exposure        0.0.8
      	libmodal-journal         0.2.2
      	libmodal-json            0.4.3
      	libmodal-pipe            2.8.5
      	libqrb5165-io            0.2.0
      	libvoxl-cci-direct       0.1.5
      	libvoxl-cutils           0.1.1
      	mv-voxl                  0.1-r0
      	qrb5165-bind             0.1-r0
      	qrb5165-dfs-server       0.1.0
      	qrb5165-imu-server       0.6.0
      	qrb5165-slpi-test-sig    01-r0
      	qrb5165-system-tweaks    0.2.2
      	qrb5165-tflite           2.8.0-2
      	voxl-bind-spektrum       0.1.0
      	voxl-camera-calibration  0.4.0
      	voxl-camera-server       1.6.2
      	voxl-configurator        0.2.7
      	voxl-cpu-monitor         0.4.6
      	voxl-docker-support      1.2.5
      	voxl-eigen3              3.4.0
      	voxl-elrs                0.0.7
      	voxl-esc                 1.2.2
      	voxl-feature-tracker     0.2.3
      	voxl-flow-server         0.3.3
      	voxl-gphoto2-server      0.0.10
      	voxl-jpeg-turbo          2.1.3
      	voxl-lepton-server       1.1.2
      	voxl-libgphoto2          0.0.4
      	voxl-libuvc              1.0.7
      	voxl-logger              0.3.4
      	voxl-mavcam-manager      0.5.1
      	voxl-mavlink             0.1.1
      	voxl-mavlink-server      1.2.0
      	voxl-modem               1.0.5
      	voxl-mongoose            7.7.0-1
      	voxl-mpa-to-ros          0.3.6
      	voxl-mpa-tools           1.0.4
      	voxl-opencv              4.5.5-1
      	voxl-portal              0.5.9
      	voxl-px4                 1.14.0-2.0.34
      	voxl-px4-imu-server      0.1.2
      	voxl-px4-params          0.1.8
      	voxl-qvio-server         0.9.3
      	voxl-remote-id           0.0.8
      	voxl-slpi-uart-bridge    1.0.1
      	voxl-streamer            0.7.1
      	voxl-suite               1.0.0
      	voxl-tag-detector        0.0.4
      	voxl-tflite-server       0.3.1
      	voxl-utils               1.3.1
      	voxl-uvc-server          0.1.6
      	voxl-vision-hub          1.6.6
      	voxl2-system-image       1.6.2-r0
      	voxl2-wlan               1.0-r0
      voxl2:/$ voxl-inspect-services -v
      Scanning services...
       Service Name          |  Version  |  Enabled  |   Running   |  CPU Usage
       docker-autorun        |    1.2.5  | Disabled  | Not Running |
       docker-daemon         |    1.2.5  | Disabled  | Not Running |
       modallink-relink      |    1.0.5  | Disabled  | Not Running |
       voxl-camera-server    |    1.6.2  |  Enabled  |   Running   |    81.7%
       voxl-cpu-monitor      |    0.4.6  |  Enabled  |   Running   |     0.6%
       voxl-dfs-server       |    0.1.0  |  Enabled  | Not Running |
       voxl-feature-tracker  |    0.2.3  | Disabled  | Not Running |
       voxl-flow-server      |    0.3.3  | Disabled  | Not Running |
       voxl-imu-server       |    0.6.0  |  Enabled  |   Running   |     5.9%
       voxl-lepton-server    |    1.1.2  | Disabled  | Not Running |
       voxl-mavcam-manager   |    0.5.1  |  Enabled  |   Running   |     0.0%
       voxl-mavlink-server   |    1.2.0  |  Enabled  |   Running   |     3.9%
       voxl-modem            |    1.0.5  | Disabled  | Not Running |
       voxl-portal           |    0.5.9  |  Enabled  |   Running   |     0.4%
       voxl-px4-imu-server   |    0.1.2  | Disabled  | Not Running |
       voxl-px4              |   1.14.0  |  Enabled  |   Running   |    40.8%
       voxl-qvio-server      |    0.9.3  |  Enabled  |   Running   |    36.7%
       voxl-remote-id        |    0.0.8  | Disabled  | Not Running |
       voxl-softap           |    0.2.2  | Disabled  | Not Running |
       voxl-static-ip        |    0.2.2  | Disabled  | Not Running |
       voxl-streamer         |    0.7.1  |  Enabled  |   Running   |     0.0%
       voxl-tag-detector     |    0.0.4  | Disabled  | Not Running |
       voxl-tflite-server    |    0.3.1  | Disabled  | Not Running |
       voxl-time-sync        |    1.3.1  | Disabled  | Not Running |
       voxl-uvc-server       |    0.1.6  | Disabled  | Not Running |
       voxl-vision-hub       |    1.6.6  |  Enabled  |   Running   |     2.1%
       voxl-wait-for-fs      |    1.3.1  |  Enabled  |  Completed  |
      The problem is with running voxl-dfs-server command, the program exit after running less than a few second with the following error
      voxl2:/$ voxl-dfs-server --debug
      Enabling debug mode
      min_disparity:   4
      max_disparity:   64
      min_threshold:   10
      cost_threshold:  10
      width:           640
      height:          480
      pc_skip_n_lines: 4
      dfs pair #0
          enable:             1
          input_pipe:         stereo_front
          skip_n_frames:      1
          blur_size:          0
          post_median_size:   0
          intrinsics_file:    /data/modalai/opencv_stereo_front_intrinsics.yml
          extrinsics_file:    /data/modalai/opencv_stereo_front_extrinsics.yml
      dfs pair #1
          enable:             1
          input_pipe:         stereo_rear
          skip_n_frames:      1
          blur_size:          0
          post_median_size:   0
          intrinsics_file:    /data/modalai/opencv_stereo_rear_intrinsics.yml
          extrinsics_file:    /data/modalai/opencv_stereo_rear_extrinsics.yml
      loading calibration files
      for Pair #0, loaded these lens params:
      f:  497.433807
      cx: 299.806549
      cy: 251.570435
      baseline_m: 0.080547
      for Pair #1, loaded these lens params:
      f:  501.798187
      cx: 280.967346
      cy: 222.201584
      baseline_m: 0.080042
      initializing dfs module
      connected to pipe stereo_front
      connected to pipe stereo_rear
      ch1 starting processing
      ch0 starting processing
      client voxl-vision-hub0 connected to ch 5
      client voxl-vision-hub0 connected to ch 2
      *** stack smashing detected ***: <unknown> terminated
      Aborted
      Each time I run voxl-dfs-server disparity image on the portal update for a split second and freezes as the service crashes.
      I tried to installing qrb5165-dfs-server from the source code with qrb5165 and with different versions dev, stag, sdk1.0, sdk0.9 but this time i got this error. With fresh install disparity image in portal doesn't update at all.
      voxl-dfs-server: symbol lookup error: voxl-dfs-server: undefined symbol: mcv_create_stereo_undistort_grid
      I already did fresh SDK install again but the problem still continues.
      Looking forward to your help. Thank you.
      Emre
      ModeratorM 1 Reply Last reply Reply Quote 1
      • ModeratorM
        Moderator ModalAI Team @esaldiran
        How did you upgrade the SDK? Did you upgrade the full platform image? These symptoms look like a software mismatch.
        Please follow the instructions for installing a Full VOXL-SDK Release: https://docs.modalai.com/flash-system-image/#flashing-a-voxl-sdk-release
        • E
          esaldiran @Moderator
          @Moderator Yes I installed full VOXL-SDK as outlined in the documentation with the following command. Set sku, camera configuration to leave as.
          tar -xzvf voxl2_SDK_1.0.0.tar.gz
          cd voxl2_SDK_1.0.0
          ./install.sh
          In my latest install, I set voxl-configure-sku configuration as "3) sentinel" and as "11 tracking(ov7251) + Hires(imx214) + Dual Stereo" but I still got the "*** stack smashing detected ***: <unknown> terminated" error.
          I'll revert back to VOXL2 Platform 0.9.5 to see if this changes anything.
          Chad SweetC 1 Reply Last reply Reply Quote 0
          • Chad SweetC
            Chad Sweet ModalAI Team @esaldiran
            @esaldiran can you take a picture or draw a diagram of your setup? Have you changed any cabling? It has to be a specific way
            • E
              esaldiran @Chad Sweet
              Hi @Chad-Sweet,
              I am using Sentinel Drone with default configuration and did not change anything at all. I encountered this problem while following the documentation.
              I reverted back to VOXL2 Platform 0.9.5 without any configuration change and I can start voxl-dfs-server without any crash and I can see the results on portal.
              Please let me know if you need any more info.
              • J
                Jgaucin @esaldiran
                @esaldiran @Chad-Sweet @Moderator The same issue was occurring for me, I am now running the dfs server on SDK 0.9.5 perfectly. stereo_dfs_s2.png
